    • Rene55
      Rene55 last edited by
      @SBorg Ich habe gerade mal die Wetterstatistik bei mir angepasst und eingebaut.
      Hier bekomme ich dann folgende Meldungen:
      javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Rekordwerte" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Jahreswerte" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.Control" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.609	info	State value to set for "0_userdata.0.Wetterstatistik.VorTag" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.Data" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.Vorjahres_Monat" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.608	info	State value to set for "0_userdata.0.Wetterstatistik.aktueller_Monat" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.533	info	State value to set for "0_userdata.0.Wetterstatistik" has to be type "folder" but received type "string"
      javascript.0	2021-10-03 17:08:58.433	warn	This object will not be created in future versions. Please report this to the developer.
      javascript.0	2021-10-03 17:08:58.433	warn	Object 0_userdata.0.Wetterstatistik.Rekordwerte is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.433	warn	Object 0_userdata.0.Wetterstatistik.Jahreswerte is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.431	warn	This object will not be created in future versions. Please report this to the developer.
      javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Control is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.VorTag is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Data is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.Vorjahres_Monat is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.431	warn	Object 0_userdata.0.Wetterstatistik.aktueller_Monat is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      javascript.0	2021-10-03 17:08:58.430	warn	Object 0_userdata.0.Wetterstatistik is invalid: obj.common.type has an invalid value (folder) but has to be one of number, string, boolean, array, object, mixed, file, json
      Ist das so OK oder gibt es da Irritationen mit den Typen der DPs?
      LG Rainer
      Negalein SBorg 2 Replies Last reply Reply Quote 0
      • da_Woody
        da_Woody @Negalein last edited by da_Woody
        @negalein ist doch egal. vor der { eine [ und hinten das umgekehrte. }]
        hab da alle geändert, das script gestoppt, das neue eingefügt, gestartet, keine fehler.
        sollte also quitschen.
            "Tiefstwert": -4.27,
            "Hoechstwert": 20.5,
            "Temp_Durchschnitt": 2.12,
            "Max_Windboe": 25.58,
            "Max_Regenmenge": 3.6,
            "Regenmenge_Monat": 12.1,
            "warme_Tage": 7,
            "Sommertage": 0,
            "heisse_Tage": 0,
            "Frost_Tage": 8,
            "kalte_Tage": 16,
            "Eistage": 0,
            "sehr_kalte_Tage": 0
        • Negalein
          Negalein Global Moderator @da_Woody last edited by
          @da_woody sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Ja Simönchen 😂
          habs eh so gemacht. Mir gings nur um das aussehen. 😘
          • Negalein
            Negalein Global Moderator @Rene55 last edited by
            @rene55 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
            zeig mal den DP und den RAW davon.
            • Rene55
              @Negalein Ich hab mal den ganzen Zweig exportiert. 0_userdata.0.Wetterstatistik.json Hoffentlich war das so richtig und Müll hier nicht alles zu.
              LG Rainer
              • Negalein
                das ist mir zuviel
                Zeig mal das
                Und dann noch ganz rechts auf den Bleistift und dann die Raw-Daten zeigen.
                • Negalein
                  Negalein Global Moderator @SBorg last edited by
                  @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                  Falls nicht bitte melden, sind ggf. nur wenige Zeilen.
                  bei mir steht es still 😞
                  • Negalein
                    Negalein Global Moderator @Negalein last edited by
                    @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                    beim Start dieses Scripts von @liv-in-sky kommt nun
                    00:14:32.040	error	javascript.0 (31206) script.js.Wetter.Wettertabelle: SyntaxError: Unexpected token o in JSON at position 1
                    00:14:32.040	error	javascript.0 (31206) at script.js.Wetter.Wettertabelle:53:17
                    00:14:32.040	error	javascript.0 (31206) at dataStuff (script.js.Wetter.Wettertabelle:49:15)
                    00:14:32.040	error	javascript.0 (31206) at main (script.js.Wetter.Wettertabelle:149:4)
                    SBorg liv-in-sky 2 Replies Last reply Reply Quote 0
                    • da_Woody
                      schau in den spiegel, dann weist du, das ist nebensächlich...
                        Langer last edited by Negalein
                        habe die Wetterstation auf den neusten Stand gebracht und bekomme nun folgende Fehler:
                        Installierte Versionen:
                        wetterstation_statistik.js V1.0.0
                        wetterstation.conf V2.8.0
                        wetterstation.js V2.9.0
                        wetterstation.sh V2.9.0
                        wetterstation.sub V2.9.0
                        ws_updater.sh v2.8.0
                        Bei:
                        chmod +x wetterstation.sh
                        keine fehler
                        Bei:
                        root@pi-slave:/home/iobroker# ./wetterstation.sh --debug
                        -bash: ./wetterstation.sh: /bin/bash^M: Defekter Interpreter: Datei oder Verzeichnis nicht gefunden
                        Bei:
                        root@pi-slave:/home/iobroker# sudo systemctl start wetterstation
                        root@pi-slave:/home/iobroker# sudo systemctl status wetterstation
                        ● wetterstation.service - Service für ioBroker Wetterstation
                           Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
                           Active: failed (Result: exit-code) since Mon 2021-10-04 08:25:58 CEST; 9s ago
                          Process: 7382 ExecStart=/home/iobroker/wetterstation.sh (code=exited, status=203/EXEC)
                         Main PID: 7382 (code=exited, status=203/EXEC)
                        Okt 04 08:25:58 pi-slave systemd[1]: Started Service für ioBroker Wetterstation.
                        Okt 04 08:25:58 pi-slave systemd[7382]: wetterstation.service: Failed to execute command: No such file or directory
                        Okt 04 08:25:58 pi-slave systemd[7382]: wetterstation.service: Failed at step EXEC spawning /home/iobroker/wetterstation.sh: No such file or directory
                        Okt 04 08:25:58 pi-slave systemd[1]: wetterstation.service: Main process exited, code=exited, status=203/EXEC
                        Okt 04 08:25:58 pi-slave systemd[1]: wetterstation.service: Failed with result 'exit-code'.
                        Was habe ich wieder falsch gemacht??
                        MfG
                        Wastl
                          Thomas Braun Most Active @Langer last edited by
                          @langer
                          Falsch?
                          root@pi-slave
                          ist falsch.
                          Gibt es das File? Wenn ja, mit welchen Rechten?
                            Langer @Thomas Braun last edited by
                            root@pi-slave:/home/iobroker# dir
                            wetterstation.conf wetterstation.sh wetterstation.sub ws_updater.sh
                            Ich hoffe das hast Du gemeint?
                            MfG
                            Wastl
                            Thomas Braun SBorg 2 Replies Last reply Reply Quote 0
                            • Rene55
                              @Negalein Ich hab im Moment nur August und September 2021, und zwar gerade gestern neu angelegt (Hatte in der vorigen Nacht einen Crash des gesamten NUCs😢 ).
                                "common": {
                                  "name": "Monatsstatistik für September 2021",
                                  "type": "object",
                                  "role": "json"
                                "native": {
                                  "type": "object",
                                  "role": "json"
                                "type": "state",
                                "_id": "0_userdata.0.Wetterstatistik.Data.2021.09",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                  "owner": "system.user.admin",
                                "user": "system.user.admin",
                                "ts": 1633278954065
                              bei der Ausführung in der Nacht gab es nur den Eintrag, dass das Script ausgeführt wurde - sonst keine weiteren Einträge ins Log. Also sollte alles gut sein.
                              • SBorg
                                SBorg Forum Testing Most Active @Negalein last edited by
                                Aber warum siehst du es in 1 Wurst und ich untereinander?
                                Kann man das umstellen?
                                Sagen wir mal so, ich wüsste aktuell nicht wie oder wo. Ist "einfach" bei mir so. Durch was das kam...? Am dunklen Skin wird es wohl nicht liegen. Ev. Browser (bei mir aktueller FF) oder ein AddOn...?
                                • SBorg
                                  SBorg Forum Testing Most Active @Rene55 last edited by
                                  @rene55 Antwort auf beide Posts 😉 :
                                  zum 1. Da stimmt so einiges an der Zuordnung der Datenpunkte nicht. Sieht aber dann beim 2. Post Ok aus 🙂
                                  Hattest du nicht auch schon öfters Probleme mit Influx/Grafana?
                                  btw @all: geht bitte nicht davon aus, dass ich mich immer an alles erinnere oder speziell auch zuordnen kann wer, was, wieso, warum....
                                  Meine "grauen Zellen" werden allmählich wirklich grau und bei der Menge an Posts, Chats, Emails, Issues ... verliere ich den Überblick. Bei einer Anfrage "...du erinnerst dich..." muss ich, ohne jemand zu Nahe treten zu wollen, öfters auch mal mit "Nein" antworten. Es ist einfach zu viel. Wenn ich also mal was verwechsele oder nicht mehr weiß, Sorry, keine Absicht 🙂
                                  • SBorg
                                    + @all liv-in-sky Skript-Nutzer:
                                    Ändere mal so um Zeile ~#53 ab:
                                    let helper=JSON.parse(getState(id).val);
                                    in
                                    //let helper=JSON.parse(getState(id).val);
                                    let helper=getState(id).val[0];
                                    also Originalzeile auskommentieren und dafür die neue einfügen. Danach sollte es wieder laufen.
                                      @langer
                                      Du springst da ja immer noch als root rum.
                                      Log dich aus und als Standarduser wieder an.
                                      ls -l /home/iobroker
                                      • SBorg
                                        SBorg Forum Testing Most Active @da_Woody last edited by
                                        Jeden Morgen...
                                        "Ich kenn dich zwar nicht, wasch dich aber trotzdem..." 😀
                                        • Negalein
                                          Merci
                                          läuft wieder 🙂
                                          • Rene55
                                            @SBorg Danke für die Antwort. Probleme mit Influx/Grafana hatte ich eigentlich noch keine, oder sind mir nicht aufgefallen. Die Fehlermeldung aus dem ersten Post hatte ich ja auch nur einmal beim ersten Start des Scripts V1.0.0. Und da ja in dem Lgeintrag drin stand "Please report this to the developer." dachte ich mir, das sollte der Entwickler mal beäugen. Wenns nur bei mir auftrat ist es auch nicht weiter wichtig - es läuft ja alles.
                                            LG Rainer
                                            152
                                            5661
                                            3782062
