    4. Stabiles Netatmo Thermostat Blockly (Adapter)
      helfi9999 @Newpicsel last edited by
      @newpicsel Hi bekomme nur noch Fehlermedlungen:
      javascript.0	2021-06-10 17:56:34.302	error	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Hame_Data kann leider nicht abgerufen werden!.
      javascript.0	2021-06-10 17:56:34.206	error	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Hame_Status kann leider nicht abgerufen werden
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:34.057	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:34.056	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:34.056	warn	(2361) at script.js.Netatmo.Heizung:187:11
      javascript.0	2021-06-10 17:56:34.056	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:34.056	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:34.047	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Refresh_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:34.046	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:34.046	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:34.046	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:34.046	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:34.046	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:34.045	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:34.045	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:34.045	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:34.045	warn	(2361) at script.js.Netatmo.Heizung:186:11
      javascript.0	2021-06-10 17:56:34.044	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:34.044	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:34.041	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Access_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:34.041	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:33.988	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:33.987	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:33.987	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:33.987	warn	(2361) at script.js.Netatmo.Heizung:208:11
      javascript.0	2021-06-10 17:56:33.987	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:33.987	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:33.984	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Refresh_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:33.984	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:33.984	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:33.983	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:33.983	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:33.983	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:33.983	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:33.982	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:33.982	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:33.982	warn	(2361) at script.js.Netatmo.Heizung:207:11
      javascript.0	2021-06-10 17:56:33.981	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:33.981	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:33.977	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Access_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:33.976	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
      javascript.0	2021-06-10 17:56:33.772	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Es wird erneut versucht.
      javascript.0	2021-06-10 17:56:33.726	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Es wird erneut versucht.
      javascript.0	2021-06-10 17:56:32.524	info	(2361) script.js.Netatmo.Heizung: Netatmo: Home_Data und Home_Status werden aktualisiert...
      javascript.0	2021-06-10 17:56:32.515	info	(2361) script.js.Netatmo.Heizung: Netatmo: Intervall abruf...
      javascript.0	2021-06-10 17:56:04.652	info	(2361) script.js.Netatmo.Heizung: Netatmo: Daten und Objekte erfolgreich aktualisiert!
      javascript.0	2021-06-10 17:56:04.638	info	(2361) script.js.Netatmo.Heizung: Netatmo: Daten und Objekte werden aktualisiert...
      javascript.0	2021-06-10 17:56:04.625	info	(2361) script.js.Netatmo.Heizung: Netatmo Status: OK
      javascript.0	2021-06-10 17:56:04.288	error	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Hame_Data kann leider nicht abgerufen werden!.
      javascript.0	2021-06-10 17:56:04.192	error	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Hame_Status kann leider nicht abgerufen werden
      javascript.0	2021-06-10 17:56:04.067	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:04.067	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:04.067	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:04.067	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:04.067	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at script.js.Netatmo.Heizung:187:11
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:04.066	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:04.056	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Refresh_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:04.056	warn	(2361) at Pipe.<anonymous> (net.js:675:12)
      javascript.0	2021-06-10 17:56:04.056	warn	(2361) at Socket.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:04.056	warn	(2361) at Socket.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:04.055	warn	(2361) at Socket.<anonymous> (internal/child_process.js:444:11)
      javascript.0	2021-06-10 17:56:04.055	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:04.054	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:04.049	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:04.049	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:04.049	warn	(2361) at script.js.Netatmo.Heizung:186:11
      javascript.0	2021-06-10 17:56:04.049	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:04.048	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:04.046	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Access_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:04.045	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
      javascript.0	2021-06-10 17:56:03.992	warn	(2361) at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
      javascript.0	2021-06-10 17:56:03.992	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:03.992	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:03.992	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:03.991	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:03.991	warn	(2361) at script.js.Netatmo.Heizung:208:11
      javascript.0	2021-06-10 17:56:03.991	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:03.990	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:03.988	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Refresh_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:03.988	warn	(2361) at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
      javascript.0	2021-06-10 17:56:03.987	warn	(2361) at maybeClose (internal/child_process.js:1022:16)
      javascript.0	2021-06-10 17:56:03.987	warn	(2361) at ChildProcess.EventEmitter.emit (domain.js:483:12)
      javascript.0	2021-06-10 17:56:03.987	warn	(2361) at ChildProcess.emit (events.js:314:20)
      javascript.0	2021-06-10 17:56:03.987	warn	(2361) at ChildProcess.exithandler (child_process.js:299:7)
      javascript.0	2021-06-10 17:56:03.986	warn	(2361) at script.js.Netatmo.Heizung:207:11
      javascript.0	2021-06-10 17:56:03.986	warn	(2361) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1471:25)
      javascript.0	2021-06-10 17:56:03.985	warn	(2361) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
      javascript.0	2021-06-10 17:56:03.983	warn	(2361) You are assigning a object to the state "0_userdata.0.Eigene_Objekte.Netatmo.Access_Token" which expects a string. Please fix your code to use a string or change the state type to object. This
      javascript.0	2021-06-10 17:56:03.982	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
      javascript.0	2021-06-10 17:56:03.829	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Es wird erneut versucht.
      javascript.0	2021-06-10 17:56:03.780	warn	(2361) script.js.Netatmo.Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Es wird erneut versucht.
      javascript.0	2021-06-10 17:56:02.523	info	(2361) script.js.Netatmo.Heizung: Netatmo: Home_Data und Home_Status werden aktualisiert...
      javascript.0	2021-06-10 17:56:02.514	info	(2361) script.js.Netatmo.Heizung: Netatmo: Intervall abruf...
      javascript.0	2021-06-10 17:55:55.502	info	(2361) script.js.Netatmo.Heizung: Netatmo: Daten und Objekte erfolgreich aktualisiert!
      javascript.0	2021-06-10 17:55:55.495	info	(2361) script.js.Netatmo.Heizung: Netatmo: Daten und Objekte werden aktualisiert...
      javascript.0	2021-06-10 17:55:55.476	info	(2361) script.js.Netatmo.Heizung: Netatmo Status: OK
        KPMC @Newpicsel last edited by
        @newpicsel Hi
        Bin neu hier und versuchte das Netatmo-Blockly erfolglos z installieren.
        Leider bekomme ich immer Fehlermeldungen.
        Die Thermostate werden nicht angezeigt.
        Alle benötigten Informationen sind eingetragen ID, Secret-ID, User und PW.
        Wie kann das behoben werden?
        Besten Dank für Eure Rückmeldungen
        22.8.2021, 13:45:54.791 [info ]: javascript.0 (902) Stop script script.js.Netatmo_Heizung
        22.8.2021, 13:46:20.636 [info ]: javascript.0 (902) Start javascript script.js.Netatmo_Heizung
        22.8.2021, 13:46:20.759 [info ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo Blockly v1.4.0 wird gestartet...
        22.8.2021, 13:46:20.760 [info ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Zugangsdaten bitte in den Objekten eingeben und Blockly neu starten!
        22.8.2021, 13:46:20.762 [info ]: javascript.0 (902) script.js.Netatmo_Heizung: registered 0 subscriptions and 0 schedules
        22.8.2021, 13:46:20.764 [info ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Das Blockly wird nun ausgeführt!
        22.8.2021, 13:46:21.231 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Es wird erneut versucht.
        22.8.2021, 13:46:21.267 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Es wird erneut versucht.
        22.8.2021, 13:46:21.532 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
        22.8.2021, 13:46:21.569 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:73:7
        22.8.2021, 13:46:21.583 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:74:7
        22.8.2021, 13:46:21.652 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
        22.8.2021, 13:46:21.661 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:95:7
        22.8.2021, 13:46:21.681 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:96:7
        22.8.2021, 13:46:21.715 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit dem Netatmo Token! Result: {"error":"invalid_grant"} Es wird versucht den Token zu erneuern.
        22.8.2021, 13:46:21.921 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Cannot get status of null
        22.8.2021, 13:46:21.923 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo Status: Fehler! Es wird erneut versucht...
        22.8.2021, 13:46:21.995 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Hame_Data kann leider nicht abgerufen werden! Bitte Später Blockly erneut starten oder Newpicsel kontaktieren...
        22.8.2021, 13:46:22.020 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Hame_Status kann leider nicht abgerufen werden! Bitte Später Blockly erneut starten oder Newpicsel kontaktieren...
        22.8.2021, 13:46:22.047 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit dem Netatmo Token! Result: {"error":"invalid_grant"}!!!ACHTUNG!!! Bitte Überprüfe alle angaben und starte das Blockly erneut!
        22.8.2021, 13:46:22.240 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Es wird erneut versucht.
        22.8.2021, 13:46:22.283 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Es wird erneut versucht.
        22.8.2021, 13:46:22.495 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
        22.8.2021, 13:46:22.500 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:149:11
        22.8.2021, 13:46:22.507 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:150:11
        22.8.2021, 13:46:22.555 [warn ]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Result: {"error":"invalid_grant"} ERROR:
        22.8.2021, 13:46:22.573 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:128:11
        22.8.2021, 13:46:22.589 [warn ]: javascript.0 (902) at script.js.Netatmo_Heizung:129:11
        22.8.2021, 13:46:22.767 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Status anfrage! Result: {"error":{"code":2,"message":"Invalid access_token"}} Hame_Status kann leider nicht abgerufen werden!.
        22.8.2021, 13:46:22.870 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo: Es gibt ein problem mit der Home_Data anfrage! Result: {"error":{"code":2,"message":"Invalid access token"}} Hame_Data kann leider nicht abgerufen werden!.
        22.8.2021, 13:46:22.925 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:590:17)
        22.8.2021, 13:46:22.929 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:591:18)
        22.8.2021, 13:46:22.933 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:592:14)
        22.8.2021, 13:46:22.951 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:593:13)
        22.8.2021, 13:46:22.987 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Cannot get status of null
        22.8.2021, 13:46:22.989 [error]: javascript.0 (902) script.js.Netatmo_Heizung: Netatmo Status: FEHLER ! BITTE DATEN ÜBERPRÜFEN UND BLOCKLY NEU STARTEN! sollte dieses problem wieder auftreten, Newpicsel informieren...
        22.8.2021, 13:46:23.934 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1183:11)
        22.8.2021, 13:46:23.942 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1207:11)
        22.8.2021, 13:46:23.949 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1231:11)
        22.8.2021, 13:46:23.956 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1255:11)
        22.8.2021, 13:46:23.963 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1279:11)
        22.8.2021, 13:46:23.970 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1303:11)
        22.8.2021, 13:46:23.976 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1327:11)
        22.8.2021, 13:46:23.982 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1351:11)
        22.8.2021, 13:46:23.988 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1375:11)
        22.8.2021, 13:46:23.994 [warn ]: javascript.0 (902) at Object.<anonymous> (script.js.Netatmo_Heizung:1399:11)
        Newpicsel 1 Reply Last reply Reply Quote 0
        • Newpicsel
          Newpicsel @KPMC last edited by Newpicsel
          @kpmc & @helfi9999
          Moin, läuft das Blockly bei euch nun oder wieder?
          Bei mir läuft alles problemlos, Blockly bei Problemen am besten eins zwei mal neu starten, sollte normal kaum bis keine Probleme machen, aber wenn sich mal etwas aufhängt, hilft das in der Regel! Sonst mal den Aktualisierungs Intervall hochsetzen, bei mir läuft es super auf 30sec.
          Wenn wirklich nichts geht, Blockly komplett löschen und erneut erstellen, in den meisten Fällen, lagen Probleme bei den Zugangsdaten oder es hat ein Neustart geholfen, sollte es dennoch Probleme geben, guck ich es mir gerne nochmal an!
          Gruß Peter
          H K 2 Replies Last reply Reply Quote 0
            @newpicsel das einzige Problem was ich habe ist das folgende Meldung immer kommt:
            26447	2021-09-15 17:59:27.268	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:58:57.102	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:58:28.617	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:57:57.096	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:57:27.093	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:56:57.104	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
            javascript.0
            	26447	2021-09-15 17:56:27.103	warn	Read-only state "0_userdata.0.Eigene_Objekte.Netatmo.null" has been written without ack-flag with value "null"
              @newpicsel
              Danke für deine Rückmeldung. Alle deine Tipps habe ich bereits befolgt und getestet. Ebenso habe ich ein neues System aufgezogen (Raspberry 3 mit Buster) und den iobroker neu installiert mit den notwendigen Adaptern. das gleiche Resultat. Ich wollte eventuelle Altlasten am aktuellen System ausschliessen.
              Ich bekomme immer die selbe Fehlermeldung: {"error":{"code":2,"message":"Invalid access token"}}
              Hat das mit dem "Token_Request" zu tun? Dort steht bei mir: {"ack":true}, ist das korrekt?
              Wenn ich auf der Netatmo seite den Curl Befehl in der Konsole eingebe bekomme ich die Werte zurück
              (curl -X GET "https://api.netatmo.com/api/homesdata" -H "accept: application/json" -H "Authorization: Bearer ......)
              Deine Anleitung ist grundsätzlich selbsterklärend (Kompliment), aber ich weiss einfach nicht wo der Hund begraben ist.
              Muss am Javascript-Adapter etwas angepasst werden oder ist es eine generelle Einstellung am System die ich noch nicht konfiguriert habe?
              Vielleicht hast du noch einen Tipp oder einen Lösungsansatz für dieses Token-Problem.
              Gruss
              B Newpicsel 3 Replies Last reply Reply Quote 0
                bubus @KPMC last edited by
                @kpmc
                Versuch mal die 1.2.1.
                  bubus @helfi9999 last edited by bubus
                  @helfi9999 sagte in Stabiles Netatmo Thermostat Blockly (Adapter):
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  Habe ich vereinzelt oder öfters auch. Ist das überhaupt ein Problem?
                  • Newpicsel
                    Newpicsel @bubus last edited by
                    @bubus @helfi9999
                    Moin
                    Ein Problem ist dieser Fehler tatsächlich nicht, aber dennoch unschön, nehme ich mir die Tage vor und den Fehler beseitigen 😊
                    Ich werde diesen dann auch bei den älteren Versionen aktualisieren!
                    • Newpicsel
                      @kpmc
                      Tatsächlich muss bei dem javascript Adapter etwas eingestellt sein, kontrolliere mal in dem Einstellungen ob ein hacken bei: Kommando "setObjekt", "exec" und "sendToHost" erlauben gesetzt ist.
                      In dem Objekt "Token_Request" sollte der übermittelte Access Token, der refresh Token, die verwendeten scopes und wann die Token verfallen eingetragen sein, hier stimmt also bereits etwas nicht, weil im Falle eines Fehlers hier der Grund und Fehler selbst eingetragen sein sollte.
                      Kannst du mir denn kompletten Inhalt dieses Objektes schicken? Vertrauliche Informationen kannst du natürlich durch ein X ersetzen!
                      Sollte hier nur {"ack":true} eingetragen sein, ist dies definitiv nicht korrekt, hier sollte zumindest eine Rückmeldung mit dem Fehler stehen, sollte die Übermittlung an sich funktionieren, so ist natürlich der Fehler {invalid access token} klar, weil kein Token übermittelt wurde!
                      Gibt es zusätzlich Fehlermeldungen im log?
                      Für mich scheint es tatsächlich so, dass die Anfrage an sich gar nicht stattfindet, oder nicht verarbeitet werden kann, was entweder an iobroker oder der api bzw. deinem Konto dort liegen könnte…
                      Müssen wir jetzt nach und nach die möglichen Ursachen ausschließen, aber sollten wir hinbekommen! 😉
                      • Newpicsel
                        @kpmc said in Stabiles Netatmo Thermostat Blockly (Adapter):
                        @newpicsel
                        Hier stehen dann bei dir aber die Token?
                        Dann liegt es nicht an der api oder deinem Konto dort, scheinen ja grundsätzlich abrufbar zu sein!
                        Dann kann es nur an ioBroker liegen, bzw. der Übermittlung oder Verarbeitung!
                        Eigentlich wird bei jeder Aktion ein Eintrag im log gemacht, starte das Blockly nochmal und schicke mir alle Einträge die damit zusammenhängen könnten, auch ein Screen der Objekte könnte hilfreich sein…
                          bubus @Newpicsel last edited by
                          @newpicsel sagte in Stabiles Netatmo Thermostat Blockly (Adapter):
                          @bubus @helfi9999
                          Moin
                          Das wäre sehr löblich von dir! 👍
                            @newpicsel Im Javascipt Adapter habe ich wie beschrieben die Hacken gesetzt.
                            Ich hatte die Version 1.3.1 auch probiert (alles gelöscht und neu installiert), leider der gleiche Fehler.
                            Ich kann den Fehler einfach nicht finden. Hatte bereits ein neues System aufgesetzt um jegliche Altlasten auszuschliessen. Immer der gleiche Fehler.
                            Wie bereits beschrieben erhalte ich mit dem Curl-Befehl (NaPlug) alle Angeben. Token hinterlegt.
                            (curl -X GET "https://api.netatmo.com/api/homesdata?gateway_types=NAPlug" -H "accept: application/json" -H "Authorization: Bearer xxxxf129bd1dbf955899771db0805acbe8854fexxxx)
                            Ich denke der Fehler am Netatmo-Konto kann ausgeschlossen werden.
                            Anbei der Auszug aus den Objekten:
                            Wenn ich den Objektbaum anschaue steht unter "Token_Request" bei "write" "false"
                            benötige ich evtl. noch zusätzliche Rechte die ich nicht aktiviert habe?
                            Habe auch keine anderen Fehler im Log.
                            Anbei den Inhalt des Objektes.
                            • Newpicsel
                              @kpmc Moin,
                              Also in den Objekten (Access_Token, Refresh_Token und Token_Request) steht "invalid grand type", das ist gar nicht so schlecht, weil das bedeutet, die Anfrage findet statt, nur stimmt mit den Daten etwas nicht!
                              Zuerst ist ein Intervall von 0sek nicht so optimal 😅
                              Stelle diesen mal auf 30-60sek…
                              Die Rechte für "Write" sind auch ok, da diese Objekte nur vom System geschrieben werden.
                              Dein curl Befehl, kannst du fast komplett ignorieren, auf der Website von Netatmo sehen die Befehle anders aus, weil du dort bereits angemeldet bist, von außerhalb jedoch nicht, deshalb muss der Befehl anders aussehen und stellt sich aus deinen Zugangsdaten zusammen!
                              Aber diesen Befehl kannst du auch komplett ignorieren, weil das Blockly alles automatisch erledigt.
                              Lediglich deine HomeID kannst du dort hervorragend abgreifen!
                              Wichtig sind deine korrekten Zugangsdaten, und so wie es aussieht, stimmt hier tatsächlich etwas nicht, was oder warum, kann ich schlecht ermitteln, wir können nur gemeinsam die Schritte durchgehen, wo und wie du diese erhalten hast, eventuell können wir so Fehler ausschließen.
                              Fangen wir mit der HomeID an:
                              Auf der Website von Netatmo eingeloggt (wichtig du musst eingeloggt sein), scrollst du runter bis auf "GET/homesdata" klickst auf "try it response" dann auf "try it out" und dann auf "execute /homesdata" direkt unter homes steht nun eine ID: das ist deine HomeID.
                              (Ich kann gerne Bilder zur Erklärung hochladen wenn gewünscht?)
                              Benutzername (Email) und Passwort sollten klar sein, dass sind die, mit denen du dich bei Netatmo anmeldest.
                              ClientID und ClientSecret, bekommst du indem ebenfalls auf der obigen Website von Netatmo, hier musst du auf dein Benutzernamen klicken und dort auf "My Apps", dort musst du eine App anlegen, hier nur die Pflichtfelder ausfüllen und die App aktivieren.
                              Diese Daten in den Objekten eintragen und den Rest macht das Blockly automatisch, hier sehr gewissenhaft alle Daten übertragen, mir selber ist es schon passiert und auch mit anderen Nutzern, mit den ich geschrieben habe, haben oft irgendwo eine Zahl beim kopieren vergessen oder ein Fehler beim tippen gemacht, bzw. ein Fehler bei der Beschaffung der Daten gemacht, es hört sich immer doof an, aber ein anderes Problem als fehlerhafte Zugangsdaten, gab es seit der ersten stabilen Version des Blocklys nicht.
                              Und auch hier sieht es so aus als ob es daran liegt.
                              Ganz WICHTIG das Blockly nach der Eingabe aller Daten neu starten! Fehlermeldungen bis dahin sind normal!
                              Ich hoffe das konnte helfen, geb bitte kurz Bescheid, sonst schauen wir uns alles noch genauer an! 😊
                              EDIT:
                              Sorry, der Fehler mit dem Intervall auf 0 liegt wohl nicht bei dir, dieser wird beim erzeugen immer auf 0 gesetzt, erst wenn der Status auf True geprüft wird, stellt sich dieser auf 60sek!
                                @newpicsel
                                ich habe den intervall auf 30 sek. gestellt. hat sich noch nichts geändert.
                                Ich habe die Home-ID wie auch nochmals von dir beschrieben ermittelt:
                                Die gelb eingekreiste Fläche sollte meine Home-ID sein.
                                Dann habe ich die App angelegt:
                                ID und SecretID -> Copy Paste in dievorgeshenen Werte im Objektbaum
                                Habt das Blockly mehrmals gestoppt/gestartet und neuinstalliert (Auch der Objektbaum gelöscht)
                                Immer mit dem gleichen Resultat.
                                Ich zweifele nicht am Blockly, eher das ich die Angaben im Netatmo-Account falsch angelegt habe.
                                Sollte eigentlich nicht schwer sein.
                                1. Einloggen, sehe meine Geräte im Account
                                2. Neue App anlegen "My Apps" -> In meinem Fall "Heizung_Netatmo"
                                3. Pflichtfelder alle ausgefüllt -> data protection officer mail: habe die gleiche Mail genommen wie für das Login bei Netatmo. Ist das falsch?
                                4. ID's in den Objektbaum kopiert.
                                redirect URI / webhook URI sind leer, muss ich hier was ausfüllen?
                                Meine Vorgehensweise beim Import vom Blockly:
                                1. deine RAR-Datei heruntergeladen und mit 7-Zip als txt-Datei geöffnet.
                                2. Neues Blockly erstellt -> Import (Copy+Paste). Muss das Blockly in eine spezielle Ordnerstruktur? (Global, Common, etc.)
                                Den kompletten Vorgang habe ich mehrere Male wiederholt, immer mit dem gleichen Resultat.
                                Newpicsel 2 Replies Last reply Reply Quote 0
                                • Newpicsel
                                  @kpmc
                                  Scheint soweit alles ok!
                                  Blockly in Common erstellen!
                                  Mir fällst sonst auch nichts mehr ein, die Abfrage passt, auch wenn es nervt und man kurz davor ist alles hinzuschmeißen, es muss an den Zugangsdaten liegen 😞
                                  Beim Copy/Paste was vergessen oder Zuviel markiert? Ein Leerzeichen könnte schon reichen oder ein Gänsefüßchen mit kopiert, ich hatte mir die Client Daten in eine TXT kopiert woraus ich sie immer gezogen habe beim Testen und dort schon eine Zahl vergessen, ich bin fast verrückt geworden!
                                  Beim Benutzernamen, hast deine Emailadresse genommen? Groß und Kleinschreibung überall korrekt?
                                  Es passieren manchmal die unerklärlichsten Fehler, jemand hatte mal ein Leerzeichen in der Emailadresse, sowas fällt nicht immer sofort auf…
                                  Einzige Möglichkeit um wirklich etwas mit dem Blockly auszuschließen, den Energie Adapter installieren und testen ob es mit diesem geht?
                                  Es kann aber eigentlich nicht an Iobrocker, dem Blockly oder ähnliches liegen, es wird ja versucht die token abzufragen, die Error Nachricht, welche zB. In dem Objekt Token_Request hinterlegt ist, kommt direkt von Netatmo und nicht vom Blockly oder iobroker etc.
                                  also werden Anfragen gesendet und auch antworten von Netatmo empfangen, Netatmo antwortet aber, dass etwas mit den Zugangsdaten nicht stimmt was da nicht stimmt ist sehr schwer zu ermitteln, wenn dies nicht sein eigenes Konto ist 😵
                                  • Newpicsel
                                    Newpicsel @Newpicsel last edited by Newpicsel
                                    (Update 20.09.2021) v1.4.1 - !!NICHT EMPFOHLEN!!
                                    Netatmo_Thermostat_Blockly_byNewpicsel_v1.4.1.rar
                                    (Wenn möglich den kompletten Netatmo Ordner löschen (muss nicht sofort passieren), gut wäre zusätzlich den Eigene_Objekte Ordner zu löschen, hier müssen keine unterverzeichnisse mitgelöscht werden, wenn der Netatmo Ordner bereits seperat gelöscht wurde!)
                                    Minimale Anpassungen, wer die v1.3.1 oder v1.4.0 laufen hat, muss diese Version nicht zwingend installieren, kleine fehlerbehebungen und optische anpassung, der Ordner "Netatmo" selber und somit dessen ID gibt nun keinen Wert "true/false" für den status des „Adapters“ mehr aus!...
                                    • Newpicsel
                                      @kpmc
                                      Moin an alle Smart Home Freunde
                                      !!Wichtig!!
                                      Es kann tatsächlich einen Fehler bei der Tokenabfrage geben! Hier werden die Token nicht richtig aktualisiert, warum oder wie der Fehler zustande kommt, weiß ich noch nicht genau, ich hatte dies beim Testen einer neuen Version, dieser hat sich jedoch schneller behoben als ihn rekonstruieren konnte!
                                      Ich bin dran und werde den Fehler beheben!
                                      Bis dahin bitte keine Aktualisierung der Blockly Version durchführen!!!
                                      Der Fehler tritt nur auf, wenn Token komplett neu angefordert werden, solange ein refresh_token vorhanden ist, wird wohl alles normal weiter laufen.
                                      Dies liegt wohl aber an einer Änderung oder Update von ioBroker bzw. des JavaScript Adapters, deshalb wird so schnell wie möglich ein Blockly mit der Version 1.5.x erscheinen, worauf dann alle Updaten sollten!
                                      Weitere Informationen folgen…
                                      Danke und schöne Grüße
                                      Newpicsel
                                      • Newpicsel
                                        (Update 28.09.2021) v2.2.0 - !!NICHT EMPFOHLEN!!
                                        Netatmo_Thermostat_Blockly_byNewpicsel_v2.2.0.rar
                                        Der komplette Ordner "Eigene_Objekte" sollte gelöscht werden! Wurde dies bereits bei der v1.4.1 gemacht, nur den Netatmo Ordner löschen!
                                        (Wer weitere Objekte im "Eigene_Objekte" Ordner hat, kann auch erst den kompletten Netatmo Ordner löschen und dann den "Eigene_Objekte" löschen und auf „DIESES OBJEKT“ klicken, dann bleiben Unterordner/Objekte bestehen!)
                                        Wichtige Neuerungen:
                                        • Das Blockly muss bei Eingabe von Externen ID‘s nicht neu gestartet werden. (Fenster Sensoren, Away ID‘s)
                                        • Das Blockly kann per Button in den Objekten neu gestartet werden! (Test bitte um Feedback)
                                        • Zusätzliche Objekte mit ID‘s und Empfangsstärke der Geräte, Details der Bridge und die in der App festgelegte Temperatur für „Frostwächter“ und „Away“ stehen nun zur Verfügung.
                                        • Die Funktion der Externen Fenstersensoren wurde komplett überarbeitet und ist nun noch sicherer!
                                        Zum Schutz vor falschen Wertänderungen durch kurzen (schnellen) öffnen und schlißen eines Sensors, wartet das System nun 10 Sekunden nach einer Aktion, prüft den soll Zustand und reagiert dann erst auf eine Änderung.
                                        Beim öffnen eines Sensors wird die in den Objekten eingetragene Temperatur bzw. Wenn diese auf 0 steht, die Frostwächter Temperatur für 24 Stunden eingestellt, sollte sich die soll Temperatur in einem Raum ändern, überprüft das System ob das Fenster geöffnet ist, falls wahr, wird entsprechende Temperatur erneut für 24 Stunden eingestellt.
                                        Beim schließen eines Sensors, wird direkt der reguläre Heizplan in diesem Raum aktiviert.
                                        (Natürlich kann dann während das Fenster offen ist, die Temperatur nicht geändert werden, dafür müsste der "fensterStatusOpen" wert in den Objekten auf "false" geändert werden, das System reagiert dann auf die nächste Aktion wieder normal und stellt beim nächsten öffnen auch wieder auf "true")
                                        • die Angabe des Batterie Levels wurde wieder hinzugefügt! (Was genau die Zahl aussagen soll ist mir ein Rätsel, solltest du da mehr wissen, gib gerne Bescheid, dann könnte ich diese eventuell zusätzlich in Prozent umwandeln!)
                                        • Sehr viele mögliche Probleme, Fehler und eventuell auftretende Fehler sind behoben oder das System so eingestellt, dass es Fehler selber behebt!
                                        • Struktur und Objekte aufgeräumt…
                                        Testen und fleißig Feedback geben bitte 😊👍
                                        Danke für eure Hilfe und besonderen Dank an @bubus
                                        @KPMC sollte jetzt auch bei dir laufen!
                                        B K 2 Replies Last reply Reply Quote 1
                                          bubus @Newpicsel last edited by bubus
                                          @newpicsel
                                          Danke!!!
                                          Ich habe nicht alle Funktionen ausprobiert, mir sind die Fenstersensoren wichtig, und die funktionieren richtig gut!
                                          Klasse Arbeit! 👍
                                            @newpicsel danke für dein Einsatz und deine Tipps.
                                            Leider bekomme ich immer noch die selbe Fehlermeldung.
                                            Ich habe einen neuen Netatmo-Account erstellt, die Thermostate in diesen gewechselt -> kein Erfolg.
                                            Ich habe eine neue virtuelle Maschine erstellt (Proxmox, Ubuntu 20.04) nur die nötigsten Features installiert. Immer das gleich Ergebnis.
                                            Das selbe auch schon mit einem Raspi 3 (Raspian Buster), auch kein Erfolg.
                                            Als nächstes werde ich meine Netzwerk prüfen (Firewall, Router, etc.) vielleicht bleibt da was hängen!
                                            Das Blockly wird sicher fehlerfrei sein, das zeigen die Tests der anderen Nutzer.
                                            Ich bleibe dran (Erst mal Ferien 😁 ).
                                            Danke nochmals für deine Tipps und Feedbacks, saubere Sache 👍
                                            adapter blockly netatmo stable tester thermostat
                                            16
                                            319
                                            52696
