    4. Test Adapter LG ThinQ
      Lucky_ESA Developer Most Active last edited by Lucky_ESA
      Hi tombox,
      schreibe mir gerade ein Blockly für den Kühlschrank..Statusabfrage etc..
      Beim übersetzen für ein HTML String sind mir leider folgende Fehler aufgefallen.
      Wenn du Zeit hast kannst du bitte den Raw der u. a. Datenpunkte anpassen.
          "states": {
                  "OFF": "OFF",
                  "ON": "ON",
                  "IGNORE": "IGNORE"
          "states": {
            "OFF": "OFF",
            "EXPRESS_ON": "EXPRESS_ON",
            "RAPID_ON": "RAPID_ON",
            "IGNORE": "IGNORE"
          "states": {
            "OFF": "OFF",
            "AUTO": "AUTO",
            "POWER": "POWER",
            "REPLACE": "REPLACE",
            "SMART_STORAGE_POWER": "SMART_STORAGE_POWER",
            "SMART_STORAGE_OFF": "SMART_STORAGE_OFF",
            "SMART_STORAGE_ON": "SMART_STORAGE_ON",
            "IGNORE": "IGNORE"
          "states": {
            "OFF": "OFF",
            "ON": "ON",
            "IGNORE": "IGNORE"
         "states": {
           "OFF": "OFF",
           "ON": "ON",
           "IGNORE": "IGNORE"
        "states": {
          "STOP": "STOP",
          "RUN": "RUN",
          "IGNORE": "IGNORE"
       "states": {
         "CELSIUS": "CELSIUS",
         "FAHRENHEIT": "FAHRENHEIT",
         "IGNORE": "IGNORE"
          "states": {
            "0_MONTH": "0_MONTH",
            "1_MONTH": "1_MONTH",
            "2_MONTH": "2_MONTH",
            "3_MONTH": "3_MONTH",
            "4_MONTH": "4_MONTH",
            "5_MONTH": "5_MONTH",
            "6_MONTH": "6_MONTH",
            "7_MONTH": "7_MONTH",
            "8_MONTH": "8_MONTH",
            "9_MONTH": "9_MONTH",
            "10_MONTH": "10_MONTH",
            "11_MONTH": "11_MONTH",
            "12_MONTH": "12_MONTH",
            "IGNORE": "IGNORE"
         "states": {
           "OFF": "OFF",
           "NIGHT_ON": "NIGHT_ON",
           "CUSTOM_ON": "CUSTOM_ON",
           "SMARTGRID_DR_ON": "SMARTGRID_DR_ON",
           "SMARTGRID_DD_ON": "SMARTGRID_DD_ON",
           "IGNORE": "IGNORE"
      Edit1: Habe gerade gesehen das fast alle Datenpunkte der Waschmaschine auch mit states erstellt werden..
          "states": {
            "0": "AIDDLed_OFF",
            "1": "AIDDLed_ON"
      Gruß//Lucky
        tombox @Lucky_ESA last edited by
        @lucky_esa Ja es sind states weil LG so arbeitet wo ist das Problem mit states
          Lucky_ESA Developer Most Active @tombox last edited by
          @tombox said in Test Adapter LG ThinQ v0.0.1:
          Weil die nicht passen. Dann lass doch einfach einen String, oder?
          So ist es jetzt:
            "states": {
               "0": "AIDDLed_OFF",
               "1": "AIDDLed_ON"
          Da ein String kommt müsste es doch so aussehen
              "states": {
                "AIDDLed_OFF": "AIDDLed_OFF",
                "AIDDLed_ON": "AIDDLed_ON"
          Wobei das Sinnfrei wäre...Vielleicht bin ich auch verwirrt oder drücke mich falsch aus..
          Gruß//Bodo
          • DenisM
            DenisM last edited by
            Hallo zusammen ich habe auch den Adapter installiert (mit einer LG Waschmaschine)
            Die Daten von der Waschmaschine kommen alle in ioBroker an aber ich habe im Protokoll pro Abfrage immer 2 Fehlerzeilen:
            Kann mir jemand erklären was die Fehler zu bedeuten haben?
              tombox @DenisM last edited by
              @denism was sagt Google translator
              DenisM 1 Reply Last reply Reply Quote 0
              • DenisM
                DenisM @tombox last edited by
                @tombox sagte in Test Adapter LG ThinQ v0.0.1:
                Ach auf die Idee bin ich noch gar nicht gekommen. Danke:
                9000 - Schlechte Anfrage
                Das Gerät verbindet sich nicht.
                Ist aber quatsch. Das Gerät ist verbunden und auch z.B. die verbleibenden Minuten einer Waschladung werden korrekt übermittelt.
                  @denism Schwer zu sagen müsste man in die zugangsdaten haben und schauen was die app macht
                  Wie ist der Wert von lg-thinq.0.xxxx.platformType
                  • DenisM
                    platformType = thinq1
                    • DenisM
                      DenisM @DenisM last edited by DenisM
                      Kann das vielleicht sein das der Fehler kommt weil sich die Waschmaschine nach einer Wäsche allein wieder ausschaltet und dann ist sie natürlich nicht mehr erreichbar für eine ganze Weile. Erst wieder wenn ich eine neue Waschladung starte. Würde Sinn machen. Aber es ist nun mal normal das sich die Waschmaschine allein ausschaltet nachdem sie fertig ist ... wenn das der Fehler ist müsste man das im Code berücksichtigen? Wie ist das bei euch?
                        Hohenbostler last edited by
                        Hi zusammen. Ist irgendwann geplant den Intervall runter zu setzten ? Leider hilft mir eine Minute nicht beim Prüfen ob die kühlschranktür offen ist.
                          tombox @Hohenbostler last edited by
                          @hohenbostler du kannst auf 0.5 setzen oder 0
                            Hallo tombox,
                            leider sehe ich keinen Unterschied bei der Auswahl 0.x oder 0. Bei allen wird nach 30 Sekunden aktualisiert.
                              Hohenbostler @tombox last edited by
                              und was genau bedeuten die werte ?
                                @lucky_esa aber 30sek sollten doch ausreichend sein oder?
                                  @tombox Wenn die frage an mich geht. Bei einer Waschmaschine sicher aber beim Kühlschrank gerade Tür öffnunf finde ich reichen auch 30 sekunden nicht ;). Aber das ist nur meine persönliche Meingung
                                    Hallo tombox,
                                    wenn die Waschmaschine fertig ist erhalten ich diese Info über meine Alexa`s. Wenn ich glücklich speicher, aktualisiert er zum Beispiel um 13:40:10. Mit ein wenig Pech dann erst um 13:40:30. Da die Maschine um 13:40:00 fertig ist, kommt die Meldung im worst case ca. 30 Sekunden später (Ist jetzt nicht so schlimm). Natürlich kommt dann auch die Alarmmeldung ca. 30 Sekunden später...
                                    Beim Kühlschrank ist das halt zu Lang. Wobei ich jetzt nicht wüsste, warum ich in IOBROKER diese Info dringend benötige. Sollte die Tür länger als 30 Sekunden auf sein, dann könnte eine Alarmmeldung kommen...Das würde also auch passen...
                                    Lieber wäre mir die Steuerung vom Kühlschrank😁
                                    @Hohenbostler Bedenke das die Datenpunkte auch immer aktualisiert werden, dass kann auch bis zu 4 Sekunden dauern.
                                    Fazit: Kann der Interval nicht per Java geändert werden, wäre eine Umstellung auf Sekunden sinnfrei.
                                    Gruß//Lucky
                                      Heute kam den ganzen Tag Request failed with status code 400.
                                      Wenn man die APP startet, muss man den neuen Nutzungsbediengungen zustimmen.
                                      Danach funktioniert der Adapter wieder.
                                      Kann man das eventuell auch in den Adapter einbauen? Wohl eher nicht...
                                      Gruß//Lucky
                                        @lucky_esa nur wenn ich ein account hätte wo die Bedingungen nicht akzeptiert sind
                                          ReiTi @tombox last edited by
                                          erstmal vielen Dank für den coolen Adapter!
                                          Ich hab den gerade installiert um meine LG Waschmaschine zu überwachen und am Ende eines Waschgangs eine Info z.B. per Telegram und / oder Sprachausgabe zu erhalten.
                                          Es werden ja unzählige Objekte erzeugt, aber irgendwie hab ich noch kein Objekt mit "Stromverbrauch" oder "Leistung" o.ä. gefunden.
                                          Gibt es das gar nicht oder bin ich einfach zu blind?
                                          Wie löst ihr das mit einer Nachricht am Waschende?
                                          Gerade läuft die erste Wäsche, vielleicht kommt ja noch was am Ende.
                                          Danke und Gruß
                                          ReiTi
                                            Hallo, du musst per Blockly remainTimeMinute und remainTimeHour auswerten. Sind beide bei Null angekommen, dann ist die Maschine fertig.
                                            1.0k
                                            908
                                            282850
