    4. Kann Adapter nicht installieren
      stenmic last edited by
      beim Versuch den "sainlogic" Adapter zu installieren kommt folgender Fehler.
      (Hatte ich aber die Tage aber auch schon beim HS100)
      $ ./iobroker add sainlogic 0 --host ioBroker-Master
      NPM version: 6.14.14
      npm install iobroker.sainlogic@0.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ETARGET
      npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-08-04T04_19_47_549Z-debug.log
      ERROR: host.ioBroker-Master Cannot install iobroker.sainlogic@0.7.2: 1
      ERROR: process exited with code 25
      log:
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli   '/usr/bin/node',
      1 verbose cli   '/usr/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker.sainlogic@0.7.2',
      1 verbose cli   '--loglevel',
      1 verbose cli   'error',
      1 verbose cli   '--prefix',
      1 verbose cli   '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.14
      3 info using node@v12.22.4
      4 verbose npm-session 9ca16e53a6913013
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 304 https://registry.npmjs.org/iobroker.sainlogic 950ms (from cache)
      8 silly registry:manifest no matching version for iobroker.sainlogic@0.7.2 in the cache. Forcing revalidation.
      9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 961ms
      10 silly fetchPackageMetaData error for iobroker.sainlogic@0.7.2 No matching version found for iobroker.sainlogic@0.7.2.
      11 timing stage:rollbackFailedOptional Completed in 1ms
      12 timing stage:runTopLevelLifecycles Completed in 5356ms
      13 verbose type version
      14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.7.2.
      14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
      14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
      14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
      14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
      14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
      14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
      14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
      14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
      14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
      14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
      14 verbose stack     at processImmediate (internal/timers.js:461:21)
      15 verbose cwd /opt/iobroker
      16 verbose Linux 4.19.0-17-amd64
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.7.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
      18 verbose node v12.22.4
      19 verbose npm  v6.14.14
      20 error code ETARGET
      21 error notarget No matching version found for iobroker.sainlogic@0.7.2.
      22 error notarget In most cases you or one of your dependencies are requesting
      22 error notarget a package version that doesn't exist.
      23 verbose exit [ 1, true ]
      Jemand ne Idee?
      • Glasfaser
        Glasfaser @stenmic last edited by Glasfaser
        @stenmic sagte in Kann Adapter nicht installieren:
        Jemand ne Idee?
        Ja , im Thread schauen :
        https://forum.iobroker.net/topic/33611/test-adapter-iobroker-sainlogic-v0-6-x-github-latest/199?_=1628052607158
        EDIT:
        siehe auch GitHub , im Issues
        https://github.com/phifogg/ioBroker.sainlogic/issues/91
        Fogg 1 Reply Last reply Reply Quote 0
        • Fogg
          Fogg @Glasfaser last edited by
          @glasfaser Hab heute eine neue Version frei gegeben... Repo ist aktualisiert, irgendwie will es trotzdem nicht. Ich warte drauf dass mir jemand sagt was falsch ist...
          • Glasfaser
            Glasfaser @Fogg last edited by
            @fogg sagte in Kann Adapter nicht installieren:
            was meinst du , ob Fehler vorhanden sind ?
            2021-10-07 20:39:38.630 - error: sainlogic.0 (11685) DB closed
            2021-10-07 20:39:38.632 - error: sainlogic.0 (11685) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) unhandled promise rejection: DB closed
            2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) Error: DB closed
            Fogg Glasfaser 2 Replies Last reply Reply Quote 0
            • Fogg
              @glasfaser Nein, ich kriege diese Meldung in meinem ioB wenn ich ein update machen will:
              npm install iobroker.sainlogic@0.7.3 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.3.
              Thomas Braun Glasfaser Fabio 3 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Fogg last edited by Thomas Braun
                @fogg
                Bei mir taucht der auch (noch?) nicht im latest-Repo auf:
                echad@chet:~ $ iobroker update
                Used repository: live-beta
                hash unchanged, use cached sources
                update done
                Adapter    "sainlogic"     : 0.6.1    , installed 0.7.2
                [Edit:]
                Oh...
                echad@chet:~ $ iobroker upgrade sainlogic@0.7.3
                This upgrade of "sainlogic" will introduce the following changes:
                -> 0.7.3:
                Security fixes in dependencies, Travis pipeline update
                Would you like to upgrade sainlogic from @0.7.2 to @0.7.3 now? [(y)es, (n)o]: y
                Update sainlogic from @0.7.2 to @0.7.3
                NPM version: 7.24.0
                npm ERR!     /home/iobroker/.npm/_logs/2021-10-07T21_02_35_619Z-debug.log
                upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                Update "system.adapter.sainlogic.0"
                upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                Adapter "sainlogic" updated
                • Glasfaser
                  Keine Ahnung , habe ihn ohne Probleme installiert ... , nur kommen dann andere Fehlermeldungen .
                  Siehe auch Screenshot oben .
                  Habe auch dir hier geantwortet :
                  https://forum.iobroker.net/topic/48293/adapter-version-wird-nicht-gefunden
                    Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                    @glasfaser
                    Regulär im Repo drin?
                    iobroker update -i
                    zeigt mir noch die 0.6.1 als verfügbar an.
                    Edith: Ah, stable zeigt 0.7.3, latest 0.6.1.
                    Aber auch aus stable kann ich das nicht ziehen. No target, wie oben schon gepostet.
                    • Fabio
                      Fabio @Fogg last edited by Fabio
                      @fogg also ich kann die Version 0.7.3 auch nicht installieren. Bekomme den selben Fehler.
                      Wenn ich aber über die Katze gehe dann kann ich Version 0.7.3 ohne Fehler installieren.
                      Es sieht so aus als ob die neue Version nicht am richtigen Platz liegt.
                      • Fogg
                        Fogg @Fabio last edited by
                        @fa-bio Ja genau, darum gehts ja 😄
                        Ich weiss nicht wo ich den sonst hinlegen soll....
                        Fabio 1 Reply Last reply Reply Quote 0
                        • Fogg
                          Fogg @Thomas Braun last edited by
                          iobroker update -i
                          Im Latest wird soweit ich das sehe keine Version angegeben. Wo er die 0.6.1 hernimmt weiss ich nicht 🤷
                          • Fabio
                            @fogg es tut mir leid ich würde dir ja sehr gerne helfen aber ich habe echt keine Ahnung. Ich hoffe jemand kann helfen.
                            • Fogg
                              Ich glaube ich weiss woran es liegt... ich habe das ganze noch nicht mit npm publish freigegeben. Da suche ich noch wie das geht...
                              • Fogg
                                Fogg last edited by
                                Gefunden.... ein login hat gefehlt. Jetzt ist 0.7.3 komplett verfügbar. Puh.. was für eine Geburt 😄
                                • Glasfaser
                                  Glasfaser @Glasfaser last edited by
                                  @Fogg
                                  @glasfaser sagte in Kann Adapter nicht installieren:
                                  Und was ist mit dem Fehler !?
                                  • Fogg
                                    Fogg @Glasfaser last edited by Fogg
                                    @glasfaser said in Kann Adapter nicht installieren:
                                    @Fogg
                                    Und was ist mit dem Fehler !?`
                                    Die sehe ich bei mir nicht. Welche node.js und js.controller Version hast Du?
                                    • Fabio
                                      @fogg Super gut gemacht.👍 😊
                                      • Glasfaser
                                        @fogg
                                        v14.17.6
                                        v14.17.6
                                        6.14.15
                                        3.3.18
                                        • Fogg
                                          @fogg
                                          v14.17.6
                                          v14.17.6
                                          6.14.15
                                          3.3.18
                                          Hm.. ich bin hier:
                                          NODE.JS: V13.14.0
                                          NPM: 6.14.5
                                          JSControler: 3.3.18
                                          Könnte quasi das Node-js sein. Aber sicher bin ich mir da nicht.
                                          • Glasfaser
                                            V13.14.0
                                            Das ist aber eine ungerade Version
                                            Node.js Versions-Anforderungen Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand bereits mit Node.js 16.x arbeiten möchte, dann bitte im Moment AUSSCHLIESSLICH mit npm 6 !! (Bei npm 7 gibt es noch Probleme mit GitHub Installs bei einigen Adaptern)
                                            1479
