    4. Test Adapter weishaupt WEM Portal v0.0.x
      AlphaSierra last edited by
      zur Info, habe grad das Update von Node.js v10 auf v12 gemacht, der weishaupt-wem-Adapter scheint da noch nicht kompatibel zu sein, nur falls jemand ein Update plant.
      Gruß, Andy
        tombox @AlphaSierra last edited by
        @AlphaSierra was ist der genaue Fehler
          host.ioBroker 2020-06-15 14:31:00.855 error instance system.adapter.weishaupt-wem.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker 2020-06-15 14:31:00.855 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          host.ioBroker 2020-06-15 14:31:00.855 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          host.ioBroker 2020-06-15 14:31:00.855 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
          host.ioBroker 2020-06-15 14:31:00.855 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
          host.ioBroker 2020-06-15 14:31:00.855 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1188:18)
          host.ioBroker 2020-06-15 14:31:00.854 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: was compiled against a different Node.js version using
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: ^
          host.ioBroker 2020-06-15 14:31:00.853 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
          host.ioBroker 2020-06-15 14:31:00.852 error Caught by controller[0]: internal/modules/cjs/loader.js:1188
            @AlphaSierra bitte iobroker update anleitung beachten
            sudo apt install libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
            cd /opt/iobroker
            npm rebuild canvas --build-from-source
            npm install canvas
              Vielen Dank! Läuft wieder 🙂
              Eigentlich war ich nach "how-to-node-js-für-iobroker-richtig-updaten" vorgegangen, aber anscheinend nicht vollständig...
              • O
                Olivbus last edited by
                Bei mir kommt seit dem Update auf node v12 einmal täglich diese Fehlermeldung und der Adapter stoppt. Man kann ihn dann problemlos neustarten und er läuft bis zum nächsten Tag. Wie kann ich das lösen?
                host.iobrokernuc	2020-07-07 13:28:36.684	info	Rebuild for adapter system.adapter.weishaupt-wem.3 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                host.iobrokernuc	2020-07-07 13:28:36.679	info	instance system.adapter.weishaupt-wem.3 terminated with code 0 (NO_ERROR)
                weishaupt-wem.3	2020-07-07 13:28:35.691	info	(21603) Terminated (NO_ERROR): Without reason
                weishaupt-wem.3	2020-07-07 13:28:35.688	info	(21603) terminating
                weishaupt-wem.3	2020-07-07 13:28:35.666	info	(21603) cleaned everything up...
                weishaupt-wem.3	2020-07-07 13:28:35.664	error	(21603) unhandled promise rejection: undefined
                weishaupt-wem.3	2020-07-07 13:28:35.663	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                weishaupt-wem.3	2020-07-07 13:28:35.645	error	(21603) Not able to parse device name and status try to relogin
                weishaupt-wem.3	2020-07-07 13:28:35.643	error	(21603) TypeError: Cannot read property 'textContent' of null at Request._callback (/opt/iobroker/node_modules/iobroker.weishaupt-wem/main.js:314:73) at Request.self.callback (/opt/iobroker/no
                weishaupt-wem.3	2020-07-07 13:28:35.624	error	(21603) TypeError: Cannot read property 'textContent' of null
                • O
                  Olivbus @tombox last edited by
                  @tombox Seit einigen Tagen bekomme ich ständig diese Fehlermeldung:
                  Der Adapter läuft aber ansonsten problemlos. Wo könnte der Fehler liegen?
                    tombox @Olivbus last edited by
                    @olivbus installier mal via github, starte die instanz neu und beobachte das ganze
                      Pietro010 last edited by
                      Hallo!
                      Mal ne grundlegende Frage als Neuling - ich hab ne WWP12 Splitwärmepumpe von Weishaupt und würde das Teil gerne über iobroker ansteuern (konkret Heizungsanforderungen für die Pufferspeicher wenn genug PV Energie da u.ä.) - Habe jetzt ein Erweiterungsmodul für den WPM Ethernet, und LWPM410 Modbus und zu guter letzt KNX angeboten bekommen - wobei das KNX Modul mal preislich aus dem Rahmen fällt und nur der Notnagel ist. Welches der zwei anderen Module würdet ihr empfehlen? (Modbus hab ich sonst noch nirgends im Einsatz), bezieht sich der Thread hier auf das Ethernet Modul?
                      glg und sry für die Fragerei aber ich muss mal in das Thema reinfinden irgendwie 😉
                      Peter
                      • N
                        niktel @Pietro010 last edited by
                        Hallo
                        Hat den Adapter jemand mit einer Biblock WBB 12 am laufen? Daten auslesen hat auf anhieb funktioniert, aber das Steuern will nicht funktionieren. Gibt es hierfür eine Lösung.
                        Gruss Nico
                          tobi19 last edited by
                          ich habe den Adapter an einer neuen WTC 15 Brennwert-Gastherme am laufen.
                          Die Datenpunkte werden angezeigt, sehr schön zum Beobachten der Reaktion.
                          Zur Optimierung würde ich jetzt gerne steuernd eingreifen.
                          Leider hab ich noch nicht verstanden, wie das gehen soll. Habe erwartet. dass der Eintrag im DP wie auf dem Bild f276424f-fda9-49dd-b1cc-76c6557290dd-image.png
                          dazu führt, dass die Raum-Solltemperatur sich auf 17 ändert
                          Tut sie aber leider nicht.
                          Auch ein Versuch mit einem Custam Befehl eingetragen unter dem DP CustomBefehl hat nichts bewirkt.
                          Im Log sind keine Meldungen des Adapters.
                          Wer kann mir auf die Spünge helfen? Danke!
                            willor last edited by
                            wir besitzen eine Hybridanlage aus WTC-GW und WWP LS, zuvor war im WEM-Portal nur die WWP eingetragen, ich konnte alle Daten auslesen und verarbeiten, das hat super funktioniert.
                            Vergangene Woche wurde im WEM-Portal noch die Gastherme hinzugefügt, seitdem funktioniert der Adapter nicht mehr, es werden keine Werte mehr aktualisiert.
                            Ich habe versucht den Adapter neu zu installieren und habe auch alle Datenpunkte gelöscht, leider funktioniert es noch immer nicht. Unterstützt der Adapter überhaupt Hybridanlagen?
                            Gerne stelle ich logs etc. zur Verfügung, falls das helfen sollte.
                            Will
                              tombox @willor last edited by
                              @willor wurde nie mit zwei Geräten getestet. Müssen denn beide Geräte in einem Account sein?
                                willor @tombox last edited by
                                @tombox müssten sie vermutlich nicht, ist nur die frage ob ich beim löschen aus diesem Account der Portal Code erneut benutz werden kann.
                                Bezüglich Administration ist es natürlich schon einfacher 🙂
                                  @willor dann bräuchte ich zugang zu dem account um das zu realisieren
                                  W P 2 Replies Last reply Reply Quote 1
                                    @tombox können wir gerne so machen
                                    • O
                                      @tombox seit dem Update auf node.js 14 funktioniert der Adapter nicht mehr. Kann jemand helfen?
                                        evgeninikolov @tobi19 last edited by
                                        Hallo @tobi19, hast du dein Problem gelöst? Ich versuche, WW Push zu aktivieren, aber es funktioniert nicht.
                                          tobi19 @evgeninikolov last edited by
                                          @evgeninikolov
                                          Nein, ich habe leider noch keine Lösung.
                                          Können andere berichten, dass dies mit dem WTC und diesem Adapter funktioniert?
                                          • O
                                            Olivbus @tobi19 last edited by
                                            @tobi19 Bei mir geht diese Funktion.
                                            31.7k
                                            79.8k
                                            weishaupt wem wem portal
                                            29
                                            163
                                            24030
