    4. Victron MPPT smartsolar 75/15 und Liontron LIFEPo4 auslesen?
      Homoran Global Moderator Administrators @panki2 last edited by
      @panki2 sagte in Victron MPPT smartsolar 75/15 und Liontron LIFEPo4 auslesen?:
      da ist proxmox drauf
      VM oder Container?
        Thomas Braun Most Active @panki2 last edited by
        @panki2
        sudo apt update
        apt policy bluez
          panki2 @Homoran last edited by
          @homoran Ich hatte auf den nackten NUC dmals Proxmox nach "Kochrezept" installiert.
            panki2 @Thomas Braun last edited by
            @thomas-braun Sorry, ich bin nicht der linux profi.
            bei apt policy bluez kommt sehr viel Text.
            Auf was muß ich da achten?
            es kommt oft : command not found
              als Code zwischen code-tags hier posten
              P 2 Replies Last reply Reply Quote 0
                @homoran ```
                panki@iobroker-nuc:~$ apt policy bluez
                bluez:
                  Installed: (none)
                  Candidate: 5.50-0ubuntu5.1
                  Version table:
                     5.50-0ubuntu5.1 500
                        500 http://archive.ubuntu.com/ubuntu eoan-updates/main amd64 Packages
                        500 http://archive.ubuntu.com/ubuntu eoan-security/main amd64 Packages
                     5.50-0ubuntu4 500
                        500 http://archive.ubuntu.com/ubuntu eoan/main amd64 Packages
                panki@iobroker-nuc:~$ bluez:
                  Version table:
                     5.50-0ubuntu5.1 500
                     5.50-0ubuntu4 500
                        500 http://archive.ubuntu.com/ubuntu eoan/main amd64 Packagesbluez:: com        mand not found
                panki@iobroker-nuc:~$   Installed: (none)
                -bash: syntax error near unexpected token `none'
                panki@iobroker-nuc:~$   Candidate: 5.50-0ubuntu5.1
                Candidate:: command not found
                panki@iobroker-nuc:~$   Version table:
                Version: command not found
                panki@iobroker-nuc:~$      5.50-0ubuntu5.1 500
                5.50-0ubuntu5.1: command not found
                panki@iobroker-nuc:~$         500 http://archive.ubuntu.com/ubuntu eoan-updates/        main amd64 Packages
                500: command not found
                panki@iobroker-nuc:~$         500 http://archive.ubuntu.com/ubuntu eoan-security        /main amd64 Packages
                panki@iobroker-nuc:~$      5.50-0ubuntu4 500
                5.50-0ubuntu4: command not found
                panki@iobroker-nuc:~$         500 http://archive.ubuntu.com/ubuntu eoan/main amd64 Packages        500: command not found
                  Thomas Braun Most Active @panki2 last edited by Thomas Braun
                  Das kommt, weil du da 'Quatsch' per copy & paste in die Konsole knallst.
                  sudo apt install bluez
                  ubuntu eoan ist schon geraume Zeit EOL. Da solltest du mal auf was lebendiges upgraden. Vorzugsweise LTS-Versionen von ubuntu.
                  Das erklärt auch u. U. den 404 von oben.
                    @thomas-braun Da magst Du Recht haben. Im Netz fand ich halt diesen Befehl mit bluez bzw bluez* mehrfach , als ich nach bluetoothtreiber unter linux installieren suchte . Bei andere Treibern hat es ja bisher auf diese Weise mit "sudo apt install XXX beim Installieren von irgendwelchen fehlenden Treibern geklappt.
                    Wie gesagt, Linux ist nicht mein Gebiet.
                      @thomas-braun said in Victron MPPT smartsolar 75/15 und Liontron LIFEPo4 auslesen?:
                      Um das upgraden hatte ich mich gedrückt, da ich ja nicht die ganze Chose neu installieren möchte.
                      Ich wüsste auch nicht, wie ich dann das ganze iobroker backup wieder einspielen kann.
                      Mit über 70 Lenzen ist man nicht mehr sooo flexibel.
                      Ich kenne das Gefummel, wenn ich mein Forum alle 2 Jahre upgraden musste. Gott sei dank geht das jetzt "automatisch". bis auf die Datensicherungen.
                        @panki2
                        Ich spreche ja auch über den Kram ab Zeile 11. Das ist kein Befehl, das ist falsch kopierter und eingefügter Quatsch. Und mit dem Quatsch kann die Konsole nichts anfangen. Daher die 'Fehlermeldungen'.
                        Hast du den Kram jetzt per
                        installiert bekommen?
                        Dann hast du dich jetzt solange gedrückt, bis es noch 'komplizierter' geworden ist da jetzt wieder runterzuspringen. Neuinstallieren muss man nicht, wenn man da am Ball bleiben würde. Jetzt empfiehlt sich dann aber evtl. doch die Neuinstallation, die du vermeiden wolltest.
                        Man nimmt also die LTS-Versionen von ubuntu und springt dann alle paar Jahre auf das jeweilig aktuelle LTS-Release weiter.
                          @thomas-braun : Der Befehl ging auch nicht. Oben stand ja, dass die Version veraltet ist. Ich war nur nicht mehr ganz hoch gescrollt.
                          Der Iobroker auf dem Nuc hatte ich erst vor 1 Jahr installiert. Dass dann die Version schon EOL ist??
                          OK, ich versuche dann mal weiter, ob es mit einem backup und einem upgrade klappt. Ich hatte nämlich lange gebastelt, bis meine Wetterstation so lief, wie sie soll.
                          Danke mal für die Hinweise.
                            Die Version Eoan ist im Juli 20 abgekündigt worden.
                            War ja auch kein LTS-Release. Diese Versionen sind nur Betas auf dem Weg zur nächsten LongTerm-Version, die dann wieder 5 Jahre Support bekommt. Deswegen installiert man am besten gleich eine LTS.
                              panki2 @Homoran last edited by panki2
                              @homoran Ich wurde von einem Bekannten auf Victron LoRaWan hingewiesen. Irgendwie muss man doch die Daten "abfangen können". der link zu dem LoRaWan
                              und
                              der link wurde mir auch genannt
                              Ich habe auf einem raspi den ble adapter installiert und er funktioniert dort.
                              Notfalls musss ich versuchen, das mit dem von Dir genannten Kabel zumindest bis zum raspi zu bewerkstelligen.
                                Homoran Global Moderator Administrators @panki2 last edited by Homoran
                                das war auch u.a. in dem Link von mir mit möglichen Interfaces
                                Dafür hatte ich diverse Software verlinkt.
                                Habe aber selbst keine Ahnung was und wie es gehen könnte
                                https://www.victronenergy.de/accessories
                                https://www.victronenergy.de/panel-systems-remote-monitoring
                                  @homoran Ok, das sind ja alles Victronstandardgeräte.
                                  Ich wollte das halt kleiner und unauffälliger machen. Ich hatte mit einem node-mcu meine smartmeterdaten via wlan mqtt an den iobroker gesandt und kann mich vage erinnern, dass es für die node mcu eine "eierlegende Wollmilchsau-firmware" gibt, wo fast "alles" geht. Ich finde nur den link nicht mehr, wo das alles beschrieben war. Ich dachte damals ja auch, dass ich nach dem smartmeter nichts mehr weiter installieren werde. (Fehlanzeige)
                                  Ich habe noch so eine node mcu rumliegen und da sind auch pins für TTL. Wenn ich den smartsolar daran "richtig" anschließe, müssten die daten ja dann per wlan "irgedenwie" im iobroker ankommen. Das ist nun so meine Vorstellung.
                                  Nur , es hängt gerade am "irgendwie".
                                    Skywalker110 last edited by
                                    Hallo zusammen läuft das System jetzt ?
                                    Ich werde mir bald einen Victron-Energy SmartSolar MPPT 100/30 bestellen.
                                    Nochmals zu meinem Verständnis es gibt keine Möglichkeit diesen per Modbus direkt anzufahren ?
                                    Ich habe auch einen Nuc.
                                    Victron und der Nuc sind aber 20 Meter auseinander .
                                    Was wäre die beste Lösung um an die Daten zu kommen ?
                                    Ich habe nur dieses Gerät von Victron daher finde ich es teuer und nicht lohnenswert extra dafür die GX Serie mit einzubinden ...
                                    Wäre interessiert an Eure Meinungen, oder ob grundsätzlich ein anderer Laderegler einfacher wäre um IOBroker mit Daten zu füttern .
                                    Es ist eine 700 Watt PV mit Batterie 100AH 24 Volt
                                    WR ist ein Hoymiles
                                    Vielen Dank
                                      Thomas Braun Most Active @Skywalker110 last edited by Thomas Braun
                                      @skywalker110 sagte in Victron MPPT smartsolar 75/15 und Liontron LIFEPo4 auslesen?:
                                      WR ist ein Hoymiles
                                      Ist da nicht openDTU oder Ahoy was für dich?
                                      Edit: Das mit der Batterie hatte ich übersehen...
                                        Homoran Global Moderator Administrators @Skywalker110 last edited by
                                        welcher genau?
                                        der hat doch einen ve-direct Anschluss. Dazu gibt es einen Adapter.
                                        Ralla66 S 2 Replies Last reply Reply Quote 0
                                        • Ralla66
                                          Ralla66 Most Active @Homoran last edited by
                                          mal bitte kurz ein Link zum Adapter, Danke
                                            Homoran Global Moderator Administrators @Ralla66 last edited by
                                            @ralla66 sagte in Victron MPPT smartsolar 75/15 und Liontron LIFEPo4 auslesen?:
                                            https://github.com/DrozmotiX/ioBroker.vedirect
                                            Ralla66 1 Reply Last reply Reply Quote 0
                                            ble adapter liontron victron
                                            6312
