    4. Js.controller update auf 0.14.x (vorher0.13.2) => totalausfall
      Elektroman last edited by
      Hallo Gemeinde, Hallo Fitti,
      ich habe meinen Schock mit dem löschen der Bilder jetzt überwunden und so gut wie alles wiederhergestellt!
      Problem ist leider das gleiche
      Ich schaffe es leider immer noch nicht iobroker auf meienen Synology NAS zu installieren
        Sorry ich bekomme das anders leider nicht hin es einzufügen
        admin@nasserver:~$ cd ..
        admin@nasserver:/var/services/homes$ cd ..
        admin@nasserver:/var/services$ cd ..
        admin@nasserver:/var$ cd ..
        admin@nasserver:/$ cd volume1
        admin@nasserver:/volume1$ sudo chmod 777 -R /opt/iobroker
        Password:
        admin@nasserver:/volume1$ cd /opt/iobroker
        admin@nasserver:/opt/iobroker$ sudo npm install iobroker --unsafe-perm
         > iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
         > node lib/setup.js
        npm install iobroker.js-controller --production --prefix /opt/iobroker
        npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to
        greenlock. Please find it at npm greenlock
        npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to
        localhost.daplie.me-certificates
        gyp ERR! build error
        gyp ERR! stack Error: not found: make
        gyp ERR! stack     at F
        (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
        gyp ERR! stack     at E
        (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
        gyp ERR! stack     at
        /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
        gyp ERR! stack     at
        /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
        gyp ERR! stack     at
        /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
        gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
        gyp ERR! System Linux 3.2.40
        gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node"
        "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js"
        "rebuild"
        gyp ERR! cwd
        /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
        gyp ERR! node -v v4.4.2
        gyp ERR! node-gyp -v v3.3.1
        gyp ERR! not ok
        npm WARN optional dep failed, continuing unix-dgram@0.2.3
        gyp ERR! stack     at F
        gyp ERR! stack     at E
        gyp ERR! stack     at
        gyp ERR! stack     at
        gyp ERR! stack     at
        "rebuild"
        gyp ERR! cwd
        /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
        gyp ERR! not ok
        npm WARN optional dep failed, continuing ursa@0.9.4
        npm install iobroker.admin --production --prefix /opt/iobroker
        Write "./iobroker start" to start the ioBroker
        iobroker@0.7.1 node_modules/iobroker
        └── yargs@4.8.1 (get-caller-file@1.0.2, decamelize@1.2.0,
        lodash.assign@4.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0,
        window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1,
        yargs-parser@2.4.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0,
        read-pkg-up@1.0.1)
        admin@nasserver:/opt/iobroker$ ./iobroker start
        Starting iobroker controller daemon...
        iobroker controller daemon failed to start:  2
        Error: 2
        Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
        https://www.avast.com/antivirus
        • Bluefox
          Bluefox last edited by
          @Elektroman:
          Password:
           > node lib/setup.js
          gyp ERR! stack     at F
          gyp ERR! stack     at E
          gyp ERR! stack     at
          gyp ERR! stack     at
          gyp ERR! stack     at
          "rebuild"
          gyp ERR! cwd
          gyp ERR! not ok
          gyp ERR! stack     at F
          gyp ERR! stack     at E
          gyp ERR! stack     at
          gyp ERR! stack     at
          gyp ERR! stack     at
          "rebuild"
          gyp ERR! cwd
          gyp ERR! not ok
          read-pkg-up@1.0.1)
          Error: 2
          NasFehler.JPG `
          Hast du build-essential installiert?
            ? [emoji15]
              Ich glaube beim ersten mal habe ich auch nichts anderes gemacht , oder?
                Fitti last edited by
                Also zuerst mal der /opt Ordner ist in Deinem Fall tabu!. Da holst Du Dir wieder die Fehler rein!
                Du darfst auf der Synologie wirklich nur im /volume1 Ordner "arbeiten"! Bei den anderen Ordner operierst Du am offenen Herzen und beim nächsten Update ist sowieso alles weg oder anders.
                Iobroker muss nicht im /opt Ordner rein - das kann man getrost auch woanders insatllieren - und wir Synologies müssen es sogar!
                <u>Okay nochmal Basics:</u> Wenn du ein cd /volume1 eingibst, Bist du vom absulut höchsten Ordner (dem Basisordner oder auch root=Wurzel) in den richtigen Ordner volume1 gelandet.
                Das erspart Dir die cd …
                Das / ist der höchste Ordner.
                In diesem Ordner - und nur da! - legst du den Ordner iobroker an.
                Das kannst du auch direkt mit einem Befehl:
                sudo mkdir /volume1/iobroker
                Dann wechselst Du in diesen Ordner:
                cd /volume1/iobroker
                Nun kannst Du mal versuchen iobroker zu installieren:
                Du wirst immer ein paar Fehler sehen. Aber am Ende sollte doch alles funktionieren.
                Schreib mal was passiert, wenn Du die Befehle hier nach und nach eingibst.
                  Hallo Fitti,
                  Funktioniert leider immer noch nicht
                   admin@nasserver:/volume1/iobroker$ sudo npm install iobroker --unsafe-perm
                  > iobroker@0.7.1 install /volume1/iobroker/node_modules/iobroker
                  > node lib/setup.js
                  npm install iobroker.js-controller --production --prefix /volume1/iobroker
                  npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
                  npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
                  gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
                  gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
                  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
                  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                  gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                  gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
                  gyp ERR! not ok
                  gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
                  gyp ERR! not ok
                  npm install iobroker.admin --production --prefix /volume1/iobroker
                  └── yargs@4.8.1 (get-caller-file@1.0.2, lodash.assign@4.2.0, decamelize@1.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1, yargs-parser@2.4.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
                    habe auch noch einmal versucht die Rechte anzupassen
                    admin@nasserver:/volume1/iobroker$ cd /
                    admin@nasserver:/$ sudo chmod 777 /volume1/iobroker
                    Password:
                    admin@nasserver:/$ cd /volume1/iobroker
                    npm ERR! not a package /volume1/iobroker/iobroker
                    npm ERR! addLocal Could not install /volume1/iobroker/iobroker
                    npm ERR! Linux 3.2.40
                    npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
                    npm ERR! node v4.4.2
                    npm ERR! npm  v2.15.1
                    npm ERR! path /tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json
                    npm ERR! code ENOENT
                    npm ERR! errno -2
                    npm ERR! syscall open
                    npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json'
                    npm ERR! enoent This is most likely not a problem with npm itself
                    npm ERR! enoent and is related to npm not being able to find a file.
                    npm ERR! enoent
                    npm ERR! Please include the following file with any support request:
                    npm ERR!     /volume1/iobroker/npm-debug.log
                      Bitte benutze code-Tags!
                      • und die edit-Funktion.
                      Hier liegt ein Fehler.
                      @Elektroman:
                      gyp ERR! stack Error: not found: make `
                      Rainer
                        Mein Problem ist das ich gezwungen bin mit Tapatalk zu arbeiten
                        glaube ich zumindest
                        habe das Psw für IOBroker vergessen, und komme nur über Tapatalk rein
                        Tapatalk unter Win finde ich noch besch …..
                          Danke für die Antwort,
                          die bringt mich aber leider nicht weiter
                            BabooN-Syno last edited by
                            hey zusammen,
                            ich klinke mich mal hier mit ein. Habe heute mein ioBroker.js-controller von 0.14.0 auf die aktuelle 0.15.3 aktualisieren wollen. Das ganze ging leider in die Hose und ich habe mittlerweile, mehrfrach iobroker neuinstalliert.
                            Meine Installationsablauf sieht genauso aus wie deiner, hast du schon probiert iobroker zu starten?
                            cd volume1/iobroker
                            sudo ./iobroker start
                            wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum..
                            mein iobroker startet und ich kann problemlos darauf zugreifen. Momentan kämpfe ich jedoch stark damit meine alten Daten, vorallem die Pakete inkl. Einstellungen zu übernehmen…
                            Ich habe zuvor den kompletten iobroker Ordner gesichert, kann mir jemand sagen welche Ordner ich auf die neue Installation übernehmen muss?
                            Nehme ich den ganzen /volume1/iobroker Ordner so bekomme ich den gleichen Fehler wie nach dem Updateversuch =/
                            EDIT: ich habe nun anders gelöst. Ich habe aus dem neuinstallierten iobroker den js-controller ordner aus node_modules in meine Datensicherung kopiert und konnte iobroker wie zuvor starten...
                            Dennoch verunsichert mich der bereits oben erwähnte Fehler - kann ich da noch Probleme bekommen?
                            Außerdem bekomme ich den Harmony Adapter nicht installiert wegen fehlendem git -.-
                              @BabooN-Syno:
                              hey zusammen,
                              wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum.. `
                              Na gut - irgendwie drehen wir uns ja nur im Kreis und verschiedenes wiederholst Du nur, was wir zuvor ja schon geschrieben haben.
                              Einschließlich auch der Antwort zu Deiner Frage, die du dir selbst beantwortet hast:
                              Siehe mal hier in diesem Thread, ein paar Einträge zuvor:
                              http://forum.iobroker.net/viewtopic.php … ake#p44448
                              http://forum.iobroker.net/viewtopic.php ... ake#p47504
                              Hast Du meinen Tipp angesehen, wie man make auf Symo installiert?
                              http://forum.iobroker.net/viewtopic.php ... hilit=make
                              Verstehe ich es richtig, dass Du es auch auf einer Symo verwendest oder welches System benutzt Du?
                                @Elektroman:
                                Ist schon verzwíckt bei Dir…
                                Na wir schauen weiter wenn Du magst:
                                geb bitte mal folgenden Befehl ein - der Ordner wo Du das machst ist egal:
                                ls -al / |grep volume1
                                Das Ergebniss bitte wieder hier posten.
                                Dann auch ein
                                ls -al /volume1 |grep iobroker
                                So, und dann hätte ich noch gerne die Infos, die Du nach den beiden Befehlen bekommst:
                                npm cache clean
                                npm find iobroker
                                  Hallo Fitti,
                                  hier das Ergebnis:
                                  admin@nasserver:~$ ls -al / |grep volume1
                                  drwxr-xr-x  33 root root 4096 Feb 26 18:54 volume1
                                  admin@nasserver:~$ ls -al /volume1 |grep iobroker
                                  drwxrwxrwx    6 root                root                     4096 Feb 19 12:22 iobroker
                                  admin@nasserver:~$ npm cache clean
                                  admin@nasserver:~$
                                  admin@nasserver:~$ npm find iobroker
                                  npm WARN Building the local index for the first time, please be patient
                                  npm WARN notice update to the newest npm client for improved search results: npmjs.com/get-npm
                                  NAME                        DESCRIPTION                                                  AUTHOR               DATE       VERSION KEYWORDS
                                  iobroker                    ...domesticate the Internet of Things                        =bluefox             2016-03-14 0.7.1
                                  iobroker.admin              The adapter opens a webserver for the ioBroker admin UI.     =bluefox             2017-01-21 1.6.11
                                  iobroker.cul                Javascript/Node.js based Busware CUL USB / culfw adapter     =bluefox             2017-01-23 0.2.2
                                  iobroker.dwd                Wetterwarnungen des deutschen Wetterdienstes                 =bluefox             2016-07-01 2.1.1
                                  iobroker.email              Send e-mails from ioBroker                                   =bluefox             2017-02-06 1.0.2
                                  iobroker.feiertage          Deutsche Feiertage                                           =bluefox =pix---     2017-01-04 0.3.6
                                  iobroker.history            Log state history in a two-stages process (first to RAM,…    =apollon77 =bluefox  2017-02-23 1.5.3
                                  iobroker.hm-rega            Connects HomeMatic CCU "Logic Layer" ("ReGaHSS") to ioBroker =bluefox             2017-02-06 1.4.3
                                  iobroker.hm-rpc             Connects HomeMatic Interface-Processes (BidCos-Services,…    =bluefox             2017-02-22 1.4.2
                                  iobroker.icons-mfd-png      Icon set for visualisation of the home automation as PNG.    =bluefox             2017-01-05 1.0.2
                                  iobroker.icons-mfd-svg      Icon set for visualisation of the home automation as SVG.    =bluefox             2017-01-05 1.0.2
                                  iobroker.influxdb           Log states in InfluxDB                                       =apollon77 =bluefox  2017-02-23 1.3.4
                                  iobroker.javascript         Javascript/Coffescript Script Engine for ioBroker            =bluefox             2017-02-14 3.2.6
                                  iobroker.jeelink            ioBroker jeelink Adapter                                     =foxthefox           2017-02-07 0.0.2
                                  iobroker.js-controller      ...domesticate the Internet of Things                        =bluefox             2017-01-20 0.15.3
                                  iobroker.knx                ioBroker knx Adapter                                         =bluefox…            2017-02-25 0.8.2
                                  iobroker.kodi               iobroker.kodi Adapter                                        =bluefox =instalator 2017-01-06 0.2.0
                                  iobroker.lightify           OSRAM Lightify Adapter                                       =soef                2017-02-18 0.0.27
                                  iobroker.megad              Lets control the MegaD-328 over ethernet…                    =bluefox             2016-08-14 1.2.1
                                  iobroker.milight            ioBroker milight Adapter                                     =foxthefox           2017-02-15 0.2.2
                                  iobroker.mpd                ioBroker mpd Adapter                                         =instalator          2017-01-28 0.2.4
                                  iobroker.mqtt               The adapter allows to send and receive MQTT messages from…   =bluefox             2017-02-08 1.3.2
                                  iobroker.mysensors          ioBroker mysensors Adapter                                   =bluefox             2016-12-18 1.0.6
                                  iobroker.mysensors-2        ioBroker mysensors-2 Adapter                                 =soef                2017-02-01 2.0.22
                                  iobroker.node-red           This adapter uses node-red as a service of ioBroker. No…     =bluefox             2017-01-25 1.1.6
                                  iobroker.nut                Network UPS Adapter                                          =apollon77           2016-11-30 1.0.0
                                  iobroker.pilight            ioBroker pilight Adapter                                     =sja                 2017-01-15 0.5.1
                                  iobroker.ping               This adapter cyclic polls configured IPs.                    =bluefox             2017-01-23 1.2.0
                                  iobroker.radar              This adapter interfaces ioBroker with Raspberry GPIO pins    =frankjoke           2016-12-27 0.7.3
                                  iobroker.rflink             ioBroker RFLink Adapter                                      =bluefox             2017-01-20 1.0.8
                                  iobroker.rpi2               RPI-Monitor for ioBroker Installations                       =bluefox             2017-01-10 0.3.1
                                  iobroker.rtv                TV Programm (jetzt, 20:15 Uhr, 22:00 Uhr und Tipps) aus den… =pix---              2016-12-18 1.0.0
                                  iobroker.sayit              Text to speech interface for ioBroker.                       =bluefox             2017-02-15 1.5.1
                                  iobroker.simple-api         RESTful interface for ioBroker.                              =bluefox             2016-09-05 1.3.0
                                  iobroker.smartmeter         Smartmeter Adapter                                           =apollon77           2017-02-24 0.4.1
                                  iobroker.socketio           This adapter allows to communicate different web…            =bluefox             2017-01-04 1.7.4
                                  iobroker.sonos              The adapter opens a webserver for the ioBroker admin UI      =bluefox             2017-01-03 1.4.2
                                  iobroker.sql                Log state sql in a two-stages process (first to Redis, then… =apollon77 =bluefox  2017-02-25 1.4.6
                                  iobroker.tankerkoenig       Spritpreise von tankerkoenig.de                              =pix---              2016-10-14 1.0.0
                                  iobroker.telegram           The adapter allows to send and receive telegram messages…    =bluefox             2017-01-14 1.0.2
                                  iobroker.text2command       Convert texts to ioBroker commands.                          =bluefox             2016-09-01 1.1.3
                                  iobroker.tr-064             ioBroker tr-064 Adapter                                      =soef                2017-02-18 0.1.33
                                  iobroker.vis-beta           BETA graphical user interface for ioBroker.                  =bluefox             2017-02-11 0.12.8
                                  iobroker.vis-timeandweather Time and weather widgets for ioBroker.vis                    =bluefox             2017-01-05 1.1.7
                                  iobroker.web                ioBroker simple web Adapter                                  =bluefox             2017-02-11 2.0.2
                                  iobroker.wifilight          WiFi Light Adapter                                           =soef                2017-02-18 0.1.1
                                  iobroker.xs1                ioBroker EZcontrol XS1 Adapter                               =frankjoke           2017-01-15 0.5.2
                                  iobroker.yamaha             ioBroker Yamaha Adapter                                      =soef                2017-02-24 0.3.5
                                  iobroker.yr                 Fetches 48h weather forecast from yr.no                      =bluefox             2016-10-10 1.0.5
                                  soef                        library for ioBroker                                         =soef                2017-02-21 0.2.0
                                  admin@nasserver:~$
                                    Okay - das sieht gut aus.
                                    Wir versuchen noch einmal eine Installation, habe zwar noch eine andere Idee, aber vorher sollten wir es noch herkömmlich testen.
                                    Fehlermeldungen kommen ganz bestimmt. Versuche dennoch einfach mal danach
                                    iobroker start
                                    und dich im Browser anzumelden.
                                      Password:
                                      npm ERR! path /tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json
                                      npm ERR! errno -2
                                      npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json'
                                      npm ERR! enoent
                                      admin@nasserver:/volume1/iobroker$ iobroker start
                                      -sh: iobroker: command not found
                                        vielen dank für die schnelle Antwort
                                          Den 'npm ERR! not a package' finde ich komisch. :shock:
                                          Als ob im iobroker-Paket ein Fehler wäre. Doch dann hätten es die anderen ja auch. :?
                                          gebe bitte mal folgendes ein:
                                          npm test iobroker
                                          Und wie immer: Ergebnis hier her.
                                            Das ist IMHO der einzige Fehler wo nichts mehr repariert werden kann.
                                            Zumindest ich hab es nicht hinbekommen.
                                            Und…tatsächlich diese Datei fehlt in den Fällen tatsächlich.
                                            Rainer
                                            10271
