    4. Fehler bei SQL 1.4.2
    • sissiwup
      sissiwup last edited by
      da steht:
      38 var adapter = utils.adapter('sql');
           39 adapter.on('objectChange', function (id, obj) {
           40     if (obj && obj.common && (
           41             // todo remove history sometime (2016.08) - Do not forget object selector in io-package.json
           42         (obj.common.history && obj.common.history[adapter.namespace]) ||
           43         (obj.common.custom  && obj.common.custom[adapter.namespace])) &&
           44         (obj.common.custom[adapter.namespace].enabled)
           45     ) {
           46         if (!sqlDPs[id] && !subscribeAll) {
        apollon77 last edited by
        jetzt kapier ichs nimmer … versuch nochmal nicht das beim letzten update nicht neu gestartet war und deswegen noch das alte lief ... 😉
        ANsonsten kann ichs echt nicht mehr verstehen weil jetzt auch die Spaltennummer nicht mehr 49 sein kann ...
        • sissiwup
          Neustart hat er heute Nacht automatisch gemacht.
          Restart REGA-Adapter:
          hm-rega.0	2017-02-18 10:57:05.154	info	added/updated 66 variables
          hm-rega.0	2017-02-18 10:57:04.640	info	got 66 variables
          zotac	2017-02-18 10:57:04.637	info	host.zotac Restart adapter system.adapter.sql.0 because enabled
          zotac	2017-02-18 10:57:04.636	error	host.zotac instance system.adapter.sql.0 terminated with code 6 (uncaught exception)
          sql.0	2017-02-18 10:57:03.650	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.650	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.650	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.649	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.649	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.648	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.648	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.647	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.647	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.647	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.646	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.646	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.646	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.644	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.644	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.644	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.643	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.643	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.643	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.642	error	uncaught exception: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.344	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
          sql.0	2017-02-18 10:57:03.318	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
          sql.0	2017-02-18 10:57:03.316	error	uncaught exception: Cannot read property 'sql.0' of undefined
          hm-rega.0	2017-02-18 10:57:03.278	info	deleted 0 programs
          hm-rega.0	2017-02-18 10:57:03.278	info	added/updated 89 programs
          hm-rega.0	2017-02-18 10:57:02.944	info	got 89 programs
          hm-rega.0	2017-02-18 10:57:00.781	info	added/updated rooms to enum.room
            Jetzt ists auch ne andere Zeilennummer 🙂
            Kannst Du mir einen gefallen tun (sonst muss ich weiter raten): Überleg mal welcher der hm-Datenpunkte die DU loggst der ist der am längsten loggt. Un bei den gehst DU in der "Objekte"-Ansicht auf den Stift rechts am Ende. Dort auf "Raw-Ansicht (Experten only)" und schick mir mal das JSON was Du da siehst. Dann sollte das simpel sein final zu fixen weil ich das Problem jetzt im Blick hab
            • sissiwup
                "common": {
                  "name": "HZ-01:4.ACTUAL_TEMPERATURE",
                  "type": "number",
                  "unit": "°C",
                  "role": "value.temperature",
                  "def": 0,
                  "min": -10,
                  "max": 56,
                  "read": true,
                  "write": false,
                  "custom": {
                    "history.0": {
                      "enabled": true,
                      "changesOnly": true,
                      "minLength": 480,
                      "maxLength": 960,
                      "retention": 0,
                      "debounce": 10000
                    "sql.0": {
                      "enabled": true,
                      "changesOnly": false,
                      "debounce": 1000,
                      "retention": 63072000
                "native": {
                  "CONTROL": "HEATING_CONTROL.TEMPERATURE",
                  "ID": "ACTUAL_TEMPERATURE",
                  "TYPE": "FLOAT",
                  "UNIT": "�C",
                  "DEFAULT": 0,
                  "FLAGS": 1,
                  "MAX": 56,
                  "MIN": -10,
                  "OPERATIONS": 5,
                  "TAB_ORDER": 5
                "acl": {
                  "object": 1638,
                  "owner": "system.user.admin",
                  "state": 1638
                "_id": "hm-rpc.0.MEQ0008905.4.ACTUAL_TEMPERATURE",
                "type": "state"
                Der kanns nicht sein … aber naja ... versuch mal neu mit der github version ... und nach install (ist dann die 1.4.5) neu startenvom sql Adapter und dann versuch nochmal
                • sissiwup
                  welcher der wirklich älteste ist, weiss ich nicht, habe einen recht alten ausgewählt.
                  Mit neuer Version 1.4.5:
                  sql.0	2017-02-19 15:36:24.010	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:24.010	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:24.010	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:24.009	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:24.009	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:24.009	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.694	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.694	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.693	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.570	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.569	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.569	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.569	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.568	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.568	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.568	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.562	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.562	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.562	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.561	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.561	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.561	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.560	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.306	warn	Exception: TypeError: Cannot read property 'sql.0' of undefined
                  sql.0	2017-02-19 15:36:23.306	error	TypeError: Cannot read property 'sql.0' of undefined at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:44:27) at emitTwo (events.js:106:13) at Adapter.emit (events.js
                  sql.0	2017-02-19 15:36:23.305	error	uncaught exception: Cannot read property 'sql.0' of undefined
                  hm-rega.0	2017-02-19 15:36:23.278	info	deleted 0 programs
                  hm-rega.0	2017-02-19 15:36:23.278	info	added/updated 89 programs
                  hm-rega.0	2017-02-19 15:36:22.923	info	got 89 programs
                  hm-rega.0	2017-02-19 15:36:21.147	info	added/updated rooms to enum.rooms
                  hm-rega.0	2017-02-19 15:36:20.872	info	added/updated functions to enum.functions
                  hm-rega.0	2017-02-19 15:36:20.385	info	added/updated 26 favorites to enum.favorites
                  hm-rega.0	2017-02-19 15:36:20.077	info	time difference local-ccu 0s
                  hm-rega.0	2017-02-19 15:36:20.004	info	ReGaHSS 192.168.1.11 up
                  hm-rega.0	2017-02-19 15:36:18.934	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                  hm-rega.0	2017-02-19 15:36:18.917	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                  host.zotac	2017-02-19 15:36:17.848	info	instance system.adapter.hm-rega.0 started with pid 397
                  host.zotac	2017-02-19 15:36:15.410	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                  hm-rega.0	2017-02-19 15:36:15.343	info	terminating
                  host.zotac	2017-02-19 15:36:15.287	info	stopInstance system.adapter.hm-rega.0 killing pid 19130
                  host.zotac	2017-02-19 15:36:15.284	info	object change system.adapter.hm-rega.0
                  host.zotac	2017-02-19 15:34:42.429	info	Update repository "default" under "conf/sources-dist.json"
                  iobroker	2017-02-19 15:34:42.114	info	exit 0
                    Also irgendwie hat Install von Github nicht geklappt oder restart hat gefehlt.Zeilennnummer des Fehlers passen wieder nicht zur neuen Version 🙂
                    Ab Zeile 40 muss es so aussehen: https://github.com/ioBroker/ioBroker.sq … ain.js#L40
                    • sissiwup
                      der sql-Adapter ist immer neu gestartet. Der Rest natürlich nicht.
                      Aber nach Neustart heute Nacht kommt folgendes:
                      admin.0	2017-02-20 11:53:06.174	info	received all states
                      admin.0	2017-02-20 11:53:05.196	info	Subscribe on all states again
                      admin.0	2017-02-20 11:52:33.385	info	Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                      hm-rega.0	2017-02-20 11:52:30.021	info	got state values
                      hm-rega.0	2017-02-20 11:52:25.223	info	request state values
                      hm-rega.0	2017-02-20 11:52:25.221	info	deleted 0 variables
                      hm-rega.0	2017-02-20 11:52:25.220	info	added/updated 66 variables
                      hm-rega.0	2017-02-20 11:52:24.707	info	got 66 variables
                      hm-rega.0	2017-02-20 11:52:23.758	info	deleted 0 programs
                      hm-rega.0	2017-02-20 11:52:23.757	info	added/updated 89 programs
                      hm-rega.0	2017-02-20 11:52:23.430	info	got 89 programs
                      hm-rega.0	2017-02-20 11:52:22.050	info	added/updated rooms to enum.rooms
                      hm-rega.0	2017-02-20 11:52:21.348	info	added/updated functions to enum.functions
                      hm-rega.0	2017-02-20 11:52:20.867	info	added/updated 26 favorites to enum.favorites
                      hm-rega.0	2017-02-20 11:52:20.517	info	time difference local-ccu 1s
                      hm-rega.0	2017-02-20 11:52:20.439	info	ReGaHSS 192.168.1.11 up
                      hm-rega.0	2017-02-20 11:52:19.394	info	subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                      hm-rega.0	2017-02-20 11:52:19.377	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.9.2
                      host.zotac	2017-02-20 11:52:18.155	info	instance system.adapter.hm-rega.0 started with pid 31795
                      host.zotac	2017-02-20 11:52:15.724	info	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                      hm-rega.0	2017-02-20 11:52:15.652	info	terminating
                      host.zotac	2017-02-20 11:52:15.607	info	stopInstance system.adapter.hm-rega.0 killing pid 21557
                      host.zotac	2017-02-20 11:52:15.605	info	stopInstance system.adapter.hm-rega.0
                      host.zotac	2017-02-20 11:52:15.598	info	object change system.adapter.hm-rega.0
                      host.zotac	2017-02-20 11:46:03.026	info	instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                        Ja das sieht doch dann nach "kein Fehler mehr "aus, oder ?! :-)))
                        1782
