      exitus @jomjol last edited by exitus
      @jomjol super das war das problem
      was ist hier das problem ????
      [MakeImage]
      ;LogImageLocation = /log/source
      WaitBeforeTakingPicture = 5
      ;LogfileRetentionInDays = 15
      Brightness = 0
      ;Contrast = 0
      ;Saturation = 0
      ImageQuality = 5
      ImageSize = VGA
      FixedExposure = false
      [Alignment]
      InitialRotate = 0
      InitialMirror = false
      SearchFieldX = 20
      SearchFieldY = 20
      AlignmentAlgo = default
      FlipImageSize = false
      /config/ref0.jpg 337 271
      /config/ref1.jpg 384 108
      [Digits]
      Model = /config/dig1210s2q.tflite
      ;LogImageLocation = /log/digit
      ;LogfileRetentionInDays = 3
      ModelInputSize = 20 32
      ;ExtendedResolution =
      main.dig1 57 62 45 78
      main.dig4 273 64 45 78
      main.dig5 344 64 40 76
      main.dig6 415 69 41 78
      main.dig7 487 68 40 78
      main.dig2 130 63 45 78
      main.dig3 201 62 45 78
      ;[Analog]
      Model = /config/ana0700s1lq.tflite
      ;LogImageLocation = /log/analog
      ModelInputSize = 32 32
      ExtendedResolution = true
      main.ana1 432 230 92 92
      main.ana2 379 332 92 92
      main.ana3 283 374 92 92
      main.ana4 155 328 92 92
      [PostProcessing]
      main.DecimalShift = -2
      PreValueUse = true
      PreValueAgeStartup = 720
      AllowNegativeRates = false
      main.MaxRateValue = 10
      ErrorMessage = true
      CheckDigitIncreaseConsistency = true
      ;IgnoreLeadingNaN =
      [MQTT]
      Uri = mqtt://192.168.10.100:1689
      MainTopic = Gaszaehler
      ClientID = Gas
      user = user
      password = admin
      ;[GPIO]
      ;IO0 = input disabled 10 false false
      ;IO1 = input disabled 10 false false
      ;IO3 = input disabled 10 false false
      ;IO4 = built-in-led disabled 10 false false
      ;IO12 = input-pullup disabled 10 false false
      ;IO13 = input-pullup disabled 10 false false
      [AutoTimer]
      AutoStart = true
      Intervall = 4.85
      [Debug]
      Logfile = false
      [System]
      TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
      ;TimeServer = undefined
      ;AutoAdjustSummertime = false
      ;Hostname = undefined
      ;SetupMode = false
        jomjol @exitus last edited by
        @exitus Kannst du bitte das Logging einschalten und das Logfile von 2-3 vollständigen Runs und die komplette config.ini schicken?
          jomjol @d0m1n1qu3 last edited by
          @d0m1n1qu3 Das Bild ist noch ziemlich hell, vielleicht kannst du das noch runterstellen (Brightness) und die ROIs sind etwas klein. Wenn du das Update aufgespielt hast, dann gibt es beim ROI zwei Rahmen, der innere soll genau auf den Zahlen liegen. Am besten hat man einen kleinen Rand um die Ziffer selbst.
          E D 2 Replies Last reply Reply Quote 0
            @jomjol danke jomjol es klappt jetzt es hatte was mit der position der zahlen zutun .
            aber evtl.hier kannst du mir helfen, bei den Stromzähler habe ich kein Platz ich muss fast bzw bis zum glas gehen. Ich habe hier ein Fischauge Objektiv irgendwie klappt es nicht so wie ich es mir wünsche .
            1.Was ist hier falsch
            2. gibt es eine andere linse außer Fischauge zb. mit Weitwinkel
            Sehr oft driftet das bild weil ich keine schöne Anhaltspunkte habe auf dem Zähler
            [MakeImage]
            Brightness = -2
            ;Contrast = 0
            ;Saturation = 0
            ImageQuality = 5
            ImageSize = VGA
            FixedExposure = true
            [Alignment]
            InitialRotate = 180
            SearchFieldX = 20
            SearchFieldY = 20
            /config/ref0.jpg 533 156
            /config/ref1.jpg 365 97
            [Digits]
            main.dig1 222 161 36 65
            main.dig2 266 161 36 65
            main.dig3 309 161 36 65
            main.dig4 354 159 40 72
            main.dig5 400 160 41 74
            main.dig6 451 158 42 76
            ;[Analog]
            [PostProcessing]
            main.DecimalShift = 0
            PreValueUse = true
            main.MaxRateValue = 0.3
            ErrorMessage = true
            ;IgnoreLeadingNaN =
            [MQTT]
            MainTopic = stromzaehler
            ClientID = strom
            user = user
            password = admin
            ;[GPIO]
            [AutoTimer]
            AutoStart = true
            Intervall = 4.85
            [Debug]
            Logfile = false
            [System]
            ;SetupMode = false
              d0m1n1qu3 @jomjol last edited by
              @jomjol danke .. glaube das wars .. behalte es mal im auge .. leider ist meine 6 jetzt krum .. hoffentlich rückt die noch nach ^^
                @exitus Ich habe dasselbe Problem und es mit einem Spiegel von 45° umgelenkt und konnte so das normale Objektiv mit passendem Abstand verwenden. Mein Aufbau ist nur 3cm tief und passt so in den Kasten.
                  @jomjol hast du einleitung hast du ein Fischauge Objektiv??
                  kannst du fotos machen damit ich sehen kann. bei mir ist das Problem das zwischen zähler und tür nicht mehr wie 2cm ist
                    @exitus Hier meine Lösung:
                    Ist noch sehr rudimentär und bastelartig, funktioniert aber. Momentan gibt es vor allem probleme mit den Reflektionen, da die Glasoberfläche hier glatt ist und nicht gewölbt, wie bei einer Wasseruhr. Da denke ich aber über exteren LEDs nach, die man an der Seite anbringen kann.
                    W D E 3 Replies Last reply Reply Quote 0
                      watcherkb @jomjol last edited by
                      @jomjol grüß dich, welche Funktion hat denn der Kondensator?
                        watcherkb last edited by
                        @all, welche SD Karte könnt ihr empfehlen. Bei mir steigt einer immer aus.
                        • BananaJoe
                          BananaJoe Most Active @watcherkb last edited by
                          @watcherkb sagte in Wasserzähler - Version 2 - all-in-device:
                          https://www.amazon.de/gp/product/B073K14CVB/
                          Funktioniert bei mir an 3 Installationen (Strom, Wasser, Gas)
                            jomjol @watcherkb last edited by
                            @watcherkb Der Kondensator dient zur Spannungsstabilierung. Bei mir hängen 3 ESP32s an einer Stromversorgung und wenn die dann ungünstig ihre LEDs und Kameras anwerfen, dann hilft das (vielleicht 🙂 ).
                            oberfragger 1 Reply Last reply Reply Quote 0
                              d0m1n1qu3 @jomjol last edited by d0m1n1qu3
                              @jomjol an dem stl hätte ich ja auch interesse 🙂
                              was mir noch einfällt .. wird es mit der spiegelung evtl besser wenn man nicht 45 grad macht sonder leicht schräg guckt?
                              oder mag das das netz dann eher nicht?
                                @jomjol die ov2640 gibt es ja mit längeren Anschlüssen ca. 75mm da könnte man ja nur die Linse ausrichten und das esp32 von der Seite einbauen
                                Sieht zwar häslich aus aber geht
                                Nur die Zahlen erkennt es nicht immer richtig mit der 2 und 8 hat es probleme
                                J D 2 Replies Last reply Reply Quote 0
                                  MischMaster @jomjol last edited by
                                  @jomjol Hi, jetzt hab ich endlich geschafft das Log so auszugeben, wie du es brauchst (denke ich).
                                  Ich hab mit dem Arduino IDE Monitor mitgeschnitten, was nach einem Reset passiert.
                                  Sieht für mich nach einem Bootloop aus. Nach dem Reboot geht es immer so weiter, wie in dem Log File.
                                  Com 3 Log.txt
                                    jomjol @MischMaster last edited by
                                    @mischmaster Du hast ein Problem mit der Kamera. Das erkennst du irgendwo eher im ersten Drittel:
                                     [0;31mE (4089) camera: Detected camera not supported. [0m
                                     [0;31mE (4089) camera: Camera probe failed with error 0x20004 [0m
                                     [0;31mE (4089) server_part_camera: Camera Init Failed [0m
                                    Das hat mit der Konfiguration nichts zu tun. Unterstützt wird nur die OV2640. Falls das bei dir passt, dann erstmal den Stecker prüfen, ansonsten ist sie vielleicht einfach defekt.
                                      @exitus auch eine ungewöhnliche aber funktionierende Lösung 👍
                                      Momentan arbeite ich bezüglich der Reflexionen an einer Möglichkeit, externe LEDs anzusteuern. Das wäre dann sogar die Helligkeit einstellbar. Dauert noch ein bisschen.
                                        @d0m1n1qu3 Schräck nutzt auch nichts, solange die LED nahe an der Bildachse liegt. Ich arbeite gerade an einem Upgrade, mit welchem man dann externe LEDs ansteuern kann. Die kannst du dann beliebig anbringen.
                                          @jomjol bei meinem stromzähler erkennt es die zahlen nicht immer richtig warum kann das sein.Gaszähler und wasserzähler läuft besser.
                                          [MakeImage]
                                          LogfileRetentionInDays = 7
                                          Brightness = 1
                                          ;Contrast = 0
                                          ;Saturation = 0
                                          ImageQuality = 5
                                          ImageSize = VGA
                                          [Alignment]
                                          InitialRotate = 180
                                          SearchFieldX = 20
                                          SearchFieldY = 20
                                          /config/ref0.jpg 279 232
                                          /config/ref1.jpg 196 25
                                          [Digits]
                                          main.dig1 143 285 36 65
                                          main.dig2 188 285 36 65
                                          main.dig3 233 280 36 65
                                          main.dig4 273 280 40 72
                                          main.dig5 315 277 41 74
                                          main.dig6 359 275 45 81
                                          ;[Analog]
                                          [PostProcessing]
                                          PreValueUse = true
                                          main.MaxRateValue = 5
                                          ErrorMessage = true
                                          ;IgnoreLeadingNaN =
                                          [MQTT]
                                          ClientID = strom
                                          user = xxxxxx
                                          password = xxxxxx
                                          ;[GPIO]
                                          [AutoTimer]
                                          AutoStart = true
                                          Intervall = 4.85
                                          [Debug]
                                          Logfile = false
                                          [System]
                                          ;SetupMode = false
                                            @exitus
                                            1. Deine ROIs sind insbesondere bei den letzten Ziffern viel zu groß. Als Orientierung gibt es 2 Rechtecke. Das innere soll genau um die Ziffern gehen, dann ist der Rand okay.
                                            2. Der Kontrast ist relativ schwach, dass könnte auch zu Problemem führen --> mal an der Beleuchtung noch etwas optimieren.
                                            B E 2 Replies Last reply Reply Quote 0
                                            238
                                            3411
                                            2009579
