Test Alpha Homekit-Controller 0.0.x
@pboeck machst mir bitte dazu mal ein debug log? Am besten vom Start bis quasi der Fehler kommt. Logfile am besten von Platte unter /opt/iobroker/logs/… holen. Admin Schneider Zeilen ab
@apollon77 hier ist ein Auszug:
2021-10-21 21:58:26.715 - info: homekit-controller.0 (23907) Got terminate signal TERMINATE_YOURSELF 2021-10-21 21:58:26.740 - info: homekit-controller.0 (23907) terminating 2021-10-21 21:58:26.742 - info: homekit-controller.0 (23907) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2021-10-21 21:58:31.434 - debug: homekit-controller.0 (3155) Redis Objects: Use Redis connection: 127.0.0.1:9001 2021-10-21 21:58:31.500 - debug: homekit-controller.0 (3155) Objects client ready ... initialize now 2021-10-21 21:58:31.504 - debug: homekit-controller.0 (3155) Objects create System PubSub Client 2021-10-21 21:58:31.506 - debug: homekit-controller.0 (3155) Objects create User PubSub Client 2021-10-21 21:58:31.508 - debug: homekit-controller.0 (3155) Objects client initialize lua scripts 2021-10-21 21:58:31.576 - debug: homekit-controller.0 (3155) Objects connected to redis: 127.0.0.1:9001 2021-10-21 21:58:31.620 - debug: homekit-controller.0 (3155) objectDB connected 2021-10-21 21:58:31.624 - debug: homekit-controller.0 (3155) Redis States: Use Redis connection: 127.0.0.1:9000 2021-10-21 21:58:31.649 - debug: homekit-controller.0 (3155) States create System PubSub Client 2021-10-21 21:58:31.651 - debug: homekit-controller.0 (3155) States create User PubSub Client 2021-10-21 21:58:32.220 - debug: homekit-controller.0 (3155) States connected to redis: 127.0.0.1:9000 2021-10-21 21:58:32.222 - debug: homekit-controller.0 (3155) statesDB connected 2021-10-21 21:58:32.625 - debug: homekit-controller.0 (3155) Plugin sentry Initialize Plugin (enabled=true) 2021-10-21 21:58:32.868 - info: homekit-controller.0 (3155) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18 2021-10-21 21:58:33.192 - debug: homekit-controller.0 (3155) Init 4 known devices without discovery ... 2021-10-21 21:58:33.196 - debug: homekit-controller.0 (3155) IP-90:09:EC:57:D8:5A Start Homekit Device Client initialization on 192.168.1.40:5010 2021-10-21 21:58:33.201 - debug: homekit-controller.0 (3155) Service: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-21 21:58:33.221 - debug: homekit-controller.0 (3155) Discovered IP device up: f9:47:a6:e8:4f:f1/hepe 429D 2021-10-21 21:58:33.222 - debug: homekit-controller.0 (3155) IP-F9:47:A6:E8:4F:F1 Discovered IP device: {"name":"hepe 429D","address":"192.168.1.4","port":37645,"c#":2,"ff":0,"id":"f9:47:a6:e8:4f:f1","md":"iobroker","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-21 21:58:33.223 - info: homekit-controller.0 (3155) IP-F9:47:A6:E8:4F:F1 (hepe 429D) found without known pairing data and already paired: ignoring 2021-10-21 21:58:33.231 - debug: homekit-controller.0 (3155) state homekit-controller.0.info.connection changed: false (ack = true) 2021-10-21 21:58:33.242 - debug: homekit-controller.0 (3155) Discovered BLE device up: 38:ab:51:14:7e:a9/Flex Ce 2021-10-21 21:58:33.243 - debug: homekit-controller.0 (3155) BLE-38:AB:51:14:7E:A9 Discovered BLE device: {"name":"Flex Ce","CoID":76,"TY":6,"AIL":109,"SF":0,"DeviceID":"38:ab:51:14:7e:a9","ACID":5,"GSN":506,"CN":1,"CV":2,"c#":1,"id":"38:ab:51:14:7e:a9","ci":5,"availableToPair":false} 2021-10-21 21:58:33.243 - info: homekit-controller.0 (3155) BLE-38:AB:51:14:7E:A9 (Flex Ce) found without known pairing data and already paired: ignoring 2021-10-21 21:58:33.285 - debug: homekit-controller.0 (3155) Discovered IP device up: 29:F4:1A:24:B3:5F/MSS210-be7e 2021-10-21 21:58:33.285 - debug: homekit-controller.0 (3155) IP-29:F4:1A:24:B3:5F Discovered IP device: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"29:F4:1A:24:B3:5F","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-21 21:58:33.287 - info: homekit-controller.0 (3155) IP-29:F4:1A:24:B3:5F (MSS210-be7e) found without known pairing data and already paired: ignoring 2021-10-21 21:58:33.293 - debug: homekit-controller.0 (3155) Discovered IP device up: 91:98:6D:AD:52:AF/Eve Extend 0630 2021-10-21 21:58:33.293 - debug: homekit-controller.0 (3155) IP-91:98:6D:AD:52:AF Discovered IP device: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":5,"ff":1,"id":"91:98:6D:AD:52:AF","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-21 21:58:33.294 - info: homekit-controller.0 (3155) IP-91:98:6D:AD:52:AF (Eve Extend 0630) found without known pairing data and already paired: ignoring 2021-10-21 21:58:33.306 - debug: homekit-controller.0 (3155) Discovered IP device up: 90:09:EC:57:D8:5A/MSS210-bc23 2021-10-21 21:58:33.307 - debug: homekit-controller.0 (3155) IP-90:09:EC:57:D8:5A Discovered IP device: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-21 21:58:33.308 - debug: homekit-controller.0 (3155) IP-90:09:EC:57:D8:5A Device initialization already in progress ... ignore call 2021-10-21 21:58:33.333 - debug: homekit-controller.0 (3155) Discovered IP device up: 48:60:FE:40:13:42/MSS620-6c70 2021-10-21 21:58:33.334 - debug: homekit-controller.0 (3155) IP-48:60:FE:40:13:42 Discovered IP device: {"name":"MSS620-6c70","address":"192.168.1.54","port":5010,"c#":4,"ff":2,"id":"48:60:FE:40:13:42","md":"MSS620","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-21 21:58:33.334 - info: homekit-controller.0 (3155) IP-48:60:FE:40:13:42 (MSS620-6c70) found without known pairing data and already paired: ignoring 2021-10-21 21:58:33.368 - debug: homekit-controller.0 (3155) Discovered IP device up: C4:7F:76:46:F9:D5/MSS210-b791 2021-10-21 21:58:33.369 - debug: homekit-controller.0 (3155) IP-C4:7F:76:46:F9:D5 Discovered IP device: {"name":"MSS210-b791","address":"192.168.1.31","port":5011,"c#":3,"ff":2,"id":"C4:7F:76:46:F9:D5","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-21 21:58:33.369 - info: homekit-controller.0 (3155) IP-C4:7F:76:46:F9:D5 (MSS210-b791) found without known pairing data and already paired: ignoring 2021-10-21 21:58:34.342 - debug: homekit-controller.0 (3155) Accessory Structure: {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"]},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Meross","perms":["pr"],"ev":false},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"MSS210","perms":["pr"],"ev":false},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"MSS210-bc23","perms":["pr"],"ev":false},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"518519200803129","perms":["pr"],"ev":false},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"4.1.9","perms":["pr"],"ev":false},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"4.0.0","perms":["pr"],"ev":false},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"2.0.1;16A75","perms":["pr"],"ev":false}]},{"iid":10,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":11,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false}]},{"iid":12,"type":"00000047-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"linked":[],"characteristics":[{"iid":13,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"outlet","perms":["pr"],"ev":false},{"iid":14,"type":"00000025-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false},{"iid":15,"type":"00000026-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","ev"],"ev":false}]}]}]} 2021-10-21 21:58:34.388 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connectionType changed: IP (ack = true) 2021-10-21 21:58:34.407 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.id changed: 90:09:EC:57:D8:5A (ack = true) 2021-10-21 21:58:34.424 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.address changed: 192.168.1.40 (ack = true) 2021-10-21 21:58:34.442 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connected changed: false (ack = true) 2021-10-21 21:58:34.469 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.isPaired changed: true (ack = true) 2021-10-21 21:58:34.487 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.unpair changed: false (ack = true) 2021-10-21 21:58:34.506 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.manufacturer changed: Meross (ack = true) 2021-10-21 21:58:34.525 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.model changed: MSS210 (ack = true) 2021-10-21 21:58:34.544 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.name changed: MSS210-bc23 (ack = true) 2021-10-21 21:58:34.563 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.serial-number changed: 518519200803129 (ack = true) 2021-10-21 21:58:34.600 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.firmware-revision changed: 4.1.9 (ack = true) 2021-10-21 21:58:34.619 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.hardware-revision changed: 4.0.0 (ack = true) 2021-10-21 21:58:34.638 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information.34AB8811-AC7F-4340-BAC3-FD6A85F9943B changed: 2.0.1;16A75 (ack = true) 2021-10-21 21:58:34.656 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.name changed: outlet (ack = true) 2021-10-21 21:58:34.670 - info: homekit-controller.0 (3155) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.on" has to be type "boolean" but received type "number" 2021-10-21 21:58:34.676 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.on changed: 1 (ack = true) 2021-10-21 21:58:34.734 - info: homekit-controller.0 (3155) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.outlet-in-use" has to be type "boolean" but received type "number" 2021-10-21 21:58:34.743 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.outlet-in-use changed: 1 (ack = true) 2021-10-21 21:58:34.746 - debug: homekit-controller.0 (3155) Device IP-90:09:EC:57:D8:5A collected polling IDs: ["1.13","1.14","1.15"] 2021-10-21 21:58:34.747 - debug: homekit-controller.0 (3155) Device IP-90:09:EC:57:D8:5A collected subscription IDs: ["1.14","1.15"] 2021-10-21 21:58:34.761 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connected changed: true (ack = true) 2021-10-21 21:58:34.766 - debug: homekit-controller.0 (3155) state homekit-controller.0.info.connection changed: true (ack = true) 2021-10-21 21:58:35.742 - debug: homekit-controller.0 (3155) IP-29:F4:1A:24:B3:5F Start Homekit Device Client initialization on 192.168.1.44:5010 2021-10-21 21:58:35.743 - debug: homekit-controller.0 (3155) Service: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"29:F4:1A:24:B3:5F","md":"MSS210","pv":"1.1","s#":1,"sf":1,"ci":7,"availableToPair":true} 2021-10-21 21:58:42.360 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.accessory-runtime-information.heart-beat changed: 1 (ack = true) 2021-10-21 21:58:42.437 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.on changed: true (ack = true) 2021-10-21 21:58:42.453 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.name changed: Eve Energy (ack = true) 2021-10-21 21:58:42.469 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.outlet-in-use changed: true (ack = true) 2021-10-21 21:58:42.485 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.volt changed: 237.4 (ack = true) 2021-10-21 21:58:42.501 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.ampere changed: 0 (ack = true) 2021-10-21 21:58:42.517 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.power changed: 0 (ack = true) 2021-10-21 21:58:42.533 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.total-consumption changed: 86.55 (ack = true) 2021-10-21 21:58:42.549 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.outlet.lock-physical-controls changed: false (ack = true) 2021-10-21 21:58:42.568 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F155-079E-48FF-8F27-9C2605A29F52 changed: 5E:D9:65:42:94:D3 (ack = true) 2021-10-21 21:58:42.585 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F156-079E-48FF-8F27-9C2605A29F52 changed: 7 (ack = true) 2021-10-21 21:58:42.602 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.3.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F157-079E-48FF-8F27-9C2605A29F52 changed: 1 (ack = true) 2021-10-21 21:58:42.619 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.manufacturer changed: Eve Systems (ack = true) 2021-10-21 21:58:42.635 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.model changed: Eve Energy 20EBO8301 (ack = true) 2021-10-21 21:58:42.652 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.name changed: Eve Energy 94EC (ack = true) 2021-10-21 21:58:42.668 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.serial-number changed: RV40J1A06310 (ack = true) 2021-10-21 21:58:42.685 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.firmware-revision changed: 2.1.0 (ack = true) 2021-10-21 21:58:42.711 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.hardware-revision changed: 1.1 (ack = true) 2021-10-21 21:58:42.725 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.1188AB34-4043-7FAC-6AFD-C3BA3B94F985 changed: "5.0";e0258992 (ack = true) 2021-10-21 21:58:42.742 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-information.product-data changed: IHdXc5VleGE= (ack = true) 2021-10-21 21:58:42.767 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.thread-transport.thread-node-capabilities changed: 8 (ack = true) 2021-10-21 21:58:42.807 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.thread-transport.thread-status changed: 1 (ack = true) 2021-10-21 21:58:42.825 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.thread-transport.thread-control-point changed: (ack = true) 2021-10-21 21:58:42.842 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.thread-transport.thread-open-thread-version changed: OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020 (ack = true) 2021-10-21 21:58:42.860 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.thread-transport.current-transport changed: false (ack = true) 2021-10-21 21:58:42.882 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.name changed: Eve Logging (ack = true) 2021-10-21 21:58:42.949 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwIBCAQMUlY0MEoxQTA2MzEwBgLgCwcEALYAAAUBANgEOVZEM5wBAB0BCNIAYAFk0AST3XMBmwS33XMBnwTOAQAARQUFMAAAAEYJBQAAAA4AAEIGRBEFHAAFAzwAAABBgj5ChawjQUcRBd8cuB1LHiQftAAAADwAAABIBgUAAAAAAEoGBQAAAAAA (ack = true) 2021-10-21 21:58:42.969 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F158-079E-48FF-8F27-9C2605A29F52 changed: gAEAAAhK5Td4cr+OKQEC//4CAd8IAA== (ack = true) 2021-10-21 21:58:43.010 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F116-079E-48FF-8F27-9C2605A29F52 changed: uN1zAYXtSgFwCPkmBQsCDAINAgcCDgHgCwAMALYAAADCXgEBAA== (ack = true) 2021-10-21 21:58:43.024 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F117-079E-48FF-8F27-9C2605A29F52 changed: EgC2AAAAwl4BDwgAKwkDAAkA (ack = true) 2021-10-21 21:58:43.049 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F112-079E-48FF-8F27-9C2605A29F52 changed: 0 (ack = true) 2021-10-21 21:58:43.067 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F007-079E-48FF-8F27-9C2605A29F52.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAAQgLAB5HvkSSfTR4 (ack = true) 2021-10-21 21:58:43.078 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-runtime-information.sleep-interval changed: 0 (ack = true) 2021-10-21 21:58:43.091 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-runtime-information.ping changed: (ack = true) 2021-10-21 21:58:43.102 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.accessory-runtime-information.heart-beat changed: 1 (ack = true) 2021-10-21 21:58:43.125 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.on changed: true (ack = true) 2021-10-21 21:58:43.146 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.name changed: Eve Energy (ack = true) 2021-10-21 21:58:43.160 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.outlet-in-use changed: true (ack = true) 2021-10-21 21:58:43.178 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 235.4 (ack = true) 2021-10-21 21:58:43.193 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.E863F126-079E-48FF-8F27-9C2605A29F52 changed: 0 (ack = true) 2021-10-21 21:58:43.216 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.E863F10D-079E-48FF-8F27-9C2605A29F52 changed: 0 (ack = true) 2021-10-21 21:58:43.281 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.E863F10C-079E-48FF-8F27-9C2605A29F52 changed: 40.08 (ack = true) 2021-10-21 21:58:43.297 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.outlet.lock-physical-controls changed: 0 (ack = true) 2021-10-21 21:58:43.317 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F155-079E-48FF-8F27-9C2605A29F52 changed: 7D:1D:48:92:00:3D (ack = true) 2021-10-21 21:58:43.335 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F156-079E-48FF-8F27-9C2605A29F52 changed: 7 (ack = true) 2021-10-21 21:58:43.386 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.4.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F157-079E-48FF-8F27-9C2605A29F52 changed: 1 (ack = true) 2021-10-21 21:58:43.402 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.manufacturer changed: Eve Systems (ack = true) 2021-10-21 21:58:43.417 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.model changed: Eve Energy 20EBO8301 (ack = true) 2021-10-21 21:58:43.433 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.name changed: Eve Energy C8B1 (ack = true) 2021-10-21 21:58:43.449 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.serial-number changed: RV40J1A06143 (ack = true) 2021-10-21 21:58:43.464 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.firmware-revision changed: 2.1.0 (ack = true) 2021-10-21 21:58:43.484 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.hardware-revision changed: 1.1 (ack = true) 2021-10-21 21:58:43.511 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.1188AB34-4043-7FAC-6AFD-C3BA3B94F985 changed: "5.0";e0258992 (ack = true) 2021-10-21 21:58:43.531 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-information.product-data changed: IHdXc5VleGE= (ack = true) 2021-10-21 21:58:43.544 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.thread-transport.thread-node-capabilities changed: 8 (ack = true) 2021-10-21 21:58:43.555 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.thread-transport.thread-status changed: 1 (ack = true) 2021-10-21 21:58:43.576 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.thread-transport.thread-control-point changed: (ack = true) 2021-10-21 21:58:43.587 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.thread-transport.thread-open-thread-version changed: OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020 (ack = true) 2021-10-21 21:58:43.598 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.thread-transport.current-transport changed: false (ack = true) 2021-10-21 21:58:43.609 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.name changed: Eve Logging (ack = true) 2021-10-21 21:58:43.632 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwIBCAQMUlY0MEoxQTA2MTQzBgL9CwcEALQAAAUBANgEVFVBWpwBAB0BCNIAYAFk0AQtvXMBmwRRvXMBnwTTAQAARQUFMAAAAEYJBQAAAA4AAEIGRBEFHAAFAzwAAABBgj5ChawjQUcRBd8cuB1LHiQftAAAADwAAABIBgUAAAAAAEoGBQAAAAAA (ack = true) 2021-10-21 21:58:43.676 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F158-079E-48FF-8F27-9C2605A29F52 changed: gAEAAAhCD5wYteaDVAEC//4CAd8IAA== (ack = true) 2021-10-21 21:58:43.689 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F116-079E-48FF-8F27-9C2605A29F52 changed: Ub1zAXCeOwHS2ekmBQsCDAINAgcCDgH9CwAMALQAALBdXgEBAA== (ack = true) 2021-10-21 21:58:43.707 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F117-079E-48FF-8F27-9C2605A29F52 changed: EgC0AACwXV4BD80ALQkTAM0A (ack = true) 2021-10-21 21:58:43.731 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F112-079E-48FF-8F27-9C2605A29F52 changed: 0 (ack = true) 2021-10-21 21:58:43.756 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F007-079E-48FF-8F27-9C2605A29F52.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAAQgLADXukOyYqdH3 (ack = true) 2021-10-21 21:58:43.767 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-runtime-information.sleep-interval changed: 0 (ack = true) 2021-10-21 21:58:43.779 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-runtime-information.ping changed: (ack = true) 2021-10-21 21:58:43.791 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.accessory-runtime-information.heart-beat changed: 1 (ack = true) 2021-10-21 21:58:44.266 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.on changed: true (ack = true) 2021-10-21 21:58:44.284 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.name changed: Eve Energy (ack = true) 2021-10-21 21:58:44.299 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.outlet-in-use changed: true (ack = true) 2021-10-21 21:58:44.316 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 237.8 (ack = true) 2021-10-21 21:58:44.331 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.E863F126-079E-48FF-8F27-9C2605A29F52 changed: 0.23 (ack = true) 2021-10-21 21:58:44.345 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.E863F10D-079E-48FF-8F27-9C2605A29F52 changed: 24.9 (ack = true) 2021-10-21 21:58:44.407 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.E863F10C-079E-48FF-8F27-9C2605A29F52 changed: 87.59 (ack = true) 2021-10-21 21:58:44.422 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.outlet.lock-physical-controls changed: 0 (ack = true) 2021-10-21 21:58:44.440 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F155-079E-48FF-8F27-9C2605A29F52 changed: 09:A6:E7:1D:F3:12 (ack = true) 2021-10-21 21:58:44.458 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F156-079E-48FF-8F27-9C2605A29F52 changed: 7 (ack = true) 2021-10-21 21:58:44.481 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.5.E863F00B-079E-48FF-8F27-9C2605A29F52.E863F157-079E-48FF-8F27-9C2605A29F52 changed: 1 (ack = true) 2021-10-21 21:58:44.484 - debug: homekit-controller.0 (3155) Device IP-91:98:6D:AD:52:AF collected polling IDs: ["1.108","1.101","1.103","1.105","1.107","2.18","2.19","2.20","2.23","2.24","2.25","2.28","2.29","2.30","2.100001","2.100002","2.100003","3.20","3.21","3.22","3.23","3.25","3.28","3.29","3.31","3.32","3.33","3.36","3.37","3.40","3.41","3.42","3.44","3.45","3.46","3.47","3.48","3.49","3.50","3.51","3.100001","3.100002","3.100003","4.20","4.21","4.22","4.23","4.25","4.28","4.29","4.31","4.32","4.33","4.36","4.37","4.40","4.41","4.42","4.44","4.45","4.46","4.47","4.48","4.49","4.50","4.51","4.100001","4.100002","4.100003","5.20","5.21","5.22","5.23","5.25","5.28","5.29","5.31","5.32","5.33","5.36","5.37","5.40","5.41","5.42","5.44","5.45","5.46","5.47","5.48","5.49","5.50","5.51","5.100001","5.100002","5.100003"] 2021-10-21 21:58:44.484 - debug: homekit-controller.0 (3155) Device IP-91:98:6D:AD:52:AF collected subscription IDs: ["1.107","2.19","2.20","2.100003","3.21","3.42","3.44","3.46","3.49","3.51","3.100003","4.21","4.42","4.44","4.46","4.49","4.51","4.100003","5.21","5.42","5.44","5.46","5.49","5.51","5.100003"] 2021-10-21 21:58:44.547 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-91:98:6D:AD:52:AF.info.connected changed: true (ack = true) 2021-10-21 21:59:05.742 - debug: homekit-controller.0 (3155) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ... 2021-10-21 21:59:06.821 - info: homekit-controller.0 (3155) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.on" has to be type "boolean" but received type "number" 2021-10-21 21:59:06.822 - info: homekit-controller.0 (3155) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.outlet-in-use" has to be type "boolean" but received type "number" 2021-10-21 21:59:06.830 - debug: homekit-controller.0 (3155) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.outlet.name changed: outlet (ack = true)Ich habe in der Zwischenzeit noch EVE Geräte über einen EVE Extended integriert. Hat auch super funktioniert.
@apollon77 Danke auch von mir für Klasse Arbeit!
Yeelight Technology MJXDD01SYL MiSmartLEDCeilingLight450-FC57
funktioniert alles bestens.
homekit-controller.0.IP-27:xxxxxx.1.lightbulb.brightness
homekit-controller.0.IP-27:xxxxxx.1.lightbulb.color-temperature
homekit-controller.0.IP-27:xxxxxx.1.lightbulb.name
homekit-controller.0.IP-27:xxxxxx.1.lightbulb.onGruß Vadim
@pboeck sagte in Test Alpha Homekit-Controller 0.0.x:
Danke, bitte mal GitHub version aktualisieren. Fehler jetzt weg und nur true/false drin?
EDIT Sa 9:43: Bitte ggf noch mal neu von Github vor neuem Log ...
So, habe es jetzt auch mit nem Meross Socket getestet und sollte gefixt sein.
Bitte von GitHub updaten und danach Adapterinstanz manuell neu starten ... Dann weg?
@apollon77 Ja, jetzt passt es.
Ich habe den ganzen Objektbaum gelöscht.
Gibt es einen Trick die vormals gepairten Geräte ohne zurücksetzen wieder zu integrieren? -
@pboeck ne leider nicht. Warum hadtvdubdie Objekte gelöscht? Hab ich nirgendwo verlangt.
Mir war das die letzten Tage auch aufgefallen das beim löschen der Objekte das ja alles weg ist. Man könnte es in nem zweiten File speichern …mal überlegen.
@apollon77 Ich wollte nur nochmals von vorne beginnen.
Update auf GitHub:
WICHTIG: Channelnamen und damit am Ende fast alle State Namen ändern sich in der Version! Die waren nicht unique genug. Also bitte updaten und ggf channelnamen die danach noch da sind ohne nummer drin löschen. Aber am besten NICHT das Hauptobjekt der geräte löschen - oder nach Update einmal neu starten das er die Pairingdaten speichert, dann sollten die wiederverwendet werden.
- (Apollon77) Store pairing data additionally in an instance directory and retry them on start if objects where deleted or such
- (Apollon77) Add info.lastDiscovered state with a timestamp to allow manual cleanup of devices that are paired somewhere else then with the adapter instance (because such objects would currently not be deleted)
- (Apollon77) Adjust some roles
@apollon77 Jetzt kommt wieder diese Meldung:
2021-10-24 08:10:02.726 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-67:1E:EB:7A:BB:97.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:02.892 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:03.196 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:03.398 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:05.811 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:07.557 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet.lock-physical-controls" has to be type "number" but received type "boolean" 2021-10-24 08:10:08.329 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.leak-detected" has to be type "number" but received type "boolean" 2021-10-24 08:10:08.387 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.status-fault" has to be type "number" but received type "boolean" 2021-10-24 08:10:11.155 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:12.741 - info: homekit-controller.0 (681) IP-9E:DB:2B:41:DE:81 Could not initialize device: connect ECONNREFUSED 192.168.1.31:5010 Error: connect ECONNREFUSED 192.168.1.31:5010 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16) 2021-10-24 08:10:13.977 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-67:1E:EB:7A:BB:97.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-24 08:10:44.496 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.leak-detected" has to be type "number" but received type "boolean" 2021-10-24 08:10:44.497 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.status-fault" has to be type "number" but received type "boolean" -
@pboeck Ok, da ist was seeehr komisch ... checke heute abend
Ok, @pboeck komisch ... Bitte update nochmal von GitHub ... Ist dann jetzt die 0.3.0 ... bei mir tut da alles ... Auch sehen in deinem Log die State-IDs noch so aus als ob es nicht eine 0.2.0 war die da lief ...
@apollon77 Ich habe nochmals die 0.3.0 installiert.
Der Adapter stellt irgendwann seinen Arbeit ein.Log nach dem Start:
2021-10-25 11:45:40.944 - debug: homekit-controller.0 (4788) Redis Objects: Use Redis connection: 127.0.0.1:9001 2021-10-25 11:45:41.030 - debug: homekit-controller.0 (4788) Objects client ready ... initialize now 2021-10-25 11:45:41.070 - debug: homekit-controller.0 (4788) Objects create System PubSub Client 2021-10-25 11:45:41.091 - debug: homekit-controller.0 (4788) Objects create User PubSub Client 2021-10-25 11:45:41.093 - debug: homekit-controller.0 (4788) Objects client initialize lua scripts 2021-10-25 11:45:41.115 - debug: homekit-controller.0 (4788) Objects connected to redis: 127.0.0.1:9001 2021-10-25 11:45:41.139 - debug: homekit-controller.0 (4788) objectDB connected 2021-10-25 11:45:41.152 - debug: homekit-controller.0 (4788) Redis States: Use Redis connection: 127.0.0.1:9000 2021-10-25 11:45:41.173 - debug: homekit-controller.0 (4788) States create System PubSub Client 2021-10-25 11:45:41.175 - debug: homekit-controller.0 (4788) States create User PubSub Client 2021-10-25 11:45:41.195 - debug: homekit-controller.0 (4788) States connected to redis: 127.0.0.1:9000 2021-10-25 11:45:41.197 - debug: homekit-controller.0 (4788) statesDB connected 2021-10-25 11:45:41.949 - debug: homekit-controller.0 (4788) Plugin sentry Initialize Plugin (enabled=true) 2021-10-25 11:45:42.288 - info: homekit-controller.0 (4788) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18 2021-10-25 11:45:42.819 - debug: homekit-controller.0 (4788) Discovered IP device up: FA:E2:76:C6:A9:AE/Eve Extend 0630 2021-10-25 11:45:42.822 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Discovered IP device: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-25 11:45:42.825 - info: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Found stored Pairing data, try it ... 2021-10-25 11:45:42.828 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Start Homekit Device Client initialization on 192.168.1.65:8080 2021-10-25 11:45:42.833 - debug: homekit-controller.0 (4788) Service: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-25 11:45:42.845 - debug: homekit-controller.0 (4788) Discovered IP device up: f9:47:a6:e8:4f:f1/hepe 429D 2021-10-25 11:45:42.846 - debug: homekit-controller.0 (4788) IP-F9:47:A6:E8:4F:F1 Discovered IP device: {"name":"hepe 429D","address":"192.168.1.4","port":42941,"c#":2,"ff":0,"id":"f9:47:a6:e8:4f:f1","md":"iobroker","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-25 11:45:42.847 - info: homekit-controller.0 (4788) IP-F9:47:A6:E8:4F:F1 (hepe 429D) found without known pairing data and already paired: ignoring 2021-10-25 11:45:42.883 - debug: homekit-controller.0 (4788) Discovered IP device up: 9E:DB:2B:41:DE:81/MSS210-b791 2021-10-25 11:45:42.884 - debug: homekit-controller.0 (4788) IP-9E:DB:2B:41:DE:81 Discovered IP device: {"name":"MSS210-b791","address":"192.168.1.31","port":5010,"c#":2,"ff":2,"id":"9E:DB:2B:41:DE:81","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.884 - info: homekit-controller.0 (4788) IP-9E:DB:2B:41:DE:81 (MSS210-b791) found without known pairing data and already paired: ignoring 2021-10-25 11:45:42.892 - debug: homekit-controller.0 (4788) Discovered IP device up: 03:09:A7:12:3E:A6/MSS210-be7e 2021-10-25 11:45:42.893 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Discovered IP device: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"03:09:A7:12:3E:A6","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.894 - info: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Found stored Pairing data, try it ... 2021-10-25 11:45:42.895 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Start Homekit Device Client initialization on 192.168.1.44:5010 2021-10-25 11:45:42.896 - debug: homekit-controller.0 (4788) Service: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"03:09:A7:12:3E:A6","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.904 - debug: homekit-controller.0 (4788) Discovered IP device up: 90:09:EC:57:D8:5A/MSS210-bc23 2021-10-25 11:45:42.905 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Discovered IP device: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.906 - info: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Found stored Pairing data, try it ... 2021-10-25 11:45:42.907 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Start Homekit Device Client initialization on 192.168.1.40:5010 2021-10-25 11:45:42.908 - debug: homekit-controller.0 (4788) Service: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.915 - debug: homekit-controller.0 (4788) Discovered IP device up: 48:60:FE:40:13:42/MSS620-6c70 2021-10-25 11:45:42.915 - debug: homekit-controller.0 (4788) IP-48:60:FE:40:13:42 Discovered IP device: {"name":"MSS620-6c70","address":"192.168.1.54","port":5010,"c#":4,"ff":2,"id":"48:60:FE:40:13:42","md":"MSS620","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false} 2021-10-25 11:45:42.916 - info: homekit-controller.0 (4788) IP-48:60:FE:40:13:42 (MSS620-6c70) found without known pairing data and already paired: ignoring 2021-10-25 11:45:42.931 - debug: homekit-controller.0 (4788) Discovered BLE device up: 38:ab:51:14:7e:a9/Flex Ce 2021-10-25 11:45:42.931 - debug: homekit-controller.0 (4788) BLE-38:AB:51:14:7E:A9 Discovered BLE device: {"name":"Flex Ce","CoID":76,"TY":6,"AIL":109,"SF":0,"DeviceID":"38:ab:51:14:7e:a9","ACID":5,"GSN":515,"CN":1,"CV":2,"c#":1,"id":"38:ab:51:14:7e:a9","ci":5,"availableToPair":false} 2021-10-25 11:45:42.932 - info: homekit-controller.0 (4788) BLE-38:AB:51:14:7E:A9 (Flex Ce) found without known pairing data and already paired: ignoring 2021-10-25 11:45:42.940 - debug: homekit-controller.0 (4788) Init 4 known devices without discovery ... 2021-10-25 11:45:42.941 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Start Homekit Device Client initialization on 192.168.1.65:8080 2021-10-25 11:45:42.942 - debug: homekit-controller.0 (4788) Service: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false} 2021-10-25 11:45:42.977 - debug: homekit-controller.0 (4788) state homekit-controller.0.info.connection changed: false (ack = true) 2021-10-25 11:45:43.694 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Accessory Structure: {"accessories":[{"aid":1,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Extend 0630"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Extend 20EAB9901"},{"format":"string","iid":5,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"DU51I1A00740"},{"format":"string","iid":6,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.1.1"},{"format":"bool","iid":7,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":108,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"tlv8","iid":101,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"format":"tlv8","iid":102,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":103,"perms":["pr"],"type":"E863F150-079E-48FF-8F27-9C2605A29F52","value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEDBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgECBwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZsGAQAHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbAGAQIHAQD/AA=="},{"format":"tlv8","iid":104,"perms":["pw"],"type":"E863F151-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":105,"perms":["pr"],"type":"E863F152-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"data","iid":106,"perms":["pw"],"type":"E863F153-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":107,"perms":["pr","ev"],"type":"E863F154-079E-48FF-8F27-9C2605A29F52","value":"AQ=="}],"hidden":true,"iid":100,"type":"E863F007-079E-48FF-8F27-9C2605A29F52"},{"characteristics":[{"format":"string","iid":201,"perms":["pr"],"type":"00000037-0000-1000-8000-0026BB765291","value":"1.1.0"}],"iid":200,"type":"000000A2-0000-1000-8000-0026BB765291"}]},{"aid":2,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94EC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06310"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"1188AB34-4043-7FAC-6AFD-C3BA3B94F985","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIKAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsELpN4AZ8E9QEAACACLAFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"LpN4AYA3dgFtWCQnBgsCDAINAgcCDgEBAgoBAAwhzwAAMTZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FCXQAAChhXgBLwAAKAkAAAAAJwE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656693245},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAI/VPp/5vo3J"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":234.60000610351562},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":0.9399999976158142},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"28:E9:52:B9:05:48"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":3,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94AC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A05837"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIJAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsEeoJ4AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"e4J4AQAAAAAAAAAABgsCDAINAgcCDgEBAgkBAAwuwwAAsyV2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDLEAAD5dngBLwAANAkAAAAAHQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694369},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAPKB5xEUGLZO"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":236},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.6699999570846558},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"AB:36:FD:90:DB:7C"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":4,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard 5B8A"},{"format":"bool","iid":3,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":4,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":5,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Water Guard 20EBG8701"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"KV45I1A04286"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.2.10"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.0.0"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":18,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard"},{"format":"uint8","iid":19,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000070-0000-1000-8000-0026BB765291","value":0},{"format":"uint8","iid":20,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000077-0000-1000-8000-0026BB765291","value":0}],"iid":17,"type":"00000083-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":23,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"data","iid":24,"perms":["pr","pw"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDkUA1QQKAP0Pevf51bfB"},{"format":"uint32","iid":25,"maxValue":4294967295,"minStep":1,"minValue":0,"perms":["pr","pw"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"data","iid":26,"perms":["pw"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":27,"perms":["pw"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":28,"perms":["pr"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"a1oCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"format":"data","iid":29,"perms":["pr"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"tlv8","iid":30,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBGtaAgDSAA=="},{"format":"tlv8","iid":31,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"}],"iid":22,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"23:7D:8E:0E:0F:08"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":10},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":5,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy C8B1"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06143"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIKAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsEPnF4AZ8E9QEAACACFQFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"PnF4AQAAAAAAAAAABgsCDAINAgcCDgEBAgoBAAw4zQAAYRZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDzOAADdY3gBLzkBHgkdADcBFQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694491},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAE1x8iUbk1uP"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":232.89999389648438},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0.28999999165534973},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":30.600000381469727},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.0499999523162842},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"13:13:B2:5C:17:5E"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]}]} 2021-10-25 11:45:44.668 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Accessory Structure: {"accessories":[{"aid":1,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Extend 0630"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Extend 20EAB9901"},{"format":"string","iid":5,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"DU51I1A00740"},{"format":"string","iid":6,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.1.1"},{"format":"bool","iid":7,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":108,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"tlv8","iid":101,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"format":"tlv8","iid":102,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":103,"perms":["pr"],"type":"E863F150-079E-48FF-8F27-9C2605A29F52","value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEEBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEDBwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZsGAQEHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbAGAQMHAQD/AA=="},{"format":"tlv8","iid":104,"perms":["pw"],"type":"E863F151-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":105,"perms":["pr"],"type":"E863F152-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"data","iid":106,"perms":["pw"],"type":"E863F153-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":107,"perms":["pr","ev"],"type":"E863F154-079E-48FF-8F27-9C2605A29F52","value":"AQ=="}],"hidden":true,"iid":100,"type":"E863F007-079E-48FF-8F27-9C2605A29F52"},{"characteristics":[{"format":"string","iid":201,"perms":["pr"],"type":"00000037-0000-1000-8000-0026BB765291","value":"1.1.0"}],"iid":200,"type":"000000A2-0000-1000-8000-0026BB765291"}]},{"aid":2,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94EC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06310"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"1188AB34-4043-7FAC-6AFD-C3BA3B94F985","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIKAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsELpN4AZ8E9QEAACACLAFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"LpN4AYA3dgFtWCQnBgsCDAINAgcCDgEBAgoBAAwhzwAAMTZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FCXQAAChhXgBLwAAKAkAAAAAJwE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656693245},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAI/VPp/5vo3J"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":234.60000610351562},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":0.9399999976158142},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"28:E9:52:B9:05:48"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":3,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94AC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A05837"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIJAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsEeoJ4AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"e4J4AQAAAAAAAAAABgsCDAINAgcCDgEBAgkBAAwuwwAAsyV2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDLEAAD5dngBLwAANAkAAAAAHQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694369},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAPKB5xEUGLZO"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":236},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.6699999570846558},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"AB:36:FD:90:DB:7C"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":4,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard 5B8A"},{"format":"bool","iid":3,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":4,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":5,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Water Guard 20EBG8701"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"KV45I1A04286"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.2.10"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.0.0"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":18,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard"},{"format":"uint8","iid":19,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000070-0000-1000-8000-0026BB765291","value":0},{"format":"uint8","iid":20,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000077-0000-1000-8000-0026BB765291","value":0}],"iid":17,"type":"00000083-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":23,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"data","iid":24,"perms":["pr","pw"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDkUA1QQKAP0Pevf51bfB"},{"format":"uint32","iid":25,"maxValue":4294967295,"minStep":1,"minValue":0,"perms":["pr","pw"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"data","iid":26,"perms":["pw"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":27,"perms":["pw"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":28,"perms":["pr"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"a1oCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"format":"data","iid":29,"perms":["pr"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"tlv8","iid":30,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBGtaAgDSAA=="},{"format":"tlv8","iid":31,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"}],"iid":22,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"23:7D:8E:0E:0F:08"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":10},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":5,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy C8B1"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06143"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIKAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsEPnF4AZ8E9QEAACACFQFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"PnF4AQAAAAAAAAAABgsCDAINAgcCDgEBAgoBAAw4zQAAYRZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDzOAADdY3gBLzkBHgkdADcBFQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694491},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAE1x8iUbk1uP"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":232.89999389648438},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0.28999999165534973},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":30.600000381469727},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.0499999523162842},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"13:13:B2:5C:17:5E"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]}]} 2021-10-25 11:45:44.772 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Accessory Structure: {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"]},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Meross","perms":["pr"],"ev":false},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"MSS210","perms":["pr"],"ev":false},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"MSS210-bc23","perms":["pr"],"ev":false},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"518519200803129","perms":["pr"],"ev":false},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"4.1.9","perms":["pr"],"ev":false},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"4.0.0","perms":["pr"],"ev":false},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"2.0.1;16A75","perms":["pr"],"ev":false}]},{"iid":10,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":11,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false}]},{"iid":12,"type":"00000047-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"linked":[],"characteristics":[{"iid":13,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"outlet","perms":["pr"],"ev":false},{"iid":14,"type":"00000025-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false},{"iid":15,"type":"00000026-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","ev"],"ev":false}]}]}]} 2021-10-25 11:45:44.795 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connectionType changed: IP (ack = true) 2021-10-25 11:45:44.849 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Accessory Structure: {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"]},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Meross","perms":["pr"],"ev":false},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"MSS210","perms":["pr"],"ev":false},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"MSS210-be7e","perms":["pr"],"ev":false},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"518519200803732","perms":["pr"],"ev":false},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"4.1.9","perms":["pr"],"ev":false},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"4.0.0","perms":["pr"],"ev":false},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"2.0.1;16A75","perms":["pr"],"ev":false}]},{"iid":10,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":11,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false}]},{"iid":12,"type":"00000047-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"linked":[],"characteristics":[{"iid":13,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"outlet","perms":["pr"],"ev":false},{"iid":14,"type":"00000025-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false},{"iid":15,"type":"00000026-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","ev"],"ev":false}]}]}]} 2021-10-25 11:45:44.880 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.id changed: FA:E2:76:C6:A9:AE (ack = true) 2021-10-25 11:45:44.927 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connectionType changed: IP (ack = true) 2021-10-25 11:45:44.993 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.address changed: 192.168.1.65 (ack = true) 2021-10-25 11:45:45.011 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connectionType changed: IP (ack = true) 2021-10-25 11:45:45.035 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.id changed: FA:E2:76:C6:A9:AE (ack = true) 2021-10-25 11:45:45.084 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connected changed: false (ack = true) 2021-10-25 11:45:45.088 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.id changed: 90:09:EC:57:D8:5A (ack = true) 2021-10-25 11:45:45.110 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.connectionType changed: IP (ack = true) 2021-10-25 11:45:45.200 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.address changed: 192.168.1.65 (ack = true) 2021-10-25 11:45:45.247 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.address changed: 192.168.1.40 (ack = true) 2021-10-25 11:45:45.259 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.id changed: 03:09:A7:12:3E:A6 (ack = true) 2021-10-25 11:45:45.362 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.isPaired changed: true (ack = true) 2021-10-25 11:45:45.399 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connected changed: false (ack = true) 2021-10-25 11:45:45.413 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connected changed: false (ack = true) 2021-10-25 11:45:45.494 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-25 11:45:45.500 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.address changed: 192.168.1.44 (ack = true) 2021-10-25 11:45:45.530 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered changed: 1635155142836 (ack = true) 2021-10-25 11:45:45.604 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.isPaired changed: true (ack = true) 2021-10-25 11:45:45.615 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.connected changed: false (ack = true) 2021-10-25 11:45:45.646 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.unpair changed: false (ack = true) 2021-10-25 11:45:45.650 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.isPaired changed: true (ack = true) 2021-10-25 11:45:45.677 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-25 11:45:45.694 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered changed: 1635155142943 (ack = true) 2021-10-25 11:45:45.710 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-25 11:45:45.735 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.name changed: Eve Extend 0630 (ack = true) 2021-10-25 11:45:45.742 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered changed: 1635155142909 (ack = true) 2021-10-25 11:45:45.763 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.admin.isPaired changed: true (ack = true) 2021-10-25 11:45:45.843 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.unpair changed: false (ack = true) 2021-10-25 11:45:45.849 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.manufacturer changed: Eve Systems (ack = true) 2021-10-25 11:45:45.878 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number" 2021-10-25 11:45:45.898 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.unpair changed: false (ack = true) 2021-10-25 11:45:45.903 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered changed: 1635155142897 (ack = true) 2021-10-25 11:45:45.930 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.name changed: Eve Extend 0630 (ack = true) 2021-10-25 11:45:45.932 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.model changed: Eve Extend 20EAB9901 (ack = true) 2021-10-25 11:45:45.990 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.manufacturer changed: Meross (ack = true) 2021-10-25 11:45:45.995 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.admin.unpair changed: false (ack = true) 2021-10-25 11:45:46.016 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.manufacturer changed: Eve Systems (ack = true) 2021-10-25 11:45:46.021 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.serial-number changed: DU51I1A00740 (ack = true) 2021-10-25 11:45:46.096 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.model changed: MSS210 (ack = true) 2021-10-25 11:45:46.102 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.manufacturer changed: Meross (ack = true) 2021-10-25 11:45:46.135 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.model changed: Eve Extend 20EAB9901 (ack = true) 2021-10-25 11:45:46.139 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.firmware-revision changed: 1.1.1 (ack = true) 2021-10-25 11:45:46.198 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.name changed: MSS210-bc23 (ack = true) 2021-10-25 11:45:46.209 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.model changed: MSS210 (ack = true) 2021-10-25 11:45:46.289 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.serial-number changed: DU51I1A00740 (ack = true) 2021-10-25 11:45:46.341 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.serial-number changed: 518519200803129 (ack = true) 2021-10-25 11:45:46.348 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.name changed: Logging (ack = true) 2021-10-25 11:45:46.385 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.name changed: MSS210-be7e (ack = true) 2021-10-25 11:45:46.388 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.firmware-revision changed: 1.1.1 (ack = true) 2021-10-25 11:45:46.392 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.firmware-revision changed: 4.1.9 (ack = true)Teil 2 folgt
@apollon77 Teil 2
Log vor dem Stop:2021-10-25 12:38:37.598 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ... 2021-10-25 12:38:38.608 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:38:39.455 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ... 2021-10-25 12:38:40.174 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ... 2021-10-25 12:38:52.120 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Subscription Event connection disconnected, try to resubscribe 2021-10-25 12:38:52.125 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Subscription Event connection disconnected, try to resubscribe 2021-10-25 12:38:52.127 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Subscription Event connection disconnected, try to resubscribe 2021-10-25 12:38:52.964 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ... 2021-10-25 12:38:55.248 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Subscription Event connection disconnected, try to resubscribe 2021-10-25 12:38:56.659 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ... 2021-10-25 12:38:57.701 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:38:58.614 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:38:59.372 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:04.198 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:05.089 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ... 2021-10-25 12:39:05.607 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ... 2021-10-25 12:39:08.609 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ... 2021-10-25 12:39:09.626 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:16.717 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Set Values to ioBroker: [{"aid":1,"iid":2,"value":"Eve Extend 0630"},{"aid":1,"iid":3,"value":"Eve Systems"},{"aid":1,"iid":4,"value":"Eve Extend 20EAB9901"},{"aid":1,"iid":5,"value":"DU51I1A00740"},{"aid":1,"iid":6,"value":"1.1.1"},{"aid":1,"iid":108,"value":"Logging"},{"aid":1,"iid":101,"value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"aid":1,"iid":103,"value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQMHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbQGAQUHAQD/AA=="},{"aid":1,"iid":105,"value":"AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQIFAbQGAQUIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQMIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA="},{"aid":1,"iid":107,"value":"AQ=="},{"aid":5,"iid":3,"value":"Eve Systems"},{"aid":5,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":5,"iid":5,"value":"Eve Energy C8B1"},{"aid":5,"iid":6,"value":"RV40J1A06143"},{"aid":5,"iid":7,"value":"2.1.1"},{"aid":5,"iid":8,"value":"1.1"},{"aid":5,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":5,"iid":10,"value":"IHdXc5VleGE="},{"aid":5,"iid":20,"value":8},{"aid":5,"iid":21,"value":1},{"aid":5,"iid":22,"value":""},{"aid":5,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":5,"iid":25,"value":false},{"aid":5,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":5,"iid":31,"value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":5,"iid":32,"value":"8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA"},{"aid":5,"iid":33,"value":""},{"aid":5,"iid":36,"value":656694491},{"aid":5,"iid":37,"value":"HwABDlAAJgsLAJUFs8Nb/Yqk"},{"aid":5,"iid":40,"value":0},{"aid":5,"iid":41,"value":""},{"aid":5,"iid":42,"value":10},{"aid":5,"iid":44,"value":true},{"aid":5,"iid":45,"value":"Eve Energy"},{"aid":5,"iid":46,"value":true},{"aid":5,"iid":47,"value":235.8000030517578},{"aid":5,"iid":48,"value":0.2800000011920929},{"aid":5,"iid":49,"value":30.200000762939453},{"aid":5,"iid":50,"value":1.0699999332427979},{"aid":5,"iid":51,"value":0},{"aid":5,"iid":100001,"value":"13:13:B2:5C:17:5E"},{"aid":5,"iid":100002,"value":7},{"aid":5,"iid":100003,"value":1},{"aid":3,"iid":3,"value":"Eve Systems"},{"aid":3,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":3,"iid":5,"value":"Eve Energy 94AC"},{"aid":3,"iid":6,"value":"RV40J1A05837"},{"aid":3,"iid":7,"value":"2.1.1"},{"aid":3,"iid":8,"value":"1.1"},{"aid":3,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":3,"iid":10,"value":"IHdXc5VleGE="},{"aid":3,"iid":20,"value":8},{"aid":3,"iid":21,"value":1},{"aid":3,"iid":22,"value":""},{"aid":3,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":3,"iid":25,"value":false},{"aid":3,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":3,"iid":31,"value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":3,"iid":32,"value":"L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA"},{"aid":3,"iid":33,"value":""},{"aid":3,"iid":36,"value":656694369},{"aid":3,"iid":37,"value":"HwABDlAAJgsLAJZFJW6DVuDk"},{"aid":3,"iid":40,"value":0},{"aid":3,"iid":41,"value":""},{"aid":3,"iid":42,"value":10},{"aid":3,"iid":44,"value":true},{"aid":3,"iid":45,"value":"Eve Energy"},{"aid":3,"iid":46,"value":true},{"aid":3,"iid":47,"value":238.1999969482422},{"aid":3,"iid":48,"value":0},{"aid":3,"iid":49,"value":0},{"aid":3,"iid":50,"value":1.6699999570846558},{"aid":3,"iid":51,"value":0},{"aid":3,"iid":100001,"value":"AB:36:FD:90:DB:7C"},{"aid":3,"iid":100002,"value":7},{"aid":3,"iid":100003,"value":1},{"aid":2,"iid":3,"value":"Eve Systems"},{"aid":2,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":2,"iid":5,"value":"Eve Energy 94EC"},{"aid":2,"iid":6,"value":"RV40J1A06310"},{"aid":2,"iid":7,"value":"2.1.1"},{"aid":2,"iid":8,"value":"1.1"},{"aid":2,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":2,"iid":10,"value":"IHdXc5VleGE="},{"aid":2,"iid":20,"value":8},{"aid":2,"iid":21,"value":1},{"aid":2,"iid":22,"value":""},{"aid":2,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":2,"iid":25,"value":false},{"aid":2,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":2,"iid":31,"value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":2,"iid":32,"value":"4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA"},{"aid":2,"iid":33,"value":""},{"aid":2,"iid":36,"value":656693245},{"aid":2,"iid":37,"value":"HwABDlAAJgsLAFIe8o1p9x0Y"},{"aid":2,"iid":40,"value":0},{"aid":2,"iid":41,"value":""},{"aid":2,"iid":42,"value":10},{"aid":2,"iid":44,"value":true},{"aid":2,"iid":45,"value":"Eve Energy"},{"aid":2,"iid":46,"value":true},{"aid":2,"iid":47,"value":236.5},{"aid":2,"iid":48,"value":0},{"aid":2,"iid":49,"value":0},{"aid":2,"iid":50,"value":0.9399999976158142},{"aid":2,"iid":51,"value":0},{"aid":2,"iid":100001,"value":"28:E9:52:B9:05:48"},{"aid":2,"iid":100002,"value":7},{"aid":2,"iid":100003,"value":1},{"aid":4,"iid":2,"value":"Eve Water Guard 5B8A"},{"aid":4,"iid":4,"value":"Eve Systems"},{"aid":4,"iid":5,"value":"Eve Water Guard 20EBG8701"},{"aid":4,"iid":6,"value":"KV45I1A04286"},{"aid":4,"iid":7,"value":"1.2.10"},{"aid":4,"iid":8,"value":"1.0.0"},{"aid":4,"iid":18,"value":"Eve Water Guard"},{"aid":4,"iid":19,"value":0},{"aid":4,"iid":20,"value":0},{"aid":4,"iid":23,"value":"Logging"},{"aid":4,"iid":24,"value":"HwABDkUA1QQKABvaYBlWSews"},{"aid":4,"iid":25,"value":0},{"aid":4,"iid":28,"value":"I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"aid":4,"iid":29,"value":""},{"aid":4,"iid":30,"value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA=="},{"aid":4,"iid":100001,"value":"23:7D:8E:0E:0F:08"},{"aid":4,"iid":100002,"value":10},{"aid":4,"iid":100003,"value":1}] 2021-10-25 12:39:16.749 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F131-079E-48FF-8F27-9C2605A29F52 changed: CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA== (ack = true) 2021-10-25 12:39:16.788 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F150-079E-48FF-8F27-9C2605A29F52 changed: gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQMHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbQGAQUHAQD/AA== (ack = true) 2021-10-25 12:39:16.807 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F152-079E-48FF-8F27-9C2605A29F52 changed: AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQIFAbQGAQUIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQMIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA= (ack = true) 2021-10-25 12:39:16.810 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true) 2021-10-25 12:39:16.815 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: 8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA (ack = true) 2021-10-25 12:39:16.838 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAJUFs8Nb/Yqk (ack = true) 2021-10-25 12:39:16.839 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 235.8 (ack = true) 2021-10-25 12:39:16.839 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F126-079E-48FF-8F27-9C2605A29F52 changed: 0.28 (ack = true) 2021-10-25 12:39:16.840 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F10D-079E-48FF-8F27-9C2605A29F52 changed: 30.2 (ack = true) 2021-10-25 12:39:16.841 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true) 2021-10-25 12:39:16.846 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA (ack = true) 2021-10-25 12:39:16.847 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAJZFJW6DVuDk (ack = true) 2021-10-25 12:39:16.861 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 238.2 (ack = true) 2021-10-25 12:39:16.868 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true) 2021-10-25 12:39:16.872 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: 4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA (ack = true) 2021-10-25 12:39:16.879 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAFIe8o1p9x0Y (ack = true) 2021-10-25 12:39:16.883 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet-43.volt changed: 236.5 (ack = true) 2021-10-25 12:39:16.890 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDkUA1QQKABvaYBlWSews (ack = true) 2021-10-25 12:39:16.895 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F116-079E-48FF-8F27-9C2605A29F52 changed: I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA= (ack = true) 2021-10-25 12:39:16.901 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F131-079E-48FF-8F27-9C2605A29F52 changed: AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA== (ack = true) 2021-10-25 12:39:16.997 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Set Values to ioBroker: [{"aid":1,"iid":2,"value":"Eve Extend 0630"},{"aid":1,"iid":3,"value":"Eve Systems"},{"aid":1,"iid":4,"value":"Eve Extend 20EAB9901"},{"aid":1,"iid":5,"value":"DU51I1A00740"},{"aid":1,"iid":6,"value":"1.1.1"},{"aid":1,"iid":108,"value":"Logging"},{"aid":1,"iid":101,"value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"aid":1,"iid":103,"value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQQHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQMFAbEGAQAHAQD/AA=="},{"aid":1,"iid":105,"value":"AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQMFAbEGAQAIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQQIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA="},{"aid":1,"iid":107,"value":"AQ=="},{"aid":5,"iid":3,"value":"Eve Systems"},{"aid":5,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":5,"iid":5,"value":"Eve Energy C8B1"},{"aid":5,"iid":6,"value":"RV40J1A06143"},{"aid":5,"iid":7,"value":"2.1.1"},{"aid":5,"iid":8,"value":"1.1"},{"aid":5,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":5,"iid":10,"value":"IHdXc5VleGE="},{"aid":5,"iid":20,"value":8},{"aid":5,"iid":21,"value":1},{"aid":5,"iid":22,"value":""},{"aid":5,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":5,"iid":25,"value":false},{"aid":5,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":5,"iid":31,"value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":5,"iid":32,"value":"8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA"},{"aid":5,"iid":33,"value":""},{"aid":5,"iid":36,"value":656694491},{"aid":5,"iid":37,"value":"HwABDlAAJgsLAJUFs8Nb/Yqk"},{"aid":5,"iid":40,"value":0},{"aid":5,"iid":41,"value":""},{"aid":5,"iid":42,"value":10},{"aid":5,"iid":44,"value":true},{"aid":5,"iid":45,"value":"Eve Energy"},{"aid":5,"iid":46,"value":true},{"aid":5,"iid":47,"value":235.8000030517578},{"aid":5,"iid":48,"value":0.2800000011920929},{"aid":5,"iid":49,"value":30.200000762939453},{"aid":5,"iid":50,"value":1.0699999332427979},{"aid":5,"iid":51,"value":0},{"aid":5,"iid":100001,"value":"13:13:B2:5C:17:5E"},{"aid":5,"iid":100002,"value":7},{"aid":5,"iid":100003,"value":1},{"aid":3,"iid":3,"value":"Eve Systems"},{"aid":3,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":3,"iid":5,"value":"Eve Energy 94AC"},{"aid":3,"iid":6,"value":"RV40J1A05837"},{"aid":3,"iid":7,"value":"2.1.1"},{"aid":3,"iid":8,"value":"1.1"},{"aid":3,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":3,"iid":10,"value":"IHdXc5VleGE="},{"aid":3,"iid":20,"value":8},{"aid":3,"iid":21,"value":1},{"aid":3,"iid":22,"value":""},{"aid":3,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":3,"iid":25,"value":false},{"aid":3,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":3,"iid":31,"value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":3,"iid":32,"value":"L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA"},{"aid":3,"iid":33,"value":""},{"aid":3,"iid":36,"value":656694369},{"aid":3,"iid":37,"value":"HwABDlAAJgsLAJZFJW6DVuDk"},{"aid":3,"iid":40,"value":0},{"aid":3,"iid":41,"value":""},{"aid":3,"iid":42,"value":10},{"aid":3,"iid":44,"value":true},{"aid":3,"iid":45,"value":"Eve Energy"},{"aid":3,"iid":46,"value":true},{"aid":3,"iid":47,"value":238.1999969482422},{"aid":3,"iid":48,"value":0},{"aid":3,"iid":49,"value":0},{"aid":3,"iid":50,"value":1.6699999570846558},{"aid":3,"iid":51,"value":0},{"aid":3,"iid":100001,"value":"AB:36:FD:90:DB:7C"},{"aid":3,"iid":100002,"value":7},{"aid":3,"iid":100003,"value":1},{"aid":2,"iid":3,"value":"Eve Systems"},{"aid":2,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":2,"iid":5,"value":"Eve Energy 94EC"},{"aid":2,"iid":6,"value":"RV40J1A06310"},{"aid":2,"iid":7,"value":"2.1.1"},{"aid":2,"iid":8,"value":"1.1"},{"aid":2,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":2,"iid":10,"value":"IHdXc5VleGE="},{"aid":2,"iid":20,"value":8},{"aid":2,"iid":21,"value":1},{"aid":2,"iid":22,"value":""},{"aid":2,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":2,"iid":25,"value":false},{"aid":2,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":2,"iid":31,"value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":2,"iid":32,"value":"4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA"},{"aid":2,"iid":33,"value":""},{"aid":2,"iid":36,"value":656693245},{"aid":2,"iid":37,"value":"HwABDlAAJgsLAFIe8o1p9x0Y"},{"aid":2,"iid":40,"value":0},{"aid":2,"iid":41,"value":""},{"aid":2,"iid":42,"value":10},{"aid":2,"iid":44,"value":true},{"aid":2,"iid":45,"value":"Eve Energy"},{"aid":2,"iid":46,"value":true},{"aid":2,"iid":47,"value":236.5},{"aid":2,"iid":48,"value":0},{"aid":2,"iid":49,"value":0},{"aid":2,"iid":50,"value":0.9399999976158142},{"aid":2,"iid":51,"value":0},{"aid":2,"iid":100001,"value":"28:E9:52:B9:05:48"},{"aid":2,"iid":100002,"value":7},{"aid":2,"iid":100003,"value":1},{"aid":4,"iid":2,"value":"Eve Water Guard 5B8A"},{"aid":4,"iid":4,"value":"Eve Systems"},{"aid":4,"iid":5,"value":"Eve Water Guard 20EBG8701"},{"aid":4,"iid":6,"value":"KV45I1A04286"},{"aid":4,"iid":7,"value":"1.2.10"},{"aid":4,"iid":8,"value":"1.0.0"},{"aid":4,"iid":18,"value":"Eve Water Guard"},{"aid":4,"iid":19,"value":0},{"aid":4,"iid":20,"value":0},{"aid":4,"iid":23,"value":"Logging"},{"aid":4,"iid":24,"value":"HwABDkUA1QQKABvaYBlWSews"},{"aid":4,"iid":25,"value":0},{"aid":4,"iid":28,"value":"I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"aid":4,"iid":29,"value":""},{"aid":4,"iid":30,"value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA=="},{"aid":4,"iid":100001,"value":"23:7D:8E:0E:0F:08"},{"aid":4,"iid":100002,"value":10},{"aid":4,"iid":100003,"value":1}] 2021-10-25 12:39:17.038 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F131-079E-48FF-8F27-9C2605A29F52 changed: CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA== (ack = true) 2021-10-25 12:39:17.040 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F150-079E-48FF-8F27-9C2605A29F52 changed: gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQQHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQMFAbEGAQAHAQD/AA== (ack = true) 2021-10-25 12:39:17.041 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F152-079E-48FF-8F27-9C2605A29F52 changed: AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQMFAbEGAQAIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQQIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA= (ack = true) 2021-10-25 12:39:17.041 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 236.5 (ack = true) 2021-10-25 12:39:27.702 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ... 2021-10-25 12:39:28.616 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ... 2021-10-25 12:39:29.373 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ... 2021-10-25 12:39:29.491 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:30.737 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:31.989 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:34.198 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ... 2021-10-25 12:39:35.988 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:39.627 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ... 2021-10-25 12:39:40.643 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}] 2021-10-25 12:39:46.721 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ... 2021-10-25 12:39:46.999 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ... 2021-10-25 12:39:59.493 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ... -
@pboeck Also wenn der Adaoter so dargestellt ist muss e sim Log mehr geben wie einen crash oder sowas ... sehe ich nichts davon in deinem log ... auch das Bild passt nicht ... da steht Loglebel "info" aber du zeigst Debug log ... also ... häää?????
@apollon77 Das Bild ist von einem vorherigem Stop.
Im Debugmodus habe ich vergessen ein Bild zu machen. -
@pboeck aber wenn der stoppt muss mehr im Log sein ...
@apollon77
Ich habe nun den iobrocker neu gestartet, jetzt stopp der Adapter seit ca. 3 Stunden nicht mehr.{ "type": "state", "common": { "name": "Last Discovered", "type": "boolean", "role": "value.time", "read": true, "write": false }, "native": {}, "from": "system.adapter.homekit-controller.0", "user": "system.user.admin", "ts": 1635176765755, "_id": "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }Müsste hier, "type": "boolean", nicht ein anderer Typ stehen?
2021-10-25 17:51:06.709 - info: homekit-controller.0 (20792) State value to set for "homekit-controller.0.IP-B8:1B:83:7E:C7:6E.info.lastDiscovered" has to be type "boolean" but received type "number" -
@pboeck Wo Du recht hast haste recht ... Den hab ich übersehen
0.3.1 auf GitHub
@apollon77 Noch was:
