Pi Überlastet ** geschlossen mit neuinstall **
@homoran also ab besten alles neu machen
@horst-böttcher sagte in Pi Überlastet:
solange du nicht weisst was du falsch hast, wird es sehr wahrscheinlich auch bei einer Neuanlage wieder so sein
@homoran das problem hab ich erst seid dem ich auf Admin 5 umgestellt hab
@horst-böttcher
iobroker update -i
@homoran sagte in Pi Überlastet:
iobroker update -i
pi@raspberrypi:/opt/iobroker $ iobroker update -i Used repository: Stable (default) hash changed or no sources cached => force download of new sources update done Adapter "admin" : 5.1.25 , installed 5.1.25 Adapter "alias-manager" : 1.2.3 , installed 1.2.3 Adapter "backitup" : 2.1.17 , installed 2.1.17 Adapter "ble" : 0.12.0 , installed 0.12.0 Adapter "bring" : 1.7.8 , installed 1.7.8 Adapter "chromecast" : 2.3.1 , installed 2.3.1 Adapter "daswetter" : 3.0.7 , installed 3.0.7 Adapter "deconz" : 1.3.19 , installed 1.3.19 Adapter "devices" : 1.0.9 , installed 1.0.9 Adapter "discovergy" : 0.5.4 , installed 0.5.4 Adapter "discovery" : 2.7.0 , installed 2.7.0 Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "fb-checkpresence": 1.1.8 , installed 1.1.8 Adapter "feiertage" : 1.0.17 , installed 1.0.17 Adapter "flot" : 1.10.6 , installed 1.10.6 Adapter "fullybrowser" : 2.0.8 , installed 2.0.8 Adapter "history" : 1.9.13 , installed 1.9.13 Adapter "hmip" : 1.13.1 , installed 1.13.1 Adapter "ical" : 1.11.4 , installed 1.11.4 Adapter "icons-mfd-svg" : 1.0.2 , installed 1.0.2 Adapter "icons-ultimate-png": 1.0.1 , installed 1.0.1 Adapter "info" : 1.9.8 , installed 1.9.8 Adapter "iot" : 1.8.22 , installed 1.8.22 Adapter "javascript" : 5.2.8 , installed 5.2.8 Controller "js-controller" : 3.3.18 , installed 3.3.18 Adapter "linux-control" : 1.1.2 , installed 1.1.2 Adapter "nuki-extended" : 2.3.1 , installed 2.3.1 Adapter "openligadb" : 1.1.0 , installed 1.2.0 Adapter "ping" : 1.5.0 , installed 1.5.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.1 , installed 1.3.1 Adapter "sayit" : 1.12.3 , installed 1.12.3 Adapter "shelly" : 4.0.7 , installed 4.0.7 Adapter "simple-api" : 2.6.1 , installed 2.6.1 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.14 , installed 4.2.14 Adapter "trashschedule" : 1.2.0 , installed 1.2.0 Adapter "tuya" : 3.6.9 , installed 3.6.9 Adapter "tvprogram" : 1.1.0 , installed 1.1.0 Adapter "tvspielfilm" : 1.0.4 , installed 1.0.4 Adapter "upnp" : 1.0.19 , installed 1.0.19 Adapter "vis" : 1.4.3 , installed 1.4.3 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5 Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-icontwo" : 0.80.0 , installed 0.80.0 Adapter "vis-inventwo" : 3.1.3 , installed 3.1.3 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-weather" : 2.5.3 , installed 2.5.3 Adapter "web" : 3.4.7 , installed 3.4.7 Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6 Adapter "windows-control": 0.1.5 , installed 0.1.5 Adapter "youtube" : 1.1.1 , installed 1.1.1 Adapter "zigbee" : 1.5.6 , installed 1.5.6
Da sind ja schon einige nahezu identische Adapter am Werk.
Ich kenne auch nicht alle, kann daher nicht sagen, welche möglicherweise dein System asubremsenAuch ob die ganzen China-Adapter sich ggf. mit den Ports in die Quere kommen
Vielleicht weiß da jemand anderes mehr
@horst-böttcher
Stoppe mal die Javascript-Instanz 0, warte einige Minuten und schaue dann mit htop, ob der js-controller immer noch so viele Ressourcen verbraucht. -
es bleibt dabei
@horst-böttcher sagte: es bleibt dabei
Der js-controller lastet die CPU voll aus (gesamte Uptime). Dann stoppe mal alle Instanzen außer admin.0 und schaue nochmal.
alles sauber per SSH Deaktiviert
@horst-böttcher
Auch nach?sudo reboot
@horst-böttcher
nodeJS sauber?
Wenn ja, dann würde ich den js-controller wohl nochmal drüber installieren. -
@thomas-braun hab ich gerade gemacht bleibt dabei
ich glaub ich darf das ganze Grund System neu machen
Was hast du wie gemacht?
Mit welchen Rückmeldungen in der Konsole? -
pi@raspberrypi:~ $ iobroker update Used repository: Stable (default) hash unchanged, use cached sources update done Adapter "admin" : 5.1.25 , installed 5.1.25 Adapter "alias-manager" : 1.2.3 , installed 1.2.3 Adapter "backitup" : 2.1.17 , installed 2.1.17 Adapter "ble" : 0.12.0 , installed 0.12.0 Adapter "bring" : 1.7.8 , installed 1.7.8 Adapter "chromecast" : 2.3.1 , installed 2.3.1 Adapter "daswetter" : 3.0.7 , installed 3.0.7 Adapter "deconz" : 1.3.19 , installed 1.3.19 Adapter "devices" : 1.0.9 , installed 1.0.9 Adapter "discovergy" : 0.5.4 , installed 0.5.4 Adapter "discovery" : 2.7.0 , installed 2.7.0 Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "fb-checkpresence": 1.1.8 , installed 1.1.8 Adapter "feiertage" : 1.0.17 , installed 1.0.17 Adapter "flot" : 1.10.6 , installed 1.10.6 Adapter "fullybrowser" : 2.0.8 , installed 2.0.8 Adapter "history" : 1.9.13 , installed 1.9.13 Adapter "hmip" : 1.13.1 , installed 1.13.1 Adapter "ical" : 1.11.4 , installed 1.11.4 Adapter "icons-mfd-svg" : 1.0.2 , installed 1.0.2 Adapter "icons-ultimate-png": 1.0.1 , installed 1.0.1 Adapter "info" : 1.9.8 , installed 1.9.8 Adapter "iot" : 1.8.22 , installed 1.8.22 Adapter "javascript" : 5.2.8 , installed 5.2.8 Controller "js-controller" : 3.3.18 , installed 3.3.18 Adapter "linux-control" : 1.1.2 , installed 1.1.2 Adapter "nuki-extended" : 2.3.1 , installed 2.3.1 Adapter "openligadb" : 1.1.0 , installed 1.2.0 Adapter "ping" : 1.5.0 , installed 1.5.0 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.1 , installed 1.3.1 Adapter "sayit" : 1.12.3 , installed 1.12.3 Adapter "shelly" : 4.0.7 , installed 4.0.7 Adapter "simple-api" : 2.6.1 , installed 2.6.1 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.14 , installed 4.2.14 Adapter "trashschedule" : 1.2.0 , installed 1.2.0 Adapter "tuya" : 3.6.9 , installed 3.6.9 Adapter "tvprogram" : 1.1.0 , installed 1.1.0 Adapter "tvspielfilm" : 1.0.4 , installed 1.0.4 Adapter "upnp" : 1.0.19 , installed 1.0.19 Adapter "vis" : 1.4.3 , installed 1.4.3 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5 Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-icontwo" : 0.80.0 , installed 0.80.0 Adapter "vis-inventwo" : 3.1.3 , installed 3.1.3 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-metro" : 1.1.2 , installed 1.1.2 Adapter "vis-weather" : 2.5.3 , installed 2.5.3 Adapter "web" : 3.4.7 , installed 3.4.7 Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6 Adapter "windows-control": 0.1.5 , installed 0.1.5 Adapter "youtube" : 1.1.1 , installed 1.1.1 Adapter "zigbee" : 1.5.6 , installed 1.5.6 pi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ iobroker upgrade self Host "raspberrypi" is up to date. pi@raspberrypi:~ $ iobroker start
@horst-böttcher Das meinte ich nicht.
which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs iobroker stop cd /opt/iobroker npm install iobroker.js-controller iobroker start
@thomas-braun sagte in Pi Überlastet:
object _design/custom updated object _design/system updated npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + iobroker.js-controller@3.3.18 updated 1 package in 92.448s 140 packages are looking for funding run `npm fund` for details
danach
@horst-böttcher Könntest du bitte vollständige Ein- und Ausgaben posten?
Was steht so in
dmesg -T
drin?
pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v12.22.6 v12.22.6 6.14.15 Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_12.x buster InRelease Hit:4 https://phoscon.de/apt/deconz buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_12.x buster InRelease Hit:4 https://phoscon.de/apt/deconz buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. nodejs: Installed: 12.22.6-deb-1nodesource1 Candidate: 12.22.6-deb-1nodesource1 Version table: *** 12.22.6-deb-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages pi@raspberrypi:~ $ iobroker stop pi@raspberrypi:~ $ cd /opt/iobroker pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller > iobroker.js-controller@3.3.18 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.15 > iobroker.js-controller@3.3.18 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object _design/custom updated object _design/system updated npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) + iobroker.js-controller@3.3.18 updated 1 package in 91.027s 140 packages are looking for funding run `npm fund` for details pi@raspberrypi:/opt/iobroker $ iobroker start pi@raspberrypi:/opt/iobroker $
dmesg -T
pi@raspberrypi:/opt/iobroker $ dmesg -T [Sat Sep 18 17:25:25 2021] Booting Linux on physical CPU 0x0 [Sat Sep 18 17:25:25 2021] Linux version 5.10.60-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:44 BST 2021 [Sat Sep 18 17:25:25 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [Sat Sep 18 17:25:25 2021] CPU: div instructions available: patching division code [Sat Sep 18 17:25:25 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [Sat Sep 18 17:25:25 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1 [Sat Sep 18 17:25:25 2021] random: fast init done [Sat Sep 18 17:25:25 2021] Memory policy: Data cache writealloc [Sat Sep 18 17:25:25 2021] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB [Sat Sep 18 17:25:25 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [Sat Sep 18 17:25:25 2021] Zone ranges: [Sat Sep 18 17:25:25 2021] DMA [mem 0x0000000000000000-0x000000002fffffff] [Sat Sep 18 17:25:25 2021] Normal empty [Sat Sep 18 17:25:25 2021] HighMem [mem 0x0000000030000000-0x00000000fbffffff] [Sat Sep 18 17:25:25 2021] Movable zone start for each node [Sat Sep 18 17:25:25 2021] Early memory node ranges [Sat Sep 18 17:25:25 2021] node 0: [mem 0x0000000000000000-0x000000003b3fffff] [Sat Sep 18 17:25:25 2021] node 0: [mem 0x0000000040000000-0x00000000fbffffff] [Sat Sep 18 17:25:25 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff] [Sat Sep 18 17:25:25 2021] On node 0 totalpages: 1012736 [Sat Sep 18 17:25:25 2021] DMA zone: 1728 pages used for memmap [Sat Sep 18 17:25:25 2021] DMA zone: 0 pages reserved [Sat Sep 18 17:25:25 2021] DMA zone: 196608 pages, LIFO batch:63 [Sat Sep 18 17:25:25 2021] HighMem zone: 816128 pages, LIFO batch:63 [Sat Sep 18 17:25:25 2021] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920 [Sat Sep 18 17:25:25 2021] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096 [Sat Sep 18 17:25:25 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [Sat Sep 18 17:25:25 2021] Built 1 zonelists, mobility grouping on. Total pages: 1011008 [Sat Sep 18 17:25:25 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:3F:39:D5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=34811267-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [Sat Sep 18 17:25:25 2021] Kernel parameter elevator= does not have any effect anymore. Please use sysfs to set IO scheduler for individual devices. [Sat Sep 18 17:25:25 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [Sat Sep 18 17:25:25 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [Sat Sep 18 17:25:25 2021] mem auto-init: stack:off, heap alloc:off, heap free:off [Sat Sep 18 17:25:25 2021] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB) [Sat Sep 18 17:25:25 2021] Memory: 3601132K/4050944K available (10240K kernel code, 1364K rwdata, 3188K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3264512K highmem) [Sat Sep 18 17:25:25 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [Sat Sep 18 17:25:25 2021] ftrace: allocating 34309 entries in 68 pages [Sat Sep 18 17:25:25 2021] ftrace: allocated 68 pages with 2 groups [Sat Sep 18 17:25:25 2021] rcu: Hierarchical RCU implementation. [Sat Sep 18 17:25:25 2021] Rude variant of Tasks RCU enabled. [Sat Sep 18 17:25:25 2021] Tracing variant of Tasks RCU enabled. [Sat Sep 18 17:25:25 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [Sat Sep 18 17:25:25 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [Sat Sep 18 17:25:25 2021] GIC: Using split EOI/Deactivate mode [Sat Sep 18 17:25:25 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1 [Sat Sep 18 17:25:25 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [Sat Sep 18 17:25:25 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [Sat Sep 18 17:25:25 2021] bcm2835: system timer (irq = 25) [Sat Sep 18 17:25:25 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [Sat Sep 18 17:25:25 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [Sat Sep 18 17:25:25 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [Sat Sep 18 17:25:25 2021] Switching to timer-based delay loop, resolution 18ns [Sat Sep 18 17:25:25 2021] Console: colour dummy device 80x30 [Sat Sep 18 17:25:25 2021] printk: console [tty1] enabled [Sat Sep 18 17:25:25 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [Sat Sep 18 17:25:25 2021] pid_max: default: 32768 minimum: 301 [Sat Sep 18 17:25:25 2021] LSM: Security Framework initializing [Sat Sep 18 17:25:25 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [Sat Sep 18 17:25:25 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [Sat Sep 18 17:25:25 2021] cgroup: Disabling memory control group subsystem [Sat Sep 18 17:25:25 2021] CPU: Testing write buffer coherency: ok [Sat Sep 18 17:25:25 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [Sat Sep 18 17:25:25 2021] Setting up static identity map for 0x200000 - 0x20003c [Sat Sep 18 17:25:25 2021] rcu: Hierarchical SRCU implementation. [Sat Sep 18 17:25:25 2021] smp: Bringing up secondary CPUs ... [Sat Sep 18 17:25:25 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [Sat Sep 18 17:25:25 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [Sat Sep 18 17:25:25 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [Sat Sep 18 17:25:25 2021] smp: Brought up 1 node, 4 CPUs [Sat Sep 18 17:25:25 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS). [Sat Sep 18 17:25:25 2021] CPU: All CPU(s) started in HYP mode. [Sat Sep 18 17:25:25 2021] CPU: Virtualization extensions available. [Sat Sep 18 17:25:25 2021] devtmpfs: initialized [Sat Sep 18 17:25:25 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [Sat Sep 18 17:25:25 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [Sat Sep 18 17:25:25 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [Sat Sep 18 17:25:25 2021] pinctrl core: initialized pinctrl subsystem [Sat Sep 18 17:25:25 2021] NET: Registered protocol family 16 [Sat Sep 18 17:25:25 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations [Sat Sep 18 17:25:25 2021] audit: initializing netlink subsys (disabled) [Sat Sep 18 17:25:25 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1 [Sat Sep 18 17:25:25 2021] thermal_sys: Registered thermal governor 'step_wise' [Sat Sep 18 17:25:25 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [Sat Sep 18 17:25:25 2021] hw-breakpoint: maximum watchpoint size is 8 bytes. [Sat Sep 18 17:25:25 2021] Serial: AMBA PL011 UART driver [Sat Sep 18 17:25:25 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled [Sat Sep 18 17:25:25 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-31T14:52:47, variant start [Sat Sep 18 17:25:25 2021] raspberrypi-firmware soc:firmware: Firmware hash is 67615e950e1e28b92dfae6303cf7a8b879a8908f [Sat Sep 18 17:25:25 2021] Kprobes globally optimized [Sat Sep 18 17:25:25 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [Sat Sep 18 17:25:25 2021] vgaarb: loaded [Sat Sep 18 17:25:25 2021] SCSI subsystem initialized [Sat Sep 18 17:25:25 2021] usbcore: registered new interface driver usbfs [Sat Sep 18 17:25:25 2021] usbcore: registered new interface driver hub [Sat Sep 18 17:25:25 2021] usbcore: registered new device driver usb [Sat Sep 18 17:25:25 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator [Sat Sep 18 17:25:25 2021] clocksource: Switched to clocksource arch_sys_counter [Sat Sep 18 17:25:26 2021] VFS: Disk quotas dquot_6.6.0 [Sat Sep 18 17:25:26 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [Sat Sep 18 17:25:26 2021] FS-Cache: Loaded [Sat Sep 18 17:25:26 2021] CacheFiles: Loaded [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 2 [Sat Sep 18 17:25:26 2021] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [Sat Sep 18 17:25:26 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [Sat Sep 18 17:25:26 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [Sat Sep 18 17:25:26 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [Sat Sep 18 17:25:26 2021] TCP: Hash tables configured (established 8192 bind 8192) [Sat Sep 18 17:25:26 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [Sat Sep 18 17:25:26 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 1 [Sat Sep 18 17:25:26 2021] RPC: Registered named UNIX socket transport module. [Sat Sep 18 17:25:26 2021] RPC: Registered udp transport module. [Sat Sep 18 17:25:26 2021] RPC: Registered tcp transport module. [Sat Sep 18 17:25:26 2021] RPC: Registered tcp NFSv4.1 backchannel transport module. [Sat Sep 18 17:25:26 2021] PCI: CLS 0 bytes, default 64 [Sat Sep 18 17:25:26 2021] Initialise system trusted keyrings [Sat Sep 18 17:25:26 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6 [Sat Sep 18 17:25:26 2021] zbud: loaded [Sat Sep 18 17:25:26 2021] FS-Cache: Netfs 'nfs' registered for caching [Sat Sep 18 17:25:26 2021] NFS: Registering the id_resolver key type [Sat Sep 18 17:25:26 2021] Key type id_resolver registered [Sat Sep 18 17:25:26 2021] Key type id_legacy registered [Sat Sep 18 17:25:26 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [Sat Sep 18 17:25:26 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [Sat Sep 18 17:25:26 2021] Key type asymmetric registered [Sat Sep 18 17:25:26 2021] Asymmetric key parser 'x509' registered [Sat Sep 18 17:25:26 2021] bounce: pool size: 64 pages [Sat Sep 18 17:25:26 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [Sat Sep 18 17:25:26 2021] io scheduler mq-deadline registered [Sat Sep 18 17:25:26 2021] io scheduler kyber registered [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000 [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000 [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC) [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [Sat Sep 18 17:25:26 2021] pci_bus 0000:00: root bus resource [bus 00-ff] [Sat Sep 18 17:25:26 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff]) [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: PME# supported from D0 D3hot [Sat Sep 18 17:25:26 2021] PCI: bus0: Fast back to back transfers disabled [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: PME# supported from D0 D3cold [Sat Sep 18 17:25:26 2021] PCI: bus1: Fast back to back transfers disabled [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: PCI bridge to [bus 01] [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [Sat Sep 18 17:25:26 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [Sat Sep 18 17:25:26 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62 [Sat Sep 18 17:25:26 2021] iproc-rng200 fe104000.rng: hwrng registered [Sat Sep 18 17:25:26 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB) [Sat Sep 18 17:25:26 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [Sat Sep 18 17:25:26 2021] brd: module loaded [Sat Sep 18 17:25:26 2021] loop: module loaded [Sat Sep 18 17:25:26 2021] Loading iSCSI transport class v2.0-870. [Sat Sep 18 17:25:26 2021] libphy: Fixed MDIO Bus: probed [Sat Sep 18 17:25:26 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [Sat Sep 18 17:25:26 2021] libphy: bcmgenet MII bus: probed [Sat Sep 18 17:25:26 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver r8152 [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver lan78xx [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver smsc95xx [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142) [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890 [Sat Sep 18 17:25:26 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [Sat Sep 18 17:25:26 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [Sat Sep 18 17:25:26 2021] usb usb1: Product: xHCI Host Controller [Sat Sep 18 17:25:26 2021] usb usb1: Manufacturer: Linux 5.10.60-v7l+ xhci-hcd [Sat Sep 18 17:25:26 2021] usb usb1: SerialNumber: 0000:01:00.0 [Sat Sep 18 17:25:26 2021] hub 1-0:1.0: USB hub found [Sat Sep 18 17:25:26 2021] hub 1-0:1.0: 1 port detected [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [Sat Sep 18 17:25:26 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [Sat Sep 18 17:25:26 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [Sat Sep 18 17:25:26 2021] usb usb2: Product: xHCI Host Controller [Sat Sep 18 17:25:26 2021] usb usb2: Manufacturer: Linux 5.10.60-v7l+ xhci-hcd [Sat Sep 18 17:25:26 2021] usb usb2: SerialNumber: 0000:01:00.0 [Sat Sep 18 17:25:26 2021] hub 2-0:1.0: USB hub found [Sat Sep 18 17:25:26 2021] hub 2-0:1.0: 4 ports detected [Sat Sep 18 17:25:26 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [Sat Sep 18 17:25:26 2021] dwc_otg: FIQ enabled [Sat Sep 18 17:25:26 2021] dwc_otg: NAK holdoff enabled [Sat Sep 18 17:25:26 2021] dwc_otg: FIQ split-transaction FSM enabled [Sat Sep 18 17:25:26 2021] Module dwc_common_port init [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver uas [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver usb-storage [Sat Sep 18 17:25:26 2021] mousedev: PS/2 mouse device common for all mice [Sat Sep 18 17:25:26 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [Sat Sep 18 17:25:26 2021] sdhci: Secure Digital Host Controller Interface driver [Sat Sep 18 17:25:26 2021] sdhci: Copyright(c) Pierre Ossman [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [Sat Sep 18 17:25:26 2021] sdhci-pltfm: SDHCI platform and OF driver helper [Sat Sep 18 17:25:26 2021] ledtrig-cpu: registered to indicate activity on CPUs [Sat Sep 18 17:25:26 2021] hid: raw HID events driver (C) Jiri Kosina [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver usbhid [Sat Sep 18 17:25:26 2021] usbhid: USB HID core driver [Sat Sep 18 17:25:26 2021] Initializing XFRM netlink socket [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 17 [Sat Sep 18 17:25:26 2021] Key type dns_resolver registered [Sat Sep 18 17:25:26 2021] Registering SWP/SWPB emulation handler [Sat Sep 18 17:25:26 2021] registered taskstats version 1 [Sat Sep 18 17:25:26 2021] Loading compiled-in X.509 certificates [Sat Sep 18 17:25:26 2021] Key type ._fscrypt registered [Sat Sep 18 17:25:26 2021] Key type .fscrypt registered [Sat Sep 18 17:25:26 2021] Key type fscrypt-provisioning registered [Sat Sep 18 17:25:26 2021] uart-pl011 fe201000.serial: there is not valid maps for state default [Sat Sep 18 17:25:26 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled [Sat Sep 18 17:25:26 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2 [Sat Sep 18 17:25:26 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [Sat Sep 18 17:25:26 2021] of_cfs_init [Sat Sep 18 17:25:26 2021] of_cfs_init: OK [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [Sat Sep 18 17:25:26 2021] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA [Sat Sep 18 17:25:26 2021] Waiting for root device PARTUUID=34811267-02... [Sat Sep 18 17:25:26 2021] mmc1: new high speed SDIO card at address 0001 [Sat Sep 18 17:25:26 2021] mmc0: new ultra high speed SDR25 SDHC card at address b368 [Sat Sep 18 17:25:26 2021] mmcblk0: mmc0:b368 CBADS 30.0 GiB [Sat Sep 18 17:25:26 2021] mmcblk0: p1 p2 [Sat Sep 18 17:25:26 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Sat Sep 18 17:25:26 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sat Sep 18 17:25:26 2021] devtmpfs: mounted [Sat Sep 18 17:25:26 2021] Freeing unused kernel memory: 2048K [Sat Sep 18 17:25:26 2021] Run /sbin/init as init process [Sat Sep 18 17:25:26 2021] with arguments: [Sat Sep 18 17:25:26 2021] /sbin/init [Sat Sep 18 17:25:26 2021] with environment: [Sat Sep 18 17:25:26 2021] HOME=/ [Sat Sep 18 17:25:26 2021] TERM=linux [Sat Sep 18 17:25:26 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd [Sat Sep 18 17:25:26 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [Sat Sep 18 17:25:26 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [Sat Sep 18 17:25:26 2021] usb 1-1: Product: USB2.0 Hub [Sat Sep 18 17:25:26 2021] hub 1-1:1.0: USB hub found [Sat Sep 18 17:25:26 2021] hub 1-1:1.0: 4 ports detected [Sat Sep 18 17:25:27 2021] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd [Sat Sep 18 17:25:27 2021] systemd[1]: System time before build time, advancing clock. [Sat Sep 18 17:25:27 2021] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00 [Sat Sep 18 17:25:27 2021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [Sat Sep 18 17:25:27 2021] usb 1-1.3: Product: ConBee II [Sat Sep 18 17:25:27 2021] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH [Sat Sep 18 17:25:27 2021] usb 1-1.3: SerialNumber: DE2407723 [Sat Sep 18 17:25:27 2021] NET: Registered protocol family 10 [Sat Sep 18 17:25:27 2021] Segment Routing with IPv6 [Sat Sep 18 17:25:27 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [Sat Sep 18 17:25:27 2021] systemd[1]: Detected architecture arm. [Sat Sep 18 17:25:27 2021] systemd[1]: Set hostname to <raspberrypi>. [Sat Sep 18 17:25:28 2021] random: systemd: uninitialized urandom read (16 bytes read) [Sat Sep 18 17:25:28 2021] random: systemd: uninitialized urandom read (16 bytes read) [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on initctl Compatibility Named Pipe. [Sat Sep 18 17:25:28 2021] random: systemd: uninitialized urandom read (16 bytes read) [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on Syslog Socket. [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on udev Kernel Socket. [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on udev Control Socket. [Sat Sep 18 17:25:28 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice. [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on Journal Socket (/dev/log). [Sat Sep 18 17:25:28 2021] systemd[1]: Created slice system-getty.slice. [Sat Sep 18 17:25:28 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [Sat Sep 18 17:25:29 2021] systemd-journald[122]: Received request to flush runtime journal from PID 1 [Sat Sep 18 17:25:29 2021] mc: Linux media interface: v0.10 [Sat Sep 18 17:25:29 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [Sat Sep 18 17:25:29 2021] [vc_sm_connected_init]: start [Sat Sep 18 17:25:29 2021] [vc_sm_connected_init]: installed successfully [Sat Sep 18 17:25:29 2021] videodev: Linux video capture interface: v2.00 [Sat Sep 18 17:25:29 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835_audio bcm2835_audio: card created with 8 channels [Sat Sep 18 17:25:29 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [Sat Sep 18 17:25:29 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [Sat Sep 18 17:25:29 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [Sat Sep 18 17:25:29 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [Sat Sep 18 17:25:29 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [Sat Sep 18 17:25:30 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [Sat Sep 18 17:25:30 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [Sat Sep 18 17:25:30 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [Sat Sep 18 17:25:30 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database [Sat Sep 18 17:25:30 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [Sat Sep 18 17:25:30 2021] brcmfmac: F1 signature read @0x18000000=0x15264345 [Sat Sep 18 17:25:30 2021] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [Sat Sep 18 17:25:30 2021] usbcore: registered new interface driver cdc_acm [Sat Sep 18 17:25:30 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [Sat Sep 18 17:25:30 2021] usbcore: registered new interface driver brcmfmac [Sat Sep 18 17:25:30 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached [Sat Sep 18 17:25:30 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [Sat Sep 18 17:25:30 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e [Sat Sep 18 17:25:33 2021] uart-pl011 fe201000.serial: no DMA platform data [Sat Sep 18 17:25:33 2021] 8021q: 802.1Q VLAN Support v1.8 [Sat Sep 18 17:25:33 2021] random: crng init done [Sat Sep 18 17:25:33 2021] random: 7 urandom warning(s) missed due to ratelimiting [Sat Sep 18 17:25:33 2021] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS [Sat Sep 18 17:25:34 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay) [Sat Sep 18 17:25:34 2021] bcmgenet fd580000.ethernet eth0: Link is Down [Sat Sep 18 17:25:38 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [Sat Sep 18 17:25:38 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [Sat Sep 18 17:25:40 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [Sat Sep 18 17:25:40 2021] Bluetooth: Core ver 2.22 [Sat Sep 18 17:25:40 2021] NET: Registered protocol family 31 [Sat Sep 18 17:25:40 2021] Bluetooth: HCI device and connection manager initialized [Sat Sep 18 17:25:40 2021] Bluetooth: HCI socket layer initialized [Sat Sep 18 17:25:40 2021] Bluetooth: L2CAP socket layer initialized [Sat Sep 18 17:25:40 2021] Bluetooth: SCO socket layer initialized [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART driver ver 2.3 [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol H4 registered [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol Broadcom registered [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP filters: protocol multicast [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP socket layer initialized
Nichts ungewöhnliches drin, soweit ich sehe.
