    4. Zigbee Backup Fehlermeldung
      Thomas Braun Most Active @frankthegreat last edited by
      @frankthegreat
      Ist das direkt über das fritz.nas? Das muss mit der Option 'noserverino' gemounted werden.
      frankthegreat 1 Reply Last reply Reply Quote 0
      • frankthegreat
        frankthegreat @Thomas Braun last edited by
        @thomas-braun OK, noserverino eingeschaltet, leider keine Besserung.
        	2021-10-18 12:19:43.011	debug	sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
        backitup.0
        	2021-10-18 12:19:43.010	error	[zigbee] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/zigbee_0/'
        backitup.0
        	2021-10-18 12:19:43.009	error	[zigbee] Zigbee Restore not completed
        backitup.0
        	2021-10-18 12:19:39.843	debug	[zigbee] zigbee tmp directory created: /opt/iobroker/backups/zigbee_0
        backitup.0
        	2021-10-18 12:19:39.834	debug	[zigbee] Filename for Restore: /opt/iobroker/backups/zigbee.0_2021_10_15-02_34_57_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:39.833	debug	[zigbee] Start Zigbee Restore ...
        backitup.0
        	2021-10-18 12:19:31.575	debug	sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
        backitup.0
        	2021-10-18 12:19:29.527	debug	mount successfully completed
        backitup.0
        	2021-10-18 12:19:29.386	debug	Backup list be read ...
        backitup.0
        	2021-10-18 12:19:29.359	debug	cifs-mount command: "sudo mount -t cifs -o username=Backup_Anna,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.181.1/fritz.nas/My_Passport/Backup_Anna /opt/iobroker/backups"
        backitup.0
        	2021-10-18 12:19:29.358	debug	noserverino option: true
        backitup.0
        	2021-10-18 12:19:14.459	debug	umount successfully completed
        backitup.0
        	2021-10-18 12:19:12.365	debug	mount activ... umount in 2 Seconds!!
        backitup.0
        	2021-10-18 12:19:04.645	debug	detect last backup file: iobroker_2021_10_18-12_17_34_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.642	debug	detect backup file 8 from cifs: iobroker_2021_10_18-12_17_34_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.641	debug	detect backup file 7 from cifs: iobroker_2021_10_18-11_50_37_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.640	debug	detect backup file 6 from cifs: iobroker_2021_10_18-11_42_57_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.639	debug	detect backup file 5 from cifs: iobroker_2021_10_17-20_02_08_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.638	debug	detect backup file 4 from cifs: iobroker_2021_10_17-19_59_25_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.637	debug	detect backup file 3 from cifs: iobroker_2021_10_17-17_56_34_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.636	debug	detect backup file 2 from cifs: iobroker_2021_10_17-17_54_23_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:04.634	debug	detect backup file 1 from cifs: iobroker_2021_10_15-02_03_27_backupiobroker.tar.gz
        backitup.0
        	2021-10-18 12:19:02.581	debug	mount successfully completed
        backitup.0
        	2021-10-18 12:19:02.446	debug	cifs-mount command: "sudo mount -t cifs -o username=Backup_Anna,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.181.1/fritz.nas/My_Passport/Backup_Anna /opt/iobroker/backups"
        backitup.0
        	2021-10-18 12:19:02.445	debug	noserverino option: true
        backitup.0
        	2021-10-18 12:19:02.352	info	[iobroker] backup was activated at 02:00 every 7 day(s)
        backitup.0
        	2021-10-18 12:19:02.265	info	starting. Version 2.1.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.18
        backitup.0
        	2021-10-18 12:19:01.584	debug	Plugin sentry Initialize Plugin (enabled=true)
          @frankthegreat
          Wem gehört denn der ganze Kram in /opt/iobroker/backups wenn das gemountet ist?
          • frankthegreat
            @thomas-braun Jetzt bin ich überfordert...welcher Kram???
            Ich hab testweise auch mal lokal Backups gemacht.
            Kann das Zigbee aber auch von dort nicht herstellen. Kommt der gleiche Fehler.
              Thomas Braun Most Active @frankthegreat last edited by Thomas Braun
              @frankthegreat
              Wenn es gemountet ist:
              ls -la /opt/iobroker/backups/zigbee_0/
              Und wenn die Freigabe nicht gemountet ist:
              Das Verzeichnis müsste dann leer sein.
              • frankthegreat
                @thomas-braun Da kommt folgendes raus:
                pi@raspberrypi:~ $ ls -la /opt/iobroker/backups/zigbee_0/
                insgesamt 0
                drwxrwxrwx 2 root root 0 Okt 17 19:10 .
                drwxrwxrwx 2 root root 0 Okt 18 12:17 ..
                insgesamt 24149
                drwxrwxr-x+ 7 iobroker iobroker    4096 Okt 17 19:43 ..
                -rwxrwxrwx  1 root     root     2168397 Okt 17 17:59 historyDB_2021_10_15-02_31_17_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root          86 Okt 17 17:56 historyDB_2021_10_17-17_56_41_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     2168594 Okt 17 20:02 historyDB_2021_10_17-20_02_16_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     2168594 Okt 18 11:43 historyDB_2021_10_18-11_43_05_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     2168594 Okt 18 11:50 historyDB_2021_10_18-11_50_45_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     2168594 Okt 18 12:17 historyDB_2021_10_18-12_17_45_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4461478 Okt 17 17:59 iobroker_2021_10_15-02_03_27_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     3591634 Okt 17 17:54 iobroker_2021_10_17-17_54_23_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     3591770 Okt 17 17:56 iobroker_2021_10_17-17_56_34_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4229270 Okt 17 19:59 iobroker_2021_10_17-19_59_25_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4229271 Okt 17 20:02 iobroker_2021_10_17-20_02_08_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4229251 Okt 18 11:43 iobroker_2021_10_18-11_42_57_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4229219 Okt 18 11:50 iobroker_2021_10_18-11_50_37_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root     4229277 Okt 18 12:17 iobroker_2021_10_18-12_17_34_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root        9122 Okt 17 17:56 javascripts_2021_10_17-17_56_42_backupiobroker.tar.gz
                -rwxrwxrwx  1 root     root         210 Okt 17 17:59 redis_2021_10_15-02_31_17_backupiobroker.tar.gz
                drwxrwxrwx  2 root     root           0 Okt 17 19:59 redistmp
                drwxrwxrwx  2 root     root           0 Okt 17 19:10 zigbee_0
                -rwxrwxrwx  1 root     root      255152 Okt 17 17:59 zigbee.0_2021_10_15-02_34_57_backupiobroker.tar.gz
                pi@raspberrypi:~ $
                  @frankthegreat sagte in Zigbee Backup Fehlermeldung:
                  muss leer sein, wenn die Freigabe nicht gemountet ist.
                  Ein Mountpunkt fungiert als Scharnier mit den Freigaben, wenn da schon was liegt knirscht das, wenn da drüber gemountet wird.
                  • frankthegreat
                    @thomas-braun Soll ich die lokalen Backups mal alle löschen?
                    Sorry für die Fragerei, steig da noch nicht so recht durch 😧
                      @frankthegreat
                      Wenn du sicher bist, das deine Backups sicher auf dem NAS liegen kannst bzw. solltest du das Verzeichnis /opt/iobroker/backups leeren. Natürlich nicht wenn die Freigabe gerade gemountet ist, dann würdest du die Dateien dort löschen.
                      Mit dem Mounten von entfernten Datei-Systemen kannst du dir das vorstellen wie einen Eisenbahnwagen. Der wird einfach (mitsamt Passagieren/Daten) an der vorgesehenen Stelle angekoppelt, setzt allerdings voraus das da nicht schon ein Waggon mit Passagieren (Daten) die Kupplung blockiert.
                      • frankthegreat
                        @thomas-braun Trotz dem leeren der lokale Backups, will er immerzu von dort die Backups ziehen und nicht vom NAS.
                        Hat garantiert was mit dem mounten zu tun...so is ja auch deine Vermutung.
                        Aber wie bekomme ich Backitup jetzt dazu, das er das Backup vom NAS zieht?
                          Das ist ja auch richtig, das Backup greift immer auf den Pfad /opt/iobroker/backups zu. Wo die Daten physisch liegen ist da irrelevant, das wird über den mount vom Betriebssytem geregelt.
                          • frankthegreat
                            OK, das hab ich jetzt denk ich verstanden 😇
                            Aber gibt's jetzt eine Möglichkeit, das Zigbee Backup wieder einzuspielen?
                            Die Fehlermeldung ist immer die gleiche, egal was ich einstelle und das ioBroker Backup hat er ohne Probleme eingespielt.
                            Das wundert mich schon ein bisschen 🙁
                              Thomas Braun Most Active last edited by
                              @frankthegreat
                              iobroker stop
                              iobroker fix
                              iobroker start
                              • frankthegreat
                                @thomas-braun OK, gemacht.
                                Fehler is noch der gleiche.
                                Was kann ich noch machen?
                                  @frankthegreat
                                  Zeig mal deine Einstellungen aus dem Adapter / Reiter 'NAS/Kopieren' und die aus dem NAS bezüglich der Freigaben.
                                  • frankthegreat
                                    Meinst du diese:
                                      @frankthegreat
                                      Eigentlich soweit i. O.
                                      Firmware auf der FritzBox?
                                      smb-Typ auf 3.1.1. setzen.
                                      • frankthegreat
                                        @thomas-braun FB Firmware ist die aktuelle: 7.28
                                        smb-Typ auf 3.1.1 gesetzt
                                        Fehler noch da.
                                          @frankthegreat
                                          Möglich das die Backups von 'vor der Umstellung' auf noserverino falsche Rechte haben.
                                          Mounte die Freigabe mal und schaue per
                                          währenddessen wem die Dateien gehören.
                                          • frankthegreat
                                            insgesamt 4
                                            drwxrwxrwx  2 root     root           0 Okt 18 19:13 .
                                            drwxrwxr-x+ 7 iobroker iobroker    4096 Okt 18 18:38 ..
                                            -rwxrwxrwx  1 root     root     4229182 Okt 18 18:08 iobroker_2021_10_18-18_08_40_backupiobroker.tar.gz
                                            -rwxrwxrwx  1 root     root     4229506 Okt 18 19:13 iobroker_2021_10_18-19_13_03_backupiobroker.tar.gz
                                            drwxrwxrwx  2 root     root           0 Okt 18 18:10 zigbee_0
                                            -rwxrwxrwx  1 root     root      255152 Okt 18 18:10 zigbee.0_2021_10_15-02_34_57_backupiobroker.tar.gz
                                            -rwxrwxrwx  1 root     root          87 Okt 18 18:08 zigbee.0_2021_10_18-18_08_49_backupiobroker.tar.gz
                                            -rwxrwxrwx  1 root     root          84 Okt 18 19:13 zigbee.0_2021_10_18-19_13_12_backupiobroker.tar.gz
                                            pi@raspberrypi:~ $
                                            1137
