    4. Test Adapter Govee v0.0.x
      Langer @JayDee last edited by
      @nbuenger
      Als erstes vielen Dank für Deine Arbeit.
      Habe den Adapter installiert, bekomme auch alle Govee's angezeigt.
      Mit Deinem Tool bekomme ich folgende Ausgabe:
        "device": "FF:ED:A4:C1:38:93:49:51",
        "model": "H6199",
        "deviceName": "TV-Backlight",
        "controllable": true,
        "retrievable": true,
        "supportCmds": [
          "turn",
          "brightness",
          "color",
          "colorTem"
        "properties": {
          "colorTem": {
            "range": {
              "min": 2000,
              "max": 9000
        "device": "8E:AA:A4:C1:38:2E:0E:0B",
        "model": "H6159",
        "deviceName": "Terrasse",
        "supportCmds": [
          "turn",
          "brightness",
          "color",
          "colorTem"
        "properties": {
          "colorTem": {
            "range": {
              "min": 2000,
              "max": 9000
        "device": "DD:C5:A4:C1:38:43:44:86",
        "model": "H6159",
        "deviceName": "Sitze",
        "supportCmds": [
          "turn",
          "brightness",
          "color",
          "colorTem"
        "properties": {
          "colorTem": {
            "range": {
              "min": 2000,
              "max": 9000
      Aber ich kann keine Werte ändern, sprich nicht Einschalten, die Farbe nicht ändern usw.
      Jeder Wert den ich ändere wird kurz danach wieder zurück gesetzt.
      Und in Protokolle kommen folgende Fehler:
      govee.0
      2021-08-25 13:56:37.678	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
      govee.0
      2021-08-25 13:56:32.978	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
      govee.0
      2021-08-25 13:56:27.734	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
      govee.0
      2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTemMod"
      govee.0
      2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTem"
      govee.0
      2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTemMod"
      govee.0
      2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTem"
      Ich hoffe das es dafür eine Lösung gibt.
      Vielen Dank im voraus.
      MfG
      Wastl
      nbuenger 1 Reply Last reply Reply Quote 0
        helfi9999 last edited by
        Hi kurze Frage,
        habe mir den H6125 geholt bekomme ihn aber nicht angezeigt. Kann es sein das das Band nicht kompatibel ist mit dem Adapter oder ist der Adapter ausbaufähig.
        Würde den Strip gerne in IObroker einbinden.
        • nbuenger
          nbuenger Developer @Langer last edited by
          @langer Moin,
          wie versuchst du die Werte denn zu bearbeiten. Machst du das über die Objekt Übersicht oder benutzt du ViS oder eine andere Visualisierung. Der Fehler mit den falschen Types kommt seid dem Update vom IOBroker. Ich würde gerne ein Update für euch raushauen aber ich komme nicht dazu da ich nur am arbeiten bin. Tut mir leid. Möglicherweise schaffe ich ja etwas in meinem Urlaub.
          • nbuenger
            nbuenger Developer @helfi9999 last edited by
            @helfi9999 Moin, du kannst das einfach prüfen indem du deinen Govee-API-Key in meinem Tool eingibst.
            https://buenger-webdesign.de/api/
            Den Output kannst du mir dann hier reinschicken oder privat wie du gerne möchtest. Dann sage ich dir ob der von der API vollständig unterstützt wird.
            Die neue Version des Testing Tools ist auch bald fertig es fehlen noch ein ein paar kleine optische Anpassungen dann bekommt ihr den Zugang dazu.
              siton23 last edited by
              Erstmal danke für die Arbeit, die bisher geleistet wurde. Ich würde auch gerne die Govee LED Stripes im iobroker einbinden und den Adapter testen.
              Meine Frage wäre noch ob es bald auch möglich sein wird die verschiedene Modi zu ändern?
              Also vor allem der Musik Modus würde mich interessieren. Dann wäre es auch schön ggf. die Szenen (nicht nur Musik Szenen) einstellen zu können.
              Würde mich sehr über Infos freuen ob dies In bereits in Planung ist, da ich es dann auch sehr gerne nutzen würde.
              • nbuenger
                nbuenger Developer @siton23 last edited by
                @siton23 Hey,
                ich danke dir. So gerne ich das in den Adapter integrieren würde wird das leider nicht möglich sein. Die Offizielle API von Govee unterstützt das Feature für den Modi Wechsel nicht. Ich hoffe das die da irgendwann nach ziehen. Sehe da bisher aber keine Hoffnung. Tut mir leid dir das sagen zu müssen.
                  @nbuenger ok das ist schade. Aber trotzdem danke für die Antwort. Ich werde den Adapter trotzdem nutzen.
                    myssv last edited by
                    Nachdem es jetzt wieder früher dunkel wird, wollte ich eben meinen LED Streifen einschalten und es geht nicht mehr ...
                    Der Power State wird auch nicht mehr korrekt erkannt. Der Streifen ist aktuell an
                      Habe gerade gesehen, dass ich auch massenhaft Fehlermeldungen erhalte:
                      • Z
                        zgadgeter last edited by
                        der ADapter bei mir ist schon laegner Rot, und ich bekomme den nicht auf gruen. Die letzte Version ist installiert. Einen neuen API habe ich auch schon beantragt...aber er bleibt auf rot.
                        Funktioniert der Adapter noch?
                          Thomas Braun Most Active @zgadgeter last edited by
                          @zgadgeter
                          Ja, hier läuft der mit 'grüner Ampel'.
                          • Z
                            zgadgeter @Thomas Braun last edited by
                            Komisch. Ich habe den Adapter mal entfernt, wieder installiert, immer noch Rot.
                            Dann habe ich den gesamten Iobroker upgedated (sieh untern), aber immer noch Rot...
                              @zgadgeter
                              Und was steht im LogFile dazu?
                              • Z
                                @thomas-braun Hi, ich habe den adapter neu gestartet, und hier ist der output.5b09225f-d99c-42f3-9831-70ef55186570-image.png
                                Also ich erkenne nichts....
                                  @zgadgeter
                                  Ich vermute, dass sollte sich mal der Maintainer von dem Adapter anschauen. Mach am besten ein Issue auf github dazu auf.
                                  • nbuenger
                                    nbuenger Developer last edited by
                                    Hey Leute, es tut mir wahnsinnig leid das ich mich nicht gemeldet habe und ihr von mir nichts weiteres mit bekommen habt. Ich würde gerne aktiv am Adapter arbeiten. Nur leider bin ich berufstätig und daher habe ich nicht die Zeit die ich gerne aufbringen würde. Möglicherweise habe ich demnächst einen neuen Job da hätte ich dann auch wieder mehr Zeit. Ich werde die Fehler die aufgetreten sind beheben. Ich kann euch nur nicht versprechen wann. Wenn es jemanden in der Community gibt der ebenfalls Bock auf das Projekt hat kann sich diese/r jemand gerne bei mir melden und ich Weihe diese/n jemand gerne in das Projekt ein.
                                    Es tut mir leid das ich keine besseren Nachrichten für euch habe. Ich hoffe das wir den Adapter bald wieder voran bringen können.
                                    1 Reply Last reply Reply Quote 5
                                      Alex975 last edited by
                                      Trotzdem mal eine generelle Frage:
                                      Die API gibt nur Stripes zurück oder wurden die gefiltert? Hintergrund ist, dass ich von Govee ein WIFI Thermometer habe was im Gewächshaus hängt. Über den Alexa Adapter bekomme ich zumindest die Temp, diese aktualisiert sich aber nicht wirklich.
                                      VG Alex
                                      • nbuenger
                                        nbuenger Developer @Alex975 last edited by
                                        Moin @alex975,
                                        die API seitens Govee ist sehr eingewchränkt.
                                        Hier hast du mal die API zum ansehen. Darin ist eine Liste aller unterstützten Geräte. Allerdings habe ich bei einigen Geräten festgestellt das die API nicht korrekt funktioniert. Der Sensoren zählen leider auch dazu.
                                        Und für alle anderen. Das Update ist in Gange aber es benötigt alles noch etwas mehr Zeit. Sobald ich ein Datum für den Release habe bekommt ihr eine Info.
                                        VG Nick
                                        • Martin Steiner
                                          Martin Steiner last edited by
                                          ich habe Probleme bei der Installation des Adpaters. Kann mir Jemand bitte hilfreiche Hinweise geben?
                                          meine Hardware/Software:
                                          Pi4 mit 4 GB
                                          ioBroker Version 5.1.25
                                          Nodejs 14.7.5 (empfohlen wird 12.22.7 aber keine Ahnung wie ich wieder runtersetzen soll, hab mehrfach was erfolglos probiert... gibt es gute Anleitung?)
                                          NPM 6.14.14
                                          der Adapter wird von Github bei mir nicht geladen, in den Instanzen taucht er nicht auf. Allerdings ist in den Objekten ein Ordner "Govee" angelegt und ein Unterordner Admin.
                                          Hier der Installationscode, vielleicht lässt sich daraus bereits ablesen wo es klemmt
                                          $ iobroker url https://github.com/nbuenger/ioBroker.govee --host raspberrypi4-ioB --debug
                                          install nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606
                                          NPM version: 6.14.14npm install nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606 --prefix "/opt/iobroker" (System call)
                                          > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam> node-gyp rebuild
                                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                                          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                                          In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
                                          ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~
                                          ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ username->WriteUtf8(m->username, sizeof(m->username) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ password->WriteUtf8(m->password, sizeof(m->password) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                          ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) { ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) { ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) { ^~~~~~~In file included from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                          ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                          make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                                          gyp ERR! build error
                                          gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)
                                          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)gyp ERR! System Linux 5.10.60-v7l+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.17.5gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                          + iobroker.govee@0.0.5updated 1 package in 44.717s
                                          68 packages are looking for funding run `npm fund` for details
                                          upload [5] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/words.js words.js application/javascript
                                          upload [4] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/style.css style.css text/css
                                          upload [3] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/index_m.html index_m.html text/html
                                          upload [2] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/govee.png govee.png image/png
                                          upload [1] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/govee-old.png govee-old.png image/png
                                          upload [0] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/admin.d.ts admin.d.ts video/mp2t
                                          Process exited with code 0
                                          Lieben Dank für Eure Hinweise und Unterstützung!
                                          Pi4 mit 4 GB
                                          Nodejs 14.7.5 (empfohlen wird 12.22.7 aber keine Ahnung wie ich wieder runtersetzen soll)
                                          NPM 6.14.14
                                            Thomas Braun Most Active @Martin Steiner last edited by Thomas Braun
                                            @martin-steiner sagte in Test Adapter Govee v0.0.x:
                                            Schau in meiner Signatur. Da erkläre ich wie man in den Versionen lustig rauf und runterspringen kann.
                                            Zu pam:
                                            Ist libpam0g-dev installiert?
                                            apt policy libpam0g-dev
                                            Martin Steiner 1 Reply Last reply Reply Quote 0
                                            312
                                            68191
