    4. [ESPHome] Beta release
    • Dutchman
      Dutchman Developer Most Active Administrators @Guest last edited by
      @menne installiere mal pip und probiere erneut
        A Former User @Dutchman last edited by
        @dutchman ,
        ein Hallo an dich.
        Pip3 war schon installiert, musste aber ein reinstall machen. Jetzt wird auch die Version angezeigt.
        pip 21.2.4 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
        Immer noch code 25 (npip install)
          A Former User @Guest last edited by A Former User
          ...ein vollständiger Rebooot brachte keine Besserung.
          Hier nochmal das Installfenster.
          $ iobroker add esphome 0 --host iobroker
          NPM version: 6.14.15
          npm install iobroker.esphome@0.2.4 --loglevel error --prefix "/opt/iobroker" (System call)
          Traceback (most recent call last):
          File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module> main() File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main bootstrap(tmpdir=tmpdir) File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap import pip File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/__init__.py", line 26, in <module> File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/utils/__init__.py", line 27, in <module> File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 668, in _load_unlocked File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3018, in <module> File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3004, in _call_aside File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 3046, in _initialize_master_working_set File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2578, in activate File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2152, in declare_namespace File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2092, in _handle_ns File "/tmp/tmpt93vp9xz/pip.zip/pip/_vendor/pkg_resources/__init__.py", line 2121, in _rebuild_mod_pathAttributeError: '_NamespacePath' object has no attribute 'sort'
          Error: Exited with code 1.
          at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20) at ChildProcess.emit (events.js:314:20) at maybeClose (internal/child_process.js:1022:16) at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
          npm ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR! iobroker.esphome@0.2.4 install: `npip install`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the iobroker.esphome@0.2.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-09-30T11_14_01_544Z-debug.log
          host.iobroker Cannot install iobroker.esphome@0.2.4: 1
          ERROR: Process exited with code 25
          Scheinbar meckert er jetzt wegen eines Attributes...
          • Dutchman
            @menne sagte in [ESPHome] Beta release:
            Scheinbare meckert er jetzt wegen eines Attributes...
            Da scheint was mit Python nicht in Ordnung zu sein was genau kan ich dir aber nicht sagen
              A Former User last edited by
              @dutchman , komisch....mein Display und Lüfter laufen über python3 deshalb war auch pip installiert. Tja...k.A.
                klassisch Most Active @Guest last edited by
                @menne @Dutchman hat mir dort die moderne Variante von Path unter Windows erklärt. Damit konnte ich dann auf meinem Windows Arbeitsrechner auf Python 3.8.1 umstellen und habe das ganze ESPHome dort instaliert und "kompiliere" auch dort. Geht auch. Vielleicht nicht ganz so komfortabel, aber geht.
                  A Former User @klassisch last edited by A Former User
                  @klassisch , ich mache gerade ein Full-Backup meines Systems. Morgen fliegt der ganze python3 Plunder runter. Danach installiere ich gleich auf eine höhere Version.
                  Wenn Kodi nicht auf Bullseye so beschixxxx laufen würde, wäre ich schon dort.
                  Dann liefe schon python 3.9.2
                  Deshalb werde ich python3 komplett reanimieren....
                  Was anderes , wie der RPI 4 kommt bei mir nicht in Frage!
                    @dutchman ,
                    Python 3.9.1
                    Dutchman K 2 Replies Last reply Reply Quote 0
                    • Dutchman
                      @dutchman ,
                      Python 3.9.1
                      Danke für die Rückmeldung! Also war wohl was mit der Python Installation verbugt 😅 na dan viel Spaß damit 😁
                        @menne Ja. was dem ioBroker sein nodejs ist dem ESPHome sein python. Segen und Fluch.
                        Sieht jetzt aber nach einem Erfolg aus. Dann kann es ja losgehen!
                          Danke Euch beiden.....Mein Besuch ist gerade weg.
                          Was ich leider feststellen musste, dass das Display mit dem Controller Chip sh1106 nicht unterstützt wird.
                          Das ist derzeit in meinem PulseCounter verbaut und über den I²C Bus angeschlosseen.
                          Nun komme ich nicht mehr weiter...so wie es aussieht muss ich beim alten System bleiben.
                          Vielleicht kann sich @Dutchman darüber äußern.
                          Anbei eine pdf von dem Display....
                          1_3_OLED_ebook_deutsch.pdf
                            pboeck @Guest last edited by
                            @menne Sch mal hier: (https://esphome.io/components/display/ssd1306.html)
                              A Former User @pboeck last edited by
                              @pboeck , Jo mal gucken....Danke 👍
                                Geflasht wurde der D1 Mini schon mal....
                                Jetzt muss ich noch die GPIO,s konfigurieren, die 4 TCRT5000 und das Display einbinden....
                                Ist derzeit alles Neuland für mich....und muss viel ins Deutsche übersetzen. Da reicht mein Schulenglisch aus den 70érn nicht mehr aus...muss das heut zu tage alles in Englisch sein?
                                Da habe ich mich auch schon bei ESPeasy drüber aufgeregt.....geschweige mit der weewx Wetterstation. Naja, was solls habe ich auch gelöst bekommen.
                                btw...das soll kein Vorwurf sein......nur eine Meinung.....
                                • Dutchman
                                  Mja man erreicht halt mehr Mensen und bekommt auch mehr hin international als in DE.
                                  Als Software Entwickler wählt man Dan halt auch dafür, wir bemühen uns unsere Adapter soweit wie möglich auch in DE zu dokumentieren (was ich auch für ESPHome gemacht habe)
                                  Aber ja das kann ich auch, obwohl ich nicht mehr in DE wohne, aber so haben wir DE / Russisch auch chinesisch etc es ist unmöglich alles immer zu übersetzen und auf neusten stand zu halten dafür gehen Entwicklungen zu schnell und dynamisch das würde uns ehrlich gesagt extrem ausbremsen
                                    klassisch Most Active @Guest last edited by klassisch
                                    [OT]
                                    Noch! Das ist derzeit die aktuelle Technik-Sprache. Die nächste wird wohl Mandarin sein.
                                    In den siebzigern waren die meisten und wichtigeren Datenblätter in Englisch. Meine Hauptmotivation, mich mit Englisch zu beschäftigen.
                                    Heute gibt es schon eine ganze Reihe von Datenblättern, die nur noch in Chinesisch existieren. Ich fürchte, diese Kurve krieg' ich nimmer....
                                    Dutchman 1 Reply Last reply Reply Quote 1
                                    • Dutchman
                                      Dutchman Developer Most Active Administrators @klassisch last edited by
                                      @klassisch sagte in [ESPHome] Beta release:
                                      Das ist auch ne kleine Lücke, wir haben z.b. in DE daas Gesetz das beilagen usw verständlich sein müssen zweifle nur gerade ob EN darin erlaubt oder es echt DE sein muss.
                                      Die Chinese knallen es rueber, oft schlecht übersetzt. Xiaomi hat sich das sehr gebessert inzwischen.
                                      Solange bei dem Chinesen aber nicht klingelt daas die Übersetzung nötig ist fuer den verkauf, werden die es auch nicht machen.... solche Geräte lasse ich links liegen sehe ich auch Aals Quality statement der Produkte
                                      Algemein, gutes beispiel fuer die Datenblätter ich kenne es auch seit jähren nicht anders, bin aber noch ziemlich Grünfrosch mit meinen. Mitte 30igern darin 🙂
                                        [OT]
                                        @dutchman sagte in [ESPHome] Beta release:
                                        Das ist auch ne kleine Lücke, wir haben z.b. in DE das Gesetz dass beilagen usw verständlich sein müssen zweifle nur gerade ob EN darin erlaubt oder es echt DE sein muss.
                                        Denke, EN ist beim Dt. Zoll auch erlaubt.
                                        Meiner Meinung nach hat DE einen grossen Fehler gemacht. Vor 25 Jahren gab eine Rechtschreibreform. Teuer und völlig unnötig. Man hätte besser beschlossen, Englisch innerhalb von 30 Jahren als erste Amtssprache einzuführen.
                                        Dann hätte man auch Platz für Chinesisch als Fremdsprache bekommen.
                                        Einfach die Fernsehserien nicht mehr übersetzen. Dann lernen die Kids spielerisch Englisch. Funktioniert in Benelux und Skandinavien exzellent.
                                        Ich weiß, die meisten halten das für verrückt. Ich meine es aber ernst. Wir würden mehr gewinnen als verlieren, wenn wir auf eine internationale Sprache umstellen würden. Für ein, zwei Generationen wäre es etwas bumpy, aber dann wäre man durch.
                                          tloeffel last edited by tloeffel
                                          Hallo Zusammen,
                                          ich habe auf meiner Synology in einer VM iobroker unter Ubuntu laufen. Klappt alles super.
                                          Nun habe ich ESPHome installiert. Hat auch nach anfänglichen Schwierigkeiten mit Python geklappt. Nun wollte ich einen Wemos D1 mini beschreiben.
                                          In der VM ist dieser USB Controller angewählt: be27324f-62fd-46e0-926f-ae0663e064de-image.png
                                          Wenn ich nun auf Install klicke blinkt der D1 mini auch wild in "blau", aber es wird ein fataler Error ausgegeben. Was mache ich denn falsch?
                                          Mfg Thomas
                                          Meine Basis Config:
                                          esphome:
                                            platform: ESP8266
                                            board: d1_mini
                                          # Enable logging
                                          logger:
                                          # Enable Home Assistant API
                                          api:
                                          ota:
                                            password: "43fa38ae12a3245ecc86ebf3f44e8ec6"
                                          wifi:
                                            ssid: "xxx-x-xx--x"
                                            password: "xxxxxxx"
                                            # Enable fallback hotspot (captive portal) in case wifi connection fails
                                            ap:
                                              ssid: "Wemostest Fallback Hotspot"
                                              password: "awDEihEdYUV1"
                                          captive_portal:
                                          INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/wemostest.yaml...
                                          INFO Generating C++ source...
                                          INFO Compiling app...
                                          INFO Running:  platformio run -d /opt/iobroker/iobroker-data/esphome.0/wemostest
                                          Processing wemostest (board: d1_mini; framework: arduino; platform: platformio/espressif8266@2.6.2)
                                          HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
                                          PACKAGES:
                                           - framework-arduinoespressif8266 3.20704.0 (2.7.4)
                                           - tool-esptool 1.413.0 (4.13)
                                           - tool-esptoolpy 1.20800.0 (2.8.0)
                                           - toolchain-xtensa 2.40802.200502 (4.8.2)
                                          Library Manager: Installing Update
                                          Warning! Could not find the package with 'Update' requirements for your system 'linux_x86_64'
                                          Dependency Graph
                                          |-- <ESPAsyncTCP-esphome> 1.2.3
                                          |   |-- <ESP8266WiFi> 1.0
                                          |-- <ESPAsyncWebServer-esphome> 1.3.0
                                          |   |-- <Hash> 1.0
                                          |-- <ESP8266mDNS> 1.2
                                          |-- <DNSServer> 1.1.1
                                          Retrieving maximum program size .pioenvs/wemostest/firmware.elf
                                          Checking size .pioenvs/wemostest/firmware.elf
                                          RAM:   [====      ]  37.9% (used 31076 bytes from 81920 bytes)
                                          Flash: [====      ]  37.7% (used 393316 bytes from 1044464 bytes)
                                          ========================= [SUCCESS] Took 2.36 seconds =========================
                                          INFO Successfully compiled program.
                                          INFO Running:  esptool.py --before default_reset --after hard_reset --baud 460800 --chip esp8266 --port /dev/ttyUSB0 write_flash 0x0 /opt/iobroker/iobroker-data/esphome.0/wemostest/.pioenvs/wemostest/firmware.bin
                                          esptool.py v3.1
                                          Serial port /dev/ttyUSB0
                                          Connecting........_____....._____....._____....._____....._____....._____....._____
                                          A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
                                          INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
                                          INFO Running:  esptool.py --before default_reset --after hard_reset --baud 115200 --chip esp8266 --port /dev/ttyUSB0 write_flash 0x0 /opt/iobroker/iobroker-data/esphome.0/wemostest/.pioenvs/wemostest/firmware.bin
                                          esptool.py v3.1
                                            e-s @tloeffel last edited by
                                            @tloeffel
                                            Du müsstet jetzt erstmal herausfinden an welchem usb Port der d1 im System steckt und wie der heißt.
                                            Am einfachsten wird es sein sich per telnet oder so anzumelden und dann ein lsusb ausgeben lassen.
                                            Was istbdenn auf dem d1 drauf, lad dir sonst einfach die Firmware auf deinen PC und installiere dort per USB oder ota.
                                            31.7k
                                            79.9k
                                            591
                                            113729
