    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      tombox @arteck last edited by
      @arteck Der Name scheint falsch von der API kommen der Datenpunkt heißt
      BSH_Common_Option_RemainingProgramTimeIsEstimated
      Der Name passt dazu ist inkorrekt. Man könnte ihn mal löschen und schauen ob er korrekt neu erstellt wird
        JohnnyBahama @tombox last edited by
        @tombox Hier der debug
        homeconnect.0
        2021-10-14 21:53:00.512	info	NEFF-D96BMV5N5-68A40E08BA18: There is no program active
        homeconnect.0
        2021-10-14 21:52:52.849	debug	Rate per min: 5
        homeconnect.0
        2021-10-14 21:52:52.848	debug	Delete: NEFF-D96BMV5N5-68A40E08BA18.programs.active.options
        homeconnect.0
        2021-10-14 21:52:52.847	debug	active.options.
        homeconnect.0
        2021-10-14 21:52:52.796	debug	""
        homeconnect.0
        2021-10-14 21:52:52.795	debug	204
        homeconnect.0
        2021-10-14 21:52:52.765	debug	NEFF-D96BMV5N5-68A40E08BA18.programs.active.BSH_Common_Root_ActiveProgram:null
        homeconnect.0
        2021-10-14 21:52:52.765	debug	NEFF-D96BMV5N5-68A40E08BA18.settings.BSH_Common_Setting_PowerState:BSH.Common.EnumType.PowerState.Off
        homeconnect.0
        2021-10-14 21:52:52.762	debug	event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1634241172,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/settings/BSH.Common.Setting.PowerState\",\"key\":\"BSH.Common.Setting.PowerState\",\"value\":\"BSH.Common.EnumType.PowerState.Off\",\"level\":\"hint\"},{\"timestamp\":1634241172,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/programs/active\",\"key\":\"BSH.Common.Root.ActiveProgram\",\"value\":null,\"level\":\"hint\"}],\"haId\":\"NEFF-D96BMV5N5-68A40E08BA18\"}","lastEventId":"NEFF-D96BMV5N5-68A40E08BA18","origin":"https://api.home-connect.com"}
        homeconnect.0
        2021-10-14 21:52:52.760	debug	NEFF-D96BMV5N5-68A40E08BA18.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Inactive
        homeconnect.0
        2021-10-14 21:52:52.759	debug	event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1634241172,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/status/BSH.Common.Status.OperationState\",\"key\":\"BSH.Common.Status.OperationState\",\"value\":\"BSH.Common.EnumType.OperationState.Inactive\",\"level\":\"hint\"}],\"haId\":\"NEFF-D96BMV5N5-68A40E08BA18\"}","lastEventId":"NEFF-D96BMV5N5-68A40E08BA18","origin":"https://api.home-connect.com"}
        homeconnect.0
        2021-10-14 20:52:46.480	debug	Rate per min: 4
        homeconnect.0
        2021-10-14 20:52:46.480	debug	{"data":{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.Off","type":"BSH.Common.Setting.PowerState"}}
        homeconnect.0
        2021-10-14 20:52:46.479	debug	NEFF-D96BMV5N5-68A40E08BA18/settings/BSH.Common.Setting.PowerState
        homeconnect.0
        2021-10-14 20:52:44.363	error	Put folder failed NEFF-D96BMV5N5-68A40E08BA18/commands/Cooking.Common.Option.Hood.VentingLevel{"data":{"key":"Cooking.Common.Option.Hood.VentingLevel","value":"Cooking.Hood.EnumType.Stage.FanStage01"}}
        homeconnect.0
        2021-10-14 20:52:44.363	info	409: Request cannot be performed since no program is selected
        homeconnect.0
        2021-10-14 20:52:39.684	debug	Rate per min: 3
        homeconnect.0
        2021-10-14 20:52:39.684	debug	{"data":{"key":"Cooking.Common.Option.Hood.VentingLevel","value":"Cooking.Hood.EnumType.Stage.FanStage01"}}
        homeconnect.0
        2021-10-14 20:52:39.683	debug	NEFF-D96BMV5N5-68A40E08BA18/programs/selected/options/Cooking.Common.Option.Hood.VentingLevel
        homeconnect.0
        2021-10-14 20:52:28.342	error	Put folder failed NEFF-D96BMV5N5-68A40E08BA18/commands/Cooking.Common.Option.Hood.VentingLevel{"data":{"key":"Cooking.Common.Option.Hood.VentingLevel","value":"Cooking.Hood.EnumType.Stage.FanStage02"}}
        homeconnect.0
        2021-10-14 20:52:28.341	info	409: Request cannot be performed since no program is selected
        homeconnect.0
        2021-10-14 20:52:28.181	debug	Rate per min: 2
        homeconnect.0
        2021-10-14 20:52:28.181	debug	{"data":{"key":"Cooking.Common.Option.Hood.VentingLevel","value":"Cooking.Hood.EnumType.Stage.FanStage02"}}
        homeconnect.0
        2021-10-14 20:52:28.180	debug	NEFF-D96BMV5N5-68A40E08BA18/programs/selected/options/Cooking.Common.Option.Hood.VentingLevel
        homeconnect.0
        2021-10-14 20:52:17.508	debug	Create State: NEFF-D96BMV5N5-68A40E08BA18.programs.active.options.BSH_Common_Option_ElapsedProgramTime
        homeconnect.0
        2021-10-14 20:52:17.508	debug	Create State: NEFF-D96BMV5N5-68A40E08BA18.programs.active.options.Cooking_Common_Option_Hood_IntensiveLevel
        homeconnect.0
        2021-10-14 20:52:17.508	debug	Create State: NEFF-D96BMV5N5-68A40E08BA18.programs.active.options.Cooking_Common_Option_Hood_VentingLevel
        homeconnect.0
        2021-10-14 20:52:17.508	debug	{"data":{"options":[{"key":"Cooking.Common.Option.Hood.VentingLevel","value":"Cooking.Hood.EnumType.Stage.FanStage02","name":"Lüfterstufe","displayvalue":"2"},{"key":"Cooking.Common.Option.Hood.IntensiveLevel","value":"Cooking.Hood.EnumType.IntensiveStage.IntensiveStageOff","name":"Intensivstufen","displayvalue":"Aus"},{"key":"BSH.Common.Option.ElapsedProgramTime","value":0,"unit":"seconds","name":"Programmlaufzeit"}]}}
        homeconnect.0
        2021-10-14 20:52:17.507	debug	/programs/active/options
        homeconnect.0
        2021-10-14 20:52:17.289	debug	Rate per min: 1
        homeconnect.0
        2021-10-14 20:52:17.287	debug	Delete: NEFF-D96BMV5N5-68A40E08BA18.programs.active.options
        homeconnect.0
        2021-10-14 20:52:17.286	debug	active.options.
        homeconnect.0
        2021-10-14 20:52:17.118	debug	NEFF-D96BMV5N5-68A40E08BA18.programs.active.options.BSH_Common_Option_ElapsedProgramTime:0
        homeconnect.0
        2021-10-14 20:52:17.118	debug	NEFF-D96BMV5N5-68A40E08BA18.programs.active.options.Cooking_Common_Option_Hood_VentingLevel:Cooking.Hood.EnumType.Stage.FanStage02
        homeconnect.0
        2021-10-14 20:52:17.117	debug	NEFF-D96BMV5N5-68A40E08BA18.programs.active.BSH_Common_Root_ActiveProgram:Cooking.Common.Program.Hood.Venting
        homeconnect.0
        2021-10-14 20:52:17.116	debug	NEFF-D96BMV5N5-68A40E08BA18.settings.BSH_Common_Setting_PowerState:BSH.Common.EnumType.PowerState.On
        homeconnect.0
        2021-10-14 20:52:17.116	debug	event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1634241137,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/settings/BSH.Common.Setting.PowerState\",\"key\":\"BSH.Common.Setting.PowerState\",\"value\":\"BSH.Common.EnumType.PowerState.On\",\"level\":\"hint\"},{\"timestamp\":1634241137,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/programs/active\",\"key\":\"BSH.Common.Root.ActiveProgram\",\"value\":\"Cooking.Common.Program.Hood.Venting\",\"level\":\"hint\"},{\"timestamp\":1634241137,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/programs/active/options/Cooking.Common.Option.Hood.VentingLevel\",\"key\":\"Cooking.Common.Option.Hood.VentingLevel\",\"value\":\"Cooking.Hood.EnumType.Stage.FanStage02\",\"level\":\"hint\"},{\"timestamp\":1634241137,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/programs/active/options/BSH.Common.Option.ElapsedProgramTime\",\"key\":\"BSH.Common.Option.ElapsedProgramTime\",\"unit\":\"seconds\",\"value\":0,\"level\":\"hint\"}],\"haId\":\"NEFF-D96BMV5N5-68A40E08BA18\"}","lastEventId":"NEFF-D96BMV5N5-68A40E08BA18","origin":"https://api.home-connect.com"}
        homeconnect.0
        2021-10-14 20:52:17.115	debug	NEFF-D96BMV5N5-68A40E08BA18.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Run
        homeconnect.0
        2021-10-14 20:52:17.114	debug	event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1634241137,\"handling\":\"none\",\"uri\":\"/api/homeappliances/NEFF-D96BMV5N5-68A40E08BA18/status/BSH.Common.Status.OperationState\",\"key\":\"BSH.Common.Status.OperationState\",\"value\":\"BSH.Common.EnumType.OperationState.Run\",\"level\":\"hint\"}],\"haId\":\"NEFF-D96BMV5N5-68A40E08BA18\"}","lastEventId":"NEFF-D96BMV5N5-68A40E08BA18","origin":"https://api.home-connect.com"}
        homeconnect.0
        2021-10-14 20:52:17.113	debug	""
        homeconnect.0
        2021-10-14 20:52:17.112	debug	204
        homeconnect.0
        2021-10-14 20:52:14.036	debug	Rate per min: 0
        homeconnect.0
        2021-10-14 20:52:14.035	debug	{"data":{"key":"BSH.Common.Setting.PowerState","value":"BSH.Common.EnumType.PowerState.On","type":"BSH.Common.Setting.PowerState"}}
        homeconnect.0
        2021-10-14 20:52:14.034	debug	NEFF-D96BMV5N5-68A40E08BA18/settings/BSH.Common.Setting.PowerState
        homeconnect.0
        2021-10-14 20:51:02.785	info	Loglevel changed from "info" to "debug"
          tombox @JohnnyBahama last edited by
          @johnnybahama Also ich vermute das problem bei der api
          Müsste man mal fragen ob das so von der api unterstützt wird
          https://developer.home-connect.com/support/contact
            arteck Developer Most Active @tombox last edited by arteck
            @tombox hab schon ..wird nicht
            die Datenpunkte oben drüber werden auch nicht mehr gefüllt wenn der Trockner läuft
            also programmfortschiritt
            geschätzte gesamtdauer
            da muss eine änderung gekommen sein setens API.. die waren mal gefüllt.. da ich mit den Werten gerechnet habe..
            das einzige was akutalisiert wird ist die Verbleibende Programmlaufzeit.. deshalb die annahme einer Verschiebung
              @arteck Das heißt wenn du sie löscht werden sie auch nicht neu erstellt?
                @tombox Nur eine saloppe allgemeine Email erhalten. Inhalt: Wir werden immer wieder mal feature hinzufügen, dass kann man sich im changelog anschauen. Nicht alles von der mobile app wird übernommen. BlaBlaBla.
                Also muss ich damit leben.
                  @tombox erstellt schon nur nicht aktualisiert
                    @arteck Der Adapter stellt nur das dar was über die API kommt wenn es dazu kein event gibt wird es nicht aktualisiert
                      JohnnyBahama last edited by JohnnyBahama
                      @tombox Siehe da, es kam noch unerwartet eine zweite Mail von Home Connect:
                      Yes, API does support venting level change for the hood.
                      It seems that you are using incorrect URL to do that:
                      Venting level is not a command but option, therefore you need to send PUT /api/homeappliances/{haId}/programs/active/options/Cooking.Common.Option.Hood.VentingLevel (also please look into: https://api-docs.home-connect.com/programs-and-options?#hood_venting-level-option) or start new program along with new options.
                        @johnnybahama ok funktioniert das so für dich als Option bevor du das Gerät aktivierst
                          JohnnyBahama @tombox last edited by JohnnyBahama
                          @tombox Es hat nur einmal funktioniert. Erst Gerät eingeschaltet, taucht der Datenpunkt auf und dann lies er sich in der Stufe anpassen. Nach dem aus und an, erscheint zwar der Datenpunkt, aber nicht mehr die States.
                          Die unterschiedlichen states kamen bei dem einem mal auch erst, wenn man die Stufen vorher durchgespielt hat, ansonsten erscheint nur ein State.
                            derdominik @tombox last edited by
                            Hallo, ich bekomme auch ab und zu das Rate-Limit angezeigt.
                            Error getting Aplliances with existing Token: 429  The rate limit "1000 calls in 1 day" was reached
                            Nach einem Tag warten funktioniert es wieder.
                            In einem vorherigen Kommentar wurde erwähnt, dass das fast nur durch zu viel Restarts des Adapters liegen kann.
                            Das wird bei mir nicht zeigesteuert ausgeführt, allerdings ist mir folgendes im Log aufgefallen:
                            Ich bekomme gerade alle paar Minuten ein "DISCONNECTED" event angezeigt. Das ist dann gleichbedeutend mit einem Adapter Restart, der Adapter holt sich alle Infos, bei mir ist dann "Rate per min: 16". Ich nehme an dass damit pro Restart 16 API calls verbraucht werden. Nach ein paar Stunden bin ich dadurch direkt wieder im 1000 calls rate limit.
                            $ grep homeconnect iobroker.current.log | grep CONNECT
                            2021-10-19 21:56:11.172  - debug: homeconnect.0 (21621) event: {"type":"DISCONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE...
                            2021-10-19 21:56:50.557  - debug: homeconnect.0 (21621) event: {"type":"CONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE-68...
                            2021-10-19 21:59:26.619  - debug: homeconnect.0 (21621) event: {"type":"DISCONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE...
                            2021-10-19 21:59:53.951  - debug: homeconnect.0 (21621) event: {"type":"CONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE-68...
                            2021-10-19 22:02:29.975  - debug: homeconnect.0 (21621) event: {"type":"DISCONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE...
                            2021-10-19 22:03:11.884  - debug: homeconnect.0 (21621) event: {"type":"CONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE-68...
                            2021-10-19 22:05:48.335  - debug: homeconnect.0 (21621) event: {"type":"DISCONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE...
                            2021-10-19 22:06:26.345  - debug: homeconnect.0 (21621) event: {"type":"CONNECTED","data":"","lastEventId":"SIEMENS-SX758X06TE-68...
                            Kann das an einer lokalen Einstellung bei mir liegen oder sind das homeconnect-Probleme?
                            T oberfragger 2 Replies Last reply Reply Quote 0
                              tombox @derdominik last edited by
                              @derdominik Also den Fall bei Disconnect könnte man sicher verbessern aber warum Verliert das Gerät so oft die Verbindung
                                derdominik @tombox last edited by derdominik
                                @tombox Ich habe gestern den Adapter gestoppt, bevor das Rate Limit wieder greift. Heute morgen wieder gestartet und seit dem habe ich keine Disconnects mehr.
                                Einige der Fehler im Adapter sind garantiert auf die instabile Homeconnect API zurückzuführen. Wenn du weisst, welche Adapter-Events zu eine Restart oder vermehrten API Call führen, könntest du dafür eine .info log oder sogar .warn schreiben?
                                Ich habe auch gesehen dass die Rate Limit pro Minute auf debug geloggt werden. Kannst du so etwa auch für das 1000-Calls-Per-24h einbauen?
                                Würde mir zumindest bei der Fehleranalyse helfen. Ich habe meine Disconnects nur durch debug level gesehen.
                                EDIT
                                zu früh gefreut, 3h später haben die DISCONNECTs wieder angefangen, alle 3-5min. Und 2h später war ich wieder im "The rate limit 1000 calls in 1 day" Modus.
                                • oberfragger
                                  oberfragger @derdominik last edited by
                                  @derdominik Das Problem habe ich auch.
                                  Ich bin bei Adapterstart so bei ca. 100... da sind die 1.000 sehr schnell voll.
                                  Aktuell habe ich mir damit geholfen, dass die Instanz morgens gestartet und nachmittags wieder deaktiviert wird. So habe ich dann meisstens eine Rückmeldung meiner Kaffeemaschine.
                                  Alle Geräte stehen im selben Raum wieder der Router und ich habe kein Schloss. Die Verbindung verlieren die auch ab und an.
                                    JohnnyBahama @derdominik last edited by JohnnyBahama
                                    @derdominik Bei mir hat ein falsches Skript die requests ausgelöst. Hast du daswas am laufen? Mal pausieren und beobachten.
                                      derdominik @JohnnyBahama last edited by
                                      @johnnybahama danke für den Hinweis. Momentan habe ich lediglich ein Skript am laufen, welches mir die geänderte Remaining-Time ausliest und umschreibt, also rein lesend.
                                      Was war in deinem Fall der Fehler im Script? Ich dachte, dass die Events "DISCONNECTED" von den Homeconnect systemen kommen.
                                        @derdominik Bei mir war es der trigger. Ich hatte den auf Alexa Summery aktualisieren anstatt geändert stehen , somit hat der mehrmals ausgelöst und die 1000 voll gemacht. Der hat zwar auch ab und an disconnected, aber nicht soviel wie bei dir, daher die vermutung das irgendein Skript das auslöst.
                                        oberfragger T 2 Replies Last reply Reply Quote 0
                                        • oberfragger
                                          oberfragger @JohnnyBahama last edited by oberfragger
                                          @johnnybahama
                                          Mhh.. Ich habe mal mein EINZIGES Script im Zusammenhang mit Homeconnect gecheckt. Alle anderen dazu sind deaktiviert.
                                          Nix mit aktualisieren (in den Homeconnect-Werten). Ich habe auch den iot-Adapter überprüft, ob da irgendein homeconnect-Gerät noch drin hängt
                                          Mag da mal bitte jemand drüberschauen? Vielleicht Habe ich mich geirrt...?
                                            <variables>
                                              <variable type="cron" id="schedule1">schedule1</variable>
                                              <variable type="cron" id="schedule2">schedule2</variable>
                                            </variables>
                                            <block type="schedule_create" id="oe|t=GQDNP8xxeo`u.U5" x="163" y="-337">
                                              <field name="NAME">schedule1</field>
                                              <value name="SCHEDULE">
                                                <shadow type="field_cron" id="sd-=*BK=Q,F(mT$-tX0q">
                                                  <field name="CRON">15 7 * * *</field>
                                                <block type="control" id="Zr2H0AeCT-Xv!]ZVDW7m">
                                                  <field name="OID">system.adapter.homeconnect.0.alive</field>
                                                    <block type="logic_boolean" id="b0K-8Ms4Q|cjO.s.3Y3O">
                                                <block type="schedule_create" id="ZBjsX*j4Tpq}/BCNJhXD">
                                                  <field name="NAME">schedule2</field>
                                                    <shadow type="field_cron" id="4gppE^]6Z3~fM4(`.p5#">
                                                      <field name="CRON">30 16 * * *</field>
                                                    <block type="control" id="OL{~ch3yVhjgNI;%$Qc2">
                                                        <block type="logic_boolean" id="mB.~3e!{tJKBPobiSyL8">
                                            <block type="comment" id="LapTK?,zWE6pz2iV@=Bd" x="163" y="-82">
                                              <field name="COMMENT">Zuletzt gewählten Kaffee in eigenen DP einsetzen</field>
                                                <block type="on" id="P[p|KIv3DklZ*7m`J=N|">
                                                  <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.selected.BSH_Common_Root_SelectedProgram</field>
                                                    <block type="controls_if" id="~6{*Ca*7l4%hOUmLmL{c">
                                                        <block type="logic_compare" id="l7)TWOm#vM5l/2R}t#2X">
                                                          <field name="OP">NEQ</field>
                                                            <block type="on_source" id="v!zVQIk]LtLD!f6}(RI5">
                                                            <block type="logic_null" id="_tcb=-(;tZt(9GRfBEol"></block>
                                                        <block type="update" id="-$7Dw9!Tr_n]x24=+ud]">
                                                          <field name="OID">0_userdata.0.Kaffemaschine.last_coffee</field>
                                                            <block type="on_source" id="R:@y-I4Qe1h({z;lMu[%">
                                                    <block type="comment" id="Pb~:L+1hh!xT[39H,0HM">
                                                      <field name="COMMENT">Alexa Ansage wenn der Kaffee fertig ist</field>
                                                        <block type="on" id="8715eV~RN{[[atjqp@A8">
                                                          <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.programs.active.options.BSH_Common_Option_ProgramProgress</field>
                                                            <block type="controls_if" id="i$4lS6+x-a-AN;|Wmh]X">
        <block type="logic_compare" id="v9co4T,*.REvm,*8J2i#">
        <field name="OP">EQ</field>
        <block type="on_source" id="W?RA#KxD4^Kb9*?T7_h?">
        <block type="text" id="B+(*%MY~j/GNKQIdmFM9">
        <field name="TEXT">100</field>
        <block type="debug" id=")HW.x=,;sH),_zIqVF}i">
        <value name="TEXT">
        <shadow type="text" id="$RUw9@byon|Z=$_ASkcR">
        <field name="TEXT">Kaffe fertig</field>
        <block type="control" id="Y}+T;Cn_Txd:w~=aM/PZ">
        <field name="OID">alexa2.0.Echo-Devices.G2A14Q04942203FS.Commands.speak</field>
        <block type="text_join" id="RoFpf:(~km;gBVgIj_Ux">
        <value name="ADD0">
        <block type="text" id="d]Vm*Ut]_wEqbN{iM.s3">
        <field name="TEXT">25; Hallo, Dein </field>
        <value name="ADD1">
        <block type="text_getSubstring" id="0{Uw?u%^MYeJCt?!jOs$" inline="false">
        <mutation at1="true" at2="false"></mutation>
        <field name="WHERE1">FROM_START</field>
        <field name="WHERE2">LAST</field>
        <value name="STRING">
        <block type="get_value" id="tOaa~3:fQ~~Fq}:TH8lA">
        <value name="AT1">
        <block type="math_arithmetic" id="sj1DNn3Ik-(Gm4$b~i02" inline="false">
        <field name="OP">ADD</field>
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="A`TLz5Lbfgw;=mJOp}(^">
        <field name="NUM">1</field>
        <block type="text_indexOf" id="3@!vQ6nf?sI?`w5-C95N" inline="false">
        <field name="END">LAST</field>
        <block type="get_value" id=":s3Jmucd~0p.rr!)#=$e">
        <value name="FIND">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="P5s;aJDPT*F;y(,VtRBs">
        <field name="TEXT">abc</field>
        <block type="text" id="T1NDF@SW`wap^ydQ(]-c">
        <field name="TEXT">.</field>
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="-9+`M14/p._`PvUM3`yk">
        <block type="math_number" id="c6Am(rXP]88U[N8J^4iD">
        <value name="ADD2">
        <block type="text" id="PvFX#`osf3d}$ICOYs*2">
        <field name="TEXT"> ist fertig</field>
        <block type="debug" id="E;l%;geOn!|rdiT.sc5a">
        <value name="TEXT">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Xs_M92/GAeD6l2|_Y~dT">
        <field name="TEXT">BSH_Common_Option_ProgramProgress_auf_100%</field>
        <block type="text_join" id="Pl2tbDK3unWM,c-2~(po">
        <value name="ADD0">
        <block type="text" id="1]-mr1)bwgU!2iJW7Gr-">
        <field name="TEXT">Hallo, Dein </field>
        <value name="ADD1">
        <block type="text_getSubstring" id="7_gd/nDVsY5t7X^aC(dH" inline="false">
        <block type="get_value" id="u#1/@sb^88T:atE:rk+*">
        <value name="AT1">
        <block type="math_arithmetic" id="L04we+5X]U^5?@Ua.Jr!" inline="false">
        <block type="text_indexOf" id="7Hg3~{#zFgX^4e]iEu[/" inline="false">
        <block type="get_value" id="]}8EkT?*B-y[0%o4SU5_">
        <value name="FIND">
        <block type="text" id="pe(!(TuP#HoKY39*~{G+">
        <block type="math_number" id="cXVm+lfkz-m:|X#O5tQ2">
        <value name="ADD2">
        <block type="text" id="0WPrr.Q,}Mn2P{0-WrTW">
                                                            <block type="comment" id="bdo3D}FyKm7rm:j@4jn:">
                                                              <field name="COMMENT">Alexa Ansage wenn Tropfschale voll ist</field>
        <block type="on" id="%Qry3R,F-w~eDWIZ;v~Q">
        <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.events.ConsumerProducts_CoffeeMaker_Event_DripTrayFull</field>
        <block type="controls_if" id="s+uRRm_,=H?8|j|GSLrD">
        <block type="logic_compare" id="({v/UANZbItzMGQVz;PO">
        <block type="on_source" id="pecp$)zA!mFQ,:p2NR($">
        <block type="text" id="9)#UKeJGU=0BXO9mzOft">
        <field name="TEXT">BSH.Common.EnumType.EventPresentState.Present</field>
        <block type="control" id="P7Bc6PLl0dxm=qX#4y}p">
        <block type="text_join" id="ifG.sB+gArs}OYhMiA#0">
        <value name="ADD0">
        <block type="text" id="VH#/ZF#A}-W=bglU-ysE">
        <field name="TEXT">25; Bitte Tropfschale leeren.</field>
        <block type="comment" id="TklKTCg(o7sKGG+Soo5`">
        <field name="COMMENT">Alexa Ansage wenn Wasserbehälter leer ist</field>
        <block type="on" id="r,rZzTgfJpvG|EMfMq?2">
        <block type="controls_if" id="/SRV4Krr?~k?C_Zc{B=[">
        <block type="logic_compare" id="[|/09!wyq_6V@Z9bkaq$">
        <block type="on_source" id="1O`h8`~4^ts5^V9/X*k$">
        <block type="text" id="[TL8I=S*Q!+x[^7aGbK1">
        <block type="control" id="riBuQRXa`*^-U|/k4!|5">
        <block type="text_join" id="6d8*@X#f_CG$HMK+?B)I">
        <value name="ADD0">
        <block type="text" id=":A+Ik@zxhqdS0Wj=j3e-">
        <block type="comment" id="h51@na;9~)#yuUC6-x7f">
        <field name="COMMENT">Ansage falls Bohnen leer sind</field>
        <block type="on" id="j?sr8Kd.S/N@pQN(A1vt">
        <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.events.ConsumerProducts_CoffeeMaker_Event_BeanContainerEmpty</field>
        <block type="controls_if" id="8{?uPOLRWYL.d~nt8AUV">
        <block type="logic_compare" id="@tLM~A-j]@aUA@-Wt`C3">
        <block type="on_source" id="K4CbR^8njT!H]#RdQdqS">
        <block type="text" id=".uE~(4Ui~h(LX?VY}yHN">
        <block type="control" id="fwEt$!^lR5grq_.5G@+s">
        <block type="text_join" id="3FtBb*%yG-r,K0Z7)nk4">
        <value name="ADD0">
        <block type="text" id="h/MN`7+=ZAG*Xw!8!*jp">
        <field name="TEXT">25; Bitte Kaffeebohnen nachfüllen.</field>
        <block type="comment" id="}I~v4EjMF9ly,k{2hP!]">
        <field name="COMMENT">Ansage falls Tür offen ist</field>
        <block type="on" id="%uv!4bEJ5Kn}MW$?2*bv">
        <field name="OID">homeconnect.0.BOSCH-CTL636ES6-68A40E26C6C6.status.BSH_Common_Status_DoorState</field>
        <block type="controls_if" id="|]ZEt[`Y-]UICeM7zC$q">
        <block type="logic_compare" id="M8t!uA?y%5h{^L*09C|l">
        <block type="on_source" id="{_nwFo2Cx:VO6bOW+)H`">
        <block type="text" id="nQ-ld:2fd5S$]IppT}Xj">
        <field name="TEXT">BSH.Common.EnumType.DoorState.Open</field>
        <block type="control" id="EEiwzKl/bO0`YQvisXFV">
        <block type="text_join" id="/`f@iijV(q7*0Q9|RUN-">
        <value name="ADD0">
        <block type="text" id="Q0S#`rS_rNRU6yFQ^28q">
        <field name="TEXT">25; Bitte Tür der Kaffeemaschine schließen.</field>
                                            @johnnybahama Kannst du nochmal genau erklären was du gemacht hast vielleicht kann man das im Adapter abfangen.
                                            Welcher Wert wurde wie gesetzt?
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            499652
