    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
      ford7 last edited by
      Откатился, вроде задышал брокер, но в логе сыпется каждые 2-3 минуты
      host-zvmubn	2016-09-07 21:10:42.120	info	Restart adapter system.adapter.admin.0 because enabled
      host-zvmubn	2016-09-07 21:10:42.119	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:42.075	info	Restart adapter system.adapter.web.0 because enabled
      host-zvmubn	2016-09-07 21:10:42.075	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:41.438	info	instance system.adapter.web.0 started with pid 10658
      host-zvmubn	2016-09-07 21:10:40.896	info	instance system.adapter.admin.0 started with pid 10656
      host-zvmubn	2016-09-07 21:10:38.908	info	Restart adapter system.adapter.sayit.0 because enabled
      host-zvmubn	2016-09-07 21:10:38.908	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:38.597	info	instance system.adapter.sayit.0 started with pid 10650
      host-zvmubn	2016-09-07 21:10:33.284	info	Update repository "fast-online" under "http://download.iobroker.net/sources-dist.json"
      host-zvmubn	2016-09-07 21:10:26.785	info	Restart adapter system.adapter.socketio.0 because enabled
      host-zvmubn	2016-09-07 21:10:26.784	error	instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:26.602	info	Restart adapter system.adapter.s7.0 because enabled
      host-zvmubn	2016-09-07 21:10:26.602	error	instance system.adapter.s7.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:26.038	info	Restart adapter system.adapter.sql.0 because enabled
      host-zvmubn	2016-09-07 21:10:26.037	error	instance system.adapter.sql.0 terminated with code 7 (Adapter already running)
      host-zvmubn	2016-09-07 21:10:25.874	info	instance system.adapter.s7.0 started with pid 10635
      host-zvmubn	2016-09-07 21:10:25.848	info	instance system.adapter.socketio.0 started with pid 10633
      host-zvmubn	2016-09-07 21:10:25.219	info	instance system.adapter.sql.0 started with pid 10631
      • Bluefox
        Bluefox last edited by
        @ford7:
        Перезапустить надо комп.
          andrey99986 last edited by
          после попытки обновить admin через админку, он пропал.
          В консоли:
          root@debian:/home/iobroker# iobroker stop
          Stopping iobroker controller daemon...
          iobroker controller daemon stopped.
          Exit code for "killall.sh": 0
          root@debian:/home/iobroker# npm install iobroker.admin --production
          iobroker.core@ /home/iobroker
          └── (empty)
          npm ERR! code 1
          Дело в том что по умолчанию указал репозитарий с гита. Может в этом проблема ? Как лечить?
          Драйвер не запускается, на порт 8081 ничего нет.
            kID last edited by
            @andrey99986:
            после попытки обновить admin через админку, он пропал. `
            вначале обновить js-controller
            iobroker upgrade self
            затем
            iobroker del admin
            iobroker add admin –enabled
            Мне помогло
              @kID:
              @andrey99986:
              затем
              iobroker del admin
              Мне помогло `
              Дело было в канале связи - ограничение скорости до 64 кбит.
              Пополнил баланс, команда на обновление после этого отработала нормально.
              Возьмите на заметку.
                spectrekr last edited by
                Обнаружил ошибку в мультихост.
                Ситуация: на основном сервере стоит драйвер, вторую версию драйвера устанавливаю на дочерний сервер. Ошибка заключается в том, что если с дочернего сервера удаляешь драйвер, то с основного сервера он тоже удаляется.
                  Настройка let's encrypt.
                  2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80
                  2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80
                  at Object.exports._errnoException (util.js:874:11)
                  at exports._exceptionWithHostPort (util.js:897:20)
                  at Server._listen2 (net.js:1221:19)
                  at listen (net.js:1270:10)
                  at Server.listen (net.js:1366:5)
                  at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21)
                  at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28)
                  at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25
                  at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21)
                  at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                  at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                  at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                  at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                  at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                  at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
                  at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                  at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                  at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14)
                  at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10)
                  at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                  at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8)
                  at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8)
                  at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10)
                  at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14)
                  at emitTwo (events.js:87:13)
                  2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081
                  2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081
                  2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure.
                  2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081
                  2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception)
                  2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous>
                    Попробовал сделать экспорт всех скриптов, получил ошибку.
                    ! TypeError: 2017-02-15 12:23:57.693 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:228:12)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:270:10)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Object.States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:228:25)
                    ! TypeError: 2017-02-15 12:23:57.693 error at processMessage (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1282:26)
                    ! TypeError: 2017-02-15 12:23:57.693 error at Object.readObjectsAsZip (/opt/iobroker/node_modules/iobroker.js-controller/lib/zipFiles.js:249:13)
                    ! TypeError: 2017-02-15 12:23:57.693 error objects.getConfigKeys is not a function
                    ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function
                    • Bluefox
                      @spectrekr:
                      ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function `
                      Multihost?
                        @Bluefox:
                        @spectrekr:
                        ! message 2017-02-15 12:23:57.679 error messagebox.system.host.raspberrypi [object Object] objects.getConfigKeys is not a function Multihost?
                        Да.
                        • Bluefox
                          @spectrekr:
                          @Bluefox:
                          @spectrekr:
                          Да. `
                          Ошибка.. Поправлю в следующей версии.
                          Спасибо.
                          • Bluefox
                            @spectrekr:
                            ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
                            Кто то висит на порту 80 и не даёт запустить web.
                            Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать.
                              @Bluefox:
                              @spectrekr:
                              Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
                              Странно, висеть больше не чему. Ну в любом случае обновился.
                                Подскажите, node-red ругается на node.js- как поправить?
                                node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
                                node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
                                node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
                                node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
                                node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
                                node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
                                node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
                                node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
                                web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
                                web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
                                web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
                                node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
                                node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
                                node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
                                  Haus last edited by
                                  @ford7:
                                  ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
                                  Сменить nodejs нужна версия v4.x и выше.
                                  • I
                                    Izzm last edited by
                                    Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
                                    Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
                                    js-controller 0.16.2
                                    Admin 1.7.0
                                    JS 3.2.6
                                    • Bluefox
                                      @Izzm:
                                      Admin 1.7.0
                                      JS 3.2.6 `
                                      А на самом деле эти переменные существуют?
                                        @Haus:
                                        Сменить nodejs нужна версия v4.x и выше. `
                                        Как это сделать, подскажите.
                                          Haus last edited by
                                          @ford7:
                                          @Haus:
                                          Сменить nodejs нужна версия v4.x и выше. Как это сделать, подскажите.
                                          apt-get --purge remove node
                                          apt-get --purge remove nodejs
                                          apt-get autoremove
                                          reboot
                                          apt-get update
                                          apt-get upgrade
                                          apt-get install curl build-essential
                                          curl -sL https://deb.nodesource.com/setup_4.x | bash -
                                          apt-get install -y nodejs
                                            @Haus:
                                            apt-get autoremove
                                            reboot
                                            apt-get update
                                            apt-get upgrade
                                            Обновил, сейчас сыплются ошибки с sql и s7
                                            host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK)
                                            s7.0 2017-03-10 12:25:46.627 info terminating
                                            s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0
                                            s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10)
                                            s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26)
                                            s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45)
                                            s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
                                            s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17)
                                            s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17)
                                            s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12)
                                            s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32)
                                            s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18)
                                            s7.0 2017-03-10 12:25:46.116 error at Error (native)
                                            s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register.
                                            s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register.
                                            host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860
                                            sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined
                                            sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                                            host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled
                                            host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK)
                                            192
                                            55990
