    4. JavaScript
    5. Script: Alexa Listen pflegen und Anzeigen
      liv-in-sky @Nordischerjung last edited by
      @nordischerjung ja bitte
      • N
        Nordischerjung @liv-in-sky last edited by
        @liv-in-sky
          <variables>
            <variable id="h!=BXv^X?0znFOj5|.T[">sendT</variable>
            <variable id="!t(_s6!A^|$7hHkJs}AV">test</variable>
            <variable id=":kI@a,4j*7?IgGv-BV0a">j</variable>
          </variables>
          <block type="on" id="Bz-8j@{0t-C?D:PP+HT:" x="-12" y="113">
            <field name="OID">javascript.0.Alexa_Listen.ALEXALists.Einkauf.Alexa_sende_BOOL</field>
              <block type="controls_if" id="XryH|r[I1#C0`P.3Sm53">
                  <block type="on_source" id="5oF#p.$Ccf@@ty%t%#%3">
                  <block type="comment" id="|l!;QjS^9oV8K{~p]|$2">
                    <field name="COMMENT">Einkaufsliste</field>
                      <block type="variables_set" id="nKaMcjH{m_1z4A2C~dfz">
                        <field name="VAR" id="h!=BXv^X?0znFOj5|.T[">sendT</field>
                          <block type="text" id="~M@jM_q$lI/l-J@YTF!5">
                            <field name="TEXT"></field>
                          <block type="variables_set" id="J|rU2BWw.iHvfh+YYbh~">
                            <field name="VAR" id="!t(_s6!A^|$7hHkJs}AV">test</field>
                              <block type="convert_json2object" id=";I*2jRK-9c2`,~Ax;Pv!">
                                  <block type="get_value" id="m.!}$Y^0_[pBiYfPGVP-">
                                    <field name="OID">alexa2.0.Lists.SHOPPING_LIST.json</field>
                              <block type="controls_forEach" id="7-pH3ft4,+Themy?-14#">
                                <field name="VAR" id=":kI@a,4j*7?IgGv-BV0a">j</field>
                                <value name="LIST">
                                  <block type="variables_get" id="yrz)9c4`{Tvx2YizK(#v">
                                <statement name="DO">
                                  <block type="variables_set" id="u_J6|Y1,EvU%ZFcGpiyF">
                                      <block type="text_join" id="25}OYFEpJrJCp`tW$9X?">
                                        <value name="ADD0">
                                          <block type="variables_get" id="LKaQRHW8[PcCc@wp%NKO">
                                        <value name="ADD1">
                                          <block type="get_attr" id=",Y3S3/-+XxNi.,=nZ57C">
                                            <value name="PATH">
                                              <shadow type="text" id=",Ref0eK;FaU|1Lj+%Y/7">
                                                <field name="TEXT">value</field>
                                            <value name="OBJECT">
                                              <block type="variables_get" id="wlSureM+,7_^^ujZ#)._">
                                        <value name="ADD2">
                                          <block type="text_newline" id="n(Z7,H4-m;@6Tw,tf/d_">
                                            <field name="Type">\n</field>
                                  <block type="debug" id=";]W!thbkiT]Tmc$W!|Fo">
                                    <value name="TEXT">
                                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="d+q.({zATE2%rD*Uko)r">
                                      <block type="variables_get" id="vv#S!!b__s6aMtg(J88p">
                                      <block type="telegram" id="]MAP0iLY2Rw~ME14yYIY">
                                        <field name="INSTANCE">.0</field>
                                        <field name="LOG"></field>
                                        <value name="MESSAGE">
                                          <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="PA,`]^*J.9_=VN:QH@t$">
                                            <field name="TEXT">/opt/iobroker//iobroker-data/files//vis.0/htmlexample.html</field>
                                          <block type="variables_get" id="rs3D_iC8/UKKG*}h;A;v">
                                          <block type="control" id="F1QnCLELdJ^Nl=IRT:04">
                                              <block type="logic_boolean" id="LHA~=M:xNse{:m7%!uGk">
          @nordischerjung
          jetzt fehlt nur noch das anlegen über telegram
          https://www.youtube.com/watch?v=ZdeOv0FObnc&feature=youtu.be
            @nordischerjung
            werd dann morgen einen neuen thread dafür öffnen - es sind noch ein paar kleinigkeiten zu machen
            N 2 Replies Last reply Reply Quote 0
            • N
              @liv-in-sky super gemacht, das scheint was gutes zu werden👍
              • N
                @liv-in-sky du sendest jetzt die Liste immer wenn du einen neuen Eintrag gemacht hast?
                  @nordischerjung nee - da ist ein timer dahinter, der für die aufnahme sher kurz war - normalerweise könnte man da all paar minuten updaten
                    @nordischerjung
                    hier gehts weiter https://forum.iobroker.net/topic/42855/html-liste-für-telegram-und-vis
                      mit dem neuen github update für alexa2 adapter funktioniert das löschen wieder 🙂 🙂
                        apollon77 @liv-in-sky last edited by
                        @liv-in-sky Kommt dann als 3.11 später heute für alle in Beta
                        • MalleRalle
                          MalleRalle last edited by
                          @liv-in-sky
                          Mit dem neuen js-controller 4.0 habe ich diese Fehlermeldungen:
                          (88099) Object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                          (88099) Object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDelete is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                            liv-in-sky @MalleRalle last edited by
                            @malleralle
                            das ist ein dp mit einer werteliste. ich ändere da ein object und schreibe das.
                            wußte nicht mal, dass es schon leute gibt, die mit js-c. 4 arbeiten - kann ich erst bearbeiten, wenn ich auch js-c 4 habe.
                            zum testen:
                            es gibt 2 zeilen in dem einmal das object geschrieben wird und einmal der state
                            suche mal diese zeile und kommentiere sie aus - kommt dann die meldung immer noch ?
                            wann kommt die meldung - immer oder nur, wenn du was in der vis ausführen läßt
                            • MalleRalle
                              MalleRalle last edited by MalleRalle
                              Deine beschriebene Zeile habe ich auskommentiert.
                              Die Meldung bleibt aber.
                              Die Meldung kommt sowohl beim Löschen über VIS als auch beim Start des Scriptes z.B. beim reboot.
                              Vieleicht ist es ja das gleiche Problem wie Hier
                              Funktionieren tut es ja.
                              Also, lass Dir Zeit.
                                saeft_2003 Most Active @liv-in-sky last edited by
                                @liv-in-sky
                                Vielen Dank für das tolle Skript! Eine Frage und zwar wenn ich z.B. zur Alexa lösche Milch von der Einkaufsliste sage dann hakt sie es ab. Aber in der html Liste bleibt es, außer ich lösche es dort oder in der alexa app. Ich sehe auch das sich der DP completed bei Milch auf true geändert hat.
                                9AF65E2C-D907-417A-9E15-8408A185D4DD.png 83F196CB-679E-4C91-98A3-4905C7EA49E3.png
                                  liv-in-sky @saeft_2003 last edited by
                                  @saeft_2003
                                  im moment ist es so - die dp bleiben bestehen, wenn in der app oder über sprache ein item gelöscht wird - es ist dann nicht gelöscht, sondern erledigt. wenn man in der app alle erledigten löscht - verschwindet der dp und die liste ist wieder richtig
                                  ich habe lange nix mehr am script geändert , ich glaube, dass war früher anders - daher müßte das angeglichen werden - ich habe mit halt angewöhnt, die erledigten items glich in der app zu löschen
                                  oder anders - im moment werden alle items angezeigt - completed mit fals und true
                                    @saeft_2003
                                    versuche mal folgendes: (ich hoffe, das ganze funktioniert dann noch 🙂
                                    füge die markierten zeilen in dein script ein:
                                    if(!getState(id.replace("value","completed")).val) {
                                    MalleRalle 1 Reply Last reply Reply Quote 0
                                      @liv-in-sky
                                      Ok verstehe. Vielleicht könntest du das anpassen, ich kann leider nicht einschätzen wie aufwendig das ist. Ich wäre dir auf jeden Fall sehr dankbar.
                                      • MalleRalle
                                        MalleRalle @liv-in-sky last edited by
                                        @liv-in-sky
                                        Wenn ich z.B. sage:
                                        Alexa, lösche Brot von meiner Liste wird es auch im VIS gelöscht.
                                        Da musst Du aber noch mal dran.
                                        Diese Meldung bekomme ich immer.
                                        Ob Adapter startet oder gelöscht oder hinzugefügt wird.
                                        javascript.0	2022-02-14 14:10:00.923	warn	(627167) This object will not be created in future versions. Please report this to the developer.
                                        javascript.0	2022-02-14 14:10:00.923	warn	(627167) Object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                          @malleralle
                                          wußte garnicht, dass ich das MUSS - vielleicht musst du dann meinen aufwand bezahlen 🙂
                                          das hier ist ein script kein adapter - aber ich habe gesehen, dass jemand auf gitub vor hat, einen adapter dafür zu schreiben - daher ist die frage, ob ich da überhaupt weiterentwickeln soll.
                                          warnung:
                                          habe schon eine vermutung was das sein könnte - früher konnte man das machen, was ich da "reinprogrammiert" habe - evtl wurde das geändert - hast du den neuen js-controller4 im einsatz ? ich habe die meldung nicht
                                          @malleralle sagte in Script: Alexa Listen pflegen und Anzeigen:
                                          bei mir nicht ??? mit dem jetztigen script - arbeite aber gerade daran und werde es dann posten
                                            liv-in-sky @saeft_2003 last edited by liv-in-sky
                                            @saeft_2003
                                            kannst du bitte testen -
                                            • completed weden nicht mehr angezeigt
                                            • das löschen sollte etwas stabiler sein - da hakte es bei mir manchmal
                                             //@liv-in-sky 2020  28.3.-9:42
                                             const dpPrefix = "javascript."+ instance +".";
                                            createState("Alexa_Listen.ALEXALists.Einkauf.Anlegen"             , "",{ name: 'Anlegen_VIS',  type: 'string', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf"           , { name: 'ALEXAEinkauf_VIS',  type: 'string', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte"   , { name: 'AuswahlDeleteWert_VIS',  type: 'string', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte"  , { name: 'AuswahlDeleteTexte_VIS',  type: 'string', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.Anzahl"  , { name: 'Einkauf_Anzahl_VIS',  type: 'number', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.DeleteALL"  , { name: 'Einkauf_DeleteALL',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.Refresh"  , { name: 'Refresh',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                                            //createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete"       , { name: 'AuswahlDelete_VIS',  type: 'number', read:  true,  write: true,});
                                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete", {
                                             role: "state",
                                             type: "number",
                                             states: "0:choose ...;1:eeee;2:test1;3:test;",
                                             min: 0,
                                             max: 50,
                                             def: 0,
                                             read: true,
                                             write: true});
                                            //HIER WIRD PFAD UND FILENAME DEFINIERT
                                            const path = "/htmltelegram.html";                   //FIlenamen definieren
                                            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                            let   braucheEinFile=false;                          // bei true wird ein file geschrieben - für iqontrol
                                            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben
                                            let   braucheTelegram=true;
                                            let dpVIS=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf";                      // dp  für VIS-HTML-Basic-Widget // Datentyp: String
                                            let dPDELETE=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete";                  // Datentyp: Werteliste
                                            let dPDELETEWert=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte";         // Datentyp: String
                                            let dPDELETEAuswahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte";      // Datentyp: String
                                            let dpANLEGEN=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anlegen";                       // Datentyp: String
                                            let dpAnzahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anzahl";                         // Datentyp: Number
                                            let dpDelAll=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.DeleteALL";                      // Datentyp: Boolean
                                            let dpRefresh=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Refresh";                      // Datentyp: Boolean
                                            let mySchedule=" */30 * * * * * ";
                                            let sortList=1;        // SORTIERUNG 1=nach datum; 2 nach Einkauf's
                                            let mitErstelldatum=false;
                                            var symbolLink="⚪";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵
                                            let farbeSchalterON="blue";
                                            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                                            var htmlFeld1='Einkauf';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left or center
                                            var htmlFeld2='Del';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                            var htmlFeld3='Erstellt vor';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                            //hier werden die styles für die tabelle definiert
                                            //ÜBERSCHRIFT ÜBER TABELLE
                                            let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                                            let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                            const htmlFeldUeber='ALEXA Einkaufsliste';              // Überschrift und Signature
                                            const htmlFarbUber="white";                         // Farbe der Überschrift
                                            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                                            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                                            //MEHRERE TABELLEN NEBENEINANDER
                                            let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                            const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                                            const farbetrennungsLinie="white";
                                            const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                            //ÜBERSCHRIFT SPALTEN
                                            const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                            const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                                            const farbeLinieUnterUeberschrift="white";
                                            const groesseUeberschrift=16;
                                            const UeberschriftStyle="normal"                     // möglich "bold"
                                            //GANZE TABELLE
                                            let abstandZelle="3";
                                            let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                            let farbeGeradeZeilen="#2E2E2E";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                            let weite="auto";                                     //Weite der Tabelle
                                            let zentriert=true;                                   //ganze tabelle zentriert
                                            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                            const htmlSchriftart="Helvetica";
                                            const htmlSchriftgroesse="14px";
                                            //FELDER UND RAHMEN
                                            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                                            const htmlFarbFelderschrift="#36d5ec";                  // SchriftFarbe der Felder
                                            const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                            const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                            let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                            // HIER NICHTS  ÄNDERN
                                            let borderHelpBottum;
                                            let borderHelpRight;
                                            let htmlcenterHelp;
                                            let htmlcenterHelp2;
                                            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                            const htmlZentriert='<center>'
                                            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                               " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                               " </style></head><body> <div>";
                                            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                            const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
        "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                            const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                            const htmlTabUeber3="</tr>";
                                            table td:first-child {}  //1
                                            table td:nth-child(2) {} //2
                                            table td:nth-child(3) {} //3
                                            table td:last-child {}   //4
                                            const buttonScript =  '<script> function setOnDblClickCustomShop( myvalue ) {	var Self = this; var objID = myvalue;	vis.setValue(myvalue,true);  var2 = \"' + dpPrefix + 'Alexa_Listen.ALEXALists.Einkauf.Refresh\"; vis.setValue(var2,true);  console.log("www")  } </script>'
                                            // const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, true);  }); var2 = \"javascript.0.Alexa_Listen.ALEXALists.Einkauf.Refresh\"; Self.servConn.setState(var2, true); console.log("www")} </script>'
                                            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                               	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                            var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                               "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                                            var htmlTabUeber="";
                                            var htmlOut="";
                                            var mix;
                                            var counter;
                                            var warte;
                                            var myIDArr=[];
                                            let myDeleterArr;
                                            var myRememberList="";
                                            var myTelegram=false;
                                            var telegramString="telegram.0";
                                            //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                                            var val1; var val2; var val0; var val3; var valSort;
                                            function writeHTML(){
                                            htmlOut="";
                                            counter=-1;
                                            htmlTabUeber="";
                                            switch (mehrfachTabelle) {
                                               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                               case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                            if (!UeberschriftSpalten) {htmlTabUeber=""}
                                            var valID; var myListWerte=""; var myListAuswahl="";
                                            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                            //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                                            var myArr=[]; var myList=""; var myListArr=[]; myIDArr=[]; myDeleterArr=[];
                                             let myhelerArr=getState("alexa2.0.Lists.SHOPPING_LIST.json").val;
                                            myListArr.push('0'+":"+'choose ...'+";");
                                                        myListWerte=myListWerte+"choose ..."+";";
                                                       myListAuswahl=myListAuswahl+(0+";");
                                                       myIDArr.push("dummy");
                                            $('alexa2.0.Lists.SHOPPING_LIST.items.*.value').each(function(id, i) {           // hier eigene schleife definierenalexa2.0.Lists.SHOPPING_LIST.items.0f43141e-029c-4860-bcd0-828702b0dc86.value
                                                    let ida=id.split('.')
                                                   // log(myhelerArr)
                                                   // log(myhelerArr.includes(ida[5]))
                                                     if(myhelerArr.includes(ida[5])) {
                                                       val0=getState(id).val;
                                                       val1=getState(id.replace("value","completed")).val;
                                                       val2=valSort=getState(id.replace("value","updatedDateTime")).val;
                                                       valID=getState(id.replace("value","id")).val;
                                                       myIDArr.push(valID);
                                                       var yy= (Math.round((new Date()).getTime() / 1000))-Math.round(val2/1000);
                                                       val2=formatDate(getDateObject(val2), "TT.MM(SS:mm)")
                                                       val3=(Math.floor( ((yy)/60/60/24) )+"d "+ Math.floor(((yy)/60/60) % 24) +"h "+ Math.floor( ((yy)/60) % 60 )+"m")
                                                    //   if (val1==false) {val1="❌"} else{val1="✅"}
                                                        let valButton=id.replace("value","#delete")
                                                        myDeleterArr.push(id.replace("value","#delete"))
                                                       //log(valButton)
                                                       val1="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustomShop\(\'"+valButton+"\')\">"+symbolLink + "</button> <font color=\""+farbeSchalterON+"\">";
                                                       myArr.push([val0,val1,val2,val3,valSort]);
                                                       val0=val0.replace(/,/g,'-');
                                                       myListArr.push((i+1)+":"+val0+";");
                                                       myListWerte=myListWerte+val0+";";
                                                       myListAuswahl=myListAuswahl+(i+1)+";";
                                                      }} else{ //log('alexa2.0.Lists.SHOPPING_LIST.items.'+ida[5]);
                                                               deleteObject('alexa2.0.Lists.SHOPPING_LIST.items.'+ida[5], true);
                                                 //  log(myIDArr.toString())
                                                    //log (myListArr.toString());
                                                   for (var x=0;x<myListArr.length;x++){
                                                     myList=myList.concat(myListArr[x]);
                                                    // log(myListArr[x]);
                                                     //log(myList);
                                                  // log("-----------myList : "+myList)
                                                   if(myList!=myRememberList){
                                                       myTelegram=true; //log("ist true")
                                                       setStateDelayed(dPDELETEWert, myListAuswahl,500);
                                                       setStateDelayed(dPDELETEAuswahl,  myListWerte,500);
                                                     var timeout = setTimeout(function () {
                                                       // var obj = getObject(dPDELETE);
                                                        // log("11---"+myList);
                                                       // obj.common.states=myList;
                                                        myRememberList=myList;
                                                        //log("22---"+myList);
                                                       extendObject(dPDELETE, {common: {states: myList}});
                                                     }, 400);
                                             //SORT
                                               if (sortList==1) {
                                                             myArr.sort(function (alpha, beta) {
                                                          if (alpha[4] > beta[4])
                                                             return -1;
                                                          if (beta[4] > alpha[4])
                                                             return 1;
                                                          return 0;
        } else
                                                   {          myArr.sort(function (alpha, beta) {
                                                          if (alpha[0].toUpperCase() > beta[0].toUpperCase())
                                                             return 1;
                                                          if (beta[0].toUpperCase() > alpha[0].toUpperCase())
                                                             return -1;
                                                          return 0;
        telegramString="";
                                              for (var x=0 ; x<myArr.length ; x++) {
                                                  counter++;
                                                 //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
                                                   val0=myArr[x][0];
                                                   val1=myArr[x][1];
                                                   var val2help=myArr[x][2]
                                                   var val3help=myArr[x][3];
                                                   if (mitErstelldatum) {val2=val3help+" am "+val2help;} else {val2=val3help}
                                                   if (backgroundAll) {
                                                      telegramString=telegramString+ myArr[x][0] + " - "+myArr[x][2] + '\n';   // "-"+ myArr[x][1]  +
                                                    tabelleBind();
                                            //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                                  tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                            } // function ende
                                            //MAIN:
                                            schedule(mySchedule,  function () {
                                              if(!getState(dpDelAll).val) writeHTML();
                                                if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                                }, 500);
                                            writeHTML();
                                             }, 2000);                                  //     <tdalign
                                             function tabelleBind(){
                                               //  counter=counter+mehrfachTabelle;
                                                     case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                                     case 2: if(counter%4==0){
        if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
        }else{
        if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                                     case 3:if(counter%2==0)   {
        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //Teil1 c=0
        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //Teil 2 c=1
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";} //Teil 3 c=3
        } break;}else{
        if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}
                                                     case 4:  // counter=counter+8;
                                                               if(counter%8==0)   {
                                                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                                    } //switch ende
                                            function tabelleFinish() {
                                                   case 1:    break;
                                                   case 2:
                                                              if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                              break;
                                                   case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                             if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                             if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                              break;
                                                   case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                                             if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                             if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                             if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                                             break; }
                                                     var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                                    if (!htmlSignature) htmlUnter="";
                                                      //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                                       var htmlOutVIS="";
                                                     //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                                        if (htmlUberschrift)
                                                            { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript ;
                                                          } else {
                                                           zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript;
                                              // log("bin raus aus tabelleBind");
                                                       if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                              var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                             //mit oder ohne überschrift - zentriert oder links
                                            htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                             //log(htmlOut);
                                             setState(dpANLEGEN,"");
                                             setState(dpAnzahl,(counter+1));
                                             setState(dPDELETE,0);
                                             if(myTelegram && braucheTelegram){
                                                 //log("sende");
                                                 myTelegram=false;
                                                sendTo('telegram.0', {
                                               text: (telegramString),
                                               type: 'text'
                                            telegramString="";
                                            } // function ende
                                            on({id: dPDELETE, ack: false, change: "ne"}, function (obj) {
                                               let a=getState(dPDELETE).val;
                                               if (a!=0){
                                               let toDelete=myIDArr[getState(dPDELETE).val];
                                               var stateHelp="alexa2.0.Lists.SHOPPING_LIST.items."+toDelete+".#delete"
                                               setState(stateHelp,true);
                                               writeHTML(); }, 4000);
                                              // log("1+bin im on !!!+++!"+a+stateHelp)
                                               on({id: dpANLEGEN, ack: false, change: "ne"}, function (obj) {
                                                  // log(getState(dpANLEGEN).val+"----aa");
                                                   if(getState(dpANLEGEN).val!="") {
                                                setState("alexa2.0.Lists.SHOPPING_LIST.#New",getState(dpANLEGEN).val)
                                               writeHTML(); }, 2000);
                                                   on({id: dpRefresh, ack: false, change: "any"}, function (obj) {
                                                   //log(getState(dpANLEGEN).val+"----refresh");
                                                   var timeout2 = setTimeout(function () {
                                                  on({id: myDeleterArr, ack: false, change: "any"}, function (obj) {
                                                 on({id: dpDelAll, ack: false,val: true}, function (obj) {
                                             let i;
                                             for (i=0;i<myIDArr.length;i++) {//log("hier : "+myIDArr[i]);
                                               if (myIDArr[i]!="dummy") {
                                               let toDelete=myIDArr[i];
                                                  setTimeout( function timer(){
                                               log("Statehelp: "+stateHelp)
                                               }, i*2500 );
                                               log(i.toString())
                                                    setState(dpDelAll,false);
                                                    writeHTML(); }, (1+myIDArr.length)*1500);
                                              // log(stateHelp)
                                            S 2 Replies Last reply Reply Quote 1
                                            1.0k
                                            javascript template
                                            29
                                            409
                                            78316
