    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    • Meister Mopper
      Meister Mopper @Newan last edited by
      @newan Den Adapter bluelinky kann ich nicht installieren:
      host.ioTest
         2021-10-16 17:19:48.564	info	iobroker exit 25
      host.ioTest
         2021-10-16 17:19:47.544	error	iobroker host.ioTest Cannot install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545: 0
      host.ioTest
         2021-10-16 17:19:44.817	info	iobroker make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.4.140-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.18.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      host.ioTest
         2021-10-16 17:19:44.680	info	iobroker In file included from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’? 175 | NODE_MODULE(authenticate_pam, init); | ^~~~/home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’ 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ 175 | NODE_MODULE(authenticate_pam, init); | ^~~~~~~~~~~
      host.ioTest
         2021-10-16 17:19:44.675	info	iobroker ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~~
      host.ioTest
         2021-10-16 17:19:44.672	info	iobroker ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token 170 | void init(Handle<Object> exports) { | ^
      host.ioTest
         2021-10-16 17:19:44.670	info	iobroker ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope 170 | void init(Handle<Object> exports) { | ^~~~~~
      host.ioTest
         2021-10-16 17:19:44.666	info	iobroker ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void 170 | void init(Handle<Object> exports) { | ^~~~
      host.ioTest
         2021-10-16 17:19:44.663	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
      host.ioTest
         2021-10-16 17:19:44.662	info	iobroker ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 161 | password->WriteUtf8(m->password, sizeof(m->password) - 1); | ~~~^~~~~~~~ | | | char [128]
      host.ioTest
         2021-10-16 17:19:44.660	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
      host.ioTest
         2021-10-16 17:19:44.658	info	iobroker ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 160 | username->WriteUtf8(m->username, sizeof(m->username) - 1); | ~~~^~~~~~~~ | | | char [128]
      host.ioTest
         2021-10-16 17:19:44.656	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
      host.ioTest
         2021-10-16 17:19:44.654	info	iobroker ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 155 | remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); | ~~~^~~~~~~~~~ | | | char [128]
      host.ioTest
         2021-10-16 17:19:44.653	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
      host.ioTest
         2021-10-16 17:19:44.651	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
      host.ioTest
         2021-10-16 17:19:44.649	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
      host.ioTest
         2021-10-16 17:19:44.648	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
      host.ioTest
         2021-10-16 17:19:44.646	info	iobroker ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 152 | res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); | ^
      host.ioTest
         2021-10-16 17:19:44.644	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note: initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 | int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, | ~~~~~~~~~^~~~~~~
      host.ioTest
         2021-10-16 17:19:44.642	info	iobroker ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’ 150 | serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); | ~~~^~~~~~~~~~~ | | | char [128]
      host.ioTest
         2021-10-16 17:19:44.640	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided
      host.ioTest
         2021-10-16 17:19:44.638	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ 3720 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
      host.ioTest
         2021-10-16 17:19:44.636	info	iobroker /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided
      host.ioTest
         2021-10-16 17:19:44.634	info	iobroker In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ 3717 | V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, | ^~~
      host.ioTest
         2021-10-16 17:19:44.632	info	iobroker ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ 147 | Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); | ^
      host.ioTest
         2021-10-16 17:19:44.629	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here 1024 | NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( | ^~~~~~~~~~~~
      host.ioTest
         2021-10-16 17:19:44.627	info	iobroker ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] 107 | Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); | ^
      host.ioTest
         2021-10-16 17:19:44.598	info	iobroker In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 2298 | , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      host.ioTest
         2021-10-16 17:19:24.442	info	iobroker NPM version: 6.14.15npm install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545 --loglevel error --prefix "/opt/iobroker" (System call)
      host.ioTest
         2021-10-16 17:19:24.117	info	iobroker install Hacksore/bluelinky#12e40a4f8c1bb5c61fa6a8b18ddd569bfadb9545
      host.ioTest
         2021-10-16 17:19:22.479	info	iobroker url https://github.com/Hacksore/bluelinky.git --host ioTest
      host.ioTest
         2021-10-16 17:18:33.664	info	instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.ioTest
         2021-10-16 17:18:33.123	info	stopInstance system.adapter.bluelink.0 send kill signal
      bluelink.0
         2021-10-16 17:18:33.120	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      bluelink.0
         2021-10-16 17:18:33.119	info	terminating
      bluelink.0
         2021-10-16 17:18:33.119	info	Adapter bluelink cleaned up everything...
      bluelink.0
         2021-10-16 17:18:33.119	info	Got terminate signal TERMINATE_YOURSELF
      host.ioTest
         2021-10-16 17:18:33.116	info	stopInstance system.adapter.bluelink.0 (force=false, process=true)
      host.ioTest
         2021-10-16 17:18:33.114	info	"system.adapter.bluelink.0" disabled
        A Former User @Meister Mopper last edited by
        @meister-mopper bluelinky ist kein iobroker adapter..
        • Meister Mopper
          Meister Mopper @Newan last edited by Meister Mopper
          @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          teste mal debug locally von der lib
          Okay, dann fehlt mir das Verständnis. Was meinst Du?
          edit:
          Okay, ich versuch mal npm install bluelinky 😕
          • Meister Mopper
            Sorry, mit npm install bluelinky aus dem Verzeichnis '/opt/iobroker' komme ich nicht zum Ziel. Wie muss ich bitte vorgehen?
              @meister-mopper
              ich kenn mich damit auch nicht aus, aber hab gerade die Anleitung gelesen, ich würd bluelinky als addon in den javascript adapter eintragen, und dann eins von den Beispielscripten die in der Doc stehen, verwenden..
                Sonnenkind @Guest last edited by
                @ilovegym
                hallöle, der Adapter schaut ja echt gut aus , danke dafür, leider Scheiter ich daran dass ich im log nach dem start folgende Meldung bekomme....eventuell hast Du ja ne Idee?
                ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"7ed8e8d6-8255-428f-b85e-0427c7b7e029","errCode":"4003","errMsg":"Invalid values"}
                  Michaelnorge @Sonnenkind last edited by
                  @sonnenkind Bist du mit der App via Hyundai angemeldet?
                    Sonnenkind @Michaelnorge last edited by
                    @michaelnorge ja , aktuell schon, warum geht das nicht, hat der server damit dann ein Problem?
                    • Meister Mopper
                      @sonnenkind exakt diesen error bekomme ich auch (allerdings kia s. o.)
                        @sonnenkind Ich meine diesen Fehler mal bekommen zu haben als ich über Bluelink angemeldet war.
                        • Meister Mopper
                          Kannst Du mir bitte auf die Sprünge helfen, wie ich dieses debug locally umsetzen muss. Bluelinky habe ich im js-Adapter aktiviert, und was muss ich jetzt tun?
                          Wo finde ich eine config.json, wo ich die credentials eintragen kann?
                          Newan 1 Reply Last reply Reply Quote 0
                          • Newan
                            Newan @Meister Mopper last edited by
                            @meister-mopper sorry fürs verwirren, dachte das wäre klar wenn man in der Materie ist verliert man da den Blickwinkel.
                            Bluelinkly hat nichts mit ioBroker zu tun, das ist die Lib die der Adapter verwendet.
                            Kannst du nicht einfach mal dein Passwort auf was einfaches ändern, das weißt doch schonmal das es nicht/oder doch am Passwortkomplex liegt.
                            Wenn das einfache Passwort auch nicht geht, könntest du mir das testweise zukommen lassen, dann teste ich das für dich im debug Script.
                            Ich denke es liegt nicht am Passwort sondern an den Server.
                            ? schmerenko 2 Replies Last reply Reply Quote 0
                              A Former User @Newan last edited by
                              @newan
                              Schaumal, ich habe den Adapter mal auf debug und hier kommen ja jede Menge Werte rein, kannst du die Umsetzen als Datenpunkte, bitte?
                              Dann wirft das log immer mal wieder ein object-object raus.. anscheinend kann er hier was nicht zuordnen oder so..?
                              Hier das log als txt:
                              2021-10-17 12:44:16.221 - info: bluelink.0 (4110878) Set new status
                              2021-10-17 12:44:16.222 - debug: bluelink.0 (4110878) {"vehicleLocation":{"coord":{"lat":49.794794,"lon":8.608631,"alt":0,"type":0},"head":0,"speed":{"value":0,"unit":0},"accuracy":{"hdop":0,"pdop":0},"time":"20211017084414"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"02H","unit":0,"hvacTempType":1},"defrost":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":43,"batteryPlugin":0,"remainTime2":{"etc1":{"value":22,"unit":1},"etc2":{"value":1060,"unit":1},"etc3":{"value":250,"unit":1},"atc":{"value":600,"unit":1}},"drvDistance":[{"rangeByFuel":{"evModeRange":{"value":164,"unit":1},"totalAvailableRange":{"value":164,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[1,2,3,4,5],"time":{"time":"0740","timeSection":0}},"reservChargeSet":false,"reservFatcSet":{"defrost":false,"airTemp":{"value":"0EH","unit":0,"hvacTempType":1},"airCtrl":0,"heating1":0}}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"0900","timeSection":1},"endtime":{"time":"0740","timeSection":0}},"offPeakPowerFlag":1},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1200","timeSection":0}},"reservChargeSet":false,"reservFatcSet":{"defrost":false,"airTemp":{"value":"0EH","unit":0,"hvacTempType":1},"airCtrl":0,"heating1":0}}},"reservFlag":0,"ect":{"start":{"day":0,"time":{"time":"0000","timeSection":0}},"end":{"day":0,"time":{"time":"0000","timeSection":0}}},"targetSOClist":[{"targetSOClevel":80,"dte":{"rangeByFuel":{"evModeRange":{"value":324,"unit":1},"totalAvailableRange":{"value":324,"unit":1}},"type":2},"plugType":0},{"targetSOClevel":100,"dte":{"rangeByFuel":{"evModeRange":{"value":415,"unit":1},"totalAvailableRange":{"value":415,"unit":1}},"type":2},"plugType":1}]},"chargePortDoorOpenStatus":2},"ign3":true,"hoodOpen":false,"transCond":false,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0},"battery":{"batState":1,"sjbDeliveryMode":0,"batSignalReferenceValue":{"batWarning":0},"powerAutoCutMode":2},"lampWireStatus":{"stopLamp":{"stopLampStatus":false,"leftLamp":false,"rightLamp":false},"headLamp":{"headLampStatus":false,"leftLowLamp":false,"rightLowLamp":false,"leftHighLamp":false,"rightHighLamp":false},"turnSignalLamp":{"turnSignalLampStatus":false,"leftFrontLamp":false,"rightFrontLamp":false,"leftRearLamp":false,"rightRearLamp":false}},"smartKeyBatteryWarning":false,"washerFluidStatus":false,"breakOilStatus":false,"sleepModeCheck":false,"time":"20211017084414","remoteWaitingTimeAlert":{"remoteControlAvailable":1},"systemCutOffAlert":0,"tailLampStatus":0,"hazardStatus":0},"odometer":{"value":3655.2,"unit":1}}
                              2021-10-17 12:44:16.282 - debug: bluelink.0 (4110878) [object Object]
                              2021-10-17 12:44:16.283 - debug: bluelink.0 (4110878) bluelink.0.vehicleStatus.battery.charge_limit_slow
                              2021-10-17 12:44:16.284 - debug: bluelink.0 (4110878) New Event for state: {"val":100,"ack":true,"ts":1634467456274,"q":0,"from":"system.adapter.bluelink.0","user":"system.user.admin","lc":1634019816679}
                              2021-10-17 12:44:16.285 - debug: bluelink.0 (4110878) ID: "bluelink.0.vehicleStatus.battery.charge_limit_slow"
                              2021-10-17 12:44:16.294 - debug: bluelink.0 (4110878) [object Object]
                              2021-10-17 12:44:16.295 - debug: bluelink.0 (4110878) bluelink.0.vehicleStatus.battery.charge_limit_fast
                              2021-10-17 12:44:16.295 - debug: bluelink.0 (4110878) New Event for state: {"val":80,"ack":true,"ts":1634467456290,"q":0,"from":"system.adapter.bluelink.0","user":"system.user.admin","lc":1633078452024}
                              2021-10-17 12:44:16.296 - debug: bluelink.0 (4110878) ID: "bluelink.0.vehicleStatus.battery.charge_limit_fast"
                              2021-10-17 12:44:16.326 - info: bluelink.0 (4110878) State value to set for "bluelink.0.vehicleStatus.battery.plugin" has to be type "boolean" but received type "number"
                              2021-10-17 12:44:16.335 - debug: bluelink.0 (4110878) Folgende Ladezeiten Moeglichkeiten wurden gefunden:
                              2021-10-17 12:44:16.336 - debug: bluelink.0 (4110878) {"etc1":{"value":22,"unit":1},"etc2":{"value":1060,"unit":1},"etc3":{"value":250,"unit":1},"atc":{"value":600,"unit":1}}
                                @ilovegym bin irgendwie verwirrt, der Adapter war doch unter Instanzen zu installieren, was muss ich da noch machen? Gibt es dazu ne Doku?
                                Sorry für meine Blöde frage ...
                                • Newan
                                  Newan @Sonnenkind last edited by
                                  @sonnenkind ihr müsst garnichts zusätzlich installieren. Das was ich sagte war nur für debug Zwecke. Also uninteressant!
                                  • schmerenko
                                    schmerenko @Newan last edited by
                                    @newan
                                    Leider kann man bei Hyundai kein einfaches Passwort verwenden, es solle zwischen 8-20 Zeichen haben,
                                    Klein und Großbuchstaben, Zahlen und Sonderzeichen
                                    selbst bei der 1.1.1 kommt bei mir dies:
                                    ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"e97beff8-4eb2-4420-aa24-ca3aba88263a","errCode":"4003","errMsg":"Invalid values"}
                                    • Newan
                                      Newan @schmerenko last edited by
                                      @schmerenko könntest du mir trotzdem eins zukommen lassen? Wie soll ich es sonst testen?
                                      • Newan
                                        dank eines Pull Request von @tombox gibt es nun Version 2.0.
                                        Diese unterstütz nun auch mehre Fahrzeuge in einer Instanz. Dazu werden aber 2 API Calls gemacht.
                                        Testet daher mal bitte ob das den Limit der API-Server verschlechtert und ob eure Handy-App noch funktionieren.
                                        Nochmal danke an @tombox
                                          @newan
                                          Die v2.0 läuft bei mir seit heute morgen um 8, keine Probleme mit dem polling.
                                          Abfrage steht im Adapter auf 48.
                                          Bitte beachtet, dass eine komplette neue Datenstruktur angelegt wird!
                                            @ilovegym
                                            Moin in die Runde, wo finde ich denn die Version 2 sorry für die blöde frage bei mir wird nur 1.07 angezeigt, und da gibt es immer noch den gleichen Fehler, damit ich mich nicht selber noch ärgere,
                                            Benutzer ist doch die email die ich bei dem Zugang eingebe und das
                                            Pw ist das was ich bei Zugang über die App als Pw eingeben oder ?
                                            Danke für euere Geduld und Hilfe bisher
                                            2316
                                            866534
