    4. Test Tesla-Motors v1.0.0
      tombox @lobomau last edited by
      @lobomau Das wäre super eigentlich sollte er ohne Unterbrechung laufen
      lobomau 1 Reply Last reply Reply Quote 0
      • lobomau
        lobomau @tombox last edited by
        @tombox ich kann schon mal sagen, dass es keine vorherige Aktion gab. Heute morgen um 00:18 Uhr war die Verbindung weg:
        2021-10-06 00:18:24.233 - error: tesla-motors.0 (4106) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-10-06 00:18:24.247 - error: tesla-motors.0 (4106) unhandled promise rejection: url is not defined
        2021-10-06 00:18:24.248 - error: tesla-motors.0 (4106) ReferenceError: url is not defined
        at /opt/iobroker/node_modules/iobroker.tesla-motors/main.js:468:36
        at runMicrotasks ()
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
        at async Teslamotors.checkState (/opt/iobroker/node_modules/iobroker.tesla-motors/main.js:453:16)
        at async /opt/iobroker/node_modules/iobroker.tesla-motors/main.js:304:29
        2021-10-06 00:18:24.249 - error: tesla-motors.0 (4106) url is not defined
        2021-10-06 00:18:24.259 - warn: tesla-motors.0 (4106) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-10-06 00:18:24.269 - warn: javascript.0 (12111) script.js.common.Telegram.Adapter_Tesla_offline: Tesla Adapter ist offline
        2021-10-06 00:18:24.378 - info: host.ioBrokerCT stopInstance system.adapter.tesla-motors.0 (force=false, process=true)
        2021-10-06 00:18:24.389 - info: host.ioBrokerCT stopInstance system.adapter.tesla-motors.0 send kill signal
        2021-10-06 00:18:25.203 - info: host.ioBrokerCT instance system.adapter.tesla-motors.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2021-10-06 00:18:27.841 - info: host.ioBrokerCT instance system.adapter.tesla-motors.0 started with pid 31706
        2021-10-06 00:18:31.069 - info: tesla-motors.0 (31706) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.tesla-motors, node: v12.22.5, js-controller: 3.3.18
        2021-10-06 00:18:31.548 - error: tesla-motors.0 (31706) own token failed
        2021-10-06 00:18:31.549 - error: tesla-motors.0 (31706) Error: Client network socket disconnected before secure TLS connection was established
        2021-10-06 00:18:31.550 - error: tesla-motors.0 (31706) Start relogin in 1min
        2021-10-06 00:18:31.751 - error: tesla-motors.0 (31706) Error: Request failed with status code 403
        2021-10-06 00:18:31.752 - error: tesla-motors.0 (31706) {"error":"invalid_grant","error_description":"Internal server error","error_uri":"https://auth.tesla.com/error/reference/c80b7afc-541d-46b8-b73b-371ad6a85a3d-1633472314123"}
        2021-10-06 00:18:31.753 - error: tesla-motors.0 (31706) Please relogin in the settings and copy a new codeURL
          tombox @lobomau last edited by tombox
          @lobomau @Kasi-m3 Das war sehr hilfreich. Ich habe das mal behoben bitte mal die github version installieren und testen
          lobomau K 2 Replies Last reply Reply Quote 1
          • lobomau
            @tombox schön, dass es vielleicht etwas gebracht hat. Installieren ging schon mal. Wir beobachten...
              Kasi-m3 @tombox last edited by
              @tombox ....nein, ICH habe zu danken, daß Du so schnell hilfst!
              Gleich mal ausprobieren.....
              Beste Grüße
              Kasi
                HolgerCW last edited by HolgerCW
                bin heute gefahren und habe Ihn gerade in diesem Moment auch nochmal per App aufgeweckt. Tür auf zu und so.
                Ich habe festegestellt das ich zwei Ordner ClimateState und ChargeState hatte. Denke das war noch von der vorherigen Instanz die ich upgedatet habe. Die Ordner hiessen Climate_State und Charge_State. habe jetzt ein paar Ordner entfernt und diese sind noch da:
                Habe ich alle Ordner ? Oder fehlt da was ? Hatte auch einen command Ordner den ich gelöscht habe da mit dem nichts steuerbar war.
                Es lässt sich hiermit nicht der Kofferraum hinten oder vorne öffnen ?
                Gruss
                Holger
                J T 2 Replies Last reply Reply Quote 0
                  JoergH @HolgerCW last edited by
                  @holgercw
                  Sieht alles korrekt aus so.
                    tombox @HolgerCW last edited by
                    @holgercw
                    ClimateState
                    ChargeState
                    Tokens
                    können gelöscht werden.
                    Kommt denn ein Fehler wenn ein Befehl nicht funktioniert?
                    J H 2 Replies Last reply Reply Quote 0
                      JoergH @tombox last edited by
                      @tombox
                      Tokens löschen? Ist bei mir auch noch vorhanden mit einer Unmenge an Einträgen drin..??
                        tombox @JoergH last edited by
                        @joergh sorry die werden doch von dem Adapter erstellt aber es ist nicht ganz klar was sie enthalten. Wieviele hast du ca. Dann Filter ich die mal
                          @tombox
                          Sind so 1400 Stück..etwas mehr
                            @joergh Kannst sie ja mal löschen und adapter via github installieren und schauen ob sie wiederkommen
                              @tombox
                              Scheint nun mit der 1.0.4 weg zu sein. Danke.
                                Schimi last edited by
                                Finde den Adapter super 🙂
                                Welcher ist den der aktuelle? Der Link im adapter selbst führt auf eine 404 seite
                                https://github.com/iobroker-community-adapters/ioBroker.tesla-motors
                                oder
                                https://github.com/dbweb-ch/ioBroker.tesla-motors
                                Benutze den Adapter in Kombination mit dem teslalogger.... scheint bisher gut zu funktionieren (Scheinen sich nicht gegenseitig zu stören und das auto aufzuwecken)
                                  JoergH @Schimi last edited by JoergH
                                  @schimi Der Link ist https://github.com/iobroker-community-adapters/ioBroker.tesla-motors.git
                                  auf Github unter "Code" den Link kopieren...
                                    Schimi @JoergH last edited by
                                    @joergh
                                    danke 🙂
                                    Benutze den Adapter aus dem Beta channel.... war nur nicht sicher im fall von Fehlern wo ich es eintrage.... bzw. wenn mal die Readme nen Update bekommt 🙂
                                    z.B. ist das "Update interval in Sekunden. Minimum 10" im Adapter nicht so verständlich... deshalb wollte ich z.B. die Readme anklicken ob da was dazu steht 🙂
                                    Ich lese hier aber mal fleißig mit 🙂
                                      HolgerCW @tombox last edited by
                                      @tombox
                                      Ich habe folgende Button:
                                      Wenn ich door_lock mache oder door_unlock klappt das.
                                      Wenn ich auf acute_trunk-rear klicke dann passiert nichts. Oder muss ich den Kofferraum mit einem anderen Button öffnen ?
                                      Gruss
                                      Holger
                                        @holgercw in der App geht es?
                                          @tombox
                                          Heute habe ich wohl einen Bug entdeckt...Charge current etc. meldet 48 A...?!
                                            @joergh Das sind die daten aus der API es kann aber sein das wenn die daten nicht aktualisiert werden der alte wert angezeigt wird
                                            927
                                            235412
