    4. Test Adapter renault v0.0.x für myRenault und myDacia
      tombox @arteck last edited by
      @arteck keine Fehler im log? Und die Remote Befehle gehen auch?
      arteck G 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @tombox last edited by arteck
        @tombox ich kann nur abfragen... hab einen Captur 2 in der app .. die Daten kommen alle
          guergen @tombox last edited by guergen
          @tombox Hier schneit es mit Fehlern bei einem Renault Captur 2:
          2021-09-29 15:40:41.006 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history?type=month&country=de
          2021-09-29 15:40:41.006 - error: renault.0 (9897) Error: Request failed with status code 404
          2021-09-29 15:40:41.007 - error: renault.0 (9897) {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"error_reference":"FUNCTIONAL"}
          2021-09-29 15:40:41.041 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
          2021-09-29 15:40:41.041 - error: renault.0 (9897) Error: Request failed with status code 502
          2021-09-29 15:40:41.041 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
          2021-09-29 15:40:41.165 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
          2021-09-29 15:40:41.165 - error: renault.0 (9897) Error: Request failed with status code 502
          2021-09-29 15:40:41.165 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.400","errorMessage":"{\"errors\":[{\"status\":\"400\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
          Die Remotes sind "null"
            tombox @guergen last edited by
            @guergen Eigentlich sollten diese Fehler nur einmal kommen. Kannst du vielleicht neuinstallieren und checken ob sie nur einmal kommen.
            die remotes müssen auf true gesetzt werden damit sie aktiv sind sie haben bisher kein response
              @tombox ok, mache ich.
              Die Fehler kommen im 10-Minutentakt (Abfrageintervall)
                @guergen werden alle Daten aus der App angezeigt oder fehlt etwas
                  @tombox Ich gucke grade alles durch...
                  • In der App wird der Fuel-Level nicht angezeigt, im Adapter schon
                  • navigationAssistanceLevel ist leer
                  Der Fehler kommt trotz Neuinstallation im Abfrageintervall:
                  2021-09-29 16:44:34.643 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
                  2021-09-29 16:44:34.643 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.643 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.653 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/res-state?country=de
                  2021-09-29 16:44:34.653 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.653 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.672 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charges?country=de
                  2021-09-29 16:44:34.672 - error: renault.0 (19060) Error: Request failed with status code 400
                  2021-09-29 16:44:34.673 - error: renault.0 (19060) {"type":"FUNCTIONAL","messages":[{"code":"err.func.400","message":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"errors":[{"errorCode":"err.func.400","errorMessage":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"error_reference":"FUNCTIONAL"}
                  2021-09-29 16:44:34.691 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/battery-inhibition-status?country=de
                  2021-09-29 16:44:34.692 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.692 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.710 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v2/cars/VF1RJXXXXXXXXXX/battery-status?country=de
                  2021-09-29 16:44:34.711 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.711 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.761 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
                  2021-09-29 16:44:34.761 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.761 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.785 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-settings?country=de
                  2021-09-29 16:44:34.786 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.786 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                  2021-09-29 16:44:34.982 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
                  2021-09-29 16:44:34.983 - error: renault.0 (19060) Error: Request failed with status code 502
                  2021-09-29 16:44:34.983 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
                    @guergen Fuel Level wird nicht in der App angezeigt. Das ist eigenartig.
                    Bitte nochmal installieren dann sollten die Fehler weg sein
                      @tombox Ich habe ein LPG-Captur, vielleicht liegt es daran.
                      Wird grade neu installiert...
                      • Jey Cee
                        Jey Cee Developer last edited by Jey Cee
                        Also der Adapter gefällt mir schon mal, aber den Objekten fehlen noch die Units und der Datenpunkt charging power.
                        Die Kilometer Anzeige stimmt auch nicht, da stehen die Kilometer drin von dem Tag als wir den gekauft haben, im ZOE2 ist der richtige Wert drin.
                        Außerdem sind da einige Fehler im Log:
                          @tombox Die Fehler kommen jetzt nur noch beim Start des Adapters.
                          Wegen der Tankanzeige gucke ich gleich nach und schreibe morgen das Ergebnis 😉
                            tombox @Jey Cee last edited by
                            @jey-cee Das heißt du hast ein zoe?
                            total Mileage ist eigentlich unter cockpit zu finden
                            Komisch das er so viele Fehler wirft. Wird denn unter location was angezeigt bzw war das im zoe2 so?
                            Ich glaube es wäre hilfreich wenn ich kurz die zugangsdaten zu einem zoe bekomme
                            Jey Cee G 2 Replies Last reply Reply Quote 0
                            • Jey Cee
                              Jey Cee Developer @tombox last edited by
                              @tombox ja hab ne ZOE, ist eine der ersten. Da kann die App so gut wie gar nix Außer Akkustand anzeigen und wenn sie lädt, den Ladevorgang abbrechen.
                              Wegen Zugangsdaten schreib ich dir nacher direkt.
                                @tombox die mileage unter general müsste der Kilometerstand sein, der beim Anmelden der App aktuell waren. bei mir passt das: 4313 km am 29.3.21
                                Obwohl... ich glaube ich habe die App nicht da installiert.... Aber Datum ind Kilometerstand stimmen von dem Tag
                                  @guergen General wird nicht aktualisiert nur beim start des adapters geschrieben. Die Daten unter Cockpit werden aktualisiert
                                  @Jey-Cee lösche mal dein log weil man da dein VIN sieht
                                    Homoran Global Moderator Administrators @tombox last edited by
                                    @tombox sagte in Test Adapter renault v0.0.x:
                                    besteht da die Möglichkeit die VIN gar nicht als object zu nehmen, sondern einen Alias, der in der Konfiguration vergeben wird?
                                    BTW: steht die VIN nicht auch in der Windschutzscheibe öffentlich sichbar?
                                      tombox @Homoran last edited by
                                      Ja die VIN ist eigentlich nichts geheimes oder lassen sich private Informationen ableiten.
                                      Eigentlich müssten die totalMileage unter cockpit sein aber ich weiß nicht warum sie leer sind vielleicht muss das Fahrzeug erst bewegt werden.
                                      Falls es länger leer bleibt werde ich auch die information unter general regelmässig updaten müssen
                                      Ich habe die Fehler am Anfang als Info geändert und werden jetz alle ignoriert
                                        nein.. die steht für jeden offen ensehbar.. am Auto
                                          @tombox Der Fuelstand ist nicht in der App; wahrscheinlich liegt es am Bi-Fuel.
                                          0b der Fuelstand (ich gehe vom Benzin aus) sich ändert kann ich erst sagen, wenn ich mal wieder tanke oder längere Zeit mit Benzin fahre, was ich ja normal vermeiden will!
                                            @guergen Kannst du kurz sagen unter welchem Ordner der Datenpunkt sichtbar ist
                                            358
                                            59615
