      jomjol @exitus last edited by
      @exitus Du musst die serielle Schnittstelle (COMx) während des Bootvorgangs mitlesen (z.B. mit Putty, Arduino oder irgendeinem anderen Schnittstellenprogramm).
        exitus @jomjol last edited by
        @jomjol hier von arduino ist in einer schleife
        Re-enable cpu cache.
        Rebooting...
        ets Jun  8 2016 00:22:57
        rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
        mode:DIO, clock div:2
        load:0x3fff0030,len:4
        load:0x3fff0034,len:7248
        ho 0 tail 12 room 4
        load:0x40078000,len:13856
        load:0x40080400,len:4052
        entry 0x40080688
        I (30) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
        I (31) boot: compile time 18:56:57
        I (31) boot: chip revision: 1
        I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
        I (41) boot.esp32: SPI Speed      : 40MHz
        I (46) boot.esp32: SPI Mode       : DIO
        I (51) boot.esp32: SPI Flash Size : 4MB
        I (55) boot: Enabling RNG early entropy source...
        I (61) boot: Partition Table:
        I (64) boot: ## Label            Usage          Type ST Offset   Length
        I (71) boot:  0 nvs              WiFi data        01 02 00009000 00004000
        I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
        I (86) boot:  2 phy_init         RF data          01 01 0000f000 00001000
        I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
        I (101) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
        I (109) boot: End of partition table
        I (113) boot_comm: chip revision: 1, min. application chip revision: 0
        I (120) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x51048 (331848) map
        I (273) esp_image: segment 1: paddr=0x00061070 vaddr=0x3ffb0000 size=0x0504c ( 20556) load
        I (283) esp_image: segment 2: paddr=0x000660c4 vaddr=0x40080000 size=0x00404 (  1028) load
        I (284) esp_image: segment 3: paddr=0x000664d0 vaddr=0x40080404 size=0x09b48 ( 39752) load
        I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x122ec8 (1191624) map
        I (826) esp_image: segment 5: paddr=0x00192ef0 vaddr=0x40089f4c size=0x12c68 ( 76904) load
        I (880) boot: Loaded app from partition at offset 0x10000
        I (880) boot: Disabling RNG early entropy source...
        I (881) psram: This chip is ESP32-D0WD
        E (885) cpu_start: Failed to init external RAM!
        abort() was called at PC 0x40081dcf on core 0
        ELF file SHA256: 49d2944a34ee25eb
        Backtrace: 0x4008cfb0:0x3ffe3c00 0x4008d3e1:0x3ffe3c20 0x40081dcf:0x3ffe3c40 0x4007931a:0x3ffe3c80 |<-CORRUPTED
        Rebooting...
        ho 0 tail 12 room 4
        entry 0x40080688
        Rebooting...
        hier vom flasch vorgang
        *************************** START ****************************
        START TIME: 202110021457
        CONNECT BAUD: 115200
        com port closed
        set state: ESP_DL_SYNC
        serial port opened
        baud:115200
        root baud:115200
        ===============BAUD : 115200===============CALL DEVICE SYNC
        connecting...
        chip sync ok
        mac l: 0xd677e1dcL
        mac h: 0x7a4ceb
        crc_cal: 122
        crc_read: 122
        crc_test: 0
        ESP32 MAC CRC OK
        get mac res: 1
        get flash id : 0x0016405e
        manufacturer_id: 0x5e
        device_id: 0x4016
        SET FLASH PARAMS
        Wrote 25264 bytes (15169 compressed) at 0x00001000 in 0.2 seconds (effective 962.4 kbit/s)...
        Hash of data verified.
        Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1638.4 kbit/s)...
        Wrote 1661824 bytes (991064 compressed) at 0x00010000 in 16.1 seconds (effective 826.3 kbit/s)...
        Leaving...
        com closed
        Use time: 21 s
        Download result: PASS
        *************************** END ****************************
          @exitus sagte in Wasserzähler - Version 2 - all-in-device:
          ESP32-D0WD
          Das Problem tritt ja schon auf, bevor meine Software richtig startet. Es sieht so aus, als ob der das PSRAM nicht initalisieren kann:
          [0;31mE (885) cpu_start: Failed to init external RAM!
          An dieser Stelle sollte folgendes passieren:
          ␛[0;32mI (775) boot: Loaded app from partition at offset 0x10000␛[0m
          ␛[0;32mI (776) boot: Disabling RNG early entropy source...␛[0m
          ␛[0;32mI (787) psram: This chip is ESP32-D0WD␛[0m
          ␛[0;32mI (788) spiram: Found 64MBit SPI RAM device␛[0m
          ␛[0;32mI (788) spiram: SPI RAM mode: flash 40m sram 40m␛[0m
          ␛[0;32mI (793) spiram: PSRAM initialized, cache is in low/high (2-core) mode.␛[0m
          ␛[0;32mI (800) cpu_start: Pro cpu up.␛[0m
          Entweder hat dein Modul kein PSRAM oder vielleicht ist es defekt. PSRAM ist aber zwingend notwendig, da die neuronalen Netze und die Bildverarbeitung ohne die 4 MB zusätzlichen Speicher nicht möglich sind.
            @jomjol ich habe 3 bestellt alle gleich
            ibetyouibetyou
            € 6,63 35% Rabatt | ESP32 CAM Entwicklungen Bord mit OV2640 Kamera Modul 66 Grad WIFI Bluetooth Download Modul KIT ESP32-CAM 2MP
            https://a.aliexpress.com/_mrt5Tl0
            J G 2 Replies Last reply Reply Quote 0
              @exitus Laut dem Link hat es alles, was du brauchst. Du kannst mal versuchen, ein anderes Programm zu flashen, erstmal ohne und dann mit PSRAM.
                senior1418 @jomjol last edited by
                @jomjol
                bisher hatte ich hier nur sporadisch mitgelesen weil es mir an Phantasie fehlte das Ganze ohne 3D Drucker zu realisieren.
                Irgendwo oben hat mich das Bild einer Blechdose auf dem Wasserzähler aufgeweckt. 😊
                Der Versuchsaufbau mit einer Lolli - Kunstoffdose klappte auf anhieb, hatte echt Spaß gemacht. Vielen Dank auch von mir für das erstklassige Projekt.
                Aber - gut es wurde vor einigen Wochen angekündigt - gestern Nachmittag klingelte der Monteur des Wasseranbieters und baute uns einen neuen Zähler ein. Und damit will es nicht mehr so einfach,
                Da die letzte Ziffer meist gekippt ist und zudem noch mittig einen Strich haben werde ich erstmal mit 1-2 Nachkommastellen weitermachen.
                Meine Frage wäre aber, weshalb die 4 hier als 5 erkannt wird. Kann ich hier noch etwas optimieren?
                  jomjol @senior1418 last edited by
                  @senior1418 Klick mal obern auf "Recognition", dann siehst du was wirklich erkannt wurde. Ansonsten könnte es auch sein, dass da im Training noch etwas nicht ganz passt. Du kannst mir Trainingsdaten erzeugen (mit den Logfiles) und je Ziffer 2-3 Beispiele schicken (nicht mehr! 🙂 ) Dann nehme ich die ins nächste Training.
                    exitus @jomjol last edited by exitus
                    @jomjol was kann ich den nehmen wie mache es nur die Firmware flashen.
                    Ich habe auch Tasmota versucht es bootet aber kein Kamera Bild . Habe noch mit arduino Gesichtserkennung drauf gepack bootet auch aber auch kein Bild. Etwas ist faul aber was
                      @jomjol
                      hi, danke für die Antwort. Mache ich gern. Recognition erzeugt:
                      Trainigsdaten erzeugen mit :
                      d52419d0-77f0-4f86-9678-6e58334cda0d-image.png 3a6a838f-64a3-4c20-bd59-49725f7c42b5-image.png
                      so richtig?
                        @senior1418 ja und wenn du von jeder ziffer 2-3 bilder hast einfach schicken.
                          @exitus Ich würde an deiner Stelle mit der Arduino Oberfläche ein paar der Beispiele probieren.
                            @jomjol habe ich aber das Kamera Bild bekomme ich nicht warum auch immer kann es was mit Strom zutun haben
                              @exitus Ich empfehle in jedem Fall die 5V Versorgung
                                @jomjol danke .. mache ich
                                  @jomjol über 5v pin geht auch nicht langsam habe ich das gefühl das sie kaputt oder gefälscht sind
                                    toki1973 @exitus last edited by
                                    Irgendwie funktioniert das nicht mit dem previous Value:
                                    Ich habe den Wert 354.7325 eingetragen. Dann Wasser bis 354.8103 verbraucht. Der Wert wird im Raw Value auch korrekt angezeigt. Warum erkennt das System diesen als zu hoch? Kann man die Schwelle dazu einstellen?
                                    Danke!
                                      jomjol @toki1973 last edited by
                                      @toki1973 Du musst auch MaxRateValue einstellen. Das ist der maximale Unterschied, der zwischen zwei abgelesenen Werten erlaub ist. Kannst du erstmal ruhig etwas höher einstellen.
                                        toki1973 @jomjol last edited by
                                        @jomjol
                                        Irgendwie bekomme ich das nicht hin. Anbei meine Einstellungen. Warum wird den 357 statt 356 interpretiert obwohl es im RAW richtig erkannt wird?
                                          homecineplexx last edited by
                                          Also bei mir haut das auch nur ganz schlecht hin:
                                          Meine Wasseruhr zeigt digital 01016 an als
                                          Value: 996.8434
                                          Previous Value: 996.84338
                                          Raw Value: 01006.9356
                                          Error:
                                          Rate too high - Read: 1006.9356 - Pre: 996.8434
                                          kann oder muss ich da irgendwas tun, damit das korrekt funkt?
                                          danke
                                          lg
                                          als version hab ich folgendes drauf:
                                          Git-Base-Branch: master - v8.5.0 - 2021-10-07
                                          HTML Version: 10.2.0
                                            @toki1973 sagte in Wasserzähler - Version 2 - all-in-device:
                                            @jomjol
                                            Der Fehler liegt irendwo im vorheriger Schritt, denn der PreValue zeigt ja schon die 357,... an. Kommt das bei dir häufiger vor? Am besten mal die Logdatei (vorher aktivieren) aufnehmen und mir dann den Ausschnitt, wo erst alles okay und dann verschoben ist. Dann schaue ich, ob es ein Fehler ist.
                                            1.0k
                                            238
                                            3411
                                            2010225
