    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      haumichel last edited by
      gestern und teilweis heute war Skoda Connect nicht erreichbar, auf der Webseite war von Wartungsarbeiten die Rede.
      Nun, nachdem die App wieder funktioniert, bekomme ich beim Start des Adapters folgende Logeinträge:
      vw-connect.0
      	2021-09-15 12:08:30.336	error	Get Vehicles Failed
      vw-connect.0
      	2021-09-15 12:08:30.335	info	No Vehicles found
      vw-connect.0
      	2021-09-15 12:08:30.334	error	400
      vw-connect.0
      	2021-09-15 12:08:30.101	info	State value to set for "vw-connect.0.personal.emailAddresses" has to be one of type "string", "number", "boolean" but received type "object"
      vw-connect.0
      	2021-09-15 12:08:30.098	info	State value to set for "vw-connect.0.personal.addresses" has to be one of type "string", "number", "boolean" but received type "object"
      vw-connect.0
      	2021-09-15 12:08:29.820	error	"<!doctype html><html lang=\"en\"><head><title>HTTP Status 403 – Forbidden</title><style type=\"text/css\">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 403 – Forbidden</h1><hr class=\"line\" /><p><b>Type</b> Status Report</p><p><b>Message</b> Access Denied</p><p><b>Description</b> The server understood the request but refuses to authorize it.</p><hr class=\"line\" /><h3>Apache Tomcat</h3></body></html>"
      vw-connect.0
      	2021-09-15 12:08:29.819	error	403
      vw-connect.0
      	2021-09-15 12:08:29.817	error	Failed to get VWToken
      vw-connect.0
      	2021-09-15 12:08:26.020	info	starting. Version 0.0.39 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.22.1, js-controller: 3.3.15
      Geht das nur mir so, oder hat Skoda da was kaputt gemacht?
      Vielen Dank
      MyzerAT BananaJoe 2 Replies Last reply Reply Quote 0
      • MyzerAT
        MyzerAT @haumichel last edited by MyzerAT
        hi @lls,
        ich habe im Juni meinen neuen VW Caddy 5 bekommen, hat mit Zusatzoptionen knapp 47k gekostet und WE Connect ist vorbereitet, heisst das ich kann das aktivieren ohne zum VW Händler zu müssen. BZW: was hat man da für Vorteile , wenn man dies nutzt ?
        bzw. wo bekomme ich den Data Plug, habe gesehen in Amazon gibt es verschiedene Modelle, welche wäre der richtige und was kostet der dann?
        thx
        • RaspiUser
          RaspiUser @tombox last edited by
          @tombox said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
          is mit 0.0.41 behoben
          Hallo tombox,
          heute hat mir VW folgende Mail geschrieben (habe es etwas gekürzt) ...:
          .... wir haben im Rahmen der Analyse einer ungewöhnlich hohen Last in einem der Systeme der mobilen Online-Dienste festgestellt, dass hierfür Anfragen verantwortlich sind, die im Zusammenhang mit Ihrem Benutzerkonto für die mobilen Online-Dienste We Connect stehen.
          Aus diesem Grund war es notwendig Ihr Passwort zurückzusetzen, damit möglicher Schaden von Ihrem Fahrzeug und den Systemen abgewendet wird.
          Bei Rückfragen stehen wir Ihnen gerne telefonisch unter der xxxxxx zur Verfügung. Nennen Sie bitte bei Ihrem Anruf die Vorgangsnummer xxxxxx, damit wir Ihnen schnellstmöglich weiterhelfen können. ....
          Ich nehme mal an, wenn ich die Update Zeit von der "Voreinstellung 15min" ändere auf z.B. "5h"sollte es nicht mehr passieren, oder ? Hast Du Erfahrungen wo hier die Grenze liegt ?
          Oder hat es etwas mit der Einstellung unter "Status Update erzwingen. (Interval in Minuten, 0 = Aus). Anzahl Updates zwischen Zündungen ist limitiert, unter 360min nicht zu empfehlen!" zutun ?
          Ich habe den Adapter erstmal angehalten, ich muss eh auf das neue Passwort warten ... 😉
            tombox @RaspiUser last edited by
            @raspiuser Ich denke das hat weniger mit dem Update Interval zu tun sondern das der Refresh des token nicht geklappt hat und er sich dann jeder Stunde neu eingeloggt hat. Das sollte mit 0.0.41 behoben sein aber macht sicher sinn mal anzurufen was genau zu der Sperre geführt hat.
            RaspiUser 1 Reply Last reply Reply Quote 0
            • RaspiUser
              ... ich wollte eigentlich auf "stable" warten aber lasse jetzt gerade aktualisieren. Schaun'mer mal ... 😉
              • BananaJoe
                BananaJoe Most Active @haumichel last edited by BananaJoe
                @haumichel ich hab das gleiche Problem.
                Die Skoda Connect Seite funktioniert, die App und der ioBroker Adapter nicht.
                Im ioBroker habe ich die gleiche Fehlermeldung wie du. Manchmal auch Status 500 statt 403
                Nachtrag: Gerade ist es 504 Gateway Time-out
                  haumichel @RaspiUser last edited by haumichel
                  Ich habe jetzt mal auf Version 0.0.41 aktualisiert.
                  Leider bekomme ich die gleichen Logeinträge.
                  App und Web funktionieren.
                  vw-connect.0
                  	2021-09-15 19:11:03.553	error	Get Vehicles Failed
                  vw-connect.0
                  	2021-09-15 19:11:03.551	info	No Vehicles found
                  vw-connect.0
                  	2021-09-15 19:11:03.549	error	400
                  vw-connect.0
                  	2021-09-15 19:11:03.279	info	State value to set for "vw-connect.0.personal.emailAddresses" has to be one of type "string", "number", "boolean" but received type "object"
                  vw-connect.0
                  	2021-09-15 19:11:03.274	info	State value to set for "vw-connect.0.personal.addresses" has to be one of type "string", "number", "boolean" but received type "object"
                  vw-connect.0
                  	2021-09-15 19:11:03.014	error	"<!doctype html><html lang=\"en\"><head><title>HTTP Status 403 – Forbidden</title><style type=\"text/css\">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 403 – Forbidden</h1><hr class=\"line\" /><p><b>Type</b> Status Report</p><p><b>Message</b> Access Denied</p><p><b>Description</b> The server understood the request but refuses to authorize it.</p><hr class=\"line\" /><h3>Apache Tomcat</h3></body></html>"
                  vw-connect.0
                  	2021-09-15 19:11:03.014	error	403
                  vw-connect.0
                  	2021-09-15 19:11:03.013	error	Failed to get VWToken
                    tombox @BananaJoe last edited by tombox
                    @bananajoe geht denn der login via skodae? Ausloggen und einloggen via App geht?
                      dr_who @haumichel last edited by
                      @haumichel bei mir auch das selbe
                      Update auf 0041 hat nichts gebracht für iobroker. Fehlermeldungen s.u.
                      Im Web kann ich mich anmelden.
                      Skoda App hängt beim anmelden und gibt eine Fehlermeldung aus, und irgendwann gehts dann doch. Dann sind auch aktuelle Daten zu sehen...
                      Scheint als läge das Problem auf der Server-Seite ?
                        tombox @dr_who last edited by
                        @dr_who @haumichel @BananaJoe Könnt ihr mal als type skodae auswählen
                        opossum D 2 Replies Last reply Reply Quote 0
                        • opossum
                          opossum @tombox last edited by opossum
                          Hallo, @tombox ,
                          mit Skoda habe ich zur Zeit gar keinen Connect, der Adapter bleibt gelb. Allerdings bin ich noch auf der 0.0.39.
                          Hier die Fehlermeldungen:
                          vw-connect.0 2021-09-16 04:58:21.276	error	Login Failed
                          vw-connect.0 2021-09-16 04:58:21.275	error	"<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n</body>\r\n</html>\r\n"
                          vw-connect.0 2021-09-16 04:58:21.274	error	504
                          vw-connect.0 2021-09-16 04:58:21.273	error	Failed to get token
                            dr_who @tombox last edited by
                            @tombox
                            Du meinst mit type skodae Skoda Enyaq ? Das hat auch nix gebracht, s.u. . Ich hab einen Superb iV.
                            Meine App kriegt heute gar keine Verbindung...
                              @dr_who ja abwarten das die 5xxer Fehler weg gehen dann kann man weiter schauen
                              • RaspiUser
                                ... der Adapter läuft bzgl. meinem Problem (bis jetzt) stabil. Danke für die Arbeit.
                                  @dr_who Ja anscheinend haben sie den login für enyaq und normale fahrzeuge zusammengelegt.
                                    tombox @tombox last edited by
                                    0.0.42 ist veröffentlicht was das Skoda Login Problem löst
                                      @tombox ja, es kappt wieder. Super !! 👏
                                        @tombox
                                        Die Anmeldung funktioniert wieder, super, vielen Dank.
                                        Ich bekomme aber immer noch Fehlermeldungen.
                                        vw-connect.0	2021-09-17 08:19:06.485	error	status update Failed TMBJJ7NE2J0xxxxxx
                                        vw-connect.0	2021-09-17 08:19:06.471	error	{"error":{"errorCode":"VSR.technical.9025","description":"TSS responded: 500 - Internal Server Error"}}
                                        vw-connect.0	2021-09-17 08:19:06.470	error	502
                                        vw-connect.0	2021-09-17 08:19:06.469	error	TMBJJ7NE2J0xxxxxx
                                          vielen Dank für den Adapter. Dieser läuft bei mir mit meinem ID4 und meiner VW Charger Pro sehr gut.
                                          Ich stehe jetzt vor folgender Herausforderung:
                                          Ich würde gerne die Ladungen, die mit meinem VW Charger Pro getätigt wurden automatisch in eine Excel Datei ausgeben oder zumindest in einer Tabelle darstellen. Damit ich in Zukunft die Ladungen nicht händisch von der Handy App übernehmen muss, um die Ladungen mit der Firma abzurechnen.
                                          Ich habe mich auch schon ein wenig eingelesen und wollte den JSON String, der die Informationen enthält zerlegen. Nur geht es dort schon los, ich kann den String erst gar nicht finden.
                                          Hat von Euch schon jemand ein ähnliches Projekt gestartet oder eventuell schon umgesetzt?
                                            @anthony-stark ich habe mal in die github version die option rawJson eingefügt. Einfach über github installieren und die Option aktiveren und schauen ob das passt
                                            1.3k
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1600455
