    4. Test ViessmannAPI v2.0.0
    • U
      Unterstedter last edited by
      Hat jemand schon mal ein schedule geändert über dieses Adapter die Zirkulationspumpe? In welchen Datenpunkt das geschrieben werden muss ist mir klar, aber das json nicht.
      Es gibt auf github ja ein Beispiel für die Ventilation, aber ich kapier nicht welche weiteren Attribute außer Start und End bei der Zirkulationspumpe erforderlich sind :
      var standard = '{"mon":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"tue":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
      "wed":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"thu":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
      "fri":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"sat":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
      "sun":[{"start":"00:00","end":"24:00","mode":"standard","position":0}]}'
      setState("viessmannapi.0.xxxxxxx.0.features.ventilation.schedule.commands.setSchedule.setValue", JSON.parse(standard));
        manrum1 @tombox last edited by
        @tombox Dann liegt das Problem bei Viessmann. Kann man Viessmann anfragen, ob sie einen solchen indikator zur Verfügung stellen? Technisch müsste es ja gehen, da im Portal ja auch erkannt wird, ob die Heizung real verbunden ist.
          manrum1 @Unterstedter last edited by manrum1
          @unterstedter Schau dir mal folgendes Beispiel an:
          var standard = '{"mon":[{"start":"04:00","end":"05:00","mode":"on","position":0},{"start":"16:00","end":"18:00","mode":"on","position":1}],"tue":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"wed":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"thu":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"fri":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"sat":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"sun":[{"start":"04:00","end":"08:00","mode":"on","position":0}]}'
          setState('viessmannapi.0.xxxx.0.features.heating.dhw.schedule.commands.setSchedule.setValue', JSON.parse(standard));
          Bei mir funktioniert das Setzen von Schedules in 4 von 5 Fällen. Leider stützt immer wieder mal der Adapter ohne Fehlermeldung ab. Deshalb setze ich keine Schedules mehr per Script, ist mir einfach zu unverlässlich.
            BlackTigga @BlackTigga last edited by
            @blacktigga sagte in Test ViessmannAPI v2.0.0:
            @tombox sagte in Test ViessmannAPI v2.0.0:
            Ich habe eingebaut das die virtuelle Geräte nicht aktualisiert werden nochmal neu installieren und testen ob das limit jetzt reicht
            Läuft seit heute morgen anstandslos durch 👍
            viessmannapi.0 2021-08-12 16:22:25.665	debug	ignore type:virtual
            viessmannapi.0 2021-08-12 16:22:25.664	debug	ignore type:virtual
            viessmannapi.0 2021-08-12 16:22:25.650	debug	ignore type:gateway
            viessmannapi.0 2021-08-12 16:21:26.324	debug	https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data"
            @tombox Seit zwei oder drei Tagen ist mein Tageslimit immer ca. um 11 Uhr aufgebraucht. Es scheint, dass die virtuellen Geräte (RoomControl-1 und HeatDemandControl) jetzt wieder mit aktualisiert werden:
            2021-09-23 07:15:31.047  - viessmannapi.0 (14905) ignore type:gateway
            2021-09-23 07:15:31.424  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
            2021-09-23 07:15:31.885  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
            2021-09-23 07:15:32.608  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
            2021-09-23 07:16:31.048  - viessmannapi.0 (14905) ignore type:gateway
            2021-09-23 07:16:31.412  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
            2021-09-23 07:16:31.812  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
            2021-09-23 07:16:33.924  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
            2021-09-23 07:17:31.055  - viessmannapi.0 (14905) ignore type:gateway
            2021-09-23 07:17:31.524  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
            2021-09-23 07:17:31.989  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
            2021-09-23 07:17:32.012  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
              tombox @BlackTigga last edited by tombox
              @blacktigga dann bräuchte ich dann wieder den kompletten debug log nach einem neustart des adapters wenn das rate limit wieder frei ist. einfach per mail senden.
                BlackTigga @tombox last edited by
                @tombox Email ist raus
                  @blacktigga Sollte behoben sein
                    manrum1 @tombox last edited by manrum1
                    @tombox Zur Info: Heute und gestern wieder Ausfälle:
                    viessmannapi.0
                    	2021-09-24 12:31:02.316	error	Error: Request failed with status code 500
                    viessmannapi.0
                    	2021-09-24 12:31:02.305	error	https://api.viessmann.com/iot/v1/equipment/installations/xxx/gateways/xxx/devices/$id/features
                    T J 2 Replies Last reply Reply Quote 0
                      tombox @manrum1 last edited by
                      @manrum1 Hier gibt es dazu ein Beitrag
                      https://www.viessmann-community.com/t5/The-Viessmann-API/Performance-and-availability-of-Viessmann-servers/td-p/187420
                        muro82 @tombox last edited by
                        Hi bin neu hier und meine Frage wäre
                        funktioniert der Adapter mit einer Vidodens 200-W mit integriertem WLAN Modul?
                        Will das über einen Raspberry laufen lassen benötige ich dazu noch etwas
                        Danke im voraus
                          jensemann @muro82 last edited by
                          @muro82
                          Also ich habe eine Vidodens 300-W (vor 2 Monaten installiert) mit integriertem WLAN Modul.
                          Der Adapter funktioniert wie gewünscht.
                          Der iobroker läuft auch auf dem Raspberry. Ich würde dann mindestens den 3B nehmen. Da hatte ich auch mal zum testen ein iobroker image drauf. Für 3-5 Module reicht da auch der eine GB RAM.
                            jensemann @manrum1 last edited by jensemann
                            @manrum1
                            @tombox
                            Habt ihr seit ein paar tagen auch Probleme?
                            ich habe nichts an meinen Settings geändert.
                            Trotzdem kommt dauert der Fehler 429 und anscheinend erreiche ich sehr schnell die max Api Calls von 1450 ?
                            viessmannapi.0
                            2021-10-12 20:38:30.040 error Error: Request failed with status code 429
                            viessmannapi.0
                            2021-10-12 20:38:30.039 error Receiving Events
                            viessmannapi.0
                            2021-10-12 20:38:29.915 error Error: Request failed with status code 429
                            viessmannapi.0
                            2021-10-12 20:38:29.796 error {"viErrorId":"XXXX","statusCode":429,"errorType":"RATE_LIMIT_EXCEEDED","message":"API calls rate limit has been exceeded. Please wait until your limit will renew.","extendedPayload":{"name":"development portal "XXXXX" daily limit","requestCountLimit":1450,"clientId":"XXXXXXX","userId":"XXXX","limitReset":1634083204599}}
                              tombox @jensemann last edited by
                              @jensemann nutzt du die aktuelle version? wieviele geräte hast du im gateway und welche refresh zeit
                                jensemann @tombox last edited by jensemann
                                @tombox said in Test ViessmannAPI v2.0.0:
                                @tombox
                                Version ist 2.0.1
                                Update device status in minutes= 1
                                Update gateway events in minutes= 300
                                Gerätei m Gateway? Was ist damit gemeint? Ich habe eine Heizung mit integriertem WLAN Modul .. wenn das gemeint ist
                                ahhhh. ich glaube ich habs: 0 Eingabeereignisse / 11 Ausgabeereignisse ...
                                  @jensemann probier mal die 2.0.4
                                    Danke,läuft ohne Fehler seit dem Update!
                                      Tucca @jensemann last edited by
                                      Hallo
                                      sorry, für die "dumme" Frage.
                                      Wie kann ich den Adapter installieren? In iobroker-Admin wird mir leider nur die Version 1.3.4 angezeigt. Auch wenn ich über npm bzw. github installieren möchte, muss ich ja etwas auswählen und dann ist dann der alte Adapter zu sehen ...
                                      Ich habe heute iobroker neu installiert, da ich den Raspberry wechseln möchte.
                                      VIelen Dank
                                      Tucca
                                        tombox @Tucca last edited by
                                        @tucca entweder wie im Beitrag 1 beschrieben installieren oder in den ioBroker Einstellung das repo auf latest stellen
                                          Al Bundy last edited by
                                          Remote Befehle sind möglich unter
                                          viessmannapi.0.XXXXX.0.features.heating.dhw.temperature.main.commands.setTargetTemperature.setValue
                                          Danke für den Adapter.
                                          Daten empfangen geht problemlos.
                                          Bei mir hackt es beim Senden von Befehlen.
                                          Wie wird z.B. der Eco-Modus aktiviert?
                                          Zuvor ging das in einem Javascript so:
                                            sendTo('viessmannapi.0.113766.0.', 'action', {
                                          		feature: 'heating.circuits.0.operating.programs.comfort',
                                          		action: 'activate',
                                          		payload: {}
                                          Ich habe nun noch die 113766 dazugefügt, im Vergleich zur vorgängigen API.
                                          Mit diesem Befehlt passiert aber nichts. Nicht mal ein Log Eintrag, den ich posten könnte (Loglevel silly).
                                          Was mache ich falsch? Wie sieht der korrekte Befehl aus?
                                          System-Info:
                                          Heizung: Gas-Brennwert-Wandgerät Vitodens 300-W
                                          Raspi 4
                                          iobroker v5.1.25
                                          js-controller v3.3.18
                                          node.js v12.22.7
                                          viessmannapi v2.0.4 (Objekte alle nochmals gelöscht und durch Adapter Neustart wieder angelegt)
                                            @al-bundy das sendto wird nicht mehr unterstützt. bitte den entsprechend setvalue suchen und setzen
                                            z.b.
                                            viessmannapi.0.113766.0.features.heating.circuits.1.operating.modes.active.commands.setMode.setValue
                                            Wenn es kein setValue gibt kann der Wert nicht gesetz werden
                                            795
                                            211088
