    4. Test Adapter renault v0.0.x für myRenault und myDacia
      guergen @tombox last edited by guergen
      @tombox Hier schneit es mit Fehlern bei einem Renault Captur 2:
      2021-09-29 15:40:41.006 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history?type=month&country=de
      2021-09-29 15:40:41.006 - error: renault.0 (9897) Error: Request failed with status code 404
      2021-09-29 15:40:41.007 - error: renault.0 (9897) {"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2021-09-29T13:40:40.769+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-history\"}"}],"error_reference":"FUNCTIONAL"}
      2021-09-29 15:40:41.041 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
      2021-09-29 15:40:41.041 - error: renault.0 (9897) Error: Request failed with status code 502
      2021-09-29 15:40:41.041 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
      2021-09-29 15:40:41.165 - error: renault.0 (9897) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
      2021-09-29 15:40:41.165 - error: renault.0 (9897) Error: Request failed with status code 502
      2021-09-29 15:40:41.165 - error: renault.0 (9897) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.400","errorMessage":"{\"errors\":[{\"status\":\"400\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
      Die Remotes sind "null"
        tombox @guergen last edited by
        @guergen Eigentlich sollten diese Fehler nur einmal kommen. Kannst du vielleicht neuinstallieren und checken ob sie nur einmal kommen.
        die remotes müssen auf true gesetzt werden damit sie aktiv sind sie haben bisher kein response
          @tombox ok, mache ich.
          Die Fehler kommen im 10-Minutentakt (Abfrageintervall)
            @guergen werden alle Daten aus der App angezeigt oder fehlt etwas
            G 2 Replies Last reply Reply Quote 0
              @tombox Ich gucke grade alles durch...
              • In der App wird der Fuel-Level nicht angezeigt, im Adapter schon
              • navigationAssistanceLevel ist leer
              Der Fehler kommt trotz Neuinstallation im Abfrageintervall:
              2021-09-29 16:44:34.643 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
              2021-09-29 16:44:34.643 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.643 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.653 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/res-state?country=de
              2021-09-29 16:44:34.653 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.653 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.672 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charges?country=de
              2021-09-29 16:44:34.672 - error: renault.0 (19060) Error: Request failed with status code 400
              2021-09-29 16:44:34.673 - error: renault.0 (19060) {"type":"FUNCTIONAL","messages":[{"code":"err.func.400","message":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"errors":[{"errorCode":"err.func.400","errorMessage":"{\"errors\":[{\"status\":\"Bad Request\",\"code\":\"400\",\"title\":\"Required LocalDate parameter 'start' is not present\",\"detail\":\"start is missing\"}]}"}],"error_reference":"FUNCTIONAL"}
              2021-09-29 16:44:34.691 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/battery-inhibition-status?country=de
              2021-09-29 16:44:34.692 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.692 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.710 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v2/cars/VF1RJXXXXXXXXXX/battery-status?country=de
              2021-09-29 16:44:34.711 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.711 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.761 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/charging-settings?country=de
              2021-09-29 16:44:34.761 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.761 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.785 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-settings?country=de
              2021-09-29 16:44:34.786 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.786 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
              2021-09-29 16:44:34.982 - error: renault.0 (19060) https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-XXXX-XXXX-XXXX-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/VF1RJXXXXXXXXXX/hvac-status?country=de
              2021-09-29 16:44:34.983 - error: renault.0 (19060) Error: Request failed with status code 502
              2021-09-29 16:44:34.983 - error: renault.0 (19060) {"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"/ vehicledata API: vnext error http_code=403/ GetCurrentScheduledPresoakCommand API: vnext error http_code=403\"}]}"}],"error_reference":"TECHNICAL"}
                @guergen Fuel Level wird nicht in der App angezeigt. Das ist eigenartig.
                Bitte nochmal installieren dann sollten die Fehler weg sein
                  @tombox Ich habe ein LPG-Captur, vielleicht liegt es daran.
                  Wird grade neu installiert...
                  • Jey Cee
                    Jey Cee Developer last edited by Jey Cee
                    Also der Adapter gefällt mir schon mal, aber den Objekten fehlen noch die Units und der Datenpunkt charging power.
                    Die Kilometer Anzeige stimmt auch nicht, da stehen die Kilometer drin von dem Tag als wir den gekauft haben, im ZOE2 ist der richtige Wert drin.
                    Außerdem sind da einige Fehler im Log:
                      @tombox Die Fehler kommen jetzt nur noch beim Start des Adapters.
                      Wegen der Tankanzeige gucke ich gleich nach und schreibe morgen das Ergebnis 😉
                        tombox @Jey Cee last edited by
                        @jey-cee Das heißt du hast ein zoe?
                        total Mileage ist eigentlich unter cockpit zu finden
                        Komisch das er so viele Fehler wirft. Wird denn unter location was angezeigt bzw war das im zoe2 so?
                        Ich glaube es wäre hilfreich wenn ich kurz die zugangsdaten zu einem zoe bekomme
                        Jey Cee G 2 Replies Last reply Reply Quote 0
                        • Jey Cee
                          Jey Cee Developer @tombox last edited by
                          @tombox ja hab ne ZOE, ist eine der ersten. Da kann die App so gut wie gar nix Außer Akkustand anzeigen und wenn sie lädt, den Ladevorgang abbrechen.
                          Wegen Zugangsdaten schreib ich dir nacher direkt.
                            @tombox die mileage unter general müsste der Kilometerstand sein, der beim Anmelden der App aktuell waren. bei mir passt das: 4313 km am 29.3.21
                            Obwohl... ich glaube ich habe die App nicht da installiert.... Aber Datum ind Kilometerstand stimmen von dem Tag
                              @guergen General wird nicht aktualisiert nur beim start des adapters geschrieben. Die Daten unter Cockpit werden aktualisiert
                              @Jey-Cee lösche mal dein log weil man da dein VIN sieht
                                Homoran Global Moderator Administrators @tombox last edited by
                                @tombox sagte in Test Adapter renault v0.0.x:
                                besteht da die Möglichkeit die VIN gar nicht als object zu nehmen, sondern einen Alias, der in der Konfiguration vergeben wird?
                                BTW: steht die VIN nicht auch in der Windschutzscheibe öffentlich sichbar?
                                  tombox @Homoran last edited by
                                  Ja die VIN ist eigentlich nichts geheimes oder lassen sich private Informationen ableiten.
                                  Eigentlich müssten die totalMileage unter cockpit sein aber ich weiß nicht warum sie leer sind vielleicht muss das Fahrzeug erst bewegt werden.
                                  Falls es länger leer bleibt werde ich auch die information unter general regelmässig updaten müssen
                                  Ich habe die Fehler am Anfang als Info geändert und werden jetz alle ignoriert
                                  arteck G 2 Replies Last reply Reply Quote 0
                                    arteck Developer Most Active @tombox last edited by
                                    nein.. die steht für jeden offen ensehbar.. am Auto
                                      @tombox Der Fuelstand ist nicht in der App; wahrscheinlich liegt es am Bi-Fuel.
                                      0b der Fuelstand (ich gehe vom Benzin aus) sich ändert kann ich erst sagen, wenn ich mal wieder tanke oder längere Zeit mit Benzin fahre, was ich ja normal vermeiden will!
                                        @guergen Kannst du kurz sagen unter welchem Ordner der Datenpunkt sichtbar ist
                                          @tombox renault.0.FIN.cockpit.fuelQuantity
                                          Da steht bei mir aktuell eine "19" drin
                                          Und hier habe ich nochmal einen DP mit einer "019":
                                          renault.0.FIN.general.vehicleDetails.energy.group
                                          Im renault.0.FIN.general.vehicleDetails.energy.label steht PETROL drin, daher geh ich von "019" als Inhalt aus... obwohl, das macht als group keinen Sinn.
                                          Die
                                          renault.0.FIN.location.lastUpdateTime stimmt leider auch nicht, da ich grade "gelandet" binund die Zeit von gestern drin steht, obwohl Lat & Long stimmt
                                            guergen @guergen last edited by guergen
                                            @guergen Jetzt ist es 15 Uhr und in den DP stehen noch die Werte von heute Morgen 7:40h drin, Kilometer ebenso.
                                            In der App sind die Kilometer aktuell, der Standort auch.
                                            Aktualisierung steht auf 10 Minuten
                                            Nach Neustart des Adapters stimmt zumindest jetzt die Kilometerangabe; mein Auto steht aber immernoch ca. 30 kilometer weit weg laut DP
                                            358
                                            59615
