    3. Entwicklung
    4. Synology Chat ...
    Synology Chat ...
    • Glasfaser
      Glasfaser last edited by Glasfaser
      @ilovegym
      Ich habe mal was gebaut ... hänge aber noch daran , das er immer das alte Bild sendet, obwohl es aktualisiert wird .
      Vielleicht ein Grundbauststein:
       <variables>
         <variable id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</variable>
         <variable id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</variable>
         <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
         <variable id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</variable>
         <variable id=")2,KTR||]G~d7xyd!QUZ">send</variable>
         <variable type="timeout" id="timeout2">timeout2</variable>
         <variable id="s`TAk}2fZk|p^o$4+d@t">result</variable>
       </variables>
       <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N" x="163" y="188">
         <field name="VAR" id="^RM=2sJ}E,A{F?bz`_me">URL_Chat</field>
           <block type="text" id="kB68_z,ak9jtsXj2XA[?">
             <field name="TEXT">http://xxxxxx.xxx.xxx.xx:5000/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&amp;payload={"text":"</field>
           <block type="variables_set" id="Q8SV]H7m2;RCEIl!I32S">
             <field name="VAR" id="yW]q[i/Yfz.,5Z+Vb.a,">URL_ioBroker</field>
               <block type="text" id="Cw;l)b1L4K(P86t9=T}E">
                 <field name="TEXT">http://xxxx.xxxx.xxx.xxx:8082/0_userdata.0/synology/bild.jpg</field>
               <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?">
                 <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                   <block type="get_value" id="Y$5X7J(i,Ijul8Pt3.]=">
                     <field name="OID">synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot</field>
                   <block type="variables_set" id="m/`Hepc#d!=l=Yu?E{!6">
                     <field name="VAR" id="`=hGQ*[0C+pxdf]k]sV]">Nachricht</field>
                       <block type="text" id="naz0gbDT{!MOKW]c|g8{">
                         <field name="TEXT">Es klingelt an der Haustuer</field>
                       <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl">
                         <value name="OID0">
                           <shadow type="field_oid" id="3VnM3u.?JEhM[^n/?X0p">
                           <block type="procedures_callcustomnoreturn" id="J8Bxi=.l@zrRJkcGT150">
                             <mutation name="Bild_holen"></mutation>
                               <block type="timeouts_cleartimeout" id="1#Qx;^WXsqqn)X|6E2jF">
                                   <block type="timeouts_cleartimeout" id="]P6ccsD65Q=LsNc=*[+u">
                                       <block type="timeouts_settimeout" id=",Vl,JVw3kG.#VrRAqd:b">
                                         <field name="DELAY">2000</field>
                                         <field name="UNIT">ms</field>
                                           <block type="variables_set" id="56pX+FA.eu/bi!ML3mDH">
                                             <field name="VAR" id=")2,KTR||]G~d7xyd!QUZ">send</field>
                                               <block type="text_join" id="+TV37k{5`41$R(X3%khD">
                                                 <mutation items="4"></mutation>
                                                 <value name="ADD0">
                                                   <block type="variables_get" id="Mkg|x~Kc=E8N`_Gd55y.">
                                                 <value name="ADD1">
                                                   <block type="text_join" id="{ZtE{Zz7!b9OAowY)%1V">
                                                     <value name="ADD0">
                                                       <block type="variables_get" id="y!U|V20vIg%ipD-$G_XY">
                                                     <value name="ADD1">
                                                       <block type="text" id="G|.7zo{,tbQ8-Uo83p,)">
                                                         <field name="TEXT">", "file_url": "</field>
                                                 <value name="ADD2">
                                                   <block type="variables_get" id="v/9SP;]`*blX7Qt=h~Eu">
                                                 <value name="ADD3">
                                                   <block type="text" id="z1]{?Af3zI_+#txN*=UR">
                                                     <field name="TEXT">"}</field>
                                               <block type="timeouts_settimeout" id="dUpl:*/S.GOlt6yy5+E?">
                                                 <field name="DELAY">1000</field>
                                                   <block type="request" id="939:VQbG=f:Lt(8,--UH">
                                                     <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                     <field name="WITH_STATEMENT">TRUE</field>
                                                     <field name="LOG"></field>
                                                     <value name="URL">
                                                       <shadow type="text" id="1o%c{S``+)7HEh-A%)U^">
                                                       <block type="variables_get" id="vAPQA_YY6uy)ow09^`*K">
                                                       <block type="debug" id="qZVJ(@5Ef)}jneJ%Q)_N">
                                                         <value name="TEXT">
                                                           <shadow type="text" id="S=pA)VcRi34L-{?F`HMz">
                                                           <block type="variables_get" id="N_1)-!F8nh][M#5EAmb6">
                                                             <field name="VAR" id="s`TAk}2fZk|p^o$4+d@t">result</field>
                                                       <block type="debug" id="v:z{{P}3]9(0mcj`VrK7">
                                                         <value name="TEXT">
                                                           <shadow type="text">
                                                           <block type="variables_get" id="/5v?Iwot|ODZ)QhG%957">
       <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="638" y="338">
         <mutation statements="false"></mutation>
         <field name="NAME">Bild_holen</field>
         <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmlsZC5qcGciLCBib2R5KTsNCg0KICAgIH0NCg0KICB9DQoNCik7DQo=</field>
      var URL_Chat, URL_ioBroker, URL_Snapshot, Nachricht, timeout, send, timeout2, result;
      // Beschreibe diese Funktion …
      async function Bild_holen() {
          request(
              url: URL_Snapshot ,
              encoding: null,
            (error, response, body) => {
              if (!error && body) {
                writeFile("0_userdata.0", "/synology/bild.jpg", body);
      URL_Chat = 'http://deineIP:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=deintoken&payload={"text":"';
      URL_ioBroker = 'http://IPvomioBroker:8082/0_userdata.0/synology/bild.jpg';
      URL_Snapshot = getState("synology.0.SurveillanceStation.cameras.Haustür.linkSnapshot").val;
      Nachricht = 'Es klingelt an der Haustuer';
      on({id: 'default', change: "ne"}, async function (obj) {
        var value = obj.state.val;
        await Bild_holen();
        (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
        (function () {if (timeout2) {clearTimeout(timeout2); timeout2 = null;}})();
        timeout = setTimeout(async function () {
          send = [URL_Chat,String(Nachricht) + '", "file_url": "',URL_ioBroker,'"}'].join('');
          timeout2 = setTimeout(async function () {
            try {
              require("request")(send, async function (error, response, result) {
                console.log(result);
              }).on("error", function (e) {console.error(e);});
            } catch (e) { console.error(e); }
            console.log(send);
          }, 1000);
        }, 2000);
      ? XBiT W 3 Replies Last reply Reply Quote 0
        A Former User @Glasfaser last edited by
        @glasfaser sieht schon prima aus, bin bis jetzt nur zum Text verschicken gekommen, mit dem Bild hatte ich auch probleme..
        • Glasfaser
          Glasfaser @Guest last edited by
          @ilovegym sagte in Synology Chat ...:
          ich habe es extra schon per writeFile. geschrieben .
          Das Bild ist auch aktuell , aber ich komme gerade nicht auf den Blöden Fehler warum er immer das erstellte ( alte ) Bild nimmt .
          ? Homoran 2 Replies Last reply Reply Quote 0
            A Former User @Glasfaser last edited by A Former User
            @glasfaser mal das alte Bild löschen lassen..?
            Ich mach das bei meinen Camera Scripten immer so: ( alle in Javascript )
            sendTo('telegram.0', {text: '/tmp/snap.jpg', caption: '🔔Es hat jemand geklingelt !🔔'});
            exec((['sudo cp /tmp/snap.jpg /mnt/photo/maindoor/maindoor-',formatDate(new Date(), "JJJJ_MM_TT_SS_mm_ss"),'.jpg'].join('')));
            exec((['sudo rm /tmp/snap.jpg'] ));
            Edit: nicht alles copiert.. 😉
              Homoran Global Moderator Administrators @Glasfaser last edited by
              @glasfaser sagte in Synology Chat ...:
              ist zu dem Zeitpunkt des holens denn wirklich das neue Bild schon geschrieben?
              • Glasfaser
                Glasfaser @Homoran last edited by
                Ja , ich habe auch schon mehere timeout im Testscript eingebaut gehabt.
                Es wird geholt und geschrieben .
                Das Bild ist immer aktuell im Ordner 0_userdata.0
                  @glasfaser hmm ich lass die immer nach /tmp schreiben.. wird es denn auch angelegt_
                  • Glasfaser
                    Ja .
                    • XBiT
                      XBiT @Glasfaser last edited by
                      @glasfaser
                      da wollte ich mal mitspielen aber bekomme nicht mal dein Blockly importiert...😢
                      sollte es laufen ist es echt gut ohne 3rd Anbieter alle Meldungen zu erhalten.
                      • Glasfaser
                        Glasfaser @XBiT last edited by Glasfaser
                        @xbit
                        Versuche nochmal .. habe gerade es neu im Spoiler gesetzt
                        XBiT 2 Replies Last reply Reply Quote 0
                        • XBiT
                          @glasfaser
                          Danke geht jetzt 👍
                          • XBiT
                            @glasfaser
                            Habe es mal verunstaltet 🙂 aber es geht... und bekomme auch immer das neue Bild....
                            Sollte ja auch mit dem Datenpunkt "synology.0.SurveillanceStation.cameras.XXXX.linkSnapshot" gehen nur bei mir geht der gerade nicht 😄
                              <variables>
                                <variable id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</variable>
                                <variable id=",O#!.RmBLV$D$25E`o7/">Syno_Port</variable>
                                <variable id="Eg)M29q*/71]Q#lGjYO;">Chat_token</variable>
                              </variables>
                              <block type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
                                <value name="OID0">
                                    <field name="oid">0_userdata.0.Testbutton</field>
                                  <block type="variables_set" id="u^*rT,0CM,T_]XeGow}h">
                                    <field name="VAR" id="0;mm8IOdOmH_wz;%[zPo">Syno_URL</field>
                                      <block type="text" id="K]+z|W)qG[s?viD8cP}Q">
                                        <field name="TEXT">192.168.X.XXX</field>
                                      <block type="variables_set" id=",|/0@uFO[kJp[pSjyfW~">
                                        <field name="VAR" id=",O#!.RmBLV$D$25E`o7/">Syno_Port</field>
                                          <block type="text" id="YmIhCu8+dV@OO0U[PWx#">
                                            <field name="TEXT">5000</field>
                                          <block type="variables_set" id="Z}%_nt.Jz``.b})ifYmx">
                                            <field name="VAR" id="Eg)M29q*/71]Q#lGjYO;">Chat_token</field>
                                              <block type="text" id="[^9?/_`o:[u8zr_:o:`T">
                                                <field name="TEXT">XXXX</field>
                                                      <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                                        <field name="TEXT">http://192.168.X.XXX/action/snapshot</field>
                                                            <field name="TEXT">http://192.168.X.XXX:8082/0_userdata.0/synology/bild.jpg</field>
        <block type="variables_set" id="0jj@r*)y_VPw~)q+,3)N">
        <block type="text_join" id="Q^/K[ogSU%663c!lHXyf">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="Xp!K%fv+S+C7_K~7ka^c">
        <field name="TEXT">http://</field>
        <value name="ADD1">
        <block type="variables_get" id="U#z.iPhHMr!oaBW_.L}$">
        <value name="ADD2">
        <block type="text" id="|ITd9=%HnJAhhwgaz3|-">
        <field name="TEXT">:</field>
        <value name="ADD3">
        <block type="variables_get" id="_E?oZ@h{l{gD!e{A..FQ">
        <value name="ADD4">
        <block type="text" id="_^c23]w8ve_wLo_pG;lU">
        <field name="TEXT">/webapi/entry.cgi?api=SYNO.Chat.External&amp;method=incoming&amp;version=2&amp;token="</field>
        <value name="ADD5">
        <block type="variables_get" id="p//Pgq^!$p27`+=TYO0t">
        <value name="ADD6">
        <block type="text" id="zG0}^=D_TXDv9Tjx8afb">
        <field name="TEXT">"&amp;payload={"text":"</field>
        <value name="ADD7">
        <block type="variables_get" id="];FJ@4Io`JJ?oyGqhlTU">
        <value name="ADD8">
        <value name="ADD9">
        <value name="ADD10">
        <value name="URL">
        <value name="TEXT">
        <value name="TEXT">
                              <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="513" y="337">
                              wrod @Glasfaser last edited by
                              @glasfaser said in Synology Chat ...:
                              Wie muss das Script denn aussehen, wenn man einfach eine Nachricht ohne Bild schicken will?
                              • Glasfaser
                                Glasfaser @wrod last edited by Glasfaser
                                @wrod
                                Beispiel :
                                <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[.;w?/pK-.4zyW!UyYBl" x="163" y="88">
                                  <value name="OID0">
                                      <field name="oid">0_userdata.0.Test123</field>
                                    <block type="variables_set" id="*dQxDuFmm[ppsJg3%3!V">
                                        <block type="text" id="+_Bx+X)YJc^_8RSz74zE">
                                          <field name="TEXT">Hier dein Text , ioBroker 2021</field>
                                              <field name="TEXT">192.168.xxx.xxx</field>
                                                      <field name="TEXT">xxxxxxxxxxxxxxxxxxxxx</field>
        <mutation items="9"></mutation>
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <value name="ADD6">
        <value name="ADD7">
        <value name="ADD8">
        <value name="URL">
        <value name="TEXT">
        <value name="TEXT">
                                Entweder vorgegeben , oder aus einem Datenpunkt
                                  wrod last edited by
                                  @glasfaser Danke! Es läuft!
                                    Tschaeens @Glasfaser last edited by Tschaeens
                                    @glasfaser
                                    Hast du vielleicht eine Idee, warum keine Umlaute (ä, ö) oder zum Beispiel Grad Celcius als Zeichen nicht gehen. Dann kommt im Log immer ein Fehler?
                                    Liebe Grüße
                                    Glasfaser 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      Glasfaser @Tschaeens last edited by
                                      @tschaeens sagte in Synology Chat ...:
                                      Weil der Text noch :
                                      encodeURIComponent()
                                      Die Methode encodeURIComponent() kodiert eine Komponente des Uniform Resource Identifier (URI) indem jedes Vorkommen bestimmter Zeichen durch ein, zwei, drei oder vier Escape-Sequenzen ersetzt werden, die der UTF8-Kodierung des Zeichens entsprechen. Vier Escape-Sequenzen werden nur bei Zeichen bestehend aus zwei "Surrogate"-Zeichen verwendet.
                                      https://www.w3schools.com/jsref/jsref_encodeuricomponent.asp
                                      Klingelt%20jemand%20an%20der%20Haust%C3%BCr
                                      22%20%C2%B0C
                                      warum%20keine%20Umlaute%20(%C3%A4%2C%20%C3%B6)%20und%20kein%2022%20%C2%B0C
                                      geht hiermit :
                                       <variables>
                                         <variable id="$Tar!(b_)qw:24xtP(vj">url</variable>
                                       </variables>
                                       <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="163" y="38">
                                           <arg name="url" varid="$Tar!(b_)qw:24xtP(vj"></arg>
                                         </mutation>
                                         <field name="NAME">encodeURI</field>
                                         <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
                                         <comment pinned="false" h="80" w="160">encode URL function</comment>
                                       <block type="comment" id="sn%:SFkGbJ1*B^:BY`FW" x="162" y="63">
                                         <field name="COMMENT">// https://forum.iobroker.net/topic/47210/synology-chat/41</field>
                                             <value name="OID0">
                                               <block type="comment" id="uRZ3rr;n#Cb)oaDZB3$)">
                                                 <field name="COMMENT">encodeURIComponent hinzugefügt</field>
                                                       <block type="procedures_callcustomreturn" id="GD%^L~Wq_LIL_y86c}(2">
                                                         <mutation name="encodeURI">
                                                           <arg name="url"></arg>
                                                         </mutation>
                                                         <value name="ARG0">
                                                             <field name="TEXT">warum keine Umlaute (ä, ö) und kein 22 °C</field>
                                                             <field name="TEXT">192.168.xxx.xx</field>
        <field name="TEXT">xxxxxxxxxxxxxxxxx</field>
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <value name="ADD6">
        <value name="ADD7">
        <value name="ADD8">
        <value name="URL">
        <value name="TEXT">
        <value name="TEXT">
                                      • Glasfaser
                                        Glasfaser @Tschaeens last edited by Glasfaser
                                        oder zum Beispiel
                                        mit der Änderung oben , können jetzt auch Emoji mit versendet werden
                                          wrod @wrod last edited by
                                          @wrod Danke.
                                          Es sieht nun so aus.
                                          Immer wenn ein anderer Vorgang (etwa ein anderes Skript) ein eigens erzeugtes Objekt "Nachrichtentext" ändert, wird dieser an mich versendet. Dann wird dieser wieder auf "false" gesetzt.
                                          Jetzt brauche ich noch Skripts, die auf Abfrage das Objekt "Nachrichtentext" sinnvoll befüllen.
                                          Gibt es dazu elegante Möglichkeiten, insbesondere für eine Abfrage mehrerer Objekte auf das Überschreiten von Grenzwerten, also etwa
                                          Wenn <Objekt_X> überschreitet <Grenzwert_X> dann setze Erzeuge Variable <Text> aus <Konstante_X> und ggf <Variable_X> und befülle Objekt <Nachrichtentext>; mit
                                          • <Objekt A> <Grenzwert A> <Konstante A> <Variable A>
                                          • <Objekt B> <Grenzwert B> <Konstante C> <Variable C>
                                          • <Objekt n> <Grenzwert n> <Konstante n> <Variable n>
                                          Das wäre ja wohl eine Schleife oder Liste in Form von
                                          Für jedes Elemente in Liste x prüfe und setze.
                                          Das Skript müsste dann aber wohl ständig abfragen. Lässt sich das auch über eine Liste/Schleife lösen im Sinne von
                                          Wenn eines der folgenden Elemente sich ändert, dann prüfe?
                                          Dank im Voraus
                                          • Glasfaser
                                            @wrod sagte in Synology Chat ...:
                                            Das würde jetzt diesen Thread "Synology Chat"dafür sprengen .
                                            @all
                                            Ich habe nochmal das Blockly verkürzt .
                                             <variables>
                                               <variable id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</variable>
                                               <variable id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</variable>
                                             </variables>
                                             <block type="procedures_defcustomreturn" id="B`%(UJ@(5HI^#[)t`k$:" x="488" y="-512">
                                               </mutation>
                                             <block type="procedures_defcustomnoreturn" id="c4Zobeu@zHx7@T7RCR[+" x="488" y="-487">
                                               <field name="NAME">Chat_senden</field>
                                               <field name="SCRIPT">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</field>
                                             <block type="comment" id="dh?Nq_).+o*LRx@ZBJ/P" x="488" y="-463">
                                               <field name="COMMENT">https://forum.iobroker.net/topic/47210/synology-chat/44</field>
                                                 <block type="comment" id="]-LvUJjLlh6nbfULNnAm">
                                                   <field name="COMMENT">Synology Chat Daten</field>
        <field name="TEXT">Hier dein Token</field>
        <block type="comment" id="#X/LLHHf]+a]HP9ULZZA">
        <field name="COMMENT">Debugmodus an/aus</field>
        <block type="variables_set" id="]Dg;,gKp,/]Sb1cUFi?n">
        <field name="VAR" id="D5Tj,(Y%B2Tp[@g/2DPn">Debug_URL</field>
        <block type="logic_boolean" id="0~lqDtIM29hgH2or)}mL">
        <block type="variables_set" id="W=GM=?`a~14E-J+QXSAQ">
        <field name="VAR" id="/j={Oe4(A3y)y{F~G67H">Debug_send_Result</field>
        <block type="logic_boolean" id="*JUO/RsrY?M/l53;H_pF">
        <block type="comment" id="[gDu2J;3btcPa(EESlU!">
        <field name="COMMENT">Ab hier Trigger</field>
        <block type="on_ext" id="9h_zLLHz{65UPzm^$7}e">
        <value name="OID0">
        <shadow type="field_oid" id="NgekYWG@PsA7G02OF}rj">
        <block type="controls_if" id="mSYXDpsYHKUM+j9uSS2s">
        <block type="logic_compare" id="55HN]QCkz$?W=xUf*cx_">
        <field name="OP">EQ</field>
        <block type="on_source" id="l[/NtLhpCNaa5/@gH6X-">
        <block type="logic_boolean" id="),*:R)Nryc!rExr_0IK=">
        </mutation>
        <value name="ARG0">
        <field name="TEXT">Ich bin ein kleiner 🐧</field>
        <block type="timeouts_settimeout" id="ht3)ckT6?(PDbQipm{_z">
        <block type="procedures_callcustomnoreturn" id="[EP#gKV7fF}Y+8x8zkZ^">
        <mutation name="Chat_senden"></mutation>
        <statement name="ELSE">
        <block type="timeouts_cleartimeout" id="TKEEXDr0Qo(}RX.!blS5">
                                            @dslraser
                                            kann man das schon Produktiv übernehmen , was meinst du oder eher noch eine Testphase !
                                            Beispiel :
                                            https://forum.iobroker.net/topic/40424/alexa-ansagen-i-telegram-i-email-i-alias-i-visu-i-html?_=1640618730944
                                            Das einzigste was mich stört , ich finde keinen Butten um eine ( Test ) -Nachricht im Syn Chat zu löschen !?
                                            dslraser Glasfaser 4 Replies Last reply Reply Quote 0
                                            adapter chat message handler synology synology diskstation
                                            19
                                            184
                                            29925
