    4. SONOFF ZigBee 3.0 USB DONGLE PLUS
      hm_krause @Thomas Braun last edited by
      com: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_1469408ef193eb1180efaa5b3d98b6d1-if00-port0
      Typ: TI-Z...
          Thomas Braun Most Active @hm_krause last edited by
          @hm_krause
          Die erweiterte PAN-Id sollte anders lauten.
          Kann aber sein, dass dann neugepairt werden muss.
            mit geänerter ID, immer noch:
            host.iobroker
            	2021-10-24 12:23:29.249	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.iobroker
            	2021-10-24 12:23:29.248	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.iobroker
            	2021-10-24 12:23:29.247	error	Caught by controller[1]: at processImmediate (internal/timers.js:464:21)
            host.iobroker
            	2021-10-24 12:23:29.247	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37)
            host.iobroker
            	2021-10-24 12:23:29.246	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34)
            host.iobroker
            	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (domain.js:475:12)
            host.iobroker
            	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (events.js:412:35)
            host.iobroker
            	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26)
            host.iobroker
            	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49)
            host.iobroker
            	2021-10-24 12:23:29.244	error	Caught by controller[1]: TypeError: Cannot read property 'getDevice' of undefined
            host.iobroker
            	2021-10-24 12:23:29.243	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            zigbee.0
            	2021-10-24 12:23:28.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              @hm_krause
              Dann fällt mir dazu konkret auch nichts mehr ein.
              Versionen von nodeJS und des Adapters? NodeJS senkrecht installiert?
                @thomas-braun said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                ----keine Ahnung----
                H Thomas Braun 2 Replies Last reply Reply Quote 0
                  hm_krause @hm_krause last edited by
                  @hm_krause
                  zigbee v 1.6.3
                    @hm_krause
                    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                      pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      Thomas Braun J 2 Replies Last reply Reply Quote 0
                        @hm_krause
                        sudo ln -s /usr/bin/node /usr/bin/nodejs
                          Jan1 @hm_krause last edited by
                          @hm_krause
                          bitte immer alles und in Code Tags angeben, dann sieht das so aus (wenn es richtig ist):
                          jan@Beelink:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v14.18.1
                          v14.18.1
                          6.14.15
                          [sudo] Passwort für jan:
                          OK:1 http://deb.debian.org/debian bullseye InRelease
                          Holen:2 http://deb.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                          Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                          Holen:4 http://deb.debian.org/debian bullseye-backports InRelease [42,1 kB]
                          OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                          Es wurden 126 kB in 1 s geholt (100 kB/s).
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Alle Pakete sind aktuell.
                          nodejs:
                            Installiert:           14.18.1-deb-1nodesource1
                            Installationskandidat: 14.18.1-deb-1nodesource1
                            Versionstabelle:
                           *** 14.18.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                                  100 /var/lib/dpkg/status
                               12.22.5~dfsg-2~11u1 500
                                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                  500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                            @thomas-braun ```
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.18.0
                            v14.18.0
                            6.14.15
                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                            Aktualisierung für 19 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            nodejs:
                            Installiert: 14.18.0-deb-1nodesource1
                            Versionstabelle:
                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                            *** 14.18.0-deb-1nodesource1 100
                            10.24.0~dfsg-1~deb10u1 500
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.18.0
                            v14.18.0
                            6.14.15
                            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:2 http://archive.raspberrypi.org/debian buster InRelease
                            nodejs:
                            Versionstabelle:
                              hm_krause @Jan1 last edited by
                              @jan1
                              ...sorry
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v14.18.0
                              v14.18.0
                              6.14.15
                              nodejs:
                                Versionstabelle:
                                @hm_krause Okay, passst grundsätzlich. Hau die 19 Updates auf das System.
                                  Updates durchgeführt, aber:
                                  zigbee.0
                                  	2021-10-24 13:06:10.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  zigbee.0
                                  	2021-10-24 13:06:10.607	info	terminating
                                  zigbee.0
                                  	2021-10-24 13:06:10.109	info	Zigbee: disabling joining new devices.
                                  zigbee.0
                                  	2021-10-24 13:06:10.106	info	cleaned everything up...
                                  zigbee.0
                                  	2021-10-24 13:06:10.097	error	Cannot read property 'getDevice' of undefined
                                  zigbee.0
                                  	2021-10-24 13:06:10.096	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                                  zigbee.0
                                  	2021-10-24 13:06:10.094	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                                  zigbee.0
                                  	2021-10-24 13:06:10.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0
                                  	2021-10-24 13:06:09.714	error	Cannot read property 'getDevice' of undefined
                                  zigbee.0
                                  	2021-10-24 13:06:09.713	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                                  zigbee.0
                                  	2021-10-24 13:06:09.698	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                                  zigbee.0
                                  	2021-10-24 13:06:09.697	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0
                                  	2021-10-24 13:06:04.251	info	Installed Version: iobroker.zigbee@1.6.3
                                  zigbee.0
                                  	2021-10-24 13:06:03.782	info	Starting Zigbee npm ...
                                    @hm_krause
                                    Reboot gemacht?
                                      Ja
                                        @hm_krause
                                        Dann bin ich raus. Fällt mir nix zu ein.
                                          Danke und ein schönes Wochenende...
                                            @hm_krause
                                            Da ist auch nix mit Container oder VM im Spiel?
                                            sonoff zigbee
                                            50
                                            435
                                            126942
