    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      fichte_112 @Newan last edited by
      @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
      @fichte_112 das ist nur Info, stell mal auf debug um aber entferne deine Persönlichen Daten!
      2021-10-14 08:33:11.423 - info: host.debian stopInstance system.adapter.bluelink.0 (force=false, process=true)
      2021-10-14 08:33:11.450 - info: bluelink.0 (114905) Got terminate signal TERMINATE_YOURSELF
      2021-10-14 08:33:11.452 - info: bluelink.0 (114905) Adapter bluelink cleaned up everything...
      2021-10-14 08:33:11.453 - info: bluelink.0 (114905) terminating
      2021-10-14 08:33:11.456 - info: bluelink.0 (114905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-14 08:33:11.459 - info: host.debian stopInstance system.adapter.bluelink.0 send kill signal
      2021-10-14 08:33:12.038 - info: host.debian instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-14 08:33:14.514 - info: host.debian instance system.adapter.bluelink.0 started with pid 114944
      2021-10-14 08:33:16.353 - debug: bluelink.0 (114944) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-10-14 08:33:16.389 - debug: bluelink.0 (114944) Objects client ready ... initialize now
      2021-10-14 08:33:16.392 - debug: bluelink.0 (114944) Objects create System PubSub Client
      2021-10-14 08:33:16.393 - debug: bluelink.0 (114944) Objects create User PubSub Client
      2021-10-14 08:33:16.395 - debug: bluelink.0 (114944) Objects client initialize lua scripts
      2021-10-14 08:33:16.640 - debug: bluelink.0 (114944) Objects connected to redis: 127.0.0.1:9001
      2021-10-14 08:33:16.656 - debug: bluelink.0 (114944) objectDB connected
      2021-10-14 08:33:16.659 - debug: bluelink.0 (114944) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-10-14 08:33:16.672 - debug: bluelink.0 (114944) States create System PubSub Client
      2021-10-14 08:33:16.674 - debug: bluelink.0 (114944) States create User PubSub Client
      2021-10-14 08:33:16.687 - debug: bluelink.0 (114944) States connected to redis: 127.0.0.1:9000
      2021-10-14 08:33:16.689 - debug: bluelink.0 (114944) statesDB connected
      2021-10-14 08:33:17.015 - info: bluelink.0 (114944) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.bluelink, node: v12.22.6, js-controller: 3.3.18
      2021-10-14 08:33:17.125 - debug: bluelink.0 (114944) Schedule restart: */60 * * * *
      2021-10-14 08:33:17.155 - info: bluelink.0 (114944) Login to api
      2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) xxx
      2021-10-14 08:33:17.157 - debug: bluelink.0 (114944) {"username":"xxx","password":"xxx","pin":"xxx","brand":"kia","vin":"xxx","region":"EU"}
      2021-10-14 08:33:21.091 - info: bluelink.0 (114944) Vehicles found
      2021-10-14 08:33:21.130 - info: bluelink.0 (114944) Read new status from api
      2021-10-14 08:33:32.424 - info: bluelink.0 (114944) Set new status
      2021-10-14 08:33:32.425 - debug: bluelink.0 (114944) {"vehicleLocation":{"coord":{"lat":51.379586,"lon":12.404494,"alt":2,"type":0},"head":70,"speed":{"value":0,"unit":0},"accuracy":{"hdop":10,"pdop":10},"time":"20211014043331"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"01H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":100,"batteryPlugin":2,"remainTime2":{"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}},"drvDistance":[{"rangeByFuel":{"gasModeRange":{"value":351,"unit":1},"evModeRange":{"value":4,"unit":1},"totalAvailableRange":{"value":355,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"1200","timeSection":0},"endtime":{"time":"1200","timeSection":0}},"offPeakPowerFlag":0},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false}},"reservFlag":0,"ect":{"start":{"day":9,"time":{"time":"1200","timeSection":0}},"end":{"day":9,"time":{"time":"1200","timeSection":0}}}}},"ign3":true,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0,"tirePressureLampFL":0,"tirePressureLampFR":0,"tirePressureLampRL":0,"tirePressureLampRR":0},"battery":{"batSoc":28,"batState":0},"time":"20211014043329","remoteWaitingTimeAlert":{"remoteControlAvailable":1},"systemCutOffAlert":0},"odometer":{"value":2379.6,"unit":1}}
      2021-10-14 08:33:32.505 - debug: bluelink.0 (114944) Folgende Ladezeiten Moeglichkeiten wurden gefunden:
      2021-10-14 08:33:32.506 - debug: bluelink.0 (114944) {"etc2":{"value":0,"unit":1},"etc3":{"value":0,"unit":1},"atc":{"value":0,"unit":1}}
      Newan 1 Reply Last reply Reply Quote 0
      • Newan
        Newan @fichte_112 last edited by Newan
        @fichte_112 ok da sind die coord drin. Wenn die nicht aktualisieren muss ich den Adapter nochmal prüfen
        F ? 3 Replies Last reply Reply Quote 0
          @newan Ja, man kann die Koordinaten auswählen. Es sind aber die, die vor dem Update gestimmt haben. Sie werden nicht aktualisiert.
            A Former User @Newan last edited by
            @newan Hi, ja, der Fehler mit den Koordinaten ist bei mir auch vorhanden. Gerade getestet. ( Hyundai ).
            • Newan
              Newan @Guest last edited by
              @ilovegym macht einer mit dem Fehler in github ein issues auf, danke
                @newan Issue aufgemacht, du hast gefixt, und ich hab Issue wieder zu gemacht. 🙂
                Vielen Dank! Super!
                • Newan
                  @ilovegym Ja so hab ich das auf github richtig dokumentiert, danke!
                    Funktioniert wieder. Vielen Dank
                    • Meister Mopper
                      Meister Mopper @fichte_112 last edited by
                      Ich möchte meinen e-Niro über diesen Adapter überwachen, bekomme aber keine Verbindung.
                      Im log steht:
                      bluelink.0 	2021-10-14 17:43:01.958 	error 	ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"e2253e03-ae98-41bd-9360-e1d1cc0e7236","errCode":"4003","errMsg":"Invalid values"}
                      Ich bin sicher, dass ich die richtige VIN eingefügt habe.
                      Kann es daran liegen, dass das Passwort keine Sonderzeichen enthalten darf?
                      Von meinem Prinzip der Groß- und Kleinschreibung, Ziffern und Sonderzeichen (insgesamt 12 Zeichen) möchte ich nicht abweichen.
                      Mit der Android-App funktioniert die Verbindung tadellos.
                      • Newan
                        Newan @Meister Mopper last edited by
                        @meister-mopper wir speichern das Passwort verschlüsselt ab. Ob es da Probleme mit Sonderzeichen gibt kannst du testen indem du schaust ob es korrekt im debuglog ausgegeben wird.
                        • Meister Mopper
                          Meister Mopper @Newan last edited by
                          @newan Die Daten stimmen so wie ich sie beim Einrichten gespeichert habe.
                          bluelink.0
                          	2021-10-16 15:56:22.859	error	ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"2b258692-e947-4d2d-82d9-3293b0c0fc7e","errCode":"4003","errMsg":"Invalid values"}
                          bluelink.0
                          	2021-10-16 15:56:22.859	debug	Error on Api login
                          bluelink.0
                          	2021-10-16 15:56:21.621	debug	{"username":"xx.xx@xx.de","password":"xxxxxxxxxxxx","pin":"xxx","brand":"kia","vin":"xxxxxxxxxxxxxxxxx","region":"EU"}
                          Aber da sind noch immer Invalid values
                          • Newan
                            @meister-mopper teste mal debug locally von der lib
                            https://github.com/Hacksore/bluelinky
                            Meister Mopper 4 Replies Last reply Reply Quote 0
                            • Meister Mopper
                              @newan Den Adapter bluelinky kann ich nicht installieren:
                              host.ioTest
                                 2021-10-16 17:19:48.564	info	iobroker exit 25
                              host.ioTest
                                 2021-10-16 17:19:47.544	error	iobroker host.ioTest Cannot install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545: 0
                              host.ioTest
                                 2021-10-16 17:19:44.817	info	iobroker make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.4.140-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.18.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                              host.ioTest
                                 2021-10-16 17:19:44.680	info	iobroker In file included from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’? 175 | NODE_MODULE(authenticate_pam, init); | ^~~~/home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’ 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ 175 | NODE_MODULE(authenticate_pam, init); | ^~~~~~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.675	info	iobroker ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.672	info	iobroker ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token 170 | void init(Handle<Object> exports) { | ^
                              host.ioTest
                                 2021-10-16 17:19:44.670	info	iobroker ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.666	info	iobroker ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void 170 | void init(Handle<Object> exports) { | ^~~~
                              host.ioTest
                                 2021-10-16 17:19:44.663	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.662	info	iobroker ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 161 | password->WriteUtf8(m->password, sizeof(m->password) - 1); | ~~~^~~~~~~~ | | | char [128]
                              host.ioTest
                                 2021-10-16 17:19:44.660	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.658	info	iobroker ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 160 | username->WriteUtf8(m->username, sizeof(m->username) - 1); | ~~~^~~~~~~~ | | | char [128]
                              host.ioTest
                                 2021-10-16 17:19:44.656	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.654	info	iobroker ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 155 | remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); | ~~~^~~~~~~~~~ | | | char [128]
                              host.ioTest
                                 2021-10-16 17:19:44.653	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
                              host.ioTest
                                 2021-10-16 17:19:44.651	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                              host.ioTest
                                 2021-10-16 17:19:44.649	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
                              host.ioTest
                                 2021-10-16 17:19:44.648	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                              host.ioTest
                                 2021-10-16 17:19:44.646	info	iobroker ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 152 | res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); | ^
                              host.ioTest
                                 2021-10-16 17:19:44.644	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.642	info	iobroker ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 150 | serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); | ~~~^~~~~~~~~~~ | | | char [128]
                              host.ioTest
                                 2021-10-16 17:19:44.640	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
                              host.ioTest
                                 2021-10-16 17:19:44.638	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                              host.ioTest
                                 2021-10-16 17:19:44.636	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
                              host.ioTest
                                 2021-10-16 17:19:44.634	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
                              host.ioTest
                                 2021-10-16 17:19:44.632	info	iobroker ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 147 | Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); | ^
                              host.ioTest
                                 2021-10-16 17:19:44.629	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here 1024 | NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( | ^~~~~~~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:44.627	info	iobroker ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] 107 | Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); | ^
                              host.ioTest
                                 2021-10-16 17:19:44.598	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 2298 | , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                              host.ioTest
                                 2021-10-16 17:19:24.442	info	iobroker NPM version: 6.14.15npm install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545 --loglevel error --prefix "/opt/iobroker" (System call)
                              host.ioTest
                                 2021-10-16 17:19:24.117	info	iobroker install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545
                              host.ioTest
                                 2021-10-16 17:19:22.479	info	iobroker url https://github.com/Hacksore/bluelinky.git --host ioTest
                              host.ioTest
                                 2021-10-16 17:18:33.664	info	instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              host.ioTest
                                 2021-10-16 17:18:33.123	info	stopInstance system.adapter.bluelink.0 send kill signal
                              bluelink.0
                                 2021-10-16 17:18:33.120	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              bluelink.0
                                 2021-10-16 17:18:33.119	info	terminating
                              bluelink.0
                                 2021-10-16 17:18:33.119	info	Adapter bluelink cleaned up everything...
                              bluelink.0
                                 2021-10-16 17:18:33.119	info	Got terminate signal TERMINATE_YOURSELF
                              host.ioTest
                                 2021-10-16 17:18:33.116	info	stopInstance system.adapter.bluelink.0 (force=false, process=true)
                              host.ioTest
                                 2021-10-16 17:18:33.114	info	"system.adapter.bluelink.0" disabled
                                A Former User @Meister Mopper last edited by
                                @meister-mopper bluelinky ist kein iobroker adapter..
                                • Meister Mopper
                                  Meister Mopper @Newan last edited by Meister Mopper
                                  Okay, dann fehlt mir das Verständnis. Was meinst Du?
                                  edit:
                                  Okay, ich versuch mal npm install bluelinky 😕
                                  • Meister Mopper
                                    Sorry, mit npm install bluelinky aus dem Verzeichnis '/opt/iobroker' komme ich nicht zum Ziel. Wie muss ich bitte vorgehen?
                                      @meister-mopper
                                      ich kenn mich damit auch nicht aus, aber hab gerade die Anleitung gelesen, ich würd bluelinky als addon in den javascript adapter eintragen, und dann eins von den Beispielscripten die in der Doc stehen, verwenden..
                                        Sonnenkind @Guest last edited by
                                        @ilovegym
                                        hallöle, der Adapter schaut ja echt gut aus , danke dafür, leider Scheiter ich daran dass ich im log nach dem start folgende Meldung bekomme....eventuell hast Du ja ne Idee?
                                        ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"7ed8e8d6-8255-428f-b85e-0427c7b7e029","errCode":"4003","errMsg":"Invalid values"}
                                          Michaelnorge @Sonnenkind last edited by
                                          @sonnenkind Bist du mit der App via Hyundai angemeldet?
                                            Sonnenkind @Michaelnorge last edited by
                                            @michaelnorge ja , aktuell schon, warum geht das nicht, hat der server damit dann ein Problem?
                                            1.2k
                                            2298
                                            859379
