    4. Test Adapter renault v0.0.x für myRenault und myDacia
      guergen @tombox last edited by guergen
      @tombox Grade erledigt, werde es weiter beobachten!
      Zur Info: grade kane die Koordinaten wieder mit Komma und nur 7 bzw. 8-stellig hinter dem Komma, also insgesamt 10-stellig rein!
      Ich weiss zwar nicht, was du hier gemacht hast, aber guck mal: 214a12ce-39e0-4a99-9333-026bb6eb10f6-grafik.png
        @tombox Jetzt kommen folgende Meldungen:
        renault.0
        	2021-10-09 15:39:28.275	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
        renault.0
        	2021-10-09 15:39:28.275	error	Error: Request failed with status code 403
        renault.0
        	2021-10-09 15:39:28.274	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-e2eb-4ce4-866f-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/FIN/charge-history?type=day&start=1970-01-01&end=2021-10-09&country=de
        renault.0
        	2021-10-09 15:39:27.679	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
        renault.0
        	2021-10-09 15:39:27.678	error	Error: Request failed with status code 403
        renault.0
        	2021-10-09 15:39:27.677	error	https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/1606d5a2-e2eb-4ce4-866f-bcf14cf103d3/kamereon/kca/car-adapter/v1/cars/FIN/charges?start=1970-01-01&end=2021-10-09&country=de
          tombox @guergen last edited by
          @guergen hast du ein e Auto waren die charges und charge history vorher gefüllt ?
            @tombox Kein E-Auto, Benzin und LPG
            Der Chargemode ist leer.
              @guergen In der aktuellen version werden die Abfragen gestoppt wenn so ein Fehler kommt
                @tombox Also es kommt echt drauf an, wo ich genau parke... mal mit komma, mal ohne
                Oder es kommt darauf an, was Renault mir für eine Location sendet....
                Heute Nachmittag hatte ich wahrshceinlich ein kurze (8-stellige logitude), da hagelte es Fehler, jetzt habe ich wieder eine lange und alles ist schick 😉
                  @guergen eigentlich sollten kein fehler kommen kannst du den ordner location löschen und den adapter neustarten
                    @tombox Erledigt, mal sehen was morgen passiert....
                      Tudo @guergen last edited by
                      ich habe die Version 0.0.3 installiert. Die Daten scheinen zuverlässig zu kommen. Jedoch funktioniert die remote Funktion nicht.
                      Wenn ich z.B. die Heizung einschalten will und den Wert auf true setze, tut sich nichts.
                      So sieht der Log aus:
                      Ich habe einen Renault Twingo Electric Intense.
                      Grüße und Danke für die Arbeit,
                      Udo
                        tombox @Tudo last edited by
                        @tudo geht es denn über die App
                          Tudo @tombox last edited by
                          @tombox Ja, es geht über die App und auch, wenn ich statt des Renault, den zoe2 Adapter starte.
                            @tudo installier nochmal neu und probier nochmal kannst auch den debug log mir via privat nachricht schicken
                            G SunkHD 2 Replies Last reply Reply Quote 0
                              @tombox Bei mir erscheint jetzt schon wieder:
                              renault.0
                              	2021-10-14 15:26:47.675	info	State value to set for "renault.0.FIN.location.gpsLatitude" has to be type "string" but received type "number"
                                @guergen
                                hast du wirklich den adapter Neuinstalliert
                                Location Ordner gelöscht
                                und dann den adapter Neustarten
                                  @tombox Ja, habe ich ,.... schon mehrfach; grade soar mein System neu installiert und dennoch bekomme ich den Fehler!
                                    @guergen Ich hab in der github version nochmal die typen für die gps location angepasst.
                                    Die Objekte nochmal löschen, neuinstallieren und dann sollte der type mixed sein.
                                      @tombox OK, grade installiert, Typ ist mixed.
                                      Ich sage Bescheid, wenn was nicht ganz rund läuft.
                                      Version ist jetzt 0.0.5
                                        heinzie last edited by
                                        ich verwende den Adapter (0.0.5) für eine zeo und läuft eigentlich auch einwandfrei. Das einzige Problem ist, dass der Adapter immer nach 1-2 Tagen keine neuen Werte holt. Wenn ich dann händisch einen Reset des Adaptzers vornehme läuft we weider ~1-2Tage.
                                        Ist der Fehler ggf. schon bekannt?
                                        2021-12-07 13:41:40.393	info	{"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
                                        renault.0
                                        	30078	2021-12-07 13:41:40.392	info	Error: Request failed with status code 502
                                        renault.0
                                        	30078	2021-12-07 13:41:40.391	info	Feature not found. Ignore lock-status for updates.
                                        renault.0
                                        	30078	2021-12-07 13:41:40.120	info	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
                                        renault.0
                                        	30078	2021-12-07 13:41:40.120	info	Error: Request failed with status code 403
                                        renault.0
                                        	30078	2021-12-07 13:41:40.118	info	Feature not found. Ignore res-state for updates.
                                        renault.0
                                        	30078	2021-12-07 13:41:38.199	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.renault, node: v14.15.4, js-controller: 3.3.20
                                          guergen @heinzie last edited by guergen
                                          @heinzie Kann ich bestätigen, dachte es läeg an meinem System...
                                          Bekomme aber nur den Fehler 402
                                            Homoran Global Moderator Administrators @guergen last edited by Homoran
                                            @guergen
                                            @heinzie
                                            Auch der zoe2-Adapter hat immer mal wieder keine Verbindung zu myRenault.
                                            Das liegt an der immer wieder kritisierten Renault Cloud
                                            Der Zoe2 kommt dann aber beim nächsten mal wieder.
                                            ggf. liegt es auch daran, wenn man parallel die App nutzt und (vielleicht) zu viele Zugriffe generiert
                                            358
                                            59676
