    4. [gelöst] Error: spawn /bin/ping ENOENT nach Update
    • Glasfaser
      Glasfaser @PeterImNetz last edited by
      @peterimnetz sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
      ENOENT
      Zeige mal die Ausgabe von :
      iobroker status
      which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      dann versuche mal :
      pkill -u iobroker
      iobroker fix
      und anschließend den Container neu starten.
        PeterImNetz @Glasfaser last edited by
        @glasfaser
        Habe ich alles gemacht:
        root@9f56db605ef8:/opt/iobroker# iobroker status
        Objects type: file
        States  type: file
        root@9f56db605ef8:/opt/iobroker# which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        /usr/bin/node
        /usr/bin/npm
        root@9f56db605ef8:/opt/iobroker# iobroker fix
        library: loaded
        Library version=2021-08-05
            Welcome to the ioBroker installation fixer!
            Script version: 2021-04-07
            Installing prerequisites (1/3)
        Get:1 http://deb.debian.org/debian bullseye InRelease [113 kB]
        Get:2 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
        Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4.586 B]
        Get:4 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
        Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [41,5 kB]
        Get:6 http://deb.debian.org/debian bullseye/main amd64 Packages [8.178 kB]
        Get:7 https://deb.nodesource.com/node_12.x bullseye/main amd64 Packages [768 B]
        Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.300 B]
        Fetched 8.423 kB in 2s (3.405 kB/s)
        Reading package lists... Done
        Installed gcc-c++
        Installed python-dev
            Checking ioBroker user and directory permissions (2/3)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Checking autostart (3/3)
        Unsupported init system, cannot enable autostart!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        Das ändert leider nichts, nach dem Neustart des Containers kommt immer noch die Fehlermeldung
        ping.0
        	2021-10-02 13:05:36.820	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.816	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.811	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.807	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.803	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.798	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        ping.0
        	2021-10-02 13:05:36.793	error	Error: ping.probe: there was an error while executing the ping program. check the path or permissions...: Error: spawn /bin/ping ENOENT
        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
        • Glasfaser
          /usr/bin/node
          /usr/bin/npm
          Da fehlt einiges ... da sollte mehr kommen
          nochmal :
          • AlCalzone
            AlCalzone Developer @PeterImNetz last edited by
            ENOENT
            bedeutet, dass das Programm nicht existiert. Ist der Pfad /bin/ping denn im Container vorhanden?
              Thomas Braun Most Active @PeterImNetz last edited by Thomas Braun
              @peterimnetz
              ping darf u. U. nur mit root-Rechten ausgeführt werden. Da muss wohl dem iobroker noch was eingeräumt werden. Aber von Docker hab ich keinen Plan.
              • Glasfaser
                Glasfaser @Thomas Braun last edited by Glasfaser
                @thomas-braun sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
                Kann man das gleiche machen :
                https://forum.iobroker.net/topic/45347/ping-adapter-liefert-unter-ubuntu-nur-false/8
                @PeterImNetz
                Bitte erstmal die Ausgabe von oben angefordert Posten
                dann
                Zeige mal :
                ls -la /bin/ping
                  @glasfaser said in Error: spawn /bin/ping ENOENT nach Update JS controller:
                  ls -la /bin/ping
                  So einfach ist das - es gibt kein ping in dem Container 🤦‍♂️
                  root@9f56db605ef8:/opt/iobroker# ls -la /bin/ping
                  ls: cannot access '/bin/ping': No such file or directory
                  OK, Danke - das erklärt es natürlich...
                  • Glasfaser
                    Glasfaser @Glasfaser last edited by Glasfaser
                    @PeterImNetz
                    @glasfaser sagte in Error: spawn /bin/ping ENOENT nach Update JS controller:
                    nochmal :
                    Nochmal :
                    Was ist hiermit .... da fehlte die hälfte der Ausgabe !?
                    EDIT:
                    nimm mal bei dir :
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      PeterImNetz @Glasfaser last edited by PeterImNetz
                      Ja, das ist ziemlich wenig
                      Ich habe keine Idee wieso das executeable weg war, aber so einfach war dann auch die Lösung...
                      • Glasfaser
                        Glasfaser @PeterImNetz last edited by Glasfaser
                        Ich habe heute meinen ibroker im Docker (buanet)
                        Kann du uns noch verraten welche Docker Version du von buanet hast ,
                        denn der ( Fehler ) ist heute hier auch aufgetreten .
                        https://forum.iobroker.net/topic/48224/error-ping-probe-ping-und-sony-bravia-adapter
                        An JS controller auf 3.3.18 aktualisiert , kann ich mir erstmal nicht vorstellen , da ich auch ein buanet Docker habe .
                          PeterImNetz last edited by PeterImNetz
                          Works as desired - https://github.com/buanet/ioBroker.docker/issues/200#issuecomment-932781681
                          Mit der Umstellung auf Debian Bullseye slim v5.2.0 gibt es kein ping mehr im Docker
                          Das Paket iputils-ping muss nun manuell mit beim Bauen des Containers berücksichtigt werden:
                          peterimnetz created this issue in buanet/ioBroker.docker
                          closed Executeable of ping is missing in image #200
                          1392
