    4. SONOFF ZigBee 3.0 USB DONGLE PLUS
      Thomas Braun Most Active @hm_krause last edited by
      @hm_krause
      Die erweiterte PAN-Id sollte anders lauten.
      Kann aber sein, dass dann neugepairt werden muss.
        hm_krause @Thomas Braun last edited by
        mit geänerter ID, immer noch:
        host.iobroker
        	2021-10-24 12:23:29.249	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.iobroker
        	2021-10-24 12:23:29.248	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        	2021-10-24 12:23:29.247	error	Caught by controller[1]: at processImmediate (internal/timers.js:464:21)
        host.iobroker
        	2021-10-24 12:23:29.247	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37)
        host.iobroker
        	2021-10-24 12:23:29.246	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34)
        host.iobroker
        	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (domain.js:475:12)
        host.iobroker
        	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (events.js:412:35)
        host.iobroker
        	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26)
        host.iobroker
        	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49)
        host.iobroker
        	2021-10-24 12:23:29.244	error	Caught by controller[1]: TypeError: Cannot read property 'getDevice' of undefined
        host.iobroker
        	2021-10-24 12:23:29.243	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        zigbee.0
        	2021-10-24 12:23:28.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          @hm_krause
          Dann fällt mir dazu konkret auch nichts mehr ein.
          Versionen von nodeJS und des Adapters? NodeJS senkrecht installiert?
            @thomas-braun said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
            ----keine Ahnung----
            H Thomas Braun 2 Replies Last reply Reply Quote 0
              hm_krause @hm_krause last edited by
              @hm_krause
              zigbee v 1.6.3
                @hm_krause
                which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                  pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  Thomas Braun J 2 Replies Last reply Reply Quote 0
                    @hm_krause
                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                      Jan1 @hm_krause last edited by
                      @hm_krause
                      bitte immer alles und in Code Tags angeben, dann sieht das so aus (wenn es richtig ist):
                      jan@Beelink:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.18.1
                      v14.18.1
                      6.14.15
                      [sudo] Passwort für jan:
                      OK:1 http://deb.debian.org/debian bullseye InRelease
                      Holen:2 http://deb.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                      Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                      Holen:4 http://deb.debian.org/debian bullseye-backports InRelease [42,1 kB]
                      OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                      Es wurden 126 kB in 1 s geholt (100 kB/s).
                      Paketlisten werden gelesen… Fertig
                      Abhängigkeitsbaum wird aufgebaut… Fertig
                      Statusinformationen werden eingelesen… Fertig
                      Alle Pakete sind aktuell.
                      nodejs:
                        Installiert:           14.18.1-deb-1nodesource1
                        Installationskandidat: 14.18.1-deb-1nodesource1
                        Versionstabelle:
                       *** 14.18.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                              100 /var/lib/dpkg/status
                           12.22.5~dfsg-2~11u1 500
                              500 http://deb.debian.org/debian bullseye/main amd64 Packages
                              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                        @thomas-braun ```
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.0
                        v14.18.0
                        6.14.15
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                        Aktualisierung für 19 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                        nodejs:
                        Installiert: 14.18.0-deb-1nodesource1
                        Versionstabelle:
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                        *** 14.18.0-deb-1nodesource1 100
                        10.24.0~dfsg-1~deb10u1 500
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.0
                        v14.18.0
                        6.14.15
                        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:2 http://archive.raspberrypi.org/debian buster InRelease
                        nodejs:
                        Versionstabelle:
                          hm_krause @Jan1 last edited by
                          @jan1
                          ...sorry
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v14.18.0
                          v14.18.0
                          6.14.15
                          nodejs:
                            Versionstabelle:
                            @hm_krause Okay, passst grundsätzlich. Hau die 19 Updates auf das System.
                              Updates durchgeführt, aber:
                              zigbee.0
                              	2021-10-24 13:06:10.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              zigbee.0
                              	2021-10-24 13:06:10.607	info	terminating
                              zigbee.0
                              	2021-10-24 13:06:10.109	info	Zigbee: disabling joining new devices.
                              zigbee.0
                              	2021-10-24 13:06:10.106	info	cleaned everything up...
                              zigbee.0
                              	2021-10-24 13:06:10.097	error	Cannot read property 'getDevice' of undefined
                              zigbee.0
                              	2021-10-24 13:06:10.096	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                              zigbee.0
                              	2021-10-24 13:06:10.094	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                              zigbee.0
                              	2021-10-24 13:06:10.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              zigbee.0
                              	2021-10-24 13:06:09.714	error	Cannot read property 'getDevice' of undefined
                              zigbee.0
                              	2021-10-24 13:06:09.713	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                              zigbee.0
                              	2021-10-24 13:06:09.698	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                              zigbee.0
                              	2021-10-24 13:06:09.697	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              zigbee.0
                              	2021-10-24 13:06:04.251	info	Installed Version: iobroker.zigbee@1.6.3
                              zigbee.0
                              	2021-10-24 13:06:03.782	info	Starting Zigbee npm ...
                                @hm_krause
                                Reboot gemacht?
                                  Ja
                                    @hm_krause
                                    Dann bin ich raus. Fällt mir nix zu ein.
                                      Danke und ein schönes Wochenende...
                                        @hm_krause
                                        Da ist auch nix mit Container oder VM im Spiel?
                                          @jan1
                                          nein, nur der iobroker allein auf dem raspi
                                          J Thomas Braun 2 Replies Last reply Reply Quote 0
                                            @hm_krause
                                            Hm, dann weiß ich auch nicht weiter.
                                            Hast nix am Stick gefummelt, nur so wie er ist angesteckt und den Pfad angepasst?
                                            sonoff zigbee
                                            50
                                            435
                                            126942
