    4. SONOFF ZigBee 3.0 USB DONGLE PLUS
      m0skit0 @arteck last edited by
      @arteck
      lxc.cgroup2.devices.allow: c 188:0 rwm
      lxc.mount.entry: /dev/bus/usb/001/014 dev/bus/usb/001/014 none bind,optional,create=>
      lxc.mount.entry: /dev/ttyUSB1 /dev/ttyUSB1 none bind,optional,create=file
      in Proxmox
      JLeg 1 Reply Last reply Reply Quote 0
        Thomas Braun Most Active @hm_krause last edited by
        @hm_krause
        Und wie sehen die Einstellungen im Adapter aus?
          hm_krause @Thomas Braun last edited by
          com: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_1469408ef193eb1180efaa5b3d98b6d1-if00-port0
          Typ: TI-Z...
              @hm_krause
              Die erweiterte PAN-Id sollte anders lauten.
              Kann aber sein, dass dann neugepairt werden muss.
                mit geänerter ID, immer noch:
                host.iobroker
                	2021-10-24 12:23:29.249	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.iobroker
                	2021-10-24 12:23:29.248	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker
                	2021-10-24 12:23:29.247	error	Caught by controller[1]: at processImmediate (internal/timers.js:464:21)
                host.iobroker
                	2021-10-24 12:23:29.247	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37)
                host.iobroker
                	2021-10-24 12:23:29.246	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34)
                host.iobroker
                	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (domain.js:475:12)
                host.iobroker
                	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (events.js:412:35)
                host.iobroker
                	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26)
                host.iobroker
                	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49)
                host.iobroker
                	2021-10-24 12:23:29.244	error	Caught by controller[1]: TypeError: Cannot read property 'getDevice' of undefined
                host.iobroker
                	2021-10-24 12:23:29.243	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                zigbee.0
                	2021-10-24 12:23:28.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  @hm_krause
                  Dann fällt mir dazu konkret auch nichts mehr ein.
                  Versionen von nodeJS und des Adapters? NodeJS senkrecht installiert?
                    @thomas-braun said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                    ----keine Ahnung----
                    H Thomas Braun 2 Replies Last reply Reply Quote 0
                      hm_krause @hm_krause last edited by
                      @hm_krause
                      zigbee v 1.6.3
                        @hm_krause
                        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                          pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          Thomas Braun J 2 Replies Last reply Reply Quote 0
                            @hm_krause
                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                              Jan1 @hm_krause last edited by
                              @hm_krause
                              bitte immer alles und in Code Tags angeben, dann sieht das so aus (wenn es richtig ist):
                              jan@Beelink:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v14.18.1
                              v14.18.1
                              6.14.15
                              [sudo] Passwort für jan:
                              OK:1 http://deb.debian.org/debian bullseye InRelease
                              Holen:2 http://deb.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                              Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                              Holen:4 http://deb.debian.org/debian bullseye-backports InRelease [42,1 kB]
                              OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                              Es wurden 126 kB in 1 s geholt (100 kB/s).
                              Paketlisten werden gelesen… Fertig
                              Abhängigkeitsbaum wird aufgebaut… Fertig
                              Statusinformationen werden eingelesen… Fertig
                              Alle Pakete sind aktuell.
                              nodejs:
                                Installiert:           14.18.1-deb-1nodesource1
                                Installationskandidat: 14.18.1-deb-1nodesource1
                                Versionstabelle:
                               *** 14.18.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   12.22.5~dfsg-2~11u1 500
                                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                      500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                @thomas-braun ```
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.18.0
                                v14.18.0
                                6.14.15
                                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                Aktualisierung für 19 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                nodejs:
                                Installiert: 14.18.0-deb-1nodesource1
                                Versionstabelle:
                                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                *** 14.18.0-deb-1nodesource1 100
                                10.24.0~dfsg-1~deb10u1 500
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.18.0
                                v14.18.0
                                6.14.15
                                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                nodejs:
                                Versionstabelle:
                                  hm_krause @Jan1 last edited by
                                  @jan1
                                  ...sorry
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.18.0
                                  v14.18.0
                                  6.14.15
                                  nodejs:
                                    Versionstabelle:
                                    @hm_krause Okay, passst grundsätzlich. Hau die 19 Updates auf das System.
                                      Updates durchgeführt, aber:
                                      zigbee.0
                                      	2021-10-24 13:06:10.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      zigbee.0
                                      	2021-10-24 13:06:10.607	info	terminating
                                      zigbee.0
                                      	2021-10-24 13:06:10.109	info	Zigbee: disabling joining new devices.
                                      zigbee.0
                                      	2021-10-24 13:06:10.106	info	cleaned everything up...
                                      zigbee.0
                                      	2021-10-24 13:06:10.097	error	Cannot read property 'getDevice' of undefined
                                      zigbee.0
                                      	2021-10-24 13:06:10.096	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                                      zigbee.0
                                      	2021-10-24 13:06:10.094	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                                      zigbee.0
                                      	2021-10-24 13:06:10.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      	2021-10-24 13:06:09.714	error	Cannot read property 'getDevice' of undefined
                                      zigbee.0
                                      	2021-10-24 13:06:09.713	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                                      zigbee.0
                                      	2021-10-24 13:06:09.698	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                                      zigbee.0
                                      	2021-10-24 13:06:09.697	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      	2021-10-24 13:06:04.251	info	Installed Version: iobroker.zigbee@1.6.3
                                      zigbee.0
                                      	2021-10-24 13:06:03.782	info	Starting Zigbee npm ...
                                        @hm_krause
                                        Reboot gemacht?
                                          Ja
                                            @hm_krause
                                            Dann bin ich raus. Fällt mir nix zu ein.
                                            sonoff zigbee
                                            50
                                            435
                                            127048
