    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      fichte_112 last edited by
      seit dem letzten Update werden bei mir die Koordinaten der Ortung nicht mehr richtig übertragen.
      Hat noch jemand dieses Problem?
      Newan 1 Reply Last reply Reply Quote 0
      • Newan
        Newan @fichte_112 last edited by
        @fichte_112 möglicherweise hab ich da was ungebaut. Bräuchte mal die debug Ausgabe
          fichte_112 @Newan last edited by
          @newan said in Adapter Hyundai (Bluelink) oder KIA (UVO):
          2021-10-14 07:52:35.281 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true)
          2021-10-14 07:52:35.298 - info: bluelink.0 (110216) Got terminate signal TERMINATE_YOURSELF
          2021-10-14 07:52:35.299 - info: bluelink.0 (110216) Adapter bluelink cleaned up everything...
          2021-10-14 07:52:35.300 - info: bluelink.0 (110216) terminating
          2021-10-14 07:52:35.302 - info: bluelink.0 (110216) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2021-10-14 07:52:35.321 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal
          2021-10-14 07:52:35.874 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2021-10-14 07:52:38.431 - info: host.debian instance system.adapter.bluelink.0 started with pid 112864
          2021-10-14 07:52:41.087 - info: bluelink.0 (112864) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18
          2021-10-14 07:52:41.210 - info: bluelink.0 (112864) Login to api
          2021-10-14 07:52:46.311 - info: bluelink.0 (112864) Vehicles found
          2021-10-14 07:52:46.386 - info: bluelink.0 (112864) Read new status from api
          2021-10-14 07:53:03.714 - info: bluelink.0 (112864) Set new status
          2021-10-14 07:53:03.781 - info: bluelink.0 (112864) State value to set for "bluelink.0.vehicleStatus.battery.plugin" has to be type "boolean" but received type "number"
          • Newan
            @fichte_112 das ist nur Info, stell mal auf debug um aber entferne deine Persönlichen Daten!
              @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
              2021-10-14 08:33:11.423 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true)
              2021-10-14 08:33:11.450 - info: bluelink.0 (114905) Got terminate signal TERMINATE_YOURSELF
              2021-10-14 08:33:11.452 - info: bluelink.0 (114905) Adapter bluelink cleaned up everything...
              2021-10-14 08:33:11.453 - info: bluelink.0 (114905) terminating
              2021-10-14 08:33:11.456 - info: bluelink.0 (114905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-10-14 08:33:11.459 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal
              2021-10-14 08:33:12.038 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-10-14 08:33:14.514 - info: host.debian instance system.adapter.bluelink.0 started with pid 114944
              2021-10-14 08:33:16.353 - debug: bluelink.0 (114944) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2021-10-14 08:33:16.389 - debug: bluelink.0 (114944) Objects client ready ... initialize now
              2021-10-14 08:33:16.392 - debug: bluelink.0 (114944) Objects create System PubSub Client
              2021-10-14 08:33:16.393 - debug: bluelink.0 (114944) Objects create User PubSub Client
              2021-10-14 08:33:16.395 - debug: bluelink.0 (114944) Objects client initialize lua scripts
              2021-10-14 08:33:16.640 - debug: bluelink.0 (114944) Objects connected to redis: 127.0.0.1:9001
              2021-10-14 08:33:16.656 - debug: bluelink.0 (114944) objectDB connected
              2021-10-14 08:33:16.659 - debug: bluelink.0 (114944) Redis States: Use Redis connection: 127.0.0.1:9000
              2021-10-14 08:33:16.672 - debug: bluelink.0 (114944) States create System PubSub Client
              2021-10-14 08:33:16.674 - debug: bluelink.0 (114944) States create User PubSub Client
              2021-10-14 08:33:16.687 - debug: bluelink.0 (114944) States connected to redis: 127.0.0.1:9000
              2021-10-14 08:33:16.689 - debug: bluelink.0 (114944) statesDB connected
              2021-10-14 08:33:17.015 - info: bluelink.0 (114944) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18
              2021-10-14 08:33:17.125 - debug: bluelink.0 (114944) Schedule restart: */60 * * * *
              2021-10-14 08:33:17.155 - info: bluelink.0 (114944) Login to api
              2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) xxx
              2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) {"username":"xxx","password":"xxx","pin":"xxx","brand":"kia","vin":"xxx","region":"EU"}
              2021-10-14 08:33:21.091 - info: bluelink.0 (114944) Vehicles found
              2021-10-14 08:33:21.130 - info: bluelink.0 (114944) Read new status from api
              2021-10-14 08:33:32.424 - info: bluelink.0 (114944) Set new status
              2021-10-14 08:33:32.425 - debug: bluelink.0 (114944) {"vehicleLocation":{"coord":{"lat":51.379586,"lon":12.404494,"alt":2,"type":0},"head":70,"speed":{"value":0,"unit":0},"accuracy":{"hdop":10,"pdop":10},"time":"20211014043331"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"01H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":100,"batteryPlugin":2,"remainTime2":{"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}},"drvDistance":[{"rangeByFuel":{"gasModeRange":{"value":351,"unit":1},"evModeRange":{"value":4,"unit":1},"totalAvailableRange":{"value":355,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"1200","timeSection":0},"endtime":{"time":"1200","timeSection":0}},"offPeakPowerFlag":0},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"reservFlag":0,"ect":{"start":{"day":9,"time":{"time":"1200","timeSection":0}},"end":{"day":9,"time":{"time":"1200","timeSection":0}}}}},"ign3":true,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"battery":{"batSoc":28,"batState":0},"time":"20211014043329","remoteWaitingTimeAlert":{"remoteControlAvailable":1},"systemCutOffAlert":0},"odometer":{"value":2379.6,"unit":1}}
              2021-10-14 08:33:32.505 - debug: bluelink.0 (114944) Folgende Ladezeiten Moeglichkeiten wurden gefunden:
              2021-10-14 08:33:32.506 - debug: bluelink.0 (114944) {"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}}
              • Newan
                Newan @fichte_112 last edited by Newan
                @fichte_112 ok da sind die coord drin. Wenn die nicht aktualisieren muss ich den Adapter nochmal prüfen
                F ? 3 Replies Last reply Reply Quote 0
                  @newan Ja, man kann die Koordinaten auswählen. Es sind aber die, die vor dem Update gestimmt haben. Sie werden nicht aktualisiert.
                    A Former User @Newan last edited by
                    @newan Hi, ja, der Fehler mit den Koordinaten ist bei mir auch vorhanden. Gerade getestet. ( Hyundai ).
                    • Newan
                      Newan @Guest last edited by
                      @ilovegym macht einer mit dem Fehler in github ein issues auf, danke
                        @newan Issue aufgemacht, du hast gefixt, und ich hab Issue wieder zu gemacht. 🙂
                        Vielen Dank! Super!
                        • Newan
                          @ilovegym Ja so hab ich das auf github richtig dokumentiert, danke!
                            Funktioniert wieder. Vielen Dank
                            • Meister Mopper
                              Meister Mopper @fichte_112 last edited by
                              Ich möchte meinen e-Niro über diesen Adapter überwachen, bekomme aber keine Verbindung.
                              Im log steht:
                              bluelink.0 	2021-10-14 17:43:01.958 	error 	ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"e2253e03-ae98-41bd-9360-e1d1cc0e7236","errCode":"4003","errMsg":"Invalid values"}
                              Ich bin sicher, dass ich die richtige VIN eingefügt habe.
                              Kann es daran liegen, dass das Passwort keine Sonderzeichen enthalten darf?
                              Von meinem Prinzip der Groß- und Kleinschreibung, Ziffern und Sonderzeichen (insgesamt 12 Zeichen) möchte ich nicht abweichen.
                              Mit der Android-App funktioniert die Verbindung tadellos.
                              • Newan
                                Newan @Meister Mopper last edited by
                                @meister-mopper wir speichern das Passwort verschlüsselt ab. Ob es da Probleme mit Sonderzeichen gibt kannst du testen indem du schaust ob es korrekt im debuglog ausgegeben wird.
                                • Meister Mopper
                                  Meister Mopper @Newan last edited by
                                  @newan Die Daten stimmen so wie ich sie beim Einrichten gespeichert habe.
                                  bluelink.0
                                  	2021-10-16 15:56:22.859	error	ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"2b258692-e947-4d2d-82d9-3293b0c0fc7e","errCode":"4003","errMsg":"Invalid values"}
                                  bluelink.0
                                  	2021-10-16 15:56:22.859	debug	Error on Api login
                                  bluelink.0
                                  	2021-10-16 15:56:21.621	debug	{"username":"xx.xx@xx.de","password":"xxxxxxxxxxxx","pin":"xxx","brand":"kia","vin":"xxxxxxxxxxxxxxxxx","region":"EU"}
                                  Aber da sind noch immer Invalid values
                                  • Newan
                                    @meister-mopper teste mal debug locally von der lib
                                    https://github.com/Hacksore/bluelinky
                                    Meister Mopper 4 Replies Last reply Reply Quote 0
                                    • Meister Mopper
                                      @newan Den Adapter bluelinky kann ich nicht installieren:
                                      host.ioTest
                                         2021-10-16 17:19:48.564	info	iobroker exit 25
                                      host.ioTest
                                         2021-10-16 17:19:47.544	error	iobroker host.ioTest Cannot install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545: 0
                                      host.ioTest
                                         2021-10-16 17:19:44.817	info	iobroker make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.4.140-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.18.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                      host.ioTest
                                         2021-10-16 17:19:44.680	info	iobroker In file included from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’? 175 | NODE_MODULE(authenticate_pam, init); | ^~~~/home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’ 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ 175 | NODE_MODULE(authenticate_pam, init); | ^~~~~~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.675	info	iobroker ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.672	info	iobroker ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token 170 | void init(Handle<Object> exports) { | ^
                                      host.ioTest
                                         2021-10-16 17:19:44.670	info	iobroker ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.666	info	iobroker ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void 170 | void init(Handle<Object> exports) { | ^~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.663	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.662	info	iobroker ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 161 | password->WriteUtf8(m->password, sizeof(m->password) - 1); | ~~~^~~~~~~~ | | | char [128]
                                      host.ioTest
                                         2021-10-16 17:19:44.660	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.658	info	iobroker ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 160 | username->WriteUtf8(m->username, sizeof(m->username) - 1); | ~~~^~~~~~~~ | | | char [128]
                                      host.ioTest
                                         2021-10-16 17:19:44.656	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.654	info	iobroker ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 155 | remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); | ~~~^~~~~~~~~~ | | | char [128]
                                      host.ioTest
                                         2021-10-16 17:19:44.653	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
                                      host.ioTest
                                         2021-10-16 17:19:44.651	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                                      host.ioTest
                                         2021-10-16 17:19:44.649	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
                                      host.ioTest
                                         2021-10-16 17:19:44.648	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                                      host.ioTest
                                         2021-10-16 17:19:44.646	info	iobroker ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 152 | res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); | ^
                                      host.ioTest
                                         2021-10-16 17:19:44.644	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.642	info	iobroker ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 150 | serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); | ~~~^~~~~~~~~~~ | | | char [128]
                                      host.ioTest
                                         2021-10-16 17:19:44.640	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
                                      host.ioTest
                                         2021-10-16 17:19:44.638	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                                      host.ioTest
                                         2021-10-16 17:19:44.636	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
                                      host.ioTest
                                         2021-10-16 17:19:44.634	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                                      host.ioTest
                                         2021-10-16 17:19:44.632	info	iobroker ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 147 | Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); | ^
                                      host.ioTest
                                         2021-10-16 17:19:44.629	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here 1024 | NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( | ^~~~~~~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:44.627	info	iobroker ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] 107 | Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); | ^
                                      host.ioTest
                                         2021-10-16 17:19:44.598	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 2298 | , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                      host.ioTest
                                         2021-10-16 17:19:24.442	info	iobroker NPM version: 6.14.15npm install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545 --loglevel error --prefix "/opt/iobroker" (System call)
                                      host.ioTest
                                         2021-10-16 17:19:24.117	info	iobroker install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545
                                      host.ioTest
                                         2021-10-16 17:19:22.479	info	iobroker url https://github.com/Hacksore/bluelinky.git --host ioTest
                                      host.ioTest
                                         2021-10-16 17:18:33.664	info	instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      host.ioTest
                                         2021-10-16 17:18:33.123	info	stopInstance system.adapter.bluelink.0 send kill signal
                                      bluelink.0
                                         2021-10-16 17:18:33.120	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      bluelink.0
                                         2021-10-16 17:18:33.119	info	terminating
                                      bluelink.0
                                         2021-10-16 17:18:33.119	info	Adapter bluelink cleaned up everything...
                                      bluelink.0
                                         2021-10-16 17:18:33.119	info	Got terminate signal TERMINATE_YOURSELF
                                      host.ioTest
                                         2021-10-16 17:18:33.116	info	stopInstance system.adapter.bluelink.0 (force=false, process=true)
                                      host.ioTest
                                         2021-10-16 17:18:33.114	info	"system.adapter.bluelink.0" disabled
                                        A Former User @Meister Mopper last edited by
                                        @meister-mopper bluelinky ist kein iobroker adapter..
                                        • Meister Mopper
                                          Meister Mopper @Newan last edited by Meister Mopper
                                          Okay, dann fehlt mir das Verständnis. Was meinst Du?
                                          edit:
                                          Okay, ich versuch mal npm install bluelinky 😕
                                          • Meister Mopper
                                            Sorry, mit npm install bluelinky aus dem Verzeichnis '/opt/iobroker' komme ich nicht zum Ziel. Wie muss ich bitte vorgehen?
                                            2298
                                            860285
