    4. Kann Adapter nicht installieren
    • Glasfaser
      Glasfaser @Fogg last edited by
      @fogg sagte in Kann Adapter nicht installieren:
      . Ich warte drauf dass mir jemand sagt was falsch ist...
      was meinst du , ob Fehler vorhanden sind ?
      2021-10-07 20:39:38.630 - error: sainlogic.0 (11685) DB closed
      2021-10-07 20:39:38.632 - error: sainlogic.0 (11685) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) unhandled promise rejection: DB closed
      2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) Error: DB closed
      Fogg Glasfaser 2 Replies Last reply Reply Quote 0
      • Fogg
        Fogg @Glasfaser last edited by
        @glasfaser Nein, ich kriege diese Meldung in meinem ioB wenn ich ein update machen will:
        npm install iobroker.sainlogic@0.7.3 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code ETARGET
        npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.3.
        npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
        Thomas Braun Glasfaser Fabio 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Fogg last edited by Thomas Braun
          @fogg
          Bei mir taucht der auch (noch?) nicht im latest-Repo auf:
          echad@chet:~ $ iobroker update
          Used repository: live-beta
          hash unchanged, use cached sources
          update done
          Adapter    "sainlogic"     : 0.6.1    , installed 0.7.2
          [Edit:]
          Oh...
          echad@chet:~ $ iobroker upgrade sainlogic@0.7.3
          This upgrade of "sainlogic" will introduce the following changes:
          -> 0.7.3:
          Security fixes in dependencies, Travis pipeline update
          Would you like to upgrade sainlogic from @0.7.2 to @0.7.3 now? [(y)es, (n)o]: y
          Update sainlogic from @0.7.2 to @0.7.3
          NPM version: 7.24.0
          npm ERR!     /home/iobroker/.npm/_logs/2021-10-07T21_02_35_619Z-debug.log
          upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
          Update "system.adapter.sainlogic.0"
          upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
          upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
          upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
          upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
          Adapter "sainlogic" updated
          • Glasfaser
            Keine Ahnung , habe ihn ohne Probleme installiert ... , nur kommen dann andere Fehlermeldungen .
            Siehe auch Screenshot oben .
            Habe auch dir hier geantwortet :
            https://forum.iobroker.net/topic/48293/adapter-version-wird-nicht-gefunden
              Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
              @glasfaser
              Regulär im Repo drin?
              iobroker update -i
              zeigt mir noch die 0.6.1 als verfügbar an.
              Edith: Ah, stable zeigt 0.7.3, latest 0.6.1.
              Aber auch aus stable kann ich das nicht ziehen. No target, wie oben schon gepostet.
              Fogg 1 Reply Last reply Reply Quote 0
              • Fabio
                Fabio @Fogg last edited by Fabio
                @fogg also ich kann die Version 0.7.3 auch nicht installieren. Bekomme den selben Fehler.
                Wenn ich aber über die Katze gehe dann kann ich Version 0.7.3 ohne Fehler installieren.
                Es sieht so aus als ob die neue Version nicht am richtigen Platz liegt.
                • Fogg
                  Fogg @Fabio last edited by
                  @fa-bio Ja genau, darum gehts ja 😄
                  Ich weiss nicht wo ich den sonst hinlegen soll....
                  Fabio 1 Reply Last reply Reply Quote 0
                  • Fogg
                    Fogg @Thomas Braun last edited by
                    iobroker update -i
                    Im Latest wird soweit ich das sehe keine Version angegeben. Wo er die 0.6.1 hernimmt weiss ich nicht 🤷
                    • Fabio
                      @fogg es tut mir leid ich würde dir ja sehr gerne helfen aber ich habe echt keine Ahnung. Ich hoffe jemand kann helfen.
                      • Fogg
                        Ich glaube ich weiss woran es liegt... ich habe das ganze noch nicht mit npm publish freigegeben. Da suche ich noch wie das geht...
                        • Fogg
                          Fogg last edited by
                          Gefunden.... ein login hat gefehlt. Jetzt ist 0.7.3 komplett verfügbar. Puh.. was für eine Geburt 😄
                          • Glasfaser
                            Glasfaser @Glasfaser last edited by
                            @Fogg
                            @glasfaser sagte in Kann Adapter nicht installieren:
                            Und was ist mit dem Fehler !?
                            • Fogg
                              Fogg @Glasfaser last edited by Fogg
                              @glasfaser said in Kann Adapter nicht installieren:
                              @Fogg
                              Und was ist mit dem Fehler !?`
                              Die sehe ich bei mir nicht. Welche node.js und js.controller Version hast Du?
                              • Fabio
                                @fogg Super gut gemacht.👍 😊
                                • Glasfaser
                                  @fogg
                                  v14.17.6
                                  v14.17.6
                                  6.14.15
                                  3.3.18
                                  • Fogg
                                    @fogg
                                    v14.17.6
                                    v14.17.6
                                    6.14.15
                                    3.3.18
                                    Hm.. ich bin hier:
                                    NODE.JS: V13.14.0
                                    NPM: 6.14.5
                                    JSControler: 3.3.18
                                    Könnte quasi das Node-js sein. Aber sicher bin ich mir da nicht.
                                    • Glasfaser
                                      V13.14.0
                                      Das ist aber eine ungerade Version
                                      Node.js Versions-Anforderungen Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand bereits mit Node.js 16.x arbeiten möchte, dann bitte im Moment AUSSCHLIESSLICH mit npm 6 !! (Bei npm 7 gibt es noch Probleme mit GitHub Installs bei einigen Adaptern)
                                      • Fogg
                                        @glasfaser Läuft halt auf einem alten MacOS hier... da ist node.js vielleicht nicht immer so aktuell wie es sein sollte. Ich schau mal auf einem Linux Host ob ich den Fehler da reproduzieren kann.
                                        1479
