    4. [SourceAnalytix 0.4.8-Final] Released !
      Aiouh @crunchip last edited by Aiouh
      @crunchip was ist denn die Ursache und kann ich das irgendwie selbst beheben?
      Das müllt mir das Log zu
      Danke im Voraus
      sourceanalytix.1
      2021-10-21 19:25:27.645	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1517.7040000000009 as valueAtDeviceReset (previous valueAtDeviceReset : 1516.950000000001)
      sourceanalytix.1
      2021-10-21 19:25:18.592	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1516.950000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1516.191000000001)
      sourceanalytix.1
      2021-10-21 19:24:54.828	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1516.191000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1515.432000000001)
      sourceanalytix.1
      2021-10-21 19:24:06.283	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1515.432000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1514.689000000001)
      sourceanalytix.1
      2021-10-21 19:23:54.772	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1514.689000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1513.920000000001)
      sourceanalytix.1
      2021-10-21 19:23:27.620	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1513.920000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1513.172000000001)
      sourceanalytix.1
      2021-10-21 19:23:16.733	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1513.172000000001 as valueAtDeviceReset (previous valueAtDeviceReset : 1512.3880000000008)
      sourceanalytix.1
      2021-10-21 19:22:54.916	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1512.3880000000008 as valueAtDeviceReset (previous valueAtDeviceReset : 1511.6290000000008)
      sourceanalytix.1
      2021-10-21 19:21:55.977	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1511.6290000000008 as valueAtDeviceReset (previous valueAtDeviceReset : 1511.0040000000008)
      sourceanalytix.1
      2021-10-21 19:21:47.973	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1511.0040000000008 as valueAtDeviceReset (previous valueAtDeviceReset : 1508.9970000000008)
      sourceanalytix.1
      2021-10-21 19:21:37.934	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1508.9970000000008 as valueAtDeviceReset (previous valueAtDeviceReset : 1506.5300000000007)
      sourceanalytix.1
      2021-10-21 19:21:06.629	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1506.5300000000007 as valueAtDeviceReset (previous valueAtDeviceReset : 1505.9240000000007)
      sourceanalytix.1
      2021-10-21 19:20:47.031	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1505.9240000000007 as valueAtDeviceReset (previous valueAtDeviceReset : 1505.3030000000006)
      sourceanalytix.1
      2021-10-21 19:20:38.049	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1505.3030000000006 as valueAtDeviceReset (previous valueAtDeviceReset : 1504.6760000000006)
      sourceanalytix.1
      2021-10-21 19:19:47.242	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1504.6760000000006 as valueAtDeviceReset (previous valueAtDeviceReset : 1504.0750000000005)
      sourceanalytix.1
      2021-10-21 19:19:15.987	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1504.0750000000005 as valueAtDeviceReset (previous valueAtDeviceReset : 1503.4790000000005)
      sourceanalytix.1
      2021-10-21 19:18:16.069	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1503.4790000000005 as valueAtDeviceReset (previous valueAtDeviceReset : 1502.9810000000004)
      sourceanalytix.1
      2021-10-21 19:18:05.919	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1502.9810000000004 as valueAtDeviceReset (previous valueAtDeviceReset : 1502.4260000000004)
      sourceanalytix.1
      2021-10-21 19:17:06.099	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1502.4260000000004 as valueAtDeviceReset (previous valueAtDeviceReset : 1501.9640000000004)
      sourceanalytix.1
      2021-10-21 19:16:37.487	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1501.9640000000004 as valueAtDeviceReset (previous valueAtDeviceReset : 1501.4860000000003)
      sourceanalytix.1
      2021-10-21 19:16:27.393	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1501.4860000000003 as valueAtDeviceReset (previous valueAtDeviceReset : 1500.9980000000003)
      sourceanalytix.1
      2021-10-21 19:16:16.335	warn	Device reset detected for mqtt.1.solaranzeige.box1.batterie_entladung store current cumulatedReading 1500.9980000000003 as valueAtDeviceReset (previous valueAtDeviceReset : 1500.5050000000003)
        crunchip Forum Testing Most Active @Aiouh last edited by crunchip
        @aiouh zwecks dem "device detected" gibt es hier schon unzählige Beiträge und auch Lösungen.
        Die Ursache scheint zu sein, daß dein Wert falsch rein kommt(plötzlich kleiner als vorher), daher das Device reset..., woher beziehst du denn diesen Wert.
        Ansonsten ein bug und muss noch behoben werden, siehe ein paar Beiträge weiter oben
          @crunchip ich habe einige freds gelesen bin aber nicht wirklich schlau daraus geworden, daher hatte ich hier nochmal gefragt, sorry. Der Wert kommt per MQTT aus meinem Wechselrichter. Seltsam ist nur, dass ich das vor dem Update auf Admin5 und zugleich die neueste V 0.4.12 nicht hatte.
          Ich blende das wohl mal geistig aus und warte auf die Behebung.
            @aiouh wenn du den Wert vergleichst, zwischen cumulatedReading und dem Wert deines Wechselrichters, sind die identisch?
            • JB_Sullivan
              JB_Sullivan last edited by JB_Sullivan
              Hallo @Dutchman - so, der Winter naht und es entwickeln sich wieder Gedankenspiele, was man an der Visualisierung noch alles so herum schrauben kann.
              Dein Adapter ist dabei für mich ein Super Auswerte Tool geworden, welches in diesem Jahr auch Klasse funktioniert hätte, wenn nicht einer der getrackten 3.- Adapter Datenpunkte, im laufe des zurück liegenden Jahres seinen Datenpunkt Namen geändert hätte. Somit war eine kontinuierliche Fortschreibung der Daten leider nicht möglich - aber dafür kann dein Adapter nichts.
              Nun ist mir die Idee gekommen, alle Daten meiner PV Anlage aus dem letzten und aus diesem Jahr tabellarisch gegenüber zu stellen - eine Mega Fleißarbeit.
              Dabei ist mir aufgefallen, das ich dieses Tabellen Template zu jedem Jahreswechsel neu anfassen muss, weil zum Jahreswechsel SA immer wieder neue Jahres Ordner anlegt.
              D.h. ein detaillierter Vergleich wie ich ihn plane zwischen Jahr und Vorjahr ist nur mit viel Handarbeit möglich.
              Du hast zwar unter CurrentYear schon die Datenpunkte "Previous" eingeführt, diese beziehen sich aber nur auf die SUMMEN der zurück liegenden Werte (Tag, Woche, Monate, Quartal, Jahr).
              Wäre es nicht möglich, das die VOLLE Objektbaumstruktur sowohl für das aktuelle Jahr ( CurrentYear), als auch für das zurückliegende Jahr (PreviousYear) einführt werden und erst ab dem 3. Jahr angefangen wird die Jahreswerte dem Kalender Jahr entsprechend weg zu speichern?
              Ich vermute, das die Leute die etwas auswerten wollen (so wie ich), dieses hauptsächlich zwischen dem aktuellen und dem Vorjahr machen werden.
              Visualisierungen mit Datenwerten rückwirkend für z.B. 10 Jahre wird sich wohl kaum jemand bauen.
              Was ich damit sagen will - Wenn es eine VOLLSTÄNDIGE Objektbaum Strukturen des aktuellen und des Vorjahres geben würde, wäre solche Tabellen wie die folgende, komplett ohne weiteren Handeingriff aktualisierbar.
              Was denkst du (auch die anderen User hier), wäre das eine Erweiterung des SA Adapters, den du vielleicht mal in Angriff nehmen würdest?
              Rein programmiertechnisch stelle ICH mir das nicht so aufwendig vor. In meinem Gedanken "Cosmos" wird zum Jahreswechsel der Objekt Ordner nicht die Zahl des zurückliegenden Jahres bekommen, sondern den Namen "PreviousYear". Erst im Folgejahr - also im Jahr 2023, würde aus dem Namen "PreviousYear", die Baumstruktur mit dem Namen 2021 werden.
              2021 (CurrentYear)
              2020 (PreviousYear) -> wird zum Jahreswechsel 2021/22 dann umbenannt in 2020
              2021 wird zum Jahreswechsel 2021/22 zu PreviousYear und 2022 wird zu CurrentYear
              ..... usw. usw. usw.
              EDIT: Bei einer grafischen Auswertung via Grafana habe ich im übrigen genau das gleiche Problem 😞
              M Dutchman 2 Replies Last reply Reply Quote 2
                MartyBr @JB_Sullivan last edited by
                @jb_sullivan
                Das kann ich auch nur begrüßen. Ich habe seit 2 Wochen auch eine Photovoltaik und versuche die Daten in den ioBroker zu bekommen. Leider bekomme ich nicht alle Daten vollständig über den Wechselrichter.
                Ich nutze daher auch den SourceAnalytix, um Daten (Differenzen) berechnen zu können.
                Könntest du deine View hier zur Verfügung stellen, ich habe bisher nur eine im Vergleich zum Vortag.
                Vielen Dank im Voraus.
                • JB_Sullivan
                  JB_Sullivan @MartyBr last edited by
                  @martybr sagte in [SourceAnalytix 0.4.8-Final] Released !:
                  Das ist keine "klassische" VIEW, das ist ein bisschen komplexer. Das ist ein HTML Tabellen Template, welches via JavaSkript die Datenpunkte aus Sourceanlytix ausliest und dann in die Platzhalter der Zellen schreibt.
                  Wenn das geschehen ist, wird daraus eine HTML Tabelle erzeugt, die wiederum als einzelner Datenpunkt im VIS als "basic-HTML" verknüpft wird. Dann ist die Tabelle so sichtbar wie im Screenshot oben.
                  Genau so ich mache ich das auch mit anderen Daten aus der PV. Da wird allerdings innerhalb des JavaSkriptes auch noch gerechnet und gerundet.
                  Beispiel:
                    @crunchip said in [SourceAnalytix 0.4.8-Final] Released !:
                    Jetzt steh ich glaube ich auf dem Schlauch.
                    Mein Wechselrichter liefert alle 10s den aktuellen Wert der Entladeleistung des Akku. Der schwankt natürlich und ist mal größer oder kleiner. Das aufsummieren passiert doch durch den Adapter, also kann ein Rechenfehler "plötzlich weniger" doch nur durch den Adapter selbst kommen, oder versteh ich da wa sfalsch.?
                      @aiouh keine Ahnung welche Datenpunkte zur Verfügung stehen bei deinem Wechselrichter, bzw welchen du verwendest, habe selbst keinen.
                      SA ist so konzipiert, das üblicherweiser ein fortlaufender Zähler(bestenfalls in kwh) geloggt wird.
                      Solltest du einen DP (Watt) verwenden und dieser sowieso nur alle 10sec übertragen wird, kommen am Ende eh nur Schätzwerte heraus.
                        ... > SA ist so konzipiert, das üblicherweiser ein fortlaufender Zähler(bestenfalls in kwh) geloggt wird.
                        Das war hilfreich ! Ich hatte es so verstanden, das der SA einen Zähler bildet wenn man keinen hat. Das mit den Schätzwerten ist klar. Dass er eigentlich auf Zählerwerte aufsetzt hatte ich nicht kapiert.
                          @jb_sullivan
                          Das ist eine tolle Lösung. Gratulation!
                          So weit bin ich noch nicht. Ich rechne die Werte in Blockys um und schreibe mit die Werte in eigene DPs.
                          Danke für deine Antwort.
                          • XBiT
                            XBiT last edited by
                            @Dutchman
                            Hallo ich habe immer wieder ein Problem bei der Zählung der Brennerstarts meiner Heizung.
                            Das ganze läuft im Optimalfall 1 Woche richtig, danach wird einfach am Folgetag mit der Gesamtzahl weitergerechnet.
                            Ich habe schon mehrfach SA in den Einstellungen vom DP ausgeschaltet, SA gestoppt, den Ordner in den Objekten gelöscht, SA gestartet, Logging für den DP neu eingeschaltet.
                            Mal läuft es 1 Woche Top, mal so wie heute schon am Folgetag nicht.
                            Installierte Version ist 0.4.12-1
                            Was könnte ich noch machen?
                            hier mal die Log vom Tageswechsel und der Einstellungen im DP:
                            2021-10-26 00:00:02.929  - info: sourceanalytix.0 (522) Reset start values for : alias.0.Viessmann.Brenner_Zuendungen
                            2021-10-26 00:00:02.930  - info: sourceanalytix.0 (522) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"alias__0__Viessmann__Brenner_Zuendungen","financialCategory":"costs","headCategory":"consumed","name":"value","stateType":"Gas","stateUnit":"m³","useUnit":"m³"},"calcValues":{"cumulativeValue":19627,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"31","unitPrice":"0.12"}}
                            2021-10-26 00:00:03.038  - info: sourceanalytix.0 (522) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"alias__0__Viessmann__Brenner_Zuendungen","financialCategory":"costs","headCategory":"consumed","name":"value","stateType":"Gas","stateUnit":"m³","useUnit":"m³"},"calcValues":{"start_day":19627,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":19627},"prices":{"basicPrice":"31","unitPrice":"0.12"}}
                            2021-10-26 00:00:03.039  - info: sourceanalytix.0 (522) Current value of state : {"val":19627,"ack":true,"ts":1635199025975,"q":0,"from":"system.adapter.viessmannapi.0","user":"system.user.admin","lc":1635198726182}
                            • Hasont
                              Hasont last edited by
                              Hallo, habe seit kurzem keine Möglichkeit mehr SourceAnalytix in den Objekten zu ändern oder hinzuzuzufügen.
                              Bei bereits angelegten Objekten wird noch weiter gezählt obwohl auch hier kein Link mehr zu SourceAnalytix gezeigt wird.
                              Neustart von SA und Raspi hilft nichts.
                              Was passiert mit bereits angelegten Daten (13 Monate Gas und Wassser) bei einer Neuanlage von SA? Kann man die speichern?
                              Als Fehlermeldung kommt bei Einstellungen in den Objekten
                              "Cannot load jsonConfig of sourceanalytix: Not exists"
                              Es wird mir noch History und Telegram als Link angezeigt.
                              • Dutchman
                                Dutchman Developer Most Active Administrators @JB_Sullivan last edited by
                                @jb_sullivan sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                das haben wir doch ?
                                CurrentYear = jetzigen Jahr
                                Parallel hat man den ordner des Jahres wo alles fuers archief geschrieben wird, jetzt ist dort der ordner 2021 und nach Silvester wird dort 2022 stehen
                                (oder übersehe ich etwas ?)
                                • Dutchman
                                  Dutchman Developer Most Active Administrators @Hasont last edited by
                                  @hasont sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                  bitte auf neue version updaten, die Meldung kommt vom admin 5 und bedeutet das du eine version einsetzt welche noch nicht umgebaut ist fuer admin 5
                                  Hasont 1 Reply Last reply Reply Quote 0
                                  • Hasont
                                    Hasont @Dutchman last edited by Hasont
                                    @dutchman sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                    Danke für die schnelle Info, wie kann ich auf 0.4.9 Updaten. Im IOBroker wird mir nur die Version 0.4.8 angeboten. Mit der Katze kann ich unter npm leider auch nichts finden. Habs gefunden unter https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix
                                    Dann hätte ich noch eine Frage. Mein Wasserzähler hat unter mqtt immer unter mqtt/0/wasserzaehler/zaehlerstand seine Daten abgelegt. Nun hat sich das leider geändert und die Daten liegen unter mqtt/0/wasserzaehler/main/value. Kann ich das irgendwie anpassen oder wird dann ein neuer Pfad angelegt.
                                    Vielen Dank für deine Hilfe.
                                    LG Horst
                                    • JB_Sullivan
                                      JB_Sullivan @Dutchman last edited by
                                      JA Leider - schau dir mal meine Tabelle genau an. JAHR (alle Monate) VORJAHR (alle Monate) - und genau das gibt es nicht - es gibt kein VORJAHR mit allen Monaten, sondern dieses wird mit dem Jahreswechsel umbenannt und somit passen die Datenpunkt Namen nicht mehr.
                                      Man muss dann alle DP Namen von currentyear in z.B. 2021 umbenennen wenn man am 01.01.2022 einen Vergleich zwischen 2021 und 2022 haben will.
                                      Currentyear wird zum Jahreswechsel halt in das zurück liegende Jahr umbenannt und somit ändern sich auch alle DP Namen der Monate aus dem Jahr 2021 😉
                                      Oder übersehe ICH etwas .....?
                                        Malz1902 @JB_Sullivan last edited by
                                        für den Vergleich aktuelles Jahr zu letzztem Jahr wäre es echt besser wenn aus currentYear nach dem Jahreswechsel preivousYear wird, dann muss man dort nicht ijmmer eine Jahreszahl eintragen
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @Malz1902 last edited by
                                          @malz1902 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                          nein, dafuer haben wir das Archive des Jahres. Man kan immer mit. variablen arbeiten z.b. $(year) womit das jähr automatisch immer jetziges ist oder $(year - 1) usw man muss nicht immer alles in daten loesen wollen 😉
                                          JB_Sullivan S 2 Replies Last reply Reply Quote 1
                                          • JB_Sullivan
                                            JB_Sullivan @Dutchman last edited by JB_Sullivan
                                            @dutchman Kannst du das ggf. an ein Beispiel präzisieren? Ich kann damit gerade gar nichts anfangen.
                                            Wie müsste denn mit dem $(year-1) so eine Zeile, wie ich sie in meiner Tabelle verwende aussehen?
                                            HTML+=" <td align=right bgcolor=#FDE2CD>" + Math.round(getState("sourceanalytix.0.discovergy__0__60xxxx58__energyOut.2021.delivered.months.01_January").val * 100) / 100 + " kwh</td>"; //Verkauf Aktuelles Jahr
                                            2302
                                            1136693
