    4. Test Adapter TrashSchedule
    • da_Woody
      da_Woody @Kueppert last edited by
      @kueppert und bei der hilfe, die man hier im brett unermüdlich bekommt, haben das bis jetzt noch alle geschafft! 👍 👍 👍
        Cino last edited by Cino
        trashschedule.0
        2021-09-03 11:01:58.931	info	State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:01:58.931	info	State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:01:58.926	warn	no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule!
        trashschedule.0
        2021-09-03 11:00:05.013	info	State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:00:05.011	info	State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:00:05.004	warn	no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule!
        trashschedule.0
        2021-09-03 11:00:03.043	info	State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:00:03.041	info	State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:00:03.037	warn	no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule!
        Ich glaube das ist nachdem ich das ganze System geupdated habe.
        trashschedule.0
        2021-09-03 11:17:43.027	info	State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:17:43.025	info	State value to set for "trashschedule.0.type.schwarzeTonne.nextWeekday" has to be type "string" but received type "number"
        trashschedule.0
        2021-09-03 11:17:42.856	debug	(5) filling "nextAfter" event with data: {"minDays":13,"minDate":"2021-09-15T22:00:00.000Z","minTypes":["Gelbe Tonne"]}
        trashschedule.0
        2021-09-03 11:17:42.855	debug	(5) filling "next" event with data: {"minDays":6,"minDate":"2021-09-08T22:00:00.000Z","minTypes":["Schwarze Tonne"]}
        trashschedule.0
        2021-09-03 11:17:42.853	warn	no events matches type "Papiertonne" with match "Papier". Check configuration of iCal (increase preview) and trashschedule!
        trashschedule.0
        2021-09-03 11:17:42.853	debug	(3) event match: "Restmüll" matches type "Schwarze Tonne" with pattern "Restmüll"
        trashschedule.0
        2021-09-03 11:17:42.852	debug	(2) processing: Restmüll (1632348000000) // dayDiff: 20 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18
        trashschedule.0
        2021-09-03 11:17:42.852	debug	(1) parsing next event {"date":"23.09.2021 07:00","event":"Restmüll","_class":"ical_Muell ","_date":"2021-09-23T05:00:00.000Z","_end":"2021-09-23T05:00:00.000Z","_section":"Restmüll","_IDID":"5e09c2ce-cbd6-450d-bf19-f43c629e3c66","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-23T05:00:00.000Z // calculated date (with offset): Thu Sep 23 2021 00:00:00 GMT+0200 (GMT+02:00)
        trashschedule.0
        2021-09-03 11:17:42.851	debug	(4) filled type: "Gelbe Tonne"
        trashschedule.0
        2021-09-03 11:17:42.850	debug	(3) event match: "Wertstofftonne" matches type "Gelbe Tonne" with pattern "Wertstofftonne"
        trashschedule.0
        2021-09-03 11:17:42.850	debug	(2) processing: Wertstofftonne (1631743200000) // dayDiff: 13 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18
        trashschedule.0
        2021-09-03 11:17:42.849	debug	(1) parsing next event {"date":"16.09.2021 07:00","event":"Wertstofftonne","_class":"ical_Muell ","_date":"2021-09-16T05:00:00.000Z","_end":"2021-09-16T05:00:00.000Z","_section":"Wertstofftonne","_IDID":"32354b51-a34e-4f78-8a35-57afe049dfcc","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-16T05:00:00.000Z // calculated date (with offset): Thu Sep 16 2021 00:00:00 GMT+0200 (GMT+02:00)
        trashschedule.0
        2021-09-03 11:17:42.849	debug	(4) filled type: "Schwarze Tonne"
        trashschedule.0
        2021-09-03 11:17:42.846	debug	(3) event match: "Restmüll" matches type "Schwarze Tonne" with pattern "Restmüll"
        trashschedule.0
        2021-09-03 11:17:42.846	debug	(2) processing: Restmüll (1631138400000) // dayDiff: 6 // current hour (date): 11 (1630620000000) // skipsamedayathour (config): 18
        trashschedule.0
        2021-09-03 11:17:42.845	debug	(1) parsing next event {"date":"In 6 Tagen 07:00","event":"Restmüll","_class":"ical_Muell ical_6days","_date":"2021-09-09T05:00:00.000Z","_end":"2021-09-09T05:00:00.000Z","_section":"Restmüll","_IDID":"affeac37-c472-4f20-b1ef-953500435a0a","_allDay":false,"_private":false,"_rule":" ","location":"Glück-Auf-Straße 105, Dorsten","_calName":"Muell","_calColor":"#000000"} // originalDate: 2021-09-09T05:00:00.000Z // calculated date (with offset): Thu Sep 09 2021 00:00:00 GMT+0200 (GMT+02:00)
        trashschedule.0
        2021-09-03 11:17:42.844	debug	(0) offset (config): 0
        trashschedule.0
        2021-09-03 11:17:42.843	debug	Start processing 3 iCal events
        trashschedule.0
        2021-09-03 11:17:42.840	debug	updating data
        trashschedule.0
        2021-09-03 11:17:42.836	debug	re-creating refresh timeout in 2542164ms (00:42:22)
        trashschedule.0
        2021-09-03 11:17:42.760	debug	Trash type found: "Papiertonne"
        trashschedule.0
        2021-09-03 11:17:42.730	debug	Trash type found: "Schwarze Tonne"
        trashschedule.0
        2021-09-03 11:17:42.712	debug	Trash type found: "Gelbe Tonne"
        trashschedule.0
        2021-09-03 11:17:42.634	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.5, js-controller: 3.3.15
        trashschedule.0
        2021-09-03 11:17:42.273	debug	Plugin sentry Initialize Plugin (enabled=true)
        trashschedule.0
        2021-09-03 11:17:41.000	debug	statesDB connected
        trashschedule.0
        2021-09-03 11:17:40.999	debug	States connected to redis: 127.0.0.1:9000
        trashschedule.0
        2021-09-03 11:17:40.985	debug	States create User PubSub Client
        trashschedule.0
        2021-09-03 11:17:40.984	debug	States create System PubSub Client
        trashschedule.0
        2021-09-03 11:17:40.972	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        trashschedule.0
        2021-09-03 11:17:40.970	debug	objectDB connected
        trashschedule.0
        2021-09-03 11:17:40.956	debug	Objects connected to redis: 127.0.0.1:9001
        trashschedule.0
        2021-09-03 11:17:40.936	debug	Objects client initialize lua scripts
        trashschedule.0
        2021-09-03 11:17:40.935	debug	Objects create User PubSub Client
        trashschedule.0
        2021-09-03 11:17:40.933	debug	Objects create System PubSub Client
        trashschedule.0
        2021-09-03 11:17:40.931	debug	Objects client ready ... initialize now
        trashschedule.0
        2021-09-03 11:17:40.894	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          Ahh, kann das daran liegen das mein Preview bei ical bei 10 tagen liegt und der nächste Termin für Papier bei +10 ist?
          edit: ical steht doch bei 20 Tagen Vorschau.
          • Glasfaser
            Glasfaser @Cino last edited by
            @cino sagte in Test Adapter TrashSchedule v1.1.x:
            steht weiter oben , was zu machen ist
            https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/814
            • N
              nu_81 last edited by
              ich habe die Eigenschaft "leuchtet wenn fällig" angehakt und nun leuchtet der Kreis um die Zahl rot.
              Dies ist mir aber nicht auffällig genug und hätte gerne das, am liebsten die ganze Tonne leuchtet / blinkt.
              Kann man das irgendwie einstellen?
              Gruß Nu
              Glasfaser da_Woody 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @nu_81 last edited by
                @nu_81
                Suche mal innerhalb des Thread´s
                Beispiel :
                https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/385
                • da_Woody
                  da_Woody @nu_81 last edited by
                  @nu_81 sorry, aber irgendwie kann man alles übertreiben... 😞
                  noch dazu, das du nicht mal schreibst, welche visualisierung du verwendest...
                  • N
                    nu_81 @da_Woody last edited by
                    @da_woody
                    Ich weiß jetzt nicht genau wie ich dir auf den Schlips getreten bin, falls ich etwas falsch gemacht haben sollte möchte ich mich aber natürlich entschuldigen.
                    Ich habe niemanden kritisiert und auch wollte mich auch nur informieren,
                    wie ich eine bereits gute Lösung für mich noch weiter individualisieren kann.
                    Habe nun letztlich einen Rahmen um alle Tonnen gelegt, der pulsiert wenn NextDays <= 1 ist.
                    • da_Woody
                      @nu_81 oi, du bist mir nicht wo draufgetreten! 🙂
                      ist aber schwer, wenn du nicht sagst, welche visu du verwendest.
                      as i c, verwendest du vis. gibt aber auch noch andere. z.b. iQontrol u.s.w.
                      so gesehn, ists halt unterschiedlich wie man vorgehn kann. 🙂
                        marsmännchen @da_Woody last edited by
                        weiß vielleicht schon jemand wie man den Rahmen um die Mülltonnen verkleinern kann um das Widget ganz in die Ecke der Vis zu schieben?
                        https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/758
                        MfG Patrick
                          c.radi last edited by
                          ich bin ganz neu im Thema ioBroker, und finde diese Adapter total super.
                          Auch das Widget lässt sich einfach ins vis einbinden.
                          Was ich allerdings nicht gefunden habe ist die Möglichkeit das Widget im vis in der Größe zu ändern.
                          Geht dies nicht, oder wie muss ich das machen, damit auch alle (bei mir) 4 Tonnen angezeigt werden.
                          Christian
                            sigi234 Forum Testing Most Active @c.radi last edited by
                            @c-radi
                            bergjet 1 Reply Last reply Reply Quote 1
                              @sigi234
                              Vielen Dank.
                              Christian
                              • bergjet
                                bergjet @sigi234 last edited by
                                @sigi234 Schade, dass beim verkleinern auch die Schrift sehr klein wird. Das Datum ist fast nicht zu lesen, wenn man die Tonnen kleiner macht.
                                sigi234 M 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @bergjet last edited by sigi234
                                  @bergjet sagte in Test Adapter TrashSchedule v1.1.x:
                                  Abhilfe eventuell:
                                  Beim Widget Haken weg bei Datum anzeigen
                                    marsmännchen @bergjet last edited by
                                    @bergjet
                                    Vielleicht kann ich dir bisschen helfen.
                                    Kennst du dich aus mit dieser CSS Sache?(bin auch noch am lernen)
                                    Versuch mal das: trash.JPG trash2.JPG
                                    Damit wird die Schrift wieder grösser. du kannst statt large auch diverse andere Werte eingeben:
                                    /* <absolute-size>-Werte */
                                    font-size: xx-small;
                                    font-size: x-small;
                                    font-size: small;
                                    font-size: medium;
                                    font-size: large;
                                    font-size: x-large;
                                    font-size: xx-large;
                                    /* <relative-size>-Werte */
                                    font-size: smaller;
                                    font-size: larger;
                                    /* <length>-Werte */
                                    font-size: 12px;
                                    font-size: 0.8em;
                                    /* <percentage>-Werte */
                                    font-size: 80%;
                                    Hoffe ich konnte auch mal was sinnvolle beitragen.
                                    MfG
                                    Patrick
                                    bergjet 1 Reply Last reply Reply Quote 0
                                    • bergjet
                                      bergjet @marsmännchen last edited by
                                      @marsmännchen Danke, ob die Welt am Mars auch so einfach ist?
                                        @bergjet
                                        Leider nicht, ich schaffe es mittlerweile nicht mal mehr mit blockly einen state auf true zu schalten.🤢
                                          Aachen1305 last edited by
                                          Kann mir jemand helfen und erklären warum der Adapter ein völlig falsches Datum angibt.
                                          Ich stehe da gerade komplett auf`m Schlauch
                                          M Glasfaser 2 Replies Last reply Reply Quote 0
                                            marsmännchen @Aachen1305 last edited by
                                            @aachen1305
                                            Wann sollte die nächste Abholung sein? Was steht im Kalender?
                                            1.0k
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            506054
