    4. CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB
      Digi-Bit last edited by
      ich habe mir einen Zigbee stick geholt und versuch den seit 4 Stunden einzubinden.
      Habe hier viel gelesen und auch woanders mir Infos versucht zu besorgen.
      Ich habe jetzt den Adapter 1.6.4 installiert wo einige Fehlermeldungen verschwunden sind aber so richtig starten will der immer noch nicht.
      zigbee.0
         2021-10-08 09:53:44.386	error	Error herdsman start
      zigbee.0
         2021-10-08 09:53:44.385	error	Failed to start Zigbee
      zigbee.0
         2021-10-08 09:53:44.384	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
         2021-10-08 09:53:44.173	info	Installed Version: ioBroker/ioBroker.zigbee
      zigbee.0
         2021-10-08 09:53:44.135	info	Starting Zigbee npm ...
      zigbee.0
         2021-10-08 09:53:44.133	info	Try to reconnect. 1 attempts left
      zigbee.0
         2021-10-08 09:53:34.131	error	Error herdsman start
      zigbee.0
         2021-10-08 09:53:34.130	error	Failed to start Zigbee
      zigbee.0
         2021-10-08 09:53:34.128	error	Starting zigbee-herdsman problem : "AREQ - ZDO - stateChangeInd after 60000ms"
      zigbee.0
         2021-10-08 09:52:31.473	info	Installed Version: ioBroker/ioBroker.zigbee
      zigbee.0
         2021-10-08 09:52:31.004	info	Starting Zigbee npm ...
      zigbee.0
         2021-10-08 09:52:30.905	info	starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.18
      zigbee.0
         2021-10-08 09:52:30.880	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
      zigbee.0
         2021-10-08 09:52:25.086	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
         2021-10-08 09:52:25.085	info	terminating
      zigbee.0
         2021-10-08 09:52:24.847	info	Zigbee: disabling joining new devices.
      zigbee.0
         2021-10-08 09:52:24.843	info	cleaned everything up...
      zigbee.0
         2021-10-08 09:52:24.841	info	Got terminate signal TERMINATE_YOURSELF
      Kann mir da einer weiter helfen damit die letzte grüner Lampe auch grün wird?
      p.s. ich habe auch eine Hui und eine Ikea Gatway aber die waren beide aus bei der installation.
      mfg
        dimaiv @Digi-Bit last edited by dimaiv
        @digi-bit sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
        mfg
        1. Verkäufer kontaktieren?
        2. Mit einem Stift grün bemalen?
        3. Oder die Suchfunktion hier im Forum benutzen.
          adapter version ist schon mal genannt.. aber wo steckt der drin ??
            Digi-Bit @dimaiv last edited by
            @dimaiv sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
            mfg
            hab ich auch schon aber das dauert wohl ....
            1. Mit einem Stift grün bemalen?
            ist blöd auf den monitor .........^^
            50. Oder die Suchfunktion hier im Forum benutzen.
            habe ich 2 oder 3 stunden lang.....
            ich find da aber nix passendes ;
            Zaunpfahl da ? 😵
            mfg
              Digi-Bit @arteck last edited by Digi-Bit
              @arteck sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
              im Usb Port vom raspberry pi unten links ^^
              ttyACM0
              pi@raspberrypi4pi:~ $ ls -l /dev/serial/by-id
              insgesamt 0
              lrwxrwxrwx 1 root root 13 Okt 8 09:29 usb-Texas_Instruments_TI_CC2531_USB_CDC__ _0X00124B0014D9038F-if00 -> ../../ttyACM0
                @digi-bit
                Und was ist in Einstellungen beim Zigbee Adapter eingetragen?
                  @digi-bit
                  dies hier
                    @digi-bit bist sicher das der CC2531 ge'flasht ist ?
                      öhmmmmmmm, najaaaaaaaa, laut beschreibung schon
                      CC2531 Zigbee USB Stick
                      vorinstalliert mit neuster Firmware von Koenkk
                      sofort nutzbar mit ioBroker, openHAB, FHEM und zigbee2mqtt
                      kein Zusatzgerät erforderlich
                      im stabilen Gehäuse zum Schutz der Elektroni
                      Produktinformation
                      Verpackungsabmessungen ‏ : ‎ 8.2 x 5.1 x 0.5 cm; 10 Gramm
                      Im Angebot von Amazon.de seit ‏ : ‎ 8. September 2020
                      Hersteller ‏ : ‎ ITSTUFF
                      ASIN ‏ : ‎ B08L21T681
                      Herstellerreferenz ‏ : ‎ CC2531-CASE
                      das ist der hier wenn man den Link posten darf
                      https://www.amazon.de/gp/product/B08L21T681/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                      kann ich das selber irgend wo auslesen ?
                      mfg
                      Post740.pdf
                      ps.s der zettel war bei
                        Digi-Bit @Digi-Bit last edited by
                        hi....
                        er rennt......
                        Hab bei Amazon nach anderen Sticks gesucht......
                        Irgend wo stand das einer auch Probs hatte und eine USB verlängerung genommen hat.
                        Zack, geht....
                        trotzdem danke für die versuchte hilf !
                        mfg
                        zigbee-stick zigbee2mqtt und zigbee
                        443
