      Thomas Braun Most Active @Humidor last edited by Thomas Braun
      @humidor
      Ja. Halte die Versionen aktuell, ich vermute es hat da Anpassungen gegeben.
      backitup
      github:	2.1.17 for 13 days
      latest:	2.1.17 for 13 days
      stable:	2.1.13 for 75 days
      Humidor 1 Reply Last reply Reply Quote 1
      • Humidor
        Humidor @Thomas Braun last edited by Humidor
        @thomas-braun hab das Update auf 2.1.13 gemacht
        hat alles wunderbar geklappt
        Started iobroker ...
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=xxx,password=****,domain=ds1621,rw,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.0.20/backup/iobrokerUbuntu /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.iobroker 4259 states saved
        [DEBUG] [iobroker] - host.iobroker 4934 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_08_29-09_33_28_ioBrokerPVUbuntu_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - Start InfluxDB Backup ...
        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
        [DEBUG] [influxDB] - Packed 108MB so far...
        [DEBUG] [influxDB] - Packed 217MB so far...
        [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_08_29-09_33_33_ioBrokerPVUbuntu_backupiobroker.tar.gz
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
        [DEBUG] [influxDB] - done
        [DEBUG] [historyDB] - compress from historyDB started ...
        [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_08_29-09_34_16_backupiobroker.tar.gz
        [DEBUG] [historyDB] - done
        [DEBUG] [cifs] - done
        [DEBUG] [clean] - done
        [DEBUG] [telegram] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        nun sehe ich auch was im ioBroker 😉
        J Thomas Braun 2 Replies Last reply Reply Quote 0
          Jan1 @Humidor last edited by Jan1
          @humidor
          Eigentlich der erste Weg wenn man ein Problem hat, ein Update des Adapter auf die jeweils letzte Version des Repo und den Rest natürlich auch. Weil nix unübersichtlicheres als ein bunter Haufen an Versionen.
          Wenn das nix bringt, hast ein echtes Problem 😉
          Humidor 1 Reply Last reply Reply Quote 0
          • Humidor
            Humidor @Jan1 last edited by
            @jan1 schon klar, aber das letzte Mal hat es dann nicht funktioniert, drum habe ich mit dem Update da jetzt gewartet
              @humidor
              Siehste.
              Und deswegen macht es keinen Sinn für veraltete Versionen Fragen zu stellen. Also zuerst sein System durchpatchen, dann schauen.
                @humidor sagte in Test Adapter Backitup v2.1.x:
                Dann war das letzte mal schon was faul.
                • Humidor
                  @jan1 jain, der Login ging nicht mehr auf der Synology. Fehlereintrag im Log. das wars dann auch, mit dieser Version fkt. es wieder einwandfrei. Und nein, ich habe da nichts gemacht.
                  Schon klar wegen dem Update, war nur eine Frage, da ich ioBroker selbst das Update verpasst habe und nun der Reiter aufgetaucht ist.
                  • simatec
                    simatec Developer Most Active @Humidor last edited by
                    @simatec Hallo, frage, sollte hier etwas kommen ? (installiert ist 2.1.6)
                    Ja da hat sich im Admin etwas geändert, so dass mit Admin 5.x diese version nicht mehr läuft.
                    Aktuell ist die Version 2.1.17, welche heute auch ins Stable geht.
                    maduuto 1 Reply Last reply Reply Quote 0
                    • maduuto
                      maduuto @simatec last edited by maduuto
                      Hallo. Ich komme nicht weiter. Habe das Fix Script mehrmals laufen lassen. ich bekomme jedoch immer folgende Fehlermeldung:
                      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.150.200:/volume1/Backup/smarthome_backup /opt/iobroker/backups"
                      [DEBUG] [iobroker] - host.rasppi4-iob 14804 states saved
                      [DEBUG] [iobroker] - host.rasppi4-iob 17432 objects saved
                      [ERROR] [iobroker] - host.rasppi4-iob Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_09_22-01_34_40_backupiobroker.tar.gz'
                      [ERROR] [iobroker] - host.rasppi4-iob Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                      [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u rasppi4-iob -** rasppi4-iob -h 192.168.150.200 -P 3307 > /opt/iobroker/backups/mysql_2021_09_22-01_35_06_backupiobroker.sql
                      /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2021_09_22-01_35_06_backupiobroker.sql: Permission denied
                      /bin/sh: 1: A7: not found
                      /bin/sh: 1: mysqldump: not found
                      [ERROR] [javascripts] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/javascripts_2021_09_22-01_35_07_backupiobroker.tar.gz'
                      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                      [EXIT] 9
                      Was kann das sein? wenn ich mich nicht verguckt habe hat der Backup Ordner Rchte für Iobroker...
                      Danke schonmal für eure Hilfe.
                      Pascal
                      A Dr. Bakterius 2 Replies Last reply Reply Quote 0
                        Apropo @maduuto last edited by
                        @maduuto Kann es sein, dass du ein Synology NAS mit DSM 7 benutzt? Mit DSM 7 wurden die Nfs Richtlinien verschärft. Nervt mich auch.
                        Ich konnte es bei mir nur wieder ans Laufen bringen indem ich dem Backup Ordner 777 Rechte vergeben haben.
                        Das finde ich zwar sehr unbefriedigend und es soll auch nur eine Zwischenlösung sein bis ich einen anderen Weg gefunden habe, aber immerhin läuft es so erstmal.
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @maduuto last edited by
                          @maduuto Ist ja schön, dass du so ein sicheres Passwort gewählt hast. Aber dann hier öffentlich stellen ist weniger klug. 😉
                          • maduuto
                            maduuto @Dr. Bakterius last edited by
                            @dr-bakterius oh ist das Kauderwelsch beiMYSQL ein Passwort? Habe mich schon gewundert was das ist. Habe ich aber nicht festgelegt 🐶
                            Danke für den Hinweis.
                            Ja ist eine Synology. Habe es nun hinbekommen. Es lag nicht an den Userrechten an Raspberry sondern an NFS. Ist ja beknackt da wäre ich nie draufgekommen. Musste in der Synology NAS bei den NFS Einstellungen den Squash everyone to Admin o.ä. einstellen. Nu geht es.
                            Thomas Braun A 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @maduuto last edited by
                              @maduuto
                              Oder auf beiden Systemen die gleiche User ID haben.
                                @maduuto sagte in Test Adapter Backitup v2.1.x:
                                wäre
                                Das klappt bei mir leider auch nicht, weil ich den Standard Admin deaktiviert habe und dafür einen anderen angelegt habe. Das wird ja seit DSM 6 so von Synology penetrant empfohlen und es kommt immer die Hinweis Melung dazu, wenn der Admin noch aktiv ist.
                                • HAL
                                  HAL @simatec last edited by
                                  @simatec ich habe seit ein paar Tagen Probleme mit dem Backup.
                                  Mein Backup läuft täglich um 05:05 Uhr. Der läuft auch durch nur ist danach die Weboberfläche von iobroker nicht mehr zu erreichen und es werden auch keine Daten mehr in meine influx db geschrieben. Nach einem iobrocker restart läuft wieder alles.
                                  Möglicherweise hängt es mit dem verfügbaren Speicher zusammen. Ich habe im log alle Meldungen die nicht vom backitup adapter stammen gelöscht, bis auf die zum Speicher ( Zeile 8 + 10 )
                                  2021-09-28 05:05:10.259 - debug: backitup.0 (2721) Backup has started ...
                                  2021-09-28 05:05:20.261 - debug: backitup.0 (2721) [iobroker/mount] noserverino option: false
                                  2021-09-28 05:05:20.263 - debug: backitup.0 (2721) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=***,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //***/*** /opt/iobroker/backups"
                                  2021-09-28 05:05:20.491 - debug: backitup.0 (2721) [iobroker/mount] mount successfully completed
                                  2021-09-28 05:05:20.494 - debug: backitup.0 (2721) [iobroker/mount] done
                                  2021-09-28 05:05:25.052 - debug: backitup.0 (2721) [iobroker/iobroker] host.tinkerboard 8984 states saved
                                  2021-09-28 05:05:25.122 - debug: backitup.0 (2721) [iobroker/iobroker] host.tinkerboard 12563 objects saved
                                  2021-09-28 05:10:01.620 - warn: host.tinkerboard Your system has only 53 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                                  2021-09-28 05:10:04.157 - debug: backitup.0 (2721) system.adapter.javascript.0: logging false
                                  2021-09-28 05:11:24.722 - warn: host.tinkerboard Your system has only 67 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                                  2021-09-28 05:13:50.493 - debug: backitup.0 (2721) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_09_28-05_05_20_TinkerS_backupiobroker.tar.gz
                                  2021-09-28 05:13:51.578 - debug: backitup.0 (2721) [iobroker/iobroker] done
                                  2021-09-28 05:13:51.733 - debug: backitup.0 (2721) [iobroker/influxDB] Start InfluxDB Backup ...
                                  2021-09-28 05:13:51.748 - debug: backitup.0 (2721) [iobroker/influxDB] InfluxDB Backup tmp directory created
                                  2021-09-28 05:15:04.628 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 51MB so far...
                                  2021-09-28 05:15:14.628 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 79MB so far...
                                  2021-09-28 05:15:24.630 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 105MB so far...
                                  2021-09-28 05:15:34.632 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 132MB so far...
                                  2021-09-28 05:15:44.631 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 158MB so far...
                                  2021-09-28 05:15:54.631 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 185MB so far...
                                  2021-09-28 05:16:04.637 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 209MB so far...
                                  2021-09-28 05:16:14.631 - debug: backitup.0 (2721) [iobroker/influxDB] Packed 236MB so far...
                                  2021-09-28 05:16:18.902 - debug: backitup.0 (2721) [iobroker/influxDB] Backup created: /opt/iobroker/backups/influxDB_2021_09_28-05_13_51_TinkerS_backupiobroker.tar.gz
                                  2021-09-28 05:16:18.975 - debug: backitup.0 (2721) [iobroker/influxDB] Try deleting the InfluxDB tmp directory
                                  2021-09-28 05:16:19.514 - debug: backitup.0 (2721) [iobroker/influxDB] InfluxDB tmp directory was successfully deleted
                                  2021-09-28 05:16:19.515 - debug: backitup.0 (2721) [iobroker/influxDB] done
                                  2021-09-28 05:16:20.426 - debug: backitup.0 (2721) [iobroker/grafana] Start Grafana Backup ...
                                  2021-09-28 05:16:20.441 - debug: backitup.0 (2721) [iobroker/grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                  2021-09-28 05:16:20.452 - debug: backitup.0 (2721) [iobroker/grafana] Created dashboard directory
                                  2021-09-28 05:16:20.465 - debug: backitup.0 (2721) [iobroker/grafana] Created dashboards_manually_restore directory
                                  2021-09-28 05:16:20.478 - debug: backitup.0 (2721) [iobroker/grafana] Created datasource directory
                                  2021-09-28 05:16:20.483 - debug: backitup.0 (2721) [iobroker/grafana] start Grafana request ...
                                  2021-09-28 05:16:20.819 - debug: backitup.0 (2721) [iobroker/grafana] Grafana is available ... Status: 200
                                  2021-09-28 05:16:21.254 - debug: backitup.0 (2721) [iobroker/grafana] Error on Grafana Dashoard Request: Error: Request failed with status code 401
                                  2021-09-28 05:16:21.255 - debug: backitup.0 (2721) [iobroker/grafana] start Grafana backup compress ...
                                  2021-09-28 05:16:21.268 - debug: backitup.0 (2721) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                  2021-09-28 05:16:21.337 - debug: backitup.0 (2721) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                  2021-09-28 05:16:21.338 - debug: backitup.0 (2721) [iobroker/grafana] cannot found Grafana Backup files
                                  2021-09-28 05:16:21.338 - debug: backitup.0 (2721) [iobroker/grafana] done
                                  2021-09-28 05:16:22.828 - debug: backitup.0 (2721) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2021_09_28-05_16_21_backupiobroker.tar.gz
                                  2021-09-28 05:16:22.829 - debug: backitup.0 (2721) [iobroker/javascripts] done
                                  2021-09-28 05:16:23.133 - debug: backitup.0 (2721) [iobroker/cifs] done
                                  2021-09-28 05:16:23.824 - debug: backitup.0 (2721) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2021_09_23-05_05_20_TinkerS_backupiobroker.tar.gz
                                  2021-09-28 05:16:23.886 - debug: backitup.0 (2721) [iobroker/clean] delete /opt/iobroker/backups/influxDB_2021_09_25-05_05_49_TinkerS_backupiobroker.tar.gz
                                  2021-09-28 05:16:23.899 - debug: backitup.0 (2721) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2021_09_23-05_08_03_backupiobroker.tar.gz
                                  2021-09-28 05:16:23.906 - debug: backitup.0 (2721) [iobroker/clean] done
                                  2021-09-28 05:16:24.702 - debug: backitup.0 (2721) [iobroker/historyHTML] new history html values created
                                  2021-09-28 05:16:24.704 - debug: backitup.0 (2721) [iobroker/historyHTML] done
                                  2021-09-28 05:16:24.867 - debug: backitup.0 (2721) [iobroker/historyJSON] new history json values created
                                  2021-09-28 05:16:24.868 - debug: backitup.0 (2721) [iobroker/historyJSON] done
                                  2021-09-28 05:16:25.050 - debug: backitup.0 (2721) [iobroker/umount] mount activ, umount is started ...
                                  2021-09-28 05:16:30.236 - debug: backitup.0 (2721) [iobroker/umount] umount successfully completed
                                  2021-09-28 05:16:30.242 - debug: backitup.0 (2721) [iobroker/umount] done
                                  2021-09-28 05:16:30.394 - debug: backitup.0 (2721) [iobroker] exec: done
                                  Was könnte den Fehler verursachen ?
                                    Thomas Braun Most Active @HAL last edited by
                                    @hal
                                    Die Meldungen sind ja mehr als eindeutig.
                                    Zuwenig RAM für den speicherhungrigen Backup-Prozess.
                                    Wie viel ist da überhaupt verfügbar?
                                    free -ht
                                    HAL 1 Reply Last reply Reply Quote 0
                                    • HAL
                                      HAL @Thomas Braun last edited by
                                      @thomas-braun sagte in Test Adapter Backitup v2.1.x:
                                      @hal
                                      free -ht
                                      pi@tinkerboard:~$ free -ht
                                      Mem:           2,0G        841M        759M         11M        407M        1,1G
                                      Swap:           99M          0B         99M
                                      Total:         2,1G        841M        859M
                                        @hal
                                        Das sieht eigentlich grundsätzlich nicht verkehrt aus.
                                        Wie sehen die einzelnen Einstellungen für die jeweiligen Backups im Backitup-Adapter aus?
                                        • HAL
                                          • simatec
                                            simatec Developer Most Active @HAL last edited by simatec
                                            @hal Der Pfad für die Javascript Sicherung sieht komisch aus?
                                            Was hast du im Javascript Adapter als Mirror Pfad eingetragen?
                                            Nimm mal lieber in beiden Adapter den Pfad /home/iobroker/javasicherung
                                            81.1k
                                            170
                                            2780
                                            2360403
