    4. JavaScript
    5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
      Pittini Developer @Kueppert last edited by
      @kueppert JS Controller schon mal neu gestartet?
        Kueppert @Pittini last edited by
        @pittini ah, geklappt 🙂 danke dir
          Kueppert last edited by Kueppert
          Hi, hab heute schon wieder ein Problem nach dem Update vom JS-Adapter:
          javascript.0
          2021-09-04 10:19:20.277	error	at main (script.js.common.Sonstiges.Xiaomi_Pufifier_3C:761:11)
          javascript.0
          2021-09-04 10:19:20.277	error	at CreateDevices (script.js.common.Sonstiges.Xiaomi_Pufifier_3C:829:36)
          javascript.0
          2021-09-04 10:19:20.276	error	at Object.createDevice [as device] (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/device.js:8:11)
          javascript.0
          2021-09-04 10:19:20.273	error	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Error: Model zhimi.airpurifier.mb4 is not supported
          javascript.0
          2021-09-04 10:19:20.269	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Now creating device for zhimi.airpurifier.mb4 / 358430664 / 192.168.178.128 / 6f90871380cfbe1aeb896519e6c8b286 / 10000
          javascript.0
          2021-09-04 10:19:20.249	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Device Mi Air Purifier 3C is supported, creating DataPoints
          javascript.0
          2021-09-04 10:19:20.249	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Now searching for supported Devices...
          javascript.0
          2021-09-04 10:19:20.248	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Mi Air Purifier 3C
          javascript.0
          2021-09-04 10:19:20.248	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Found 1 MiHome Devices, those are:
          javascript.0
          2021-09-04 10:19:20.152	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Retrieving your in de registered MiHome Devices
          javascript.0
          2021-09-04 10:19:17.653	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: registered 0 subscriptions and 0 schedules
          javascript.0
          2021-09-04 10:19:17.623	info	script.js.common.Sonstiges.Xiaomi_Pufifier_3C: Starting AllMyMi V.0.2.25
          javascript.0
          2021-09-04 10:19:17.534	info	Start javascript script.js.common.Sonstiges.Xiaomi_Pufifier_3C
          Die Error-Meldung verwirrt mich etwas...3C wird nicht unterstützt? O.o 2 Zeilen drunter steht das Gegenteil. Hab den JS-Adapter + Skript auch schon neu gestartet
            Pittini Developer @Kueppert last edited by Pittini
            @kueppert Siehe Anleitung, "Known Issues". Die Def Files müssen neu kopiert werden. Deswegen auch die komische Meldung, das Skript unterstützt weiterhin Dein Gerät und meldet das, die node-mihome unterstützt Dein Gerät aber mangels Def Datei nicht mehr und meldet das auch.
              @pittini oh...hatte ich sogar gelesen, das aber mit meinem Problem irgendwie nicht zusammen gebracht. Mag an der Erkältung liegen die mir aufs Hirn drückt :-S Danke dir
                Bender275 last edited by Bender275
                Hi, ich habe seit einigen Tagen das Problem, dass mein Air Purifier 3H nicht mehr erreicht wird.
                In der App war er zwar da und Daten wurden angezeigt, er ließ sich aber dabei nicht mehr ein- und ausschalten.
                Ich habe ihn dann ins Gast-WLAN gehängt, seitdem geht er per App wieder.
                Mit dem JavaScript geht es aber nicht mehr.
                Version ist aktuell, Definitionsdatei aktualisiert.
                Der Luftreiniger wird auch gefunden, aber es werden keine Werte im IObroker abgerufen:
                javascript.0 2021-09-24 18:38:47.792 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Setting trigger #0 for zhimi.airpurifier.mb3
                javascript.0 2021-09-24 18:38:47.791 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Init Device# 0 - device="zhimi.airpurifier.mb3"
                javascript.0 2021-09-24 18:38:43.294 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"...","address":"192.168.189.20","token":"fa327ee344f1d819de69ea43723e852c",
                javascript.0 2021-09-24 18:38:43.293 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Now creating device for zhimi.airpurifier.mb3 / ... / 192.168.189.20 / ... / 10000
                javascript.0 2021-09-24 18:38:43.284 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Device Mi Air Purifier 3/3H is supported, creating DataPoints
                javascript.0 2021-09-24 18:38:43.283 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Now searching for supported Devices...
                javascript.0 2021-09-24 18:38:43.283 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Mi Air Purifier 3/3H
                javascript.0 2021-09-24 18:38:43.283 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Found 1 MiHome Devices, those are:
                javascript.0 2021-09-24 18:38:43.161 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Retrieving your in de registered MiHome Devices
                javascript.0 2021-09-24 18:38:43.160 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: You are already logged in, login canceled
                javascript.0 2021-09-24 18:38:43.159 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: registered 0 subscriptions and 0 schedules
                javascript.0 2021-09-24 18:38:43.154 info (20452) script.js.Räume.Wohnen.Xiaomi_0_2_25: Starting AllMyMi V.0.2.25
                javascript.0 2021-09-24 18:38:43.144 info (20452) Start javascript script.js.Räume.Wohnen.Xiaomi_0_2_2
                Wenige Male habe ich auch den Fehler:
                (20452) Error: network timeout at: https://de.api.io.mi.com/app/home/device_list
                Nachtrag:
                Wenn ich das Gerät z.B. über Google einschalten will, kommt:
                javascript.0 2021-09-24 18:49:01.805 error at processTimers (internal/timers.js:497:7)
                javascript.0 2021-09-24 18:49:01.805 error at listOnTimeout (internal/timers.js:554:17)
                javascript.0 2021-09-24 18:49:01.805 error at Timeout.retry [as _onTimeout] (/opt/iobroker/node_modules/node-mihome/lib/protocol-miio.js:358:23)
                javascript.0 2021-09-24 18:49:01.805 error (20452) Error: Call to device timed out
                javascript.0 2021-09-24 18:49:01.804 error (20452) Error: Call to device timed out
                Die Seite ist auch nicht aufrufbar bzw. es wird nicht viel angezeigt.
                Jemand ne Idee?
                Danke!
                  Pittini Developer @Bender275 last edited by
                  @bender275 Stimmt denn die IP Adresse die reinkommt, also die 192.168.189.20? System schon mal komplett neu gestartet? Wenns schon mal ging und jetzt nimmer, liegts imho nich am Skript, worauf auch hindeuten würde dass Du auch in der App Probs hattest. Wenn die Datenpunkte bei null bleiben aber sonst alles ok erscheint, liegt das vermutlich am Xiaomi Server (oder fehlerhafter Def Datei, was aber auszuschliessen ist, da es ja schon ging).
                    Bender275 @Pittini last edited by
                    @pittini
                    Ich habe die IPs nochmal geprüft, alles sauber. App geht jetzt ja wieder. Ich habe ihn extra ins Gastnetz, nicht, dass da was vom Pihole geblockt wird.
                    Wenn ich die Webseite von mi.com aufrufe, kommt:
                    Hat sonst noch wer diese Probleme?
                    • I
                      iThiel last edited by iThiel
                      ich versuch seit einigen Tagen dieses Skript (iobroker-nodemihome) ans laufen zu verwenden, habe allerdings das Problem, das mein Login nicht funktioniert.
                      Hier der Log dazu:
                      javascript.0	2021-09-26 19:01:02.837	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      javascript.0	2021-09-26 19:01:02.837	error	at runMicrotasks (<anonymous>)
                      javascript.0	2021-09-26 19:01:02.837	error	at Init (script.js.devices.AllMyMi:800:50)
                      javascript.0	2021-09-26 19:01:02.837	error	at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
                      javascript.0	2021-09-26 19:01:02.837	error	at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
                      javascript.0	2021-09-26 19:01:02.837	error	script.js.devices.AllMyMi: Error: Pls login before make any request
                      javascript.0	2021-09-26 19:01:02.837	info	script.js.devices.AllMyMi: Retrieving your in de registered MiHome Devices
                      javascript.0	2021-09-26 19:01:02.836	info	script.js.devices.AllMyMi: You are already logged in, login canceled
                      javascript.0	2021-09-26 19:01:01.621	info	script.js.devices.AllMyMi: registered 0 subscriptions and 0 schedules
                      javascript.0	2021-09-26 19:01:01.619	info	script.js.devices.AllMyMi: Starting AllMyMi V.0.2.25
                      javascript.0	2021-09-26 19:01:01.612	info	Start javascript script.js.devices.AllMyMi
                      Merkwürdig finde ich, dass das Skript meldet das ich schon eingeloggt bin deshalb den Login abbricht und anschließend sagt das ich mich einloggen muss bevor Geräte abgefragt werden können.
                      Ich habe jetzt schon alles versucht, sogar ein komplett neues Xiaomi Konto angelegt, alle meine Geräte aus dem alten entfernt und in das neue eingefügt. Das Ergebnis ist allerdings das selbe. Wenn ich meine Login-Daten im web oder dem mihome-vacuum Adapter eingebe funktioniert es direkt.
                      Hat jemand eine Idee, was ich falsch mache?
                        Pittini Developer @iThiel last edited by
                        @ithiel Schon mal System oder JS Controller neugestartet? Und wie geht das Log dann weiter, was sagt das Skript? Richtiger Server gewählt? Sonderzeichen im Passwort?
                          Bender275 @Bender275 last edited by
                          Es geht wieder!
                          Keine Ahnung warum, aber auf einmal kann der 3H wieder ausgelesen werden. Auch das Ein- und Ausschalten klappt wieder.
                          Danke!
                          • I
                            iThiel @Pittini last edited by
                            @Pittini Das Problem, das ich mich nicht einloggen konnte habe ich lösen können. So wie es aussieht, unterstützt das Skript keine Sonderzeichen im Passwort, bzw. nur die üblichen Satzzeichen. Getestet habe ich die Sonderzeichen ".+-_" und diese funktionieren. Es werden alle Geräte erkannt und auch im Objektbaum angelegt, allerdings werden die Werte alle nur mit (null) befüllt.
                            Fehler sind leider keine in der Logdatei ersichtlich. Auch der trigger von 10 Sekunden funktioniert nicht, oder gibt keine Log-Daten aus. Hier das Skript log der letzten 2,5 Stunden
                            javascript.0	2021-09-27 18:45:04.538	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.rssi, state={"val":-84,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.physical-controls-locked.physical-controls-locked","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.custom-service.favorite-speed","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.screen.brightness","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.alarm.alarm","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.air-purifier.mode","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.412	info	script.js.devices.AllMyMi: subscribe: {"pattern":{"id":"javascript.0.MiHomeAll.362072163.air-purifier.on","change":"ne","ack":false,"q":0},"name":"script.js.devices.AllMyMi"}
                            javascript.0	2021-09-27 18:44:54.411	info	script.js.devices.AllMyMi: onStop(timeout=10)
                            javascript.0	2021-09-27 18:44:54.411	info	script.js.devices.AllMyMi: setInterval(ms=10000)
                            javascript.0	2021-09-27 18:44:54.411	info	script.js.devices.AllMyMi: Setting trigger #0 for zhimi.airpurifier.mb4
                            javascript.0	2021-09-27 18:44:54.411	info	script.js.devices.AllMyMi: Init Device# 0 - device="zhimi.airpurifier.mb4"
                            javascript.0	2021-09-27 16:44:50.319	info	script.js.devices.AllMyMi: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"362072163","address":"10.1.20.71","token":"030a70e4c6f04cc8d5249efe963c0156","protocol":"local","refresh":10000,"_properties":{},"_propertiesToMonitor":["air-purifier:fault","air-purifier:on","air-purifier:mode","environment:pm2.5-density","filter:filter-life-level","filter:filter-used-time","alarm:alarm","screen:brightness","physical-controls-locked:physical-controls-locked","custom-service:favorite-speed","custom-service:moto-speed-rpm"],"_miotSpec":null,"_miotSpecType":"urn:miot-spec-v2:device:air-purifier:0000A007:zhimi-mb4:2","model":"zhimi.airpurifier.mb4","setter":{},"definition":{"info":[{"id":"localip","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Ip Adress","type":"string","role":"value","def":""}},{"id":"token","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Token","type":"string","role":"value","def":""}},{"id":"did","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Device Id","type":"string","role":"value","def":""}},{"id":"model","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Model","type":"string","role":"value","def":""}},{"id":"rssi","initial":0,"forceCreation":false,"common":{"read":true,"write":false,"name":"rssi","type":"number","role":"value.rssi","def":0}},{"id":"name","initial":"","forceCreation":false,"common":{"read":true,"write":true,"name":"Name","type":"string","role":"value","def":""}},{"id":"isOnline","initial":false,"forceCreation":false,"common":{"read":true,"write":true,"name":"Is online","type":"boolean","role":"value","def":false}}],"model":"zhimi.airpurifier.mb4","description":"Purifier 3C","setter":{},"common":[{"name":"air-purifier.on","type":"boolean","role":"switch","read":true,"write":true,"min":false,"max":true},{"name":"air-purifier.fault","type":"string","read":true,"write":false,"role":"state"},{"name":"air-purifier.mode","type":"number","read":true,"write":true,"min":0,"max":3,"states":{"0":"auto","1":"sleep","2":"favorite","3":"fanset"},"role":"state"},{"name":"alarm.alarm","type":"boolean","role":"switch","read":true,"write":true,"min":false,"max":true},{"name":"screen.brightness","type":"number","read":true,"write":true,"min":0,"max":8,"role":"state"},{"name":"environment.pm2_5-density","type":"number","read":true,"write":false,"min":0,"max":600,"unit":"μg/m³","role":"state"},{"name":"custom-service.moto-speed-rpm","type":"number","read":true,"write":false,"min":0,"max":65535,"unit":"rpm","role":"state"},{"name":"custom-service.favorite-speed","type":"number","read":true,"write":true,"min":300,"max":2300,"unit":"rpm","role":"state"},{"name":"filter.filter-life-level","type":"number","read":true,"write":false,"min":0,"max":100,"unit":"%","role":"state"},{"name":"filter.filter-used-time","type":"number","read":true,"write":false,"unit":"h","role":"state"},{"name":"physical-controls-locked.physical-controls-locked","type":"boolean","role":"switch","read":true,"write":true,"min":false,"max":true}]},"firstrun":true,"rssi":0,"isOnline":true} now fetching data
                            javascript.0	2021-09-27 16:44:50.319	info	script.js.devices.AllMyMi: Now creating device for zhimi.airpurifier.mb4 / 362072163 / 10.1.20.71 / 030a70e4c6f04cc8d5249efe963c0156 / 10000
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.isOnline, state={"val":false,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.name, state={"val":"Mi Electric Scooter 1S","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.rssi, state={"val":0,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.model, state={"val":"ninebot.scooter.v3","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.did, state={"val":"blt.4.1754sfbvcgc00","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.token, state={"val":"4c223987dbd5a32e1283667b","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00.info.localip, state={"val":"91.67.208.22","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.isOnline, state={"val":true,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.318	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.name, state={"val":"Roborock S5 Max","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.rssi, state={"val":-36,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.model, state={"val":"roborock.vacuum.s5e","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.did, state={"val":"320389496","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.token, state={"val":"72383051456d5373586a325851786833","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.320389496.info.localip, state={"val":"10.1.20.230","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.isOnline, state={"val":true,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.name, state={"val":"Mi Air Purifier 3C","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.rssi, state={"val":-84,"ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.model, state={"val":"zhimi.airpurifier.mb4","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.317	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.did, state={"val":"362072163","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.token, state={"val":"030a70e4c6f04cc8d5249efe963c0156","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setForeignState(id=javascript.0.MiHomeAll.362072163.info.localip, state={"val":"10.1.20.71","ack":true,"c":"script.js.devices.AllMyMi"})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setObject(id=javascript.0.MiHomeAll.blt.4.1754sfbvcgc00, obj={"type":"device","common":{"name":"Mi Electric Scooter 1S"},"native":{}})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setObject(id=javascript.0.MiHomeAll.320389496, obj={"type":"device","common":{"name":"Roborock S5 Max"},"native":{}})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setObject(id=javascript.0.MiHomeAll.362072163, obj={"type":"device","common":{"name":"Mi Air Purifier 3C"},"native":{}})
                            javascript.0	2021-09-27 16:44:50.316	info	script.js.devices.AllMyMi: setObject(id=javascript.0.MiHomeAll, obj={"type":"channel","common":{"name":""},"native":{}})
                            javascript.0	2021-09-27 16:44:50.311	info	script.js.devices.AllMyMi: Device Mi Air Purifier 3C is supported, creating DataPoints
                            javascript.0	2021-09-27 16:44:50.311	info	script.js.devices.AllMyMi: Now searching for supported Devices...
                            javascript.0	2021-09-27 16:44:50.311	info	script.js.devices.AllMyMi: Mi Electric Scooter 1S
                            javascript.0	2021-09-27 16:44:50.311	info	script.js.devices.AllMyMi: Roborock S5 Max
                            javascript.0	2021-09-27 16:44:50.311	info	script.js.devices.AllMyMi: Mi Air Purifier 3C
                            javascript.0	2021-09-27 16:44:50.310	info	script.js.devices.AllMyMi: Found 3 MiHome Devices, those are:
                            javascript.0	2021-09-27 16:44:50.138	info	script.js.devices.AllMyMi: Retrieving your in de registered MiHome Devices
                            javascript.0	2021-09-27 16:44:50.138	info	script.js.devices.AllMyMi: You are already logged in, login canceled
                            javascript.0	2021-09-27 16:44:50.137	info	script.js.devices.AllMyMi: registered 0 subscriptions and 0 schedules
                            javascript.0	2021-09-27 16:44:50.136	info	script.js.devices.AllMyMi: Starting AllMyMi V.0.2.25
                            javascript.0	2021-09-27 16:44:50.129	info	Start javascript script.js.devices.AllMyMi
                            javascript.0	2021-09-27 16:44:50.090	info	script.js.devices.AllMyMi: clearInterval() => cleared
                            javascript.0	2021-09-27 16:44:50.090	info	script.js.devices.AllMyMi: adapterUnsubscribe(id=properties)
                            javascript.0	2021-09-27 16:44:50.090	info	Stop script script.js.devices.AllMyMi
                            Habe echt keine Ahnung warum und wieso. Der Server ist komplett neu eingerichtet und läuft als LXC auf Proxmox.
                              @ithiel sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                              Ist das wirklich die IP des Gerätes? Is eigentlich das einzig auffällige. Zum Thema Sonderzeichen im Passwort, dem Skript ist das wumpe, aber offenbar irgendeinem Teil des "Unterbaus" nicht, hört man aber öfters (nicht bezogen auf dieses Skript), deswegen hatte ich es erwähnt. Thema Trigger, der macht natürlich nur was wenn Daten kommen, was ja bei Dir das Problem ist. Mir fällt nix ein worans liegen könnte, am Skript selber kaum, bei allen anderen läuft das Gerät ja mit dem Skript, im dümmsten Fall hängtn Server bei Xiaomi, da sind ja mehr Sachen im Spiel als nur das Skript.
                              • I
                                @pittini habe den Objektbaum jetzt nochmal komplett entfernt, den Purifier nochmal auf Werkseinstellungen gesetzt und in die Xiaomi Cloud eingebunden. Er wird auch wieder richtig erkannt, auch mit neue IP-Adresse (die andere war übrigens richtig), aber es stehen weiterhin alle werte auf null. Wenn ich den Status verändere, z.B. Luftqualität, bleibt der Wert auf (null) obwohl die Daten aktualisiert werden (grünes aufleuchten). Naja ich werde es einfach mal ein bisschen laufen lassen, vielleicht ändert sich ja was. Danke für deine Hilfe
                                ChrisNett 1 Reply Last reply Reply Quote 0
                                • ChrisNett
                                  ChrisNett @iThiel last edited by ChrisNett
                                  hat sich erledigt ich war zu ungeduldig...
                                    Gukerl last edited by Gukerl
                                    Grüß Euch,
                                    ich scheitere leider schon am Anfang! Die Zugangsdaten passen alle, leider gibts da den folgenden Fehler:
                                    Ich hab trotz intensiver Suche im Forum nix gefunden
                                    Das Skript startet soweit:
                                    9:55:56.255	info	javascript.0 (10006) script.js.Zeug.AitPur: registered 0 subscriptions and 0 schedules
                                    19:55:56.256	info	javascript.0 (10006) script.js.Zeug.AitPur: You are already logged in, login canceled
                                    19:55:56.256	info	javascript.0 (10006) script.js.Zeug.AitPur: Retrieving your in de registered MiHome Devices
                                    javascript.0
                                    2021-10-23 19:56:01.304	error	FetchError: network timeout at: https://de.api.io.mi.com/app/home/device_list at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch/lib/index.js:1476:13) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7)
                                    javascript.0
                                    2021-10-23 19:56:01.303	error	Error: network timeout at: https://de.api.io.mi.com/app/home/device_list
                                    javascript.0
                                    2021-10-23 19:56:01.302	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                      Thomas Braun Most Active @Gukerl last edited by
                                      @gukerl
                                      Soll heißen?
                                        Gukerl @Thomas Braun last edited by Gukerl
                                        @thomas-braun Zu früh Enter gedrückt 🙂 Jetzt passts aber!
                                          @gukerl
                                          ping de.api.io.mi.com
                                          PING de-api-io-mi-com-new-1496482937.eu-central-1.elb.amazonaws.com (3.120.13.91) 56(84) bytes of data.
                                          ^C
                                          --- de-api-io-mi-com-new-1496482937.eu-central-1.elb.amazonaws.com ping statistics ---
                                          9 packets transmitted, 0 received, 100% packet loss, time 8328ms
                                          Der Server ist wohl down.
                                            Beim Aufruf im Browser bekomme ich was zurück
                                            {"code":0,"message":"auth err"}
                                            Und der Air 3H lässt sich zumindest über die App einwandfrei bedienen.
                                            Aber vielen DANK für den Hinweis!!
                                            LG, Andi
                                            458
                                            92130
