    4. (GELÖST) JSON Zeitplan auslesen
      Langer last edited by Langer
      Dies bekomme ich vom bshb-Adapter unter dem DP "schedule"
      {"profiles":[{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"MONDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"TUESDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"WEDNESDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"THURSDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"FRIDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"SATURDAY"},{"switchPoints":[{"startTimeMinutes":0,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}},{"startTimeMinutes":255,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"COMFORT"}},{"startTimeMinutes":1300,"value":{"@type":"temperatureLevelSwitchPointValue","temperatureLevel":"ECO"}}],"day":"SUNDAY"}]}
      Nun möchte ich folgendes auslesen:
      MONDAY ECO 0 COMFORT 255 ECO 1300
      TUESDAY ECO 0 COMFORT 255 ECO 1300
      usw.
      Wie geht das?
      Kann mir mal einer einen Schubs geben?
      Habe schon mit JSON.parse() versucht aber ich verstehe JSON einfach nicht!!!
      MfG
      Wastl
      paul53 mickym 2 Replies Last reply Reply Quote 0
        paul53 @Langer last edited by paul53
        @langer
        Ansatz:
        on(idJSON, function(dp) {
           let profile = JSON.parse(dp.state.val).profiles; // Array mit 7 Wochentagen, Mo = 0
           for(let wd = 0; wd < 7; wd++) {
              let switchpoints = profile[wd].switchPoints; // Array mit Schaltpunkten eines Tages
              for(let i = 0; i < switchpoints.length; i++) {
                  // enthält switchpoints[i].startTimeMinutes und switchpoints[i].value.temperatureLevel
        • mickym
          mickym Most Active @Langer last edited by mickym
          @langer Unabhängig von @paul53 's Ansatz, nutz doch mal den JSON Formater: https://jsonformatter.org/
          Wenn man da Deinen String reinkopiert und dann schön formatierst dann kommt sowas raus:
          Du siehst also Du bekommst ein in profiles ein Array[0-7] aus, das wiederrum ein Array aus 3 switchpoint Objekten enthält.
          profiles[0].switchPoints[0].value.temperatureLevel ist dann der Pfad zu dem grün markierten Wert:
          Das kann man in dem JSON Formatter sehen, wenn man auf den TreeView umschaltet (oranger Pfeil).
            Langer @mickym last edited by
            @mickym
            Guten Morgen Ihr beiden,
            Danke für die Hilfe, hat funktioniert!!!!
            MfG
            Wastl
            javascript
