    4. Status vom Kostal Wechselrichter auslesen?
      MartyBr @Homoran last edited by
      Der Javascript Adapter läuft auf debug. Das Script triggert im Sekundenrythmus, die Werte werden geliefert.
      Im Log ändert sich trotz Debug nichts.
      ipt.0
      2021-10-04 17:17:55.048	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:17:44.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:17:33.124	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:17:22.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:17:11.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:17:00.138	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:55.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:44.052	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:33.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:22.053	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:11.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:16:00.116	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      javascript.0
      2021-10-04 17:15:55.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
      Im Script-Editor kommt kein Fehler:
        Homoran Global Moderator Administrators @MartyBr last edited by
        @martybr sagte in Status vom Kostal Wechselrichter auslesen?:
        und was ist das für eine rote Welle am oberen Rand des Screenshots?
          Markierungen im Script-Editor:
            @martybr lass dir doch nicht alles aus der Nase ziehen!
            was steht dann im mouse over, wenn du mit der Maus über die Welle gehst
            • Glasfaser
              Glasfaser @MartyBr last edited by Glasfaser
              @homoran sagte in Status vom Kostal Wechselrichter auslesen?:
              <IP>/api/dxs.json?dxsEntries=33555715
              nein !! Das ist String 3. Ihr so so verdammt schnell, da komme ich nicht mit 😀
              Bei 33555715
              Ist eigentlich dort ein Ergebniss gekommen !?
              Homoran M 2 Replies Last reply Reply Quote 0
                Cannot find name "ID_Eigenverbrauch_d"
                Das steht bei jeder Variable.
                Auch in dem Original-Script, dass einwandfrei funktioniert.
                Sorry, ich bin in Scripting nicht so versiert. Habe dein Script genommen, es funktioniert, es fehlen nur die Werte für den String 3.
                  Homoran Global Moderator Administrators @Glasfaser last edited by
                  @glasfaser sagte in Status vom Kostal Wechselrichter auslesen?:
                  Bei 33555715
                  steht zumindest im code, den er gepostet hat
                    MartyBr @Glasfaser last edited by
                    @glasfaser
                    Ja, der Aufruf liefert genau den fehlenden Wert für den String 3.
                    {"dxsEntries":[{"dxsId":33555715,"value":137.251205}],"session":{"sessionId":0,"roleId":0},"status":{"code":0}}
                      MartyBr @MartyBr last edited by
                      @martybr
                      Hier der Piko (zeitlich versetzt):
                        Homoran Global Moderator Administrators @MartyBr last edited by Homoran
                        wirklich?
                        ich sehe nur rot
                        @Glasfaser
                        kannst du damit was anfangen?
                        muss da etwa jedesmal ein var oder const davor?
                        • Glasfaser
                          Glasfaser @Homoran last edited by
                          @Homoran
                          ich importier es mal bei mir .. warte mal .
                          Leider fehlen immer noch die Werte für den String 3:
                          Ich hatte die Tage auch einen blöden Fehler mit (null) , erst beim erneuten Admin Anmelden waren dort Werte enthalten .
                            Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                            Danke!
                            das fehlende value kann ich nicht finden
                            @MartyBr
                            vielleicht ist jede Sekunde auch einfach zu schnell
                            Glasfaser M 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Toll , hänge in der schleife ..
                                dann geh ich da auch mal rein 😂
                                  @glasfaser
                                  @Homoran
                                  Das von mir genutzte Original Script stammt hier aus dem Thread:
                                  // Ausleseskript Wechselrichter Kostal Piko ab Firmware v05.31 (12.10.2015)
                                  //Variable
                                  var url = '192.168.178.77'; // IP der Photovoltaik-Anlage eintragen
                                  var IPAnlage = url + '/api/dxs.json';
                                  //Leistungswerte
                                     ID_DCEingangGesamt = 33556736;         // in W
                                     ID_Ausgangsleistung = 67109120;        // in W
                                     ID_Eigenverbrauch = 83888128;          // in W
                                     //Status
                                     ID_Status = 16780032;                  // 0:Off
                                     //Statistik - Tag
                                     ID_Ertrag_d = 251658754;               // in Wh
                                     ID_Hausverbrauch_d = 251659010;        // in Wh
                                     ID_Eigenverbrauch_d = 251659266;       // in Wh
                                     ID_Eigenverbrauchsquote_d = 251659278; // in %
                                     ID_Autarkiegrad_d = 251659279;         // in %
                                     //Statistik - Gesamt
                                     ID_Ertrag_G = 251658753;               // in kWh
                                     ID_Hausverbrauch_G = 251659009;        // in kWh
                                     ID_Eigenverbrauch_G = 251659265;       // in kWh
                                     ID_Eigenverbrauchsquote_G = 251659280; // in %
                                     ID_Autarkiegrad_G = 251659281;         // in %
                                     ID_Betriebszeit = 251658496;           // in h
                                     //Momentanwerte - PV Generator
                                     ID_DC1Spannung = 33555202;             // in V
                                     ID_DC1Strom = 33555201;                // in A
                                     ID_DC1Leistung = 33555203;             // in W
                                     ID_DC2Spannung = 33555458;             // in V
                                     ID_DC2Strom = 33555457;                // in A
                                     ID_DC2Leistung = 33555459;             // in W
                                     //Momentanwerte Haus
                                     ID_HausverbrauchSolar = 83886336;      // in W
                                     ID_HausverbrauchBatterie = 83886592;   // in W
                                     ID_HausverbrauchNetz = 83886848;       // in W
                                     ID_HausverbrauchPhase1 = 83887106;     // in W
                                     ID_HausverbrauchPhase2 = 83887362;     // in W
                                     ID_HausverbrauchPhase3 = 83887618;     // in W
                                     //Netz Netzparameter
                                     ID_NetzAusgangLeistung = 67109120;     // in W
                                     ID_NetzFrequenz = 67110400;            // in Hz
                                     ID_NetzCosPhi = 67110656;
                                     //Netz Phase 1
                                     ID_P1Spannung = 67109378;              // in V
                                     ID_P1Strom = 67109377;                 // in A
                                     ID_P1Leistung = 67109379;              // in W
                                     //Netz Phase 2
                                     ID_P2Spannung = 67109634;              // in V
                                     ID_P2Strom = 67109633;                 // in A
                                     ID_P2Leistung = 67109635;              // in W
                                     //Netz Phase 3
                                     ID_P3Spannung = 67109890;              // in V
                                     ID_P3Strom = 67109889;                 // in A
                                     ID_P3Leistung = 67109891;              // in W
                                  createState('Solaranlage.Momentanwerte.Leistung_AC_aktuell', 0);
                                  createState('Solaranlage.Summenwerte.Autarkiegrad_d',0);
                                  createState('Solaranlage.Summenwerte.Autarkiegrad_G',0);
                                  createState('Solaranlage.Summenwerte.Betriebszeit',0);
                                  createState('Solaranlage.Momentanwerte.Status','aus');
                                  createState('Solaranlage.Momentanwerte.Leistung_DC_aktuell',0);
                                  createState('Solaranlage.Momentanwerte.Eigenverbrauch',0);
                                  createState('Solaranlage.Summenwerte.Eigenverbrauch_d');
                                  createState('Solaranlage.Summenwerte.Eigenverbrauch_G', 0);
                                  createState('Solaranlage.Summenwerte.Eigenverbrauchsquote_d', 0);
                                  createState('Solaranlage.Summenwerte.Eigenverbrauchsquote_G', 0);
                                  createState('Solaranlage.Summenwerte.Tagesertrag', 0);
                                  createState('Solaranlage.Summenwerte.Gesamtertrag', 0);
                                  createState('Solaranlage.Summenwerte.Hausverbrauch_d', 0);
                                  createState('Solaranlage.Summenwerte.Hausverbrauch_G', 0);
                                  createState('Solaranlage.Momentanwerte.P1Spannung');
                                  createState('Solaranlage.Momentanwerte.P2Spannung');
                                  createState('Solaranlage.Momentanwerte.P1Strom');
                                  createState('Solaranlage.Momentanwerte.P2Strom');
                                  createState('Solaranlage.Momentanwerte.P1Leistung');
                                  createState('Solaranlage.Momentanwerte.P2Leistung');
                                  createState('Solaranlage.Momentanwerte.Leistung_String1');
                                  createState('Solaranlage.Momentanwerte.Leistung_String2');
                                  var logging = false;
                                  var request = require('request');
                                  function Piko() {
                                     if (logging) log("Piko 5.5 auslesen");
                                     request('http://' + IPAnlage +
                                     '?dxsEntries=' + ID_DCEingangGesamt +
                                     '&dxsEntries=' + ID_Ausgangsleistung +
                                     '&dxsEntries=' + ID_Eigenverbrauch +
                                     '&dxsEntries=' + ID_Eigenverbrauch_d +
                                     '&dxsEntries=' + ID_Eigenverbrauch_G +
                                     '&dxsEntries=' + ID_Eigenverbrauchsquote_d +
                                     '&dxsEntries=' + ID_Eigenverbrauchsquote_G +
                                     '&dxsEntries=' + ID_Ertrag_d +
                                     '&dxsEntries=' + ID_Ertrag_G +
                                     '&dxsEntries=' + ID_Hausverbrauch_d +
                                     '&dxsEntries=' + ID_Hausverbrauch_G +
                                     '&dxsEntries=' + ID_Autarkiegrad_G +
                                     '&dxsEntries=' + ID_Autarkiegrad_d +
                                     '&dxsEntries=' + ID_Betriebszeit +
                                     '&dxsEntries=' + ID_P1Spannung +
                                     '&dxsEntries=' + ID_P2Spannung +
                                     '&dxsEntries=' + ID_P1Strom +
                                     '&dxsEntries=' + ID_P2Strom +
                                     '&dxsEntries=' + ID_P1Leistung +
                                     '&dxsEntries=' + ID_P2Leistung +
                                     '&dxsEntries=' + ID_Status +
                                     '&dxsEntries=' + ID_DC1Leistung +
                                     '&dxsEntries=' + ID_DC2Leistung,
                                     function (error, response, body) {
                                         if(!error && response.statusCode ==200) {
                                             if(logging) log(body);
                                             var result = JSON.parse(body).dxsEntries;
                                     		var Zustand = 'aus';
                                     		if (result[20].val == 0) {
                                             Zustand = 'aus';
                                             } else if (result[20].value== 1) {
                                             Zustand = 'Leerlauf';
                                             } else if (result[20].value == 2) {
                                             Zustand = 'Anfahren';
                                             } else if (result[20].value == 3) {
                                             Zustand = 'Einspeisen MPP';
                                             } else if (result[20].value == 4) {
                                             Zustand = 'Einspeisen abgeregelt';
                                             } else if (result[20].value == 7) {
                                             Zustand = 'Isolationsmessung';
                                             } else {
                                             Zustand = (String('Code ') + String('' + result[20].value));
                                             setState('Solaranlage.Momentanwerte.Leistung_DC_aktuell', result[0].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.Leistung_AC_aktuell', result[1].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.Eigenverbrauch', result[2].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Eigenverbrauch_d', result[3].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Eigenverbrauch_G', result[4].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Eigenverbrauchsquote_d', result[5].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Eigenverbrauchsquote_G', result[6].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Tagesertrag', result[7].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Gesamtertrag', result[8].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Hausverbrauch_d', result[9].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Hausverbrauch_G', result[10].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Autarkiegrad_G', result[11].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Autarkiegrad_d', result[12].value || 0, true);
                                             setState('Solaranlage.Summenwerte.Betriebszeit', result[13].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P1Spannung', result[14].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P2Spannung', result[15].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P1Strom', result[16].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P2Strom', result[17].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P1Leistung', result[18].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P2Leistung', result[19].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.Status', Zustand || 0, true);
                                             setState('Solaranlage.Momentanwerte.Leistung_String1', result[21].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.Leistung_String2', result[22].value || 0, true);
                                         } else {
                                             log("Fehler: " + error + " bei Abfrage von: " + url, "warn");
                                  schedule("*/11 * 5-23 * * *", Piko);
                                  //on('smartmeter.0.1-0:16_7_0__255.value', Piko); // triggert bei Wertänderung;
                                  Es liefert alle Werte, obwohl die Datenpunkte rot unterkriegest sind.
                                  Ich habe nun in deinem letzten Script ein "var" vor den Variablen gesetzt:
                                  //Variable
                                  //Leistungswerte
                                  var   ID_DCEingangGesamt = 33556736;         // in W
                                  var   ID_Ausgangsleistung = 67109120;        // in W
                                  var   ID_Eigenverbrauch = 83888128;          // in W
                                     //Status
                                  var   ID_Status = 16780032;                  // 0:Off
                                     //Statistik - Tag
                                  var   ID_Ertrag_d = 251658754;               // in Wh
                                  var   ID_Hausverbrauch_d = 251659010;        // in Wh
                                  var   ID_Eigenverbrauch_d = 251659266;       // in Wh
                                  var   ID_Eigenverbrauchsquote_d = 251659278; // in %
                                  var   ID_Autarkiegrad_d = 251659279;         // in %
                                  var   ID_Ertrag_G = 251658753;               // in kWh
                                  var   ID_Hausverbrauch_G = 251659009;        // in kWh
                                  var   ID_Eigenverbrauch_G = 251659265;       // in kWh
                                  var   ID_Eigenverbrauchsquote_G = 251659280; // in %
                                  var   ID_Autarkiegrad_G = 251659281;         // in %
                                  var   ID_Betriebszeit = 251658496;           // in h
                                  var   ID_DC1Spannung = 33555202;             // in V
                                  var   ID_DC1Strom = 33555201;                // in A
                                  var   ID_DC1Leistung = 33555203;             // in W
                                  var   ID_DC2Spannung = 33555458;             // in V
                                  var   ID_DC2Strom = 33555457;                // in A
                                  var   ID_DC2Leistung = 33555459;             // in W
                                  var   ID_DC3Spannung = 33555714;             // in V
                                  var   ID_DC3Strom = 33555713;                // in A
                                  var   ID_DC3Leistung = 33555715;             // in W
                                  var   ID_HausverbrauchSolar = 83886336;      // in W
                                  var   ID_HausverbrauchBatterie = 83886592;   // in W
                                  var   ID_HausverbrauchNetz = 83886848;       // in W
                                  var   ID_HausverbrauchPhase1 = 83887106;     // in W
                                  var   ID_HausverbrauchPhase2 = 83887362;     // in W
                                  var   ID_HausverbrauchPhase3 = 83887618;     // in W
                                  var   ID_NetzAusgangLeistung = 67109120;     // in W
                                  var   ID_NetzFrequenz = 67110400;            // in Hz
                                  var   ID_NetzCosPhi = 67110656;
                                     //Netz Phase 1
                                  var   ID_P1Spannung = 67109378;              // in V
                                  var   ID_P1Strom = 67109377;                 // in A
                                  var   ID_P1Leistung = 67109379;              // in W
                                     //Netz Phase 2
                                  var   ID_P2Spannung = 67109634;              // in V
                                  var   ID_P2Strom = 67109633;                 // in A
                                  var   ID_P2Leistung = 67109635;              // in W
                                     //Netz Phase 3
                                  var   ID_P3Spannung = 67109890;              // in V
                                  var   ID_P3Strom = 67109889;                 // in A
                                  var   ID_P3Leistung = 67109891;              // in W
                                  createState('Solaranlage.Momentanwerte.P3Spannung');
                                  createState('Solaranlage.Momentanwerte.P3Strom');
                                  createState('Solaranlage.Momentanwerte.P3Leistung');
                                  createState('Solaranlage.Momentanwerte.Leistung_String3');
                                  function Piko() {
                                     '&dxsEntries=' + ID_DC2Leistung +
                                     '&dxsEntries=' + ID_P3Spannung +    // 23
                                     '&dxsEntries=' + ID_P3Strom +       // 24
                                     '&dxsEntries=' + ID_DC3Leistung,    //25
                                             Zustand = 'aus';
                                             } else {
                                             setState('Solaranlage.Momentanwerte.P3Spannung', result[23].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.P3Strom', result[24].value || 0, true);
                                             setState('Solaranlage.Momentanwerte.Leistung_String3', result[25].value || 0, true);
                                         } else {
                                  Nun sind die Kringel weg.
                                  Es fehlen die Werte für "Leistung_String3" und "P3Leistung".
                                  Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    //Leistungswerte
                                    Ich hänge noch ....
                                    das var fehlt
                                      muss da tatsächlich jedesmal ein var davor????
                                        dann müsste ich jetzt wissen wie das ARRAY aufgebaut ist und welche Werte da an welcher Position sind.
                                        vielleicht kann @Glasfaser da noch ein log einbauen
                                          MartyBr @Homoran last edited by MartyBr
                                          @Glasfaser
                                          Kann ich mit irgendwas noch helfen?
                                          Die Datenpunkte lösche ich jedesmal, wenn ich Änderungen am Script mache. Aktuell sehen die so aus:
                                          • Glasfaser
                                            @martybr
                                            Ich komme bei mir nicht weiter .Schleife .. muss ein timeout machen bzw. mein ioBroker 😞
                                            331
                                            76444
