    4. [ESPHome] Beta release
      pboeck @Guest last edited by
      @noah3112
      Hier ist die komplette .yaml und das Blockly:
      esphome:
        platform: ESP32
        board: nodemcu-32s
      wifi:
        ssid: "XX"
        password: "XX"
        manual_ip:
          static_ip: X
          gateway: X
          subnet: X
        # Enable fallback hotspot (captive portal) in case wifi connection fails
        ap:
          ssid: "Test Display Fallback Hotspot"
          password: "X"
      captive_portal:
      # Enable logging
      logger:
        baud_rate: 0
      #  level: ERROR
      # Enable Home Assistant API
      # api:
      #  password: "XX"
      mqtt:
        broker: XX
        username: XX
        password: XX
      ota:
        password: "X"
      web_server:
        port: 80
        auth:
          username: XX
          password: XX
      time:
        - platform: sntp
          servers: XX
      spi:
        clk_pin: GPIO18
        mosi_pin: GPIO23
        miso_pin: GPIO19
      sensor:
        - platform: wifi_signal
          update_interval: 60s
      font:
        - file: "Roboto-Regular.ttf"
          id:
      color:
        - id: red_01
          red: 100%
          green: 0%
          blue: 0%
        - id: blue_01
          red: 0%
          green: 0%
          blue: 100%
        - id: green_01
          red: 0%
          green: 100%
          blue: 0%
      display:
        - platform: ili9341
          model: TFT 2.4
          cs_pin: GPIO5
          dc_pin: GPIO4
          led_pin: GPIO15
          reset_pin: GPIO22
          rotation: 90°
          pages:
            - id: page1
              lambda: |-
                it.strftime(160, 0, id(RB1), TextAlign::TOP_CENTER, "%X    %d.%m.%y", id(timeact).now());
                it.printf(5, 25, id(RB3), id(green_01), "%s", id(Zeile11).state.c_str());
                it.printf(5, 60, id(RB3), id(green_01), "%s", id(Zeile12).state.c_str());
                it.printf(5, 90, id(RB3), id(green_01), "%s", id(Zeile13).state.c_str());
                it.printf(5, 120, id(RB3), id(green_01), "%s", id(Zeile14).state.c_str());
                it.printf(5, 150, id(RB3), id(green_01), "%s", id(Zeile15).state.c_str());
                it.printf(5, 180, id(RB3), id(blue_01), "%s", id(Zeile16).state.c_str());
                it.printf(5, 210, id(RB3), id(blue_01), "%s", id(Zeile17).state.c_str());
            - id: page2
              lambda: |-
                it.printf(5, 25, id(RB3), id(green_01), "%s", id(Zeile21).state.c_str());
                it.printf(5, 60, id(RB3), id(green_01), "%s", id(Zeile22).state.c_str());
                it.printf(5, 90, id(RB3), id(green_01), "%s", id(Zeile23).state.c_str());
                it.printf(5, 120, id(RB3), id(green_01), "%s", id(Zeile24).state.c_str());
                it.printf(5, 150, id(RB3), id(green_01), "%s", id(Zeile25).state.c_str());
                it.printf(5, 180, id(RB3), id(blue_01), "%s", id(Zeile26).state.c_str());
                it.printf(5, 210, id(RB3), id(blue_01), "%s", id(Zeile27).state.c_str());
      text_sensor:
        - platform: mqtt_subscribe
          topic: Seite1/Zeile1
          topic: Seite1/Zeile2
          topic: Seite1/Zeile3
          topic: Seite1/Zeile4
          topic: Seite1/Zeile5
          topic: Seite1/Zeile6
          topic: Seite1/Zeile7
          topic: Seite2/Zeile1
          topic: Seite2/Zeile2
          topic: Seite2/Zeile3
          topic: Seite2/Zeile4
          topic: Seite2/Zeile5
          topic: Seite2/Zeile6
          topic: Seite2/Zeile7
      output:
        - platform: ledc
          pin: GPIO15
          inverted: yes
      light:
        - platform: monochromatic
          output: gpio_32_backlight_pwm
          name: "ILI9341 Display Backlight"
          restore_mode: ALWAYS_OFF
          on_turn_on:
          - delay: 10s
          - light.turn_off: back_light
      xpt2046:
        cs_pin: GPIO14
        irq_pin: GPIO27
        update_interval: 50ms
        report_interval: 1s
        threshold: 400
        dimension_x: 240
        dimension_y: 320
        calibration_x_min: 3860
        calibration_x_max: 280
        calibration_y_min: 340
        calibration_y_max: 3860
        swap_x_y: false
        on_state:
          - lambda: |-
              ESP_LOGI("main", "args x=%d, y=%d, touched=%s", x, y, (touched ? "touch" : "release"));
              ESP_LOGI("main", "member x=%d, y=%d, touched=%d, x_raw=%d, y_raw=%d, z_raw=%d",
                  id(touchscreen).x,
                  id(touchscreen).y,
                  (int) id(touchscreen).touched,
                  id(touchscreen).x_raw,
                  id(touchscreen).y_raw,
                  id(touchscreen).z_raw
      binary_sensor:
        - platform: xpt2046
          xpt2046_id: touchscreen
          x_min: 20
          x_max: 80
          y_min: 200
          y_max: 280
          on_press:
            - display.page.show_next: Display1
            - component.update: Display1
        - platform: xpt2046
          x_min: 90
          x_max: 140
          y_min: 100
          y_max: 160
          on_press:
            - light.turn_on: back_light
      ? draexler 2 Replies Last reply Reply Quote 1
        A Former User @pboeck last edited by
        @pboeck Supi 😊 Danke 👍
          @Dutchman,
          ich dachte vorhin das der Adapter installiert wurde, da ich das Laptop geschlossen habe wärend der Installation....nein er brach bei der Installation mit code 25 ab.
          Den installations Fixer habe ich schon durchlaufen lassen, brachte aber nichts.
          Anbei das installations Log.
          2021-09-29T21_49_57_821Z-debug.log
          RPI 4 Debian Buster
          Python 3.7.3
          • Dutchman
            Dutchman Developer Most Active Administrators @Guest last edited by
            @menne installiere mal pip und probiere erneut
              A Former User @Dutchman last edited by
              @dutchman ,
              ein Hallo an dich.
              Pip3 war schon installiert, musste aber ein reinstall machen. Jetzt wird auch die Version angezeigt.
              pip 21.2.4 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
              Immer noch code 25 (npip install)
                A Former User @Guest last edited by A Former User
                ...ein vollständiger Rebooot brachte keine Besserung.
                Hier nochmal das Installfenster.
                $ iobroker add esphome 0 --host iobroker
                NPM version: 6.14.15
                npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
                Traceback (most recent call last):
                File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module> main() File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main bootstrap(tmpdir=tmpdir) File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap import pip File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/__init__.py", line 26, in <module> File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/utils/__init__.py", line 27, in <module> File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3018, in <module> File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3004, in _call_aside File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3046, in _initialize_master_working_set File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2578, in activate File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2152, in declare_namespace File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2092, in _handle_ns File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2121, in _rebuild_mod_pathAttributeError: '_NamespacePath' object has no attribute 'sort'
                Error: Exited with code 1.
                at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20) at ChildProcess.emit (events.js:314:20) at maybeClose (internal/child_process.js:1022:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
                npm ERR! code ELIFECYCLEnpm ERR! errno 1
                npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-09-30T11_14_01_544Z-debug.log
                host.iobroker Cannot install iobroker.esphome@0.2.4: 1
                ERROR: Process exited with code 25
                Scheinbar meckert er jetzt wegen eines Attributes...
                • Dutchman
                  @menne sagte in [ESPHome] Beta release:
                  Scheinbare meckert er jetzt wegen eines Attributes...
                  Da scheint was mit Python nicht in Ordnung zu sein was genau kan ich dir aber nicht sagen
                    A Former User last edited by
                    @dutchman , komisch....mein Display und Lüfter laufen über python3 deshalb war auch pip installiert. Tja...k.A.
                      klassisch Most Active @Guest last edited by
                      @menne @Dutchman hat mir dort die moderne Variante von Path unter Windows erklärt. Damit konnte ich dann auf meinem Windows Arbeitsrechner auf Python 3.8.1 umstellen und habe das ganze ESPHome dort instaliert und "kompiliere" auch dort. Geht auch. Vielleicht nicht ganz so komfortabel, aber geht.
                        A Former User @klassisch last edited by A Former User
                        @klassisch , ich mache gerade ein Full-Backup meines Systems. Morgen fliegt der ganze python3 Plunder runter. Danach installiere ich gleich auf eine höhere Version.
                        Wenn Kodi nicht auf Bullseye so beschixxxx laufen würde, wäre ich schon dort.
                        Dann liefe schon python 3.9.2
                        Deshalb werde ich python3 komplett reanimieren....
                        Was anderes , wie der RPI 4 kommt bei mir nicht in Frage!
                          @dutchman ,
                          Python 3.9.1
                          Dutchman K 2 Replies Last reply Reply Quote 0
                          • Dutchman
                            @dutchman ,
                            Python 3.9.1
                            Danke für die Rückmeldung! Also war wohl was mit der Python Installation verbugt 😅 na dan viel Spaß damit 😁
                              @menne Ja. was dem ioBroker sein nodejs ist dem ESPHome sein python. Segen und Fluch.
                              Sieht jetzt aber nach einem Erfolg aus. Dann kann es ja losgehen!
                                Danke Euch beiden.....Mein Besuch ist gerade weg.
                                Was ich leider feststellen musste, dass das Display mit dem Controller Chip sh1106 nicht unterstützt wird.
                                Das ist derzeit in meinem PulseCounter verbaut und über den I²C Bus angeschlosseen.
                                Nun komme ich nicht mehr weiter...so wie es aussieht muss ich beim alten System bleiben.
                                Vielleicht kann sich @Dutchman darüber äußern.
                                Anbei eine pdf von dem Display....
                                1_3_OLED_ebook_deutsch.pdf
                                  @menne Sch mal hier: (https://esphome.io/components/display/ssd1306.html)
                                    @pboeck , Jo mal gucken....Danke 👍
                                      Geflasht wurde der D1 Mini schon mal....
                                      Jetzt muss ich noch die GPIO,s konfigurieren, die 4 TCRT5000 und das Display einbinden....
                                      Ist derzeit alles Neuland für mich....und muss viel ins Deutsche übersetzen. Da reicht mein Schulenglisch aus den 70érn nicht mehr aus...muss das heut zu tage alles in Englisch sein?
                                      Da habe ich mich auch schon bei ESPeasy drüber aufgeregt.....geschweige mit der weewx Wetterstation. Naja, was solls habe ich auch gelöst bekommen.
                                      btw...das soll kein Vorwurf sein......nur eine Meinung.....
                                      • Dutchman
                                        Mja man erreicht halt mehr Mensen und bekommt auch mehr hin international als in DE.
                                        Als Software Entwickler wählt man Dan halt auch dafür, wir bemühen uns unsere Adapter soweit wie möglich auch in DE zu dokumentieren (was ich auch für ESPHome gemacht habe)
                                        Aber ja das kann ich auch, obwohl ich nicht mehr in DE wohne, aber so haben wir DE / Russisch auch chinesisch etc es ist unmöglich alles immer zu übersetzen und auf neusten stand zu halten dafür gehen Entwicklungen zu schnell und dynamisch das würde uns ehrlich gesagt extrem ausbremsen
                                          klassisch Most Active @Guest last edited by klassisch
                                          [OT]
                                          Noch! Das ist derzeit die aktuelle Technik-Sprache. Die nächste wird wohl Mandarin sein.
                                          In den siebzigern waren die meisten und wichtigeren Datenblätter in Englisch. Meine Hauptmotivation, mich mit Englisch zu beschäftigen.
                                          Heute gibt es schon eine ganze Reihe von Datenblättern, die nur noch in Chinesisch existieren. Ich fürchte, diese Kurve krieg' ich nimmer....
                                          Dutchman 1 Reply Last reply Reply Quote 1
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @klassisch last edited by
                                            @klassisch sagte in [ESPHome] Beta release:
                                            Das ist auch ne kleine Lücke, wir haben z.b. in DE daas Gesetz das beilagen usw verständlich sein müssen zweifle nur gerade ob EN darin erlaubt oder es echt DE sein muss.
                                            Die Chinese knallen es rueber, oft schlecht übersetzt. Xiaomi hat sich das sehr gebessert inzwischen.
                                            Solange bei dem Chinesen aber nicht klingelt daas die Übersetzung nötig ist fuer den verkauf, werden die es auch nicht machen.... solche Geräte lasse ich links liegen sehe ich auch Aals Quality statement der Produkte
                                            Algemein, gutes beispiel fuer die Datenblätter ich kenne es auch seit jähren nicht anders, bin aber noch ziemlich Grünfrosch mit meinen. Mitte 30igern darin 🙂
                                            31.7k
                                            79.9k
                                            591
                                            113729
