    4. MieleCloudService Adapter
    • FredF
      FredF Most Active Forum Testing last edited by
      @Grizzelbee Hatte heute auch den error 500, v4.2.0
      2021-09-24 10:22:34.894 - error: mielecloudservice.0 (5176) [APISendRequest] {"message":"Request failed with status code 500","name":"Error","stack":"Error: Request failed with status code 500\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at IncomingMessage.EventEmitter.emit (domain.js:483:12)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000150629009/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_4f86661b22d680693752561c7a7e8199","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true}} | [Stack]: Error: Request failed with status code 500
      2021-09-24 10:22:34.900 - error: mielecloudservice.0 (5176) Request made and server responded:
      2021-09-24 10:22:34.900 - error: mielecloudservice.0 (5176) Response.status:500
      2021-09-24 10:22:34.900 - error: mielecloudservice.0 (5176) Response.headers: {"date":"Fri, 24 Sep 2021 08:22:34 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains","x-mcs-error-code":"500","x-mcs-error-message":"GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)","x-environment":"mcs-eu-prod-default","access-control-allow-origin":"*","access-control-allow-credentials":"true","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization"}
      2021-09-24 10:22:34.900 - error: mielecloudservice.0 (5176) Response.data: {"code":500,"message":"GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)"}
      2021-09-24 10:22:34.901 - error: mielecloudservice.0 (5176) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-09-24 10:22:34.901 - error: mielecloudservice.0 (5176) unhandled promise rejection: GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)
      2021-09-24 10:22:34.906 - error: mielecloudservice.0 (5176) Error: GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)
      at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:353:19)
      at runMicrotasks ()
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-09-24 10:22:34.906 - error: mielecloudservice.0 (5176) GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)
      2021-09-24 10:22:35.225 - warn: mielecloudservice.0 (5176) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-09-24 10:22:35.811 - error: host.ioBrokerVM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2021-09-24 10:22:35.812 - error: host.ioBrokerVM Caught by controller[1]: Error: GENERIC_TECHNICAL_ERROR (Error-ID: 2dd9fb53a334c9b4)
      2021-09-24 10:22:35.812 - error: host.ioBrokerVM Caught by controller[1]: at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:353:19)
      2021-09-24 10:22:35.812 - error: host.ioBrokerVM Caught by controller[1]: at runMicrotasks ()
      2021-09-24 10:22:35.812 - error: host.ioBrokerVM Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-09-24 10:22:35.812 - error: host.ioBrokerVM instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-09-24 10:22:35.812 - info: host.ioBrokerVM Restart adapter system.adapter.mielecloudservice.0 because enabled
      2021-09-24 10:23:00.068 - info: host.ioBrokerVM instance system.adapter.dwd.0 started with pid 32565
      2021-09-24 10:23:02.328 - info: host.ioBrokerVM instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-24 10:23:05.836 - info: host.ioBrokerVM instance system.adapter.mielecloudservice.0 started with pid 599
      2021-09-24 10:30:00.080 - info: host.ioBrokerVM instance system.adapter.tvspielfilm.0 started with pid 9636
      2021-09-24 10:30:04.103 - info: host.ioBrokerVM instance system.adapter.netatmo-crawler.0 started with pid 10014
      2021-09-24 10:30:08.000 - info: host.ioBrokerVM instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-09-24 10:30:08.127 - info: host.ioBrokerVM instance system.adapter.ical.0 started with pid 10556
      2021-09-24 10:30:12.147 - info: host.ioBrokerVM instance system.adapter.odl.0 started with pid 11170
      2021-09-24 10:30:14.313 - info: host.ioBrokerVM instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
      2021-09-24 10:30:15.794 - info: host.ioBrokerVM instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2021-09-24 10:31:00.035 - info: host.ioBrokerVM instance system.adapter.ical.1 started with pid 15825
      2021-09-24 10:31:02.776 - info: host.ioBrokerVM instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2021-09-24 10:31:08.092 - info: host.ioBrokerVM instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2021-09-24 10:32:59.344 - error: mielecloudservice.0 (599) [APISendRequest] {"message":"Request failed with status code 500","name":"Error","stack":"Error: Request failed with status code 500\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at IncomingMessage.EventEmitter.emit (domain.js:483:12)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000150629009/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_8a5575778706ea1cde03322b57df8261","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true}} | [Stack]: Error: Request failed with status code 500
      2021-09-24 10:32:59.345 - error: mielecloudservice.0 (599) Request made and server responded:
      2021-09-24 10:32:59.346 - error: mielecloudservice.0 (599) Response.status:500
      2021-09-24 10:32:59.346 - error: mielecloudservice.0 (599) Response.headers: {"date":"Fri, 24 Sep 2021 08:32:59 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains","x-mcs-error-code":"500","x-mcs-error-message":"GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)","x-environment":"mcs-eu-prod-default","access-control-allow-origin":"*","access-control-allow-credentials":"true","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization"}
      2021-09-24 10:32:59.346 - error: mielecloudservice.0 (599) Response.data: {"code":500,"message":"GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)"}
      2021-09-24 10:32:59.347 - error: mielecloudservice.0 (599) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-09-24 10:32:59.347 - error: mielecloudservice.0 (599) unhandled promise rejection: GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)
      2021-09-24 10:32:59.348 - error: mielecloudservice.0 (599) Error: GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)
      at runMicrotasks ()
      2021-09-24 10:32:59.348 - error: mielecloudservice.0 (599) GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)
      2021-09-24 10:32:59.860 - warn: mielecloudservice.0 (599) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-09-24 10:33:00.035 - info: host.ioBrokerVM instance system.adapter.yr.0 started with pid 27847
      2021-09-24 10:33:00.531 - error: host.ioBrokerVM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2021-09-24 10:33:00.531 - error: host.ioBrokerVM Caught by controller[1]: Error: GENERIC_TECHNICAL_ERROR (Error-ID: d0456a9ef72ab12f)
      2021-09-24 10:33:00.531 - error: host.ioBrokerVM Caught by controller[1]: at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:353:19)
      2021-09-24 10:33:00.532 - error: host.ioBrokerVM Caught by controller[1]: at runMicrotasks ()
      2021-09-24 10:33:00.532 - error: host.ioBrokerVM Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-09-24 10:33:00.532 - error: host.ioBrokerVM instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-09-24 10:33:00.532 - info: host.ioBrokerVM Restart adapter system.adapter.mielecloudservice.0 because enabled
      2021-09-24 10:33:30.560 - info: host.ioBrokerVM instance system.adapter.mielecloudservice.0 started with pid 30438
      2021-09-24 10:33:42.356 - error: mielecloudservice.0 (30438) [APISendRequest] {"message":"Request failed with status code 500","name":"Error","stack":"Error: Request failed with status code 500\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at IncomingMessage.EventEmitter.emit (domain.js:483:12)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/?language=de","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_be8107a168382e5c549b196b2ba2338f","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true}} | [Stack]: Error: Request failed with status code 500
      2021-09-24 10:33:42.357 - error: mielecloudservice.0 (30438) Request made and server responded:
      2021-09-24 10:33:42.357 - error: mielecloudservice.0 (30438) Response.status:500
      2021-09-24 10:33:42.358 - error: mielecloudservice.0 (30438) Response.headers: {"date":"Fri, 24 Sep 2021 08:33:42 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains","x-mcs-error-code":"500","x-mcs-error-message":"GENERIC_TECHNICAL_ERROR (Error-ID: 9babc031cd17a86b)","x-environment":"mcs-eu-prod-default","access-control-allow-origin":"*","access-control-allow-credentials":"true","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization"}
      2021-09-24 10:33:42.358 - error: mielecloudservice.0 (30438) Response.data: {"code":500,"message":"GENERIC_TECHNICAL_ERROR (Error-ID: 9babc031cd17a86b)"}
      2021-09-24 10:33:42.358 - error: mielecloudservice.0 (30438) [refreshMieleData] [Error: GENERIC_TECHNICAL_ERROR (Error-ID: 9babc031cd17a86b)] |-> JSON.stringify(error):{}
      2021-09-24 10:33:42.533 - error: mielecloudservice.0 (30438) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-09-24 10:33:42.533 - error: mielecloudservice.0 (30438) unhandled promise rejection: Cannot read property 'icon' of undefined
      2021-09-24 10:33:42.534 - error: mielecloudservice.0 (30438) TypeError: Cannot read property 'icon' of undefined
      at addMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:329:119)
      at parseMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:311:11)
      at splitMieleDevices (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:287:15)
      at Timeout.schedule [as _onTimeout] (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:678:27)
      2021-09-24 10:33:42.534 - error: mielecloudservice.0 (30438) Cannot read property 'icon' of undefined
      2021-09-24 10:33:43.042 - warn: mielecloudservice.0 (30438) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-09-24 10:33:43.625 - error: host.ioBrokerVM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2021-09-24 10:33:43.625 - error: host.ioBrokerVM Caught by controller[1]: TypeError: Cannot read property 'icon' of undefined
      2021-09-24 10:33:43.625 - error: host.ioBrokerVM Caught by controller[1]: at addMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:329:119)
      2021-09-24 10:33:43.626 - error: host.ioBrokerVM Caught by controller[1]: at parseMieleDevice (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:311:11)
      2021-09-24 10:33:43.626 - error: host.ioBrokerVM Caught by controller[1]: at splitMieleDevices (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:287:15)
      2021-09-24 10:33:43.626 - error: host.ioBrokerVM Caught by controller[1]: at Timeout.schedule [as _onTimeout] (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:678:27)
      2021-09-24 10:33:43.626 - error: host.ioBrokerVM Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-09-24 10:33:43.626 - error: host.ioBrokerVM instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-09-24 10:33:43.626 - info: host.ioBrokerVM Restart adapter system.adapter.mielecloudservice.0 because enabled
      2021-09-24 10:34:13.648 - info: host.ioBrokerVM instance system.adapter.mielecloudservice.0 started with pid 2244
      2021-09-24 10:34:22.053 - error: mielecloudservice.0 (2244) [APISendRequest] {"message":"Request failed with status code 500","name":"Error","stack":"Error: Request failed with status code 500\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at IncomingMessage.EventEmitter.emit (domain.js:483:12)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/?language=de","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_82cec8acdc83de06920dcf1fbd0f4a30","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true}} | [Stack]: Error: Request failed with status code 500
      2021-09-24 10:34:22.054 - error: mielecloudservice.0 (2244) Request made and server responded:
      2021-09-24 10:34:22.054 - error: mielecloudservice.0 (2244) Response.status:500
      2021-09-24 10:34:22.054 - error: mielecloudservice.0 (2244) Response.headers: {"date":"Fri, 24 Sep 2021 08:34:22 GMT","content-type":"text/html","content-length":"174","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains, max-age=15724800; includeSubDomains","access-control-allow-credentials":"true","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-origin":"*","x-environment":"mcs-eu-prod-default"}
      2021-09-24 10:34:22.054 - error: mielecloudservice.0 (2244) Response.data: "\r\n\r\n\r\n
      500 Internal Server Error
      \r\n
      openresty
      \r\n\r\n\r\n"
      2021-09-24 10:34:22.054 - error: mielecloudservice.0 (2244) [refreshMieleData] [Error] |-> JSON.stringify(error):{}
        JoergH @Grizzelbee last edited by
        Hi @grizzelbee ,
        ich hatte jetzt wieder einmal einen "Stillstand" der Datenpunkte. Mir ist aufgefallen, dass die Datenpunkte nach einer gewissen Zeit einfach nicht mehr aufgefrischt werden, obwohl die Instanz grün anzeigt. Ich muss dann die Instanz neu starten, dann geht es wieder weiter. Wie lange es dauert bis das ganz steht, weiss ich noch nicht, jedenfalls läuft dann natürlich auch kein Skript korrekt, denn er zeigt bei mir dann permanent "Gerät Aus" an...
        oberfragger Grizzelbee 2 Replies Last reply Reply Quote 0
        • oberfragger
          oberfragger @JoergH last edited by
          @Grizzelbee Ich kann das nur bestätigen was @JoergH geschrieben hat. Nach ein paar Tagen tut sich nichts mehr. Habe nun einen nächstlich Neustart der Instanz eingestellt. Damit läuft es sehr zuverlässig.
          • Gargano
            Gargano @Grizzelbee last edited by Gargano
            @grizzelbee Jetzt habe ich auch einige Fehler im Log
            mielecloudservice.0
            2021-09-28 11:18:30.133	error	[refreshMieleData] [Error] |-> JSON.stringify(error):{}
            mielecloudservice.0
            2021-09-28 11:18:30.133	error	Response.data: "<html>\r\n<head><title>504 Gateway Time-out</title></head>\r\n<body>\r\n<center><h1>504 Gateway Time-out</h1></center>\r\n<hr><center>openresty</center>\r\n</body>\r\n</html>\r\n"
            mielecloudservice.0
            2021-09-28 11:18:30.132	error	Response.headers: {"date":"Tue, 28 Sep 2021 09:18:30 GMT","content-type":"text/html","content-length":"164","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains","access-control-allow-origin":"*","access-control-allow-credentials":"true","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization"}
            mielecloudservice.0
            2021-09-28 11:18:30.132	error	Response.status:504
            mielecloudservice.0
            2021-09-28 11:18:30.131	error	Request made and server responded:
            mielecloudservice.0
            2021-09-28 11:18:30.112	error	[APISendRequest] {"message":"Request failed with status code 504","name":"Error","stack":"Error: Request failed with status code 504\n at createError (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at IncomingMessage.EventEmitter.emit (domain.js:483:12)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/?language=de","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_34db0592cccf69b1dad74a069540a73d","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true}} | [Stack]: Error: Request failed with status code 504 at createError (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/core/createError.js:16:15) at settle (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/core/settle.js:17:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.mielecloudservice/node_modules/axios/lib/adapters/http.js:260:11) at IncomingMessage.emit (events.js:326:22) at IncomingMessage.EventEmitter.emit (domain.js:483:12) at endReadableNT (_stream_readable.js:1241:12) at processTicksAndRejections (internal/process/task_queues.js:84:21)
            mielecloudservice.0
            2021-09-28 11:53:41.260	error	[main] APIGetAccessToken returned neither a token nor an errormessage. Returned value=[undefined]
            mielecloudservice.0
            2021-09-28 11:53:41.258	error	[error.response.headers]: [{"date":"1","content-type":"2","content-length":"3","connection":"4","strict-transport-security":"5","access-control-allow-origin":"6","access-control-allow-credentials":"7","access-control-allow-methods":"8","access-control-allow-headers":"9"},"Tue, 28 Sep 2021 09:53:41 GMT","text/html","174","close","max-age=15724800; includeSubDomains","*","true","PUT, GET, POST, OPTIONS","DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization"]
            mielecloudservice.0
            2021-09-28 11:53:41.257	error	[error.response.status]: 500
            mielecloudservice.0
            2021-09-28 11:53:41.257	error	[error.response.data]: <html> <head><title>500 Internal Server Error</title></head> <body> <center><h1>500 Internal Server Error</h1></center> <hr><center>openresty</center> </body> </html>
            mielecloudservice.0
            2021-09-28 11:53:41.254	error	OAuth2 returned an error during first login!
            host.raspberrypi
            2021-09-28 11:53:08.859	error	instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.raspberrypi
            2021-09-28 11:53:08.859	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
            host.raspberrypi
            2021-09-28 11:53:08.859	error	Caught by controller[1]: at runMicrotasks (<anonymous>)
            host.raspberrypi
            2021-09-28 11:53:08.858	error	Caught by controller[1]: at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:353:19)
            host.raspberrypi
            2021-09-28 11:53:08.858	error	Caught by controller[1]: Error: GENERIC_TECHNICAL_ERROR (Error-ID: 7cecd7b7fe1f30be)
            host.raspberrypi
            2021-09-28 11:53:08.857	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            Ich habe WLAN, kein Gateway
            Wäschetrockner TWF660WP
            Adapterversion 4.2.0
            Und ein Schönheitsfehler :
            mielecloudservice.0
            2021-09-28 11:53:41.273	warn	Read-only state "mielecloudservice.0.info.connection" has been written without ack-flag with value "false"
              michael 1975 @oberfragger last edited by
              @oberfragger @JoergH sind das bei euch Wlan Geräte oder Zigbee mit dem Gatway.
              Meine Wlan Geräte funtionieren ohne Problem
              • Grizzelbee
                Grizzelbee Developer @JoergH last edited by
                @joergh sagte in MieleCloudService Adapter:
                Also ... habe ich heute auch gehaubt. Keinen Fehler im Log, alles auf Grün, aber trotzdem irgendwie kaputt. Ich habe allerdings auch die 4.5.0 im Langzeittest laufen. Keine Ahnung was das sein kann. Ob da etwas mit den Events kaputt geht oder was ... Vielleicht muss ich da eine Art keinen Watchdog einbauen. Wir weden sehen.
                Bin aber weiterhin für jeden Hinweis dankbar!
                @Gargano
                Der 504 ist ein Gateway Fehler. Der hat erst einmal nichts mit dem Adapter zu tun. Bitte google mal wie es dazu kommt und welche Lösungsansätze es gibt.
                Und der 500er ist ein "Internal Server Error" bei Miele. Da reagiert die API also doof. Vielleicht weil sie wirklich einen Bug hat, vielleicht aber auch, weil der Adapter Crap gesendet hat und die API deswegen aus dem Tritt gerät. Das ist von Außen leider nicht zu erkennen und zu beurteilen. Bedeutet aber am Ende, dass ich da auch erstmal nicht so viel tun kann.
                  JoergH @michael 1975 last edited by
                  @michael-1975 said in MieleCloudService Adapter:
                  Beides WLAN Geräte
                    schweiger2 last edited by schweiger2
                    Ich habe jetzt auf die Version 4.5.0 ge-updatet und seitdem ist Ruhe im Karton.
                    Die Probleme hatte ich mit der vorherigen Version.
                      JoergH @schweiger2 last edited by
                      @schweiger2
                      Ich habe die aktuellen Probleme mit der 4.5.0
                        Ich habe seit 3 Tagen das Problem das sich meine Spülmaschine nicht mehr aktuellisiert an was kann das liegen?? Wenn ich den Adapter neu starte sind die aktuellen daten sofort wieder da.
                        Gruß Michael
                        Grizzelbee 1 Reply Last reply Reply Quote 0
                        • Grizzelbee
                          Grizzelbee Developer @michael 1975 last edited by
                          @michael-1975
                          Diesem Phänomen jage ich noch hinterher. Ich habe ebenfalls sporadisch das Problem das der Adapter plötzlich nicht mehr aktualisiert. Komischerweise habe ich aber auch rein gar nichts auffälliges im Log stehen. Ich habe noch keine rechte Idee was das Problem sein könnte.
                          Der einzige Hinweis für mich/bei mir ist, dass es bei mir die Version 4.5.0 mit den Server-send-events ist. Sieht so aus, als würde die Verbindung da einfach zusammenbrechen. Außer einem täglichen re-connnect fällt mir da aktuell nicht viel zu ein.
                          • Gargano
                            Gargano last edited by
                            @grizzelbee nur so ein Gedanke : die Fritzbox macht ja nachts ein Zwangsreconnet. Was passiert dann mit offenen Verbindungen?
                            • Grizzelbee
                              Grizzelbee Developer @Gargano last edited by
                              @gargano
                              Ja - darüber habe ich bereits vor der Implementierung der Server-Send-Events nachgedacht. Allerdings ist es ja nicht die Fritzbox, die die Zwangstrennung macht, sondern der DSL Anbieter. Und genau das zieht bei mir nicht, weil ich bei einem Kabelnetzbetreiber bin. Da gibt es keine Zwangstrennung. Ich habe oft über Monate die selbe IP-Adresse.
                              Gargano 1 Reply Last reply Reply Quote 0
                                Ich habe auch Kabel Bunisses mit fester IP adresse falls das relevant ist.
                                • Gargano
                                  @grizzelbee die Fritzbox macht aber selber ei reconnect um der Zwangstrennung der Telekom zuvorzukommen.
                                  Ist das eine stehende Verbindung zum Server?
                                  Wer verbindet ? Der Adapter oder der Server(Cloud)?
                                  Wenn der Adapter verbindet, kommst Du nicht drum herum die Verbindung zu checken und wenn nötig neu zu verbinden. Gibt es ein Event “Verbindung getrennt“ ?
                                  • Grizzelbee
                                    @gargano
                                    Das mit der Trennung durch die Fritzbox ist mir neu, das wusste ich nicht - danke für die Info.
                                    Über die Art der Verbindung bin ich mir noch nicht komplett im Klaren. Leider habe ich im Internet auch nicht allzu viel tiefschürfendes dazu gefunden. Die erste Verbindungsanfrage kommt vom Adapter. Danach gibt es aber keine weiteren Infos mehr dazu. Also kein "Connection lost", "Reconnect", oder so. Ich muss da echt noch einmal tiefer einsteigen.
                                    • Gargano
                                      @grizzelbee kann aber auch sein, dass der Server die Connection aus irgendeinem Grund schliesst. Evtl. ist das Event onClose geeignet
                                      • Grizzelbee
                                        Ich habe mich entschieden das Ganze mal in eine größere Beta-Phase zu geben. Deshab habe ich gerade die V5.0.0 veröffentlicht:
                                        V5.0.0 (2021-10-21) (Invincible)
                                        • (grizzelbee) Chg: BREAKING CHANGE: Removed useless grouping folders for device types - check your VIS and scripts
                                        • (grizzelbee) New: 164 fixed bug in SignalFailure and signalInfo when havin no value
                                        • (grizzelbee) New: 155 fixed >missing object< bug on arrays
                                        • (grizzelbee) New: 154 Reintroduced TargetTemp to washer dryers
                                        • (grizzelbee) New: 140 Switched from data polling to server sent events (push data)
                                        • (grizzelbee) New: 71 If there is no internet connection on startup retry connecting until connection is established
                                        • (grizzelbee) Fix: estimatedEndTime won't be shown anymore when device is off
                                        • (grizzelbee) Fix: Don't rethrowing errors in APISendRequest anymore
                                        • (grizzelbee) Fix: fixed a few minor bugs
                                        • (grizzelbee) Upd: Updated dependencies
                                        • (grizzelbee) New: Added some additional API languages newly supported by Miele
                                        • (grizzelbee) New: Added support for Miele API V1.0.5
                                        • (grizzelbee) New: Added correct tier of adapter to io-package
                                        • (grizzelbee) New: Added more program phases for tumble dryers to documentation
                                        • (grizzelbee) Fix: Switched type of Power-Switch from string to boolean for being compliant with ioBroker expectation (e.g. for Text2Command adapter) - maybe more to follow. Please delete the data point let it create newly.
                                        • (germanBluefox) Fix: Fixed icon link
                                          @Grizzelbee Wie kann ich die Instalieren bis jetzt habe ich es immer über Github gemacht da bleibe ich aber auf der Version 4.5 ?
                                          Gruß Michael
                                          • Grizzelbee
                                            Grizzelbee Developer @michael 1975 last edited by Grizzelbee
                                            @michael-1975
                                            Die einfache Lösung ist: Habe noch ein bisschen Geduld. Die Repos scannen zweimal am Tag auf neue Versionen. Wenn ich das richtig im Kopf habe um 12:00 und um 22:00 Uhr. Danach sind die dann in den Repos verfügbar und werden auch (sobald dein Broker das eingestelle Repo aktualisiert) im Broker als Update angeboten.
                                            Wenn Du dem zuvor kommen möchtest, kannst du entweder über den Expertenmodus direkt von git oder über die Kommandozeile via :
                                            npm install iobroker.mielecloudservice@5.0.0 installieren.
                                            miele mieleathome mielecloudservice
                                            90
                                            851
                                            205577
