    5. Astrofunktion mit Temperaturüberwachung
      paul53 @Blueskorpion last edited by
      @blueskorpion sagt: Über Vorschläge würde ich mich freuen.
        lessthanmore @Blueskorpion last edited by
        @blueskorpion Mist, war zu langsam.
        Hier mein Vorschlag:
        <variables>
        <variable type="timeout" id="timeout2">timeout2</variable>
        </variables>
        <block type="astro" id="k@MtEi#%?fpln!-?d7:W" x="113" y="312">
        <field name="TYPE">sunrise</field>
        <field name="OFFSET">0</field>
        <block type="comment" id="5ckb9V5^tVi#K+4+@Rlr">
        <field name="COMMENT">Zum Sonnenaufgang, falls Temp über 5, Brunnen an</field>
        <block type="controls_if" id="]}Wty_Er!_Wt$ta:xl.f">
        <block type="logic_compare" id="WrSAd5I?5ziPHcK,Ub">
        <field name="OP">GT</field>
        <block type="get_value" id="6KDpcZkO=[j#x]sv:1|E">
        <field name="OID">ID auswählen</field>
        <block type="math_number" id="M3GY;$#:#2;MQAzn!mYC">
        <field name="NUM">5</field>
        <block type="control" id="q(H@{ODJF3gX0?c%O@w*">
        <block type="logic_boolean" id="Vg8B$oj.].h_YpSUYDMw">
        <block type="astro" id="kKuC|xq}!UucCVdhD|iA">
        <block type="comment" id="7ek6~!O}0W,M%R+D)zLV">
        <field name="COMMENT">Zum Sonnenuntergang, falls Brunnen an, mach aus</field>
        <block type="controls_if" id="ILfvAOR4UG9nWhh{Yvhe">
        <block type="get_value" id="XHf-zr{#{aIn^|Q82{)2">
        <block type="control" id="kA.,@q]6WqUGUMsd!C%1">
        <block type="logic_boolean" id="jQ/[H!KW_rT]NAg02o/=">
        <block type="on" id="Iq9]dQmA{Blsgm|@;/cj">
        <block type="comment" id="v~ND{-#-/4[wA41$z~-a">
        <field name="COMMENT">Temperaturänderung zwischen Sonnenauf und untergang</field>
        <block type="controls_if" id="%+kh9Fl!LBm|zO-|o5u+">
        <block type="logic_operation" id="4tBrC;Ccj}hbTu2AWyyl" inline="false">
        <field name="OP">AND</field>
        <block type="time_compare_ex" id="E${B/x3GmWUmEWN=7]h1">
        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false" actual_time="true"></mutation>
        <field name="OPTION">>=</field>
        <value name="START_TIME">
        <shadow type="text" id="O4kps[{OcN}5kMptq=]">
        <field name="TEXT">12:00</field>
        <block type="time_astro" id="4pN(@N=I
        HA[^!(X]/}"> <field name="TYPE">sunrise</field> <field name="OFFSET">0</field> </block> </value> </block> </value> <value name="B"> <block type="time_compare_ex" id="=A4HCiilcr%R/tea:eZ">
        <field name="OPTION"><=</field>
        <shadow type="text">
        <block type="time_astro" id="h^aYZZ|jE[N7Jh@f}p1"> <field name="TYPE">sunset</field> <field name="OFFSET">0</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="comment" id=";8sXZ{z9{DHxS-tBAbhC"> <field name="COMMENT">Falls Temperatur über 5 und Brunnen aus warte 30 Minuten</field> <next> <block type="controls_if" id="RS~AT?3*MXi?GWb$%qN">
        <block type="logic_operation" id="VwaqqWb).OqXn7_7ML0" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="bLhc=ZF4z;gyCRyrD4"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id=",ub0de-?lL}5Q(#,kt*-"> <field name="ATTR">val</field> <field name="OID">ID auswählen</field> </block> </value> <value name="B"> <block type="math_number" id="_F*.+zegUrTf(,~(E+$!"> <field name="NUM">5</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="+C#wo$Ju[w+HK8$8t}W">
        <value name="BOOL">
        <block type="get_value" id="E7_VY8S]^ZxkN^6I}mQ8">
        <block type="timeouts_cleartimeout" id="QPMI-,zqPo7Mi{zR5wTY">
        <block type="timeouts_settimeout" id="Oj+7@jt5;@w8cMU*ypgL">
        <field name="DELAY">30</field>
        <block type="comment" id=")CH)T3)sWY^3s+lNn)ZK">
        <field name="COMMENT">Brunnen an nach 30 Minuten Temp über 5</field>
        <block type="control" id="NMyY3lybI;-}BY(hjPG"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">Object ID</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="UB*(^+A1-V++B7HAcTAM"> <field name="BOOL">TRUE</field> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> <value name="IF1"> <block type="get_value" id="C4MxYat+|)4+vl1[)-6q"> <field name="ATTR">val</field> <field name="OID">ID auswählen</field> </block> </value> <statement name="DO1"> <block type="comment" id="!tL@i.fjbVAv|0Bhf*uA"> <field name="COMMENT">Falls Brunnen an und Temp unter 5, mach aus</field> <next> <block type="timeouts_cleartimeout" id="-VwVl]s[?@JI|]@V0dY">
        <block type="timeouts_settimeout" id="B,Q3];yX2i^3`CdMu_sT">
        <field name="DELAY">1000</field>
        <field name="UNIT">ms</field>
        <block type="control" id="|#7wDV$7A0!x!{mg]P2M">
        <block type="logic_boolean" id="ofN]0gY|FFCB7mp3PjdJ">
        @paul53 hat die Schwankungen um 5° über 5,5° ausgeschlossen. Ich habe ein Timeout, so dass die Temperatur 30 Minuten über oder unter 5° sein muss, bevor geschaltet wird.
        Denke dass das mit den 5,5 sinnvoller ist.
        Aber da ich es nunmal schon gebaut hatte, wollte ich es nicht wieder löschen 😉
          Blueskorpion @paul53 last edited by
          @paul53 wird bei diesen Scrips die Temperatur mehrfach überprüft, so das wenn es beim Sonnenaufgang noch unter 5° ist, der runnen aus bleibt und wenn es dann Tagsüber wärmer wird, Trotzdem der Brunnen anspringt?
            @blueskorpion sagte: Temperatur mehrfach überprüft
            Die Temperatur triggert bei jeder Wertänderung.
            @blueskorpion sagte in Astrofunktion mit Temperaturüberwachung:
            Ja.
              Homoran Global Moderator Administrators @Blueskorpion last edited by
              ja! Es wird bei jeder Änderung der Temperatur geprüft und ggf. geschaltet
                Blueskorpion @lessthanmore last edited by
                @lessthanmore die gelben zeilen, muss ich die dort auch einfügen?
                L Homoran 2 Replies Last reply Reply Quote 0
                  @blueskorpion Nein, das sind Kommentare, damit du weißt, was wo sein sollte.
                  Im Spoiler kannst du den Code kopieren und einfach in Blockly importieren.
                    das sind (optionale) Kommentare, damit du nach Monaten auch noch weisst warum das jetzt so ist
                      @lessthanmore wie kann ich den Code Kopieren? Also brauche ich im Blockly nicht alles suchen?
                        Spoiler öffnen, inhalt mit STRG-C in die Zwischenablage
                        js-Editor mit neuem Blockly öffnen und Importieren (Icon oben rechts "irgendwo")
                          @paul53 said in Astrofunktion mit Temperaturüberwachung:
                          Nochmal ne frage, was hat es mit der Pumpe in dem Script Aufsich?
                            @blueskorpion sagte: was hat es mit der Pumpe in dem Script Aufsich?
                            Das ist der Datenpunkt, der den Brunnen aktiviert (hatte gerade keinen anderen zur Hand).
                              Blueskorpion @paul53 last edited by Blueskorpion
                              Sorry, aber was muss ich den da eintragen? Stehe bisschen auf dem Schlauch. Ich habe doch nur einmal die Temperatur und den Trigger fürs Ein und ausschalten
                                @blueskorpion Den Datenpunkt mit dem du den Brunnen einschaltest.
                                  @lessthanmore also entweder die Temperatur oder die Astro Funktion
                                    @blueskorpion sagte: Brunnen installiert, welcher über ein Shelly Plug S gesteuert wird.
                                      @paul53 richtig, also ist brunnen der plug s?
                                        @blueskorpion sagte: ist brunnen der plug s?
                                        Was sonst?
                                          @paul53 das verstehe ich ja, nur die Pumpe war für mich nicht verständlich.
                                          268
