    4. ESPHome: Wandfeuchte messen-Schimmel vermeiden+Anwendungen
      klassisch Most Active last edited by klassisch
      So, verstehe diese Form von embedded JS nicht wirklich und habe es jetzt mal mäßig quick aber sehr dirty umgeschrieben
      Edit: Quelle des Algo: http://www.TH80.de/
      /*  Calculate Humidity and moisture data **********************
       Calculations of Humidity and water content in air
       modifications of http://www.TH80.de/
      Purpose:
      * Input values:
        ** Temp: temperaure of air
        ** Hrel: humidity in air at the same location (measured by the same sensor) SHT35 or SHT85 recommende for precise data
        ** T_wall: wall temperature. measured e.g. by a contact thermometer. To minimize calculation errors, it is reommended, to locate the T/H sensor close to the wall and contact T-sensor
      * Output data:
        **  TH70 Air: temperature to acieve a relative humidity of 70%
        **  TH80 Air: temperature to acieve a relative humidity of 80%
        **  TH90 Air: temperature to acieve a relative humidity of 90%
        **  T_dew Air: temperature to achieve a relative humidity of 100% (dew point, TH100)
        **  H_abs Mass: of water in grams in 1 m³ of air
        **  H_standard: Value of the relative humidity @20°C (standardized humidity)
        **  P_vaporSatur: Current water vapor saturation pressure in Pa
        **  P_vapor: Current water vapor pressure in Pa
        **  H_wall: Current wall moisture: relative humidty @ T-wall.
        **  P_vaporSaturWall: vapor saturation pressure at T_wall
      const debugLogOn = true;
      const nameOfThisScript = name.split('.')[name.split('.').length - 1];
      // test Variables
      var Temp = 14;
      var Hrel = 8;
      var T_wall = 12;
      //=20.13°C humidity=56.55%
      // temperature=20.52°C humidity=55.44%
      // end test variables
      var Hrel = Hrel
      var P_vaporSatur;
      var P_vaporSaturWall;
      var P_vapor;
      var T_dew;
      var TH70;
      var TH80;
      var TH90;
      var H_abs;
      var H_standard;
      var H_wall;
      var P_vaporSaturRound;
      var P_vaporRound;
      var T_dewRound;
      var TH70Round;
      var	TH80Round;
      var	TH90Round;
      var H_absRound;
      var H_standardRound;
      var H_wallRound;
      function calculateHumidityValues() {
      		P_vaporSatur = 611*Math.pow(10,7.5*Temp/(237.3+Temp));
      		P_vaporSaturWall = 611*Math.pow(10,7.5*T_wall/(237.3+T_wall));
      		P_vapor = Hrel/100*P_vaporSatur;
      		T_dew = 237.3*Math.log(P_vapor/610.78)/Math.log(10)/(7.5-Math.log(P_vapor/610.78)/Math.log(10));
      		TH70 = 237.3*Math.log(P_vapor/(610.78*0.7))/Math.log(10)/(7.5-Math.log(P_vapor/(610.78*0.7))/Math.log(10));
      		TH80 = 237.3*Math.log(P_vapor/(610.78*0.8))/Math.log(10)/(7.5-Math.log(P_vapor/(610.78*0.8))/Math.log(10));
      		TH90 = 237.3*Math.log(P_vapor/(610.78*0.9))/Math.log(10)/(7.5-Math.log(P_vapor/(610.78*0.9))/Math.log(10));
      		H_abs = 1000*18.016/8314.3*P_vapor/(Temp+273.15);
      		H_standard = P_vaporSatur*Hrel/2340;
      		H_wall = (P_vapor / P_vaporSaturWall)*100;
      		P_vaporSaturRound = Math.round(P_vaporSatur);
      		P_vaporRound = Math.round(P_vapor);
      		T_dewRound = Math.round(T_dew*100)/100;
      		TH70Round = Math.round(TH70*100)/100;
      		TH80Round = Math.round(TH80*100)/100;
      		TH90Round = Math.round(TH90*100)/100;
      		H_absRound = Math.round(H_abs*100)/100;
      		H_standardRound = Math.round(H_standard*100)/100;
         		H_wallRound = Math.round(H_wall*100)/100;
      // start calculation using the predefined data
         calculateHumidityValues();
      // output
         if(debugLogOn)console.log('Temp: ' +Temp+';  Hrel: ' + Hrel + ';  T_wall: ' + T_wall);
         if(debugLogOn)console.log('T bei 70% ' + TH70Round);
         if(debugLogOn)console.log('T bei 80% ' + TH80Round);
         if(debugLogOn)console.log('T bei 90% ' + TH90Round);
         if(debugLogOn)console.log('T_dewRound: ' + T_dewRound);
         if(debugLogOn)console.log('Habs: ' + H_absRound);
         if(debugLogOn)console.log('H_standard ' + H_standardRound);
         if(debugLogOn)console.log('Saettigungsdampfdruck: ' + P_vaporSaturRound);
         if(debugLogOn)console.log('Partialdruck: ' + P_vaporRound);
         if(debugLogOn)console.log('H_wall: ' + H_wallRound);
      //end script
      Schätze mal, daß der PWM Dimmer um 100Hz hat.
      • OpenSourceNomad
        OpenSourceNomad Most Active @Homoran last edited by OpenSourceNomad
        @homoran said in ESPHome: Wandfeuchte messen - Schimmel vermeiden:
        bestellen mache ich aus Prinzip nur hier
        Wenn du bereits bist ein vielfaches zu zahlen damit das (immer) in fern Ost produzierte Teil einen extra Zwischenstopp in Bayern einlegt kannst du hier ein mosfet board (ohne esp!) für 5€ erstehen. 💰
        Zum Vergleich direkt aus dem Erzeugerland:
        Deine Konsequenz die (noch) existieren Zwischenhändler zu subventionieren und damit das Sterben zu verlangsamen finde ich sehr altruistisch.
        Ich habe nie Verstanden welchen Mehrwert ich habe von einem Zwischenhändler für das identische (⚠) Produkt mehr zu zahlen. Wenn irgendwie Möglich kaufe ich immer direkt vom Produzenten.
        Ist der hier
        https://de.elv.com/homematic-led-funk-dimmer-1-fach-12-24v-pwm-hm-lc-dim1pwm-cv-fuer-smart-home-hausautomation-099444
        Habe da keine Frequenz gefunden
        Im Forum berichtet ein Kunde von einem erkennbaren 200Hz flimmern
        ELV selber dazu:
        der Homematic PWM-Dimmer hat eine Ausgangsfrequenz von ca. 400 Hz. Dieses reicht in der Regel völlig aus, da Flimmern ab 200 Hz vom Menschen normalerweise nicht mehr wahrgenommen werden kann.
        Von den 60 Euronen für das Gerät waren wohl nach Personalkosten (und Gewinn) nur noch 2,5€ pro Stück über um die Hardware aus China einzukaufen (vorausgesetzt die Geräte werden überhaupt in DE zusammengeschraubt) 😬
          Homoran Global Moderator Administrators @klassisch last edited by
          @klassisch sagte in ESPHome: Wandfeuchte messen - Schimmel vermeiden:
          Danke erstmal dafür, setze ich nachher mal um
          @opensourcenomad sagte in ESPHome: Wandfeuchte messen - Schimmel vermeiden:
          so bin ich halt.
          Habe davon zuviel im Fachhandel erlebt, wo es inzwischen nur noch sehr schwer ist Händler zu finden.
          Herrn Bezos möchte ich nicht unbedingt unterstützen.
          Danke dafür!
            Homoran Global Moderator Administrators @OpenSourceNomad last edited by
            Werden sie, und zwar von mir
              ich hab es versucht noch dirtier zu machen:
              muss da bei der ID noch irgendwo ein .val oder so rein?
                klassisch Most Active @Homoran last edited by
                @homoran var Temp = getState('DeineID').val;
                  getState
                  Danke - läuft!
                  19:35:07.082	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: Taupunkt: 10.548477384785869
                  19:35:07.083	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: Saettigungsdampfdruck: 2090.4541817975487
                  19:35:07.083	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: Partialdruck: 1275.1770508965046
                  19:35:07.083	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: Habs: 9.484498607491766
                  19:35:07.083	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: T bei 80% 14.182271687551786
                  19:35:07.083	info	javascript.1 (6588) script.js.Wetter_und_Klima.Werkstatt_TP80: T bei 70% 16.064102027198793
                  dann will ich mal sehen, ob ich damit noch etwas meine js-Kenntnisse aufbessern kann. (z.B. DP anlegen und befüllen)
                    @homoran Anlegen erst mal manuell über Admin. Beschreiben via
                    setState('DeineId',variable);
                      @klassisch wollte ich doch machen 😢
                      DANKE!
                      was ist denn habs?
                      die Werte, die dabei rauskommen passen nicht zum Raumklima Skript.
                      kann es z.B. sein, dass hier g/Cubicmeter und nicht g/kg gerechnet wird
                      hier kommt 9,48 heraus, beim Lüftungsskript 7,6
                        @homoran Habs ist die Absolute Feuchte in g/m³. Die bevorzugte Einheit, weil man da den Luftdruck nicht braucht.
                          Homoran Global Moderator Administrators @klassisch last edited by Homoran
                          @klassisch
                          Nochmals Danke für deine Unterstützung.
                          Hab es jetzt implementiert bekommen und hoffentlich auch den Trigger korrekt gesetzt.
                          Datenpunkte werden korrekt gefüllt und den offset des Raumsensors ("kalibriert" mit den neuen Senosren) hab ich auch drin. Werte passen jetzt mit dem Raumklima übereinander.
                          Jetzt wird es langsam unübersichtlich
                          Ausschnitt Werkstatt:
                          Der aw 70 liegt aber verdammt dicht an der Wandtemperatur.
                          Da muss ich mal mein Entfeuchter/Heizprogramm nochmal durchdenken.
                          EDIT:
                          @klassisch
                          hier mein Machwerk:
                          // Luftfeuchteberechnungen
                          // modifiziert nach https://www.pb-schilling.de/baubiologie/luftfeuchte-rechner/
                          // Testvariablen
                          var Temp = getState('hm-rpc.0.JEQ0046663.1.TEMPERATURE').val/*Klima Werkstatt:1 TEMPERATURE*/;
                          var Hrel = (getState('hm-rpc.0.JEQ0046663.1.HUMIDITY').val)-2.5/*Klima Werkstatt:1 HUMIDITY*/;
                          // end Testvariablen
                          Luftfeuchteberechnungen(Temp,Hrel);
                          function Luftfeuchteberechnungen(myTemp,myHrel){
                            Luftfeuchtevorbereitung(myTemp, myHrel);
                            taupunktTemperatur();
                            //if(debugLogOn)console.log('Taupunkt: ' + taupunktTemperatur());
                            wasserdampfSaettingungsdruck();
                            //if(debugLogOn)console.log('Saettigungsdampfdruck: ' + wasserdampfSaettingungsdruck());
                            wasserdampfTeildruck();
                            //if(debugLogOn)console.log('Partialdruck: ' + wasserdampfTeildruck());
                            wassergehaltLuft();
                            //if(debugLogOn)console.log('Habs: ' + wassergehaltLuft());
                            awWert80();
                            //if(debugLogOn)console.log('T bei 80% ' + awWert80());
                            awWert70();
                            //if(debugLogOn)console.log('T bei 70% ' + awWert70());
                             function Luftfeuchtevorbereitung( theta, phi) {
                               this.theta = theta;
                               this.phi = phi;
                               if (this.phi > 1) {
                                 this.phi = this.phi / 100;
                               if (this.phi > 1) {
                                 this.phi = 1;
                             function taupunktTemperatur() {
                               return Math.pow(this.phi, 0.1247) * (109.8 + this.theta) - 109.8;
                             function wasserdampfSaettingungsdruck() {
                               if (this.theta > 0) {
                                 return 288.68 * Math.pow(1.098 + this.theta / 100, 8.02);
                               } else {
                                 return 4.689 * Math.pow(1.486 + this.theta / 100, 12.3);
                             function wasserdampfTeildruck() {
                               return this.phi * wasserdampfSaettingungsdruck();
                             function wassergehaltLuft() {
                               return 216.7 * wasserdampfTeildruck() * 0.01 / (this.theta + 273.15);
                             function awWert80() {
                               var oben, unten;
                               oben = 237.3 * Math.log(611 * Math.pow(10, 7.5 * this.theta / (237.3 + this.theta) * this.phi) / 488.62) / Math.LN10;
                               unten = 7.5 - Math.log(611 * Math.pow(10, 7.5 * this.theta / (237.3 + this.theta) * this.phi) / 488.62) / Math.LN10;
                               return oben / unten;
                             function awWert70() {
                               var oben, unten;
                               oben = 237.8 * Math.log(wasserdampfTeildruck() / (610.78 * 0.7)) / Math.LN10;
                               unten = 7.5 - Math.log(wasserdampfTeildruck() / (610.78 * 0.7)) / Math.LN10;
                          setState('javascript.1.Raumklima.Raum.Werkstatt.DETAILS.aw70',Math.round(awWert70()*10)/10, true);
                          setState('javascript.1.Raumklima.Raum.Werkstatt.DETAILS.aw80',Math.round(awWert80()*10)/10, true);
                          on('javascript.1.Raumklima.Raum.Werkstatt.Taupunkt',Luftfeuchteberechnungen); // triggert bei Wertänderung;
                          //end script
                            @klassisch
                            ich brauche doch nochmal deine Hilfe.
                            Entweder ich habe den Trigger nicht richtig gesetzt, oder da ist noch was falsch.
                            beim Scriptstart klappt alles, aber entweder die Triggersyntax passt nicht, was mich nicht wundern würde, oder ich rufe die falsche Funktion auf, oder in der Funktion fehlt was (vobereitung()).
                              @homoran ich sehe nichts
                                keinen Fehler oder nicht das Skript im Spoiler?
                                  klassisch Most Active @Homoran last edited by klassisch
                                  @homoran So, habe jetzt den Spoiler gefunden
                                  on({id: 'javascript.1.Raumklima.Raum.Werkstatt.Taupunkt', change: "any"}, function() { // löst bei jeder Aktualisierung aus
                                   Hrel = getState('hm-rpc.0.JEQ0046663.1.HUMIDITY').val - 2.5/*Klima Werkstatt:1 HUMIDITY*/;
                                    @klassisch danke!
                                    und ich dachte ich hätte etwas mehr js gelernt 😢
                                      @homoran Ich kratze da auch nur an der Oberfläche. Und gewisse Dinge plappere ich nach wie ein Papagei, ohne mich mal grundegend mit der Struktur beschäftigt zu haben. Das Triggern durch "on" gehört dazu
                                      Warum triggerst Du eigentlich auf den Taupunkt, der ja bereits ein verarbeiteter Wert ist und nicht auf einen direkten Sensorwert wie z.B.
                                        weil ich faul bin.
                                        die Änderung des Taupunktes beinhalter mögliche Änderungen von Temperatur und/oder Feuchte.
                                        Damit erschlage ich beides (denke ich zumindest)
                                        Das mit dem Papagei ist genau mein Thema. Aber ich muss es verstanden haben um nicht immer wieder irgendwo nachsehen zu müssen.
                                        Deswegen arbeite ich mit Blockly, weil ich nichtmal die Syntax hinbekomme.
                                        Inzwischen hat sich der Wert zumindest einmal geändert und getriggert!
                                          @homoran sagte in ESPHome: Wandfeuchte messen - Schimmel vermeiden:
                                          Der HM-Sensor wird wohl eh beides gleichzeitig einliefern, vermute ich.
                                          Den Anspruch habe ich nicht an mich. Habe mir einen Spickzettel in Notepad++ aufgemacht, wo die häufigsten Dinge als Beispiele drin stehen und ein paar Links zur Doku.
                                          Für Grobschlosser-Programmierung braucht man gar nicht sooo viel.
                                          Und bei den recht seltenen und langsamen Brechnungen muß ich nicht wirklich optimieren. Habe ja nicht den Anspruch, Adapter-Entwickler zu sein.
                                          Habe mir auch deshalb ein i5-6300U Notebook, der nebenbei auch ioBroker macht, für 160 EUR incl. Windows gegönnt.
                                          Ich bekomme mit "Rules" gar nichts hin. Nicht gleich kapiert, sofort verworfen.
                                          Blockly hat den Spickzettel eingebaut. Das ist praktisch. Aber ich komme mit dem graphischen Zeug immer an die Grenzen. Das wird bei mir recht schnell unübersichtlich.
                                          Deshalb habe ich mich auf JS festgelegt. Da findet man auch viele Beispiele bei selfhtml und mediaevent.de
                                          Das sieht doch nach einem Erfolg aus! Glückwunsch!
                                          Man kann ja mit dem console.log notfalls mitverfolgen, was er tut.
                                          Dazu habe ich die constante debugLogOn eingeführt. Während der Entwicklung setze ich die auf true und wenn alles läuft auf false.
                                            ist großteils deine Leistung. ich hab nur die Rundung und die states eingebaut.
                                            Das mit dem Trigger ärgert mich jetzt.
                                            also entweder alles notwendige in einer Funktion (z.B. main()) und diese im Trigger aufrufen, oder im Zrigger innerhalb einer eigenen Funktion (??) alle notwendigen Schritte abarbeiten? Wobei ich diese Syntax nicht auf Anhieb zusammenbekomme.
                                            Irgendwann in diesem Leben will ich js können, so!
                                            und ich Idiot kommentiere sie aus, weil ich das nicht erkannt habe.
                                            13105
