    4. Adapter: ebus
    Adapter: ebus
      winny1900 @Dre83 last edited by
      Bei mir läuft es nun auch so la la.
      Meine frage: Wenn ich das hier ausführe steht da no data stored
      root@ServerEbus:/home/pi# ebusctl find
      boiler nominal = no data stored
      boiler status = no data stored
      boiler tb = no data stored
      broadcast datetime = 11.398;10:15:34;12.10.2021
      buffer boiler_b = no data stored
      buffer flow = no data stored
      buffer heating = no data stored
      buffer nominal = no data stored
      buffer status_b = no data stored
      buffer tpm = no data stored
      buffer tpo = no data stored
      circuit1config manualT = no data stored
      circuit1config status = no data stored
      circuit1mode manualtemp = no data stored
      circuit1mode modeC1 = no data stored
      circuit1preferences dayTH = no data stored
      circuit1preferences heating_limit = no data stored
      circuit1preferences heatinglimit = no data stored
      circuit1preferences nightTH = no data stored
      circuit1preferences outsideTH = no data stored
      circuit1preferences pointtemp = no data stored
      circuit1preferences remotecontrol = no data stored
      circuit1preferences roomfrost = no data stored
      circuit1preferences supplyTH = no data stored
      curveC outsideC = no data stored
      curveC pointC = no data stored
      curveC supplyC = no data stored
      curveH outsideH = no data stored
      curveH pointH = no data stored
      curveH supplyH = no data stored
      heatpump coolkwh = no data stored
      heatpump coolmwh = -;31;00;00;0;0;0
      heatpump cycles = no data stored
      heatpump heatkwh = no data stored
      heatpump heatmwh = no data stored
      heatpump hours = no data stored
      heatpump nominal = no data stored
      heatpump status = no data stored
      heatpump tqa = 71;0;0d;02;1000;0;10.8
      heatpump tqe = 80;1;1d;00;1;7721;0.0
      heatpump twr = 70;0;0d;02;1000;0;6.9
      heatpump twv = 7;0;0d;02;1000;0;32.0
      heatpump volumekwh = no data stored
      heatpump volumemwh = no data stored
      heatpump waterkwh = no data stored
      heatpump watermwh = no data stored
      heatpump_m mode = 53;1;00;00;255;0;Extern gesperrt
      master 10u0503 = 1;0;0;0.0;1;0
      master data1 = 32.398;-;0;0;0;0;0;0;1;27.398
      master data2 = 0.000;53.000;0;0;2
      scan.06  = TEM;25440;0113;0000
      scan.08  = TEM;WE_1 ;3632;3030
      scan.15  = TEM;24849;0605;0102
      scan.18  = TEM;WE_2 ;3632;3030
      target dayC = no data stored
      target dayH = no data stored
      target limitH = no data stored
      target nightC = no data stored
      target nightH = no data stored
      target SpointS = no data stored
      target Ssummer = no data stored
      temperature boiler2 = no data stored
      temperature buffer1 = 96;0;0d;02;1000;0;32.4
      temperature buffer2 = no data stored
      temperature outside1 = no data stored
      temperature outside2 = no data stored
      temperature outside = 0;0;0d;02;500;-500;11.4
      temperature tqe1 = no data stored
      temperature twr1 = no data stored
      temperature twv1 = no data stored
      temperature water = 4;0;0d;02;1000;0;52.3
      unknow 01940048 = no data stored
      unknow 01960042 = no data stored
      unknow 01cc0042 = no data stored
      unknow 02c60040 = 70;65;04;28;-1;0;192
      unknow 02c80040 = 72;65;04;2a;1439;0;103
      Dann kann ich mit z.B.
      root@ServerEbus:/home/pi# ebusctl r -c heatpump volumekwh
      218;10;0d;34;1000;0;0.0
      den wert holen.
      Nach einen reboot sind diese Werte alle wieder auf no data stored.
      Gibt's da ne Lösung für?
      • Rene_HM
        Rene_HM Developer @winny1900 last edited by
        @winny1900 typischerweise lauscht der ebusd nur, was am Bus vorbeikommt. Wenn kein anderes Gerät die Daten abfragt, gelangen sie nicht auf den Bus und somit auch nicht in ebusd. Zusätzlich speichert ebusd keine Daten. Wenn du also möchtest, das bestimmte Daten aktualisiert werden, musst du sie aktiv abfragen, was du ja mit
        ebusctl r
        schon machst.
          winny1900 @Rene_HM last edited by
          @rene_hm also wenn ich dieses einmal eingelesen habe sind die Werte ja einmal da.
          Wofür kann ich im ebus Adapter die Abfrage Werte eintragen die mit einem , getrennt werden?
          Oder muss ich wenn ich diese Werte alle 5 min aktualisiert haben möchte das über ein Script lösen
          • Rene_HM
            @winny1900 sagte in Adapter: ebus:
            nein, genau dafür ist die Funktion da. Ich schicke für jeden Wert, der in der Liste steht ein "read" an den ebusd inkl. Parameter, dass der read auch auf den Bus gelegt wird.. Das mit dem script benötigt man, wenn man weitere Parameter nutzen möchte, wie z.bsp. von @Dre83 oben beschrieben wurde
              @rene_hm okay das heißt wenn ich möchte das heatpump tqa ausgelesen wird, muss ich das dann da eintragen. Der Abfrage Punkt wäre tqa,usw......
              • Rene_HM
                @winny1900 du musst den Namen des Datenpunktes (z.Bsp. tqa) eintragen. Bei mir sieht das so aus:
                  @rene_hm
                  hier heißt es buffer nominal und in der HTML nur nominal. Nominal gibt es auch mehrmal.
                  Müsste ich dann nominal, eitragen oder buffernominal, ??
                  • Rene_HM
                    @winny1900 schau bitte die Datenpunkte in ioBroker an. Dort nimmst du den nur Namen des Datenpunktes.
                      @rene_hm muss ich dafür Telnet haben ?
                      Weil die Werte stehen so in der Config.
                      • Rene_HM
                        @winny1900 nein, siehe hier (als Beispiel):
                          winny1904 last edited by
                          hab ich ja so richtig.
                          Der Wert ist von 17:37 Uhr . Aktuell sind es 22,3
                          Nach dem ich auf dem PI
                          ebusctl r -c temperature tqa1
                          wird wieder Aktualsiert
                          • Rene_HM
                            Rene_HM Developer @winny1904 last edited by Rene_HM
                            @winny1904 kannst du den Adapter mal auf debug schalten und schauen, welche Meldungen bzgl. tqa1 kommen?
                            es wird geloggt, was per telnet gesendet wird und was vom ebusd wieder zurück kommt.
                            Beispiel:
                            2021-10-14 19:25:07.437	debug	received on for Hc1Pump
                            2021-10-14 19:25:07.279	debug	send cmd read -f Hc1Pump
                            2021-10-14 19:25:07.277	debug	received on for CirPump
                            2021-10-14 19:25:07.083	debug	send cmd read -f CirPump
                            Du kannst auch versuchen, anstatt
                            tqa1
                            den gleichen string wie am Raspi in die Liste aufzunehmen (ohne "ebusctl r ")
                            -c temperature tqa1
                            Komma kommt dann hinter tqa1 und dann das gleiche für den nächsten Wert...
                            @Dre83 das könnte auch bei dir funktionieren...
                            • Rene_HM
                              Rene_HM Developer @Rene_HM last edited by
                              @Dre83 , @winny1904 ich habe mal den Adapter ein wenig umgebaut. Man kann jetzt den circuit und weitere Parameter für die abgefragten Datenpunkte hinzufügen.
                              Damit sollten die Möglichkeiten des ebusd komplett abbildbar sein. Der circuit und die zusätzlichen Parameter sind optional. Wenn man die weglässt, funktioniert alles wie bisher. Fügt man einen circuit hinzu, wird "-c circuit_name" dem Kommando hinzugefügt. Wenn man weitere Parameter laut ebusd-Doku hinzufügt, werden diese einfach mitgeschickt.
                              Das ganze sieht im admin so aus:
                              Wenn ihr wollt, könnt ihr das schon testen. Die Version liegt im github (aber noch nicht im NPM).
                              Achtung: das ganze ist abwärtskompatibel, d.h. die neue Version übernimmt die Einstellungen von der alten Version. ABER: wenn man dann wieder die alte Version installiert, ist die Komma-separierte Liste leer. Dann einfach die Liste wieder eintragen und speichern...
                              Ich baue jetzt die command-Funktion noch um. Damit kann man zukünftig mehrere Befehle wegschicken...
                              • Rene_HM
                                Rene_HM Developer last edited by
                                @rene_hm sagte in Adapter: ebus:
                                Im github und NPM liegt die 2.4.0 zum Testen bereit.
                                siehe auch github
                                Es gibt folgende Änderungen:
                                • die Einstellung für die gepollten Datenpunkte und die für die History-Datenpunkte wurden überarbeitet. Man kann nun den circuit und weitere Parameter (beides optional) angeben.
                                • Der Datenpunkt ebus.0.cmd interpretiert nun eine Liste von Kommandos.
                                • Die vielen Warnungen aufgrund fehlender Daten wurde zu debug-Meldungen
                                Feedback ist wie immer willkommen...
                                  winny1900 @Rene_HM last edited by winny1900
                                  @rene_hm
                                  Moin danke.
                                  Das Heißt der Circuit ist gleich Schaltkreis. In minem Fall wäre es dann heatpump , buffer usw... ??
                                  Weil den Namen Nominal gibt's 2 mal bei mir. Wenn ich nun buffer nominal haben möchte schreibe ich bei Circuit buffer und bei Name Nominal richtig ?
                                  Eine Frage am Rande. Wie finde ich den Telnet port von Pi raus ??
                                    Cino last edited by
                                    Steht in der Config von ebusd
                                      winny1900 @Cino last edited by winny1900
                                      Muss ich telnet nur haben wenn ich die Werte schreiben möchte ?
                                      Oder brauch ich telnet auch wenn ich Werte über cmd abfragen möchte???
                                        Cino last edited by
                                        nur wenn du schreiben wirst. Die Abfragen laufen über http
                                        • Rene_HM
                                          cmd sind Kommandos, die über telnet an ebusd gesendet werden...
                                          • Rene_HM
                                            Viel interessanter ist aber, auf welchen Port ebusd reagiert! Das kannst per Konfiguration einstellen:
                                            in /etc/default/ebusd
                                            EBUSD_OPTS = "--port 8890 --httpport=8889"
                                            hier lauscht der ebusd auf Port 8890
                                            siehe auch https://github.com/john30/ebusd/wiki/2.-Run#daemon-options
                                            1.3k
                                            ebus adapter
                                            71
                                            708
                                            248614
