    4. Test Adapter luxtronik2 v0.4.x
    • Schariez
      Schariez last edited by
      @lessthanmore
      Alles klar, ich schau mir das mal an, da ist ja einiges an Gedankenschmalz drin. Was hängt unter den Listen auf dem zweiten Bild?
      @UncleSam
      Ich habe auf einmal unerklärliche Fehler, anbei mein Log-Auszug:
      host.raspberrypi
      2021-09-06 17:38:52.422	error	instance system.adapter.luxtronik2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2021-09-06 17:38:52.421	error	Caught by controller[1]: at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      host.raspberrypi
      2021-09-06 17:38:52.421	error	Caught by controller[1]: at Socket.Readable.push (internal/streams/readable.js:204:10)
      host.raspberrypi
      2021-09-06 17:38:52.421	error	Caught by controller[1]: at readableAddChunk (internal/streams/readable.js:265:9)
      host.raspberrypi
      2021-09-06 17:38:52.421	error	Caught by controller[1]: at addChunk (internal/streams/readable.js:290:12)
      host.raspberrypi
      2021-09-06 17:38:52.420	error	Caught by controller[1]: at Socket.emit (domain.js:470:12)
      host.raspberrypi
      2021-09-06 17:38:52.420	error	Caught by controller[1]: at Socket.emit (events.js:400:28)
      host.raspberrypi
      2021-09-06 17:38:52.420	error	Caught by controller[1]: at Luxtronik.<anonymous> (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:559:26)
      host.raspberrypi
      2021-09-06 17:38:52.420	error	Caught by controller[1]: TypeError: Cannot read property 'end' of null
      host.raspberrypi
      2021-09-06 17:38:52.419	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:77:11)
      host.raspberrypi
      2021-09-06 17:38:52.419	error	Caught by controller[0]: at Luxtronik._nextJob (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:416:21)
      host.raspberrypi
      2021-09-06 17:38:52.414	error	Caught by controller[0]: TypeError: Cannot read property 'end' of null
      luxtronik2.0
      2021-09-06 17:38:52.074	error	Cannot read property 'end' of null
      luxtronik2.0
      2021-09-06 17:38:52.074	error	TypeError: Cannot read property 'end' of null at Luxtronik.<anonymous> (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:559:26) at Socket.emit (events.js:400:28) at Socket.emit (domain.js:470:12) at addChunk (internal/streams/readable.js:290:12) at readableAddChunk (internal/streams/readable.js:265:9) at Socket.Readable.push (internal/streams/readable.js:204:10) at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      luxtronik2.0
      2021-09-06 17:38:52.073	error	uncaught exception: Cannot read property 'end' of null
      luxtronik2.0
      2021-09-06 17:38:52.056	error	Cannot read property 'end' of null
      luxtronik2.0
      2021-09-06 17:38:52.056	error	TypeError: Cannot read property 'end' of null at Luxtronik._nextJob (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:416:21) at processTicksAndRejections (internal/process/task_queues.js:77:11)
      luxtronik2.0
      2021-09-06 17:38:52.054	error	uncaught exception: Cannot read property 'end' of null
      Gruß,
      Thorsten
        lessthanmore @Schariez last edited by
        @schariez Darunter kommt nichts mehr bzgl. PV.
        Sperrobjekte für den Sonnenschutz für KNX …
        Schariez 1 Reply Last reply Reply Quote 0
        • Schariez
          Schariez @lessthanmore last edited by
          @lessthanmore
          OK, danke.
          Ich krieg allerdings Deine Steuerung des WW nicht mit der Durchschnittsberechnung (Einspeisung Bezug / Consumption) zusammen. Oder laufen die Skripte bei Dir grade unabhängig?
          Danke und Gruß,
          Thorsten
            @schariez Laufen in zwei unterschiedlichen Skripten, aber das ist ja egal.
            Hier mal zum Importieren:
            <block type="on" id="O;:~BSoWS91IK~bpap?" x="88" y="-1411">
            <field name="OID">luxtronik2.0.Informationen.Temperaturen.Warmwasser-Ist</field>
            <block type="controls_if" id="0u0S|@SyhyowokYMtR">
            <block type="logic_compare" id="~#[K{32lFcYj3p[ig[-O">
            <field name="OP">LTE</field>
            <block type="on_source" id="rnhHJGCxHr!g1=,~l|Ke">
            <block type="math_number" id="JOlg/2K-GT%7.i~dMoL~">
            <field name="NUM">47.1</field>
            <block type="controls_if" id="0KB042rJZ_:d[w+|
            %z%">
            <block type="logic_operation" id="tOGu/WMi7|UzA.sUrk]f" inline="false">
            <field name="OP">AND</field>
            <block type="logic_compare" id="s%[q5n!oRazE7WMM$EDJ">
            <field name="OP">EQ</field>
            <block type="get_value" id="b0m[0ubRB.KinZUk{},"> <field name="ATTR">val</field> <field name="OID">luxtronik2.0.Informationen.Temperaturen.Warmwasser-Soll</field> </block> </value> <value name="B"> <block type="math_number" id="[zFmOt[Ft{Ii=e|=#uF">
            <field name="NUM">48</field>
            <block type="logic_compare" id="[6AxL4}z[lFxN7?{#Z7">
            <field name="OP">GTE</field>
            <block type="get_value" id="UXggsRlX:{~uNrvWJ#dU">
            <field name="OID">0_userdata.0.PV_Erzeugung</field>
            <block type="math_number" id="1UhLnn(4Y!/IbVfl)QC~">
            <field name="NUM">2000</field>
            <block type="control" id="^Y_FYrkEA~BXPPpK7].:">
            <field name="OID">luxtronik2.0.parameters.warmwater_temperature</field>
            <block type="math_number" id="v^BWzz+LTtp3/yGUI/to">
            <field name="NUM">54</field>
            <value name="IF1">
            <block type="logic_operation" id="FbfRfjxb4}uuRw]rOrL" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="1zk|PL?Veoz(wKP%3YjG"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="UQc,wB99oL#{mB@^O,#">
            <block type="math_number" id="u|FRz(QDA8_j}-.HqlH4">
            <block type="logic_compare" id="6hz/HfMZm4%}=j#k^6zE">
            <field name="OP">LT</field>
            <block type="get_value" id="^;wdm39bOkYYrlz8Jlzv">
            <block type="math_number" id="svL+VuC%0tJF||7w6X">
            <statement name="DO1">
            <block type="control" id="z_%IJUpk,;Cbf|yF-qIe">
            <block type="math_number" id="0RlW
            z.d;E17K[wuiw8k">
            <block type="on" id="b,YSCK^9P@,{84~GW|aq">
            <field name="OID">modbus.0.inputRegisters.3.30775_PVLeistung</field>
            <block type="controls_if" id=",:dCqDV.s_KL$Ict{Ro*">
            <block type="logic_compare" id="]m),s9#]zkJWuT%r]m%">
            <block type="on_source" id="tMCM%[YP5cJ$v:XJr0Ms">
            <block type="math_number" id="Z:U!RlMfB
            x3UpRY;)Qr">
            <field name="NUM">0</field>
            <block type="update" id="#1}fd4xnuUH,P6#X(()A">
            <block type="on_source" id="1IZ1H_t@j.(/0_aDHhME">
            <statement name="ELSE">
            <block type="update" id="UD2wqC%?a4ad71`7{o]D">
            <block type="math_number" id="0RTq.:lz$ksom[A4UY:a">
            Von oben runter:
            Modbus ... ist der Wechselrichter. Hier setze ich den Wert auf 0, sofern ein negativer Wert angezeigt wird. Sobald kein Strom mehr erzeugt wird zeigt der SMA Wechselrichter leider -irgendwas an.
            PV ist die reine Erzeugung. Die nutze ich für das Warmwasser. Mir fällt gerade auf, dass ich hier gar keinen Durchschnitt ermittele für die Prüfung beim Warmwasser 🙂
            Hatte ich ausgebaut, da ich es ja bereits bei den beiden unteren Datenpunkte mache.
            Einspeisung_Bezug und comsumption sind lediglich für meine Visu (Lovelace).
            Schariez 2 Replies Last reply Reply Quote 0
            • Schariez
              @lessthanmore
              Vielen Dank, dass hilft mir schon mal sehr weiter. Ich werde mal die Werte protokollieren, um mir für meine Anlage ein Bild machen zu können.
              @UncleSam
              Hallo, anbei noch weitere Fehler. Obwohl ich grade alle Skripte und Szenen gestoppt habe:
              host.raspberrypi
              2021-09-07 10:23:23.616	error	instance system.adapter.luxtronik2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2021-09-07 10:23:23.616	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:77:11)
              host.raspberrypi
              2021-09-07 10:23:23.615	error	Caught by controller[0]: at Luxtronik._nextJob (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:416:21)
              host.raspberrypi
              2021-09-07 10:23:23.610	error	Caught by controller[0]: TypeError: Cannot read property 'end' of null
              luxtronik2.0
              2021-09-07 10:23:23.250	error	Cannot read property 'end' of null
              luxtronik2.0
              2021-09-07 10:23:23.250	error	TypeError: Cannot read property 'end' of null at Luxtronik._nextJob (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:416:21) at processTicksAndRejections (internal/process/task_queues.js:77:11)
              luxtronik2.0
              2021-09-07 10:23:23.232	error	uncaught exception: Cannot read property 'end' of null
              • Chriz
                Chriz last edited by
                kann mir jemand erklären wie ich diesen Adapter aus ioBroker heraus installieren kann?
                Dachte wenn ich über die "Katze" danach suche finde ich was, aber weder unter NPM noch bei Github finde ich diesen.
                Wenn ich den NPM befehl auf meiner Shell ausführe (iobroker läuft in nem Docker) dann funktioniert der Install leider nicht 😞
                • Schariez
                  Schariez @lessthanmore last edited by Schariez
                  @lessthanmore
                  noch einmal vielen Dank. Ich habe Dein Script und die Überlegungen von Andreas Staeker zu Mittelwerten genommen und folgende Skripte daraus gebaut:
                  Zuerst ermittelt ich den Mittelwert aus meiner Solaren Einspeisung. Da ich eine Batterie verbaut habe, wird das eingespeist, was beim Laden der Batterie und nach Abzug des Eigenverbrauchs übrig bleibt. Bei uns ist das alles über 2,2 kW + Eigenverbrauch.
                  Dann prüfe ich, ob die Wärmepumpe grade warmes Wasser aufbereitet, wenn ja, wird bei einer Einspeisung von mehr als 2,0 kW die Solltemperatur und die Hysterese angehoben. Ab dem Moment, wo wir Strom aus der Batterie oder dem Netz beziehen, wird die Solltemperatur und die Hysterese entsprechende geändert.
                  Dann gibt es noch einen Gerät im Alexa Still (Gaeste), wenn wir Gäste haben, kann damit ein Schalter gelegt werdend wir haben auch im Winter mehr warmes Wasser zur Verfügung, damit alle warm duschen können.
                  Ich habe auch über einen Mittelwert für den Strombezug aus Batterie und Netz nachgedacht. Ggf. muss ich das im Herbst ml prüfen. Allerdings ist in dem Fall davon auszugehen, dass der Mittelwert der Einspeisung nicht mehr die 2,0 kW überschreiten wird.
                  Nochmal allen Danke für die Hilfe!
                  Gruß,
                  Thorsten
                    @schariez Sieht gut aus.
                    Ich glaube ich würde die Hysterese umgekehrt steuern. Bei viel Sonnenenergie will ich ja die hohe Temperatur halten, um Abends bspw. nicht nachheizen zu müssen.
                    Bei einer Hysterese von 3 K bedeutet das, dass WW aufbereitet wird, sobald die Temperatur unter 54°C fällt.
                    3 K ist sehr wenig. Wenn du eine Zirkulationspumpe in Betrieb hast bedenke, dass da auch ein Wärmeverlust ist und die 3 K schnell erreicht sind.
                    Standardmäßig hat mein Heizungsbauer 2 K eingestellt, was darin resultierte (inkl. Zirkulationspumpe 5min an und 10 min aus), dass innerhalb von 1-2 Stunden die 2 K bereits erreicht wurden und die Wärempumpe 3-5 Mal am Tag(!) WW aufbereitet hat.
                    Lass es einfach mal eine Woche laufen. Gerade bei Heizung und Warmwasser braucht alles immer etwas Zeit und man sieht nie direkt ein Ergebnis. Wettermäßig ist es natürlich gerade denkbar schlecht zum testen 🙂
                    • Schariez
                      Schariez @Chriz last edited by
                      @chriz
                      Ich kenn mich leider nicht mit den Docker Containern aus. Ich brauchte aber bei der RPi auch einige Versuche, über NPM und als Github Link, weiß grade nicht, welches nach min. 5 Versuchen kurz den installierten Adapter gezeigt hatte, damit ich die Instanz installieren konnte.
                      Chriz 1 Reply Last reply Reply Quote 0
                      • Chriz
                        Chriz @Schariez last edited by
                        @schariez
                        Danke für die Antwort.
                        Hab es jetzt mehrfach probiert aber er findet den Adapter einfach nicht.
                        Es werden aber viele andere Adapter gefunden über die NPM oder GITHUB Funktion.
                        Daher glaube ich nicht das es am Docker liegt, welcher im übrigen weniger Probleme macht als erwartet.
                        Hat noch jemand eine Idee?
                        Chriz
                        UncleSam 1 Reply Last reply Reply Quote 0
                        • UncleSam
                          UncleSam Developer last edited by
                          Bitte aktualisiert schnellstmöglich auf die aktuellste Version 0.3.2.
                          Leider hat sich in der Vorversion ein Fehler eingeschlichen, der in gewissen Fällen unseren Sentry Server mit Anfragen überhäuft.
                          • UncleSam
                            UncleSam Developer @Chriz last edited by
                            @chriz sagte in Test Adapter luxtronik2 v0.3.x:
                            Grundsätzlich hat das ja nichts mit diesem Adapter zu tun, aber hier eine Bildanleitung (einfach 1, 2, 3 folgen):
                            Habe mir soeben einen neuen Docker Container gemacht und darin den Adapter installiert - funktioniert also einwandfrei.
                            • Chriz
                              Chriz @UncleSam last edited by
                              @unclesam
                              Hi UncleSam,
                              danke für den Post, funktioniert leider nicht 😞
                              $ iobroker url iobroker.luxtronik2 --host f8b0bb8c6d11 --debug
                              install iobroker.luxtronik2
                              NPM version: 6.14.14
                              npm install iobroker.luxtronik2 --prefix "/opt/iobroker" (System call)
                              npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                              + iobroker.luxtronik2@0.3.1updated 1 package in 12.553s
                              142 packages are looking for funding run `npm fund` for details
                              upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                              upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                              upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                              upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                              upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                              Process exited with code 0
                              • UncleSam
                                @chriz Den Fehler hatte ich auch schon.
                                Was mir genützt hat, ist anstatt des Adapter-Namens einfach <adaptername>@<versionsnummer> einzugeben. In diesem Fall: iobroker.luxtronik2@0.3.2.
                                @foxriver76 oder @apollon77, ist es ein bekanntes Problem, dass sich neue Versionen (teilweise?) nicht über das Katzensymbol über bestehende Versionen installieren lassen?
                                foxriver76 apollon77 2 Replies Last reply Reply Quote 0
                                • foxriver76
                                  foxriver76 Developer @UncleSam last edited by foxriver76
                                  @unclesam Meines Wissens nach erwartet das url Kommando tatsächlich eine Url. Evtl. ging es früher mehr oder minder zufällig (?), glaube @AlCalzone hat das parsing zuletzt angepasst.
                                  Wenn du aber jemand auf die nächstmögliche Version (npm latest tag) updaten lassen möchtest, wieso benutzt du dann nicht im Custom Dialog "from npm"?
                                  Edit: geht bei mir doch mit iob url iobroker.luxtronik2.
                                  • UncleSam
                                    UncleSam Developer @foxriver76 last edited by UncleSam
                                    @foxriver76 sagte in Test Adapter luxtronik2 v0.3.x:
                                    Inzwischen (da der Adapter in Latest ist) wird das auch gehen, da hast du recht. Aber ich glaube die Bedingung für "from npm" ist doch, dass es im Latest drin ist, richtig?
                                    • AlCalzone
                                      AlCalzone Developer last edited by AlCalzone
                                      Ich habe erst gestern adapter@version per "eigener URL" installiert. Das hat am Ende dann iobroker url adapter@version aufgerufen und funktioniert.
                                        apollon77 @UncleSam last edited by
                                        @unclesam also der npm Befehl passt laut log perfekt. Ich hatte schon mal Fälle wo einzelne User line Alte Versionen von npm bekommen haben. Scheint manchmal an deren cdn zu klemmen. Ggf mit Versionsnummer machen.
                                          killroy2 last edited by
                                          Hi hat jemand zur Luxtronik schonmal eine hübsche Visu gemacht?
                                          • TbsJah
                                            TbsJah last edited by
                                            @UncleSam luxtronik2.0.parameters.deltaHeatingReduction könntest du den bitte auch als schreibend erstellen?
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            67959
