    4. SONOFF ZigBee 3.0 USB DONGLE PLUS
      hm_krause @Thomas Braun last edited by
      mit geänerter ID, immer noch:
      host.iobroker
      	2021-10-24 12:23:29.249	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker
      	2021-10-24 12:23:29.248	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      	2021-10-24 12:23:29.247	error	Caught by controller[1]: at processImmediate (internal/timers.js:464:21)
      host.iobroker
      	2021-10-24 12:23:29.247	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37)
      host.iobroker
      	2021-10-24 12:23:29.246	error	Caught by controller[1]: at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34)
      host.iobroker
      	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (domain.js:475:12)
      host.iobroker
      	2021-10-24 12:23:29.246	error	Caught by controller[1]: at Zigbee.emit (events.js:412:35)
      host.iobroker
      	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26)
      host.iobroker
      	2021-10-24 12:23:29.245	error	Caught by controller[1]: at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49)
      host.iobroker
      	2021-10-24 12:23:29.244	error	Caught by controller[1]: TypeError: Cannot read property 'getDevice' of undefined
      host.iobroker
      	2021-10-24 12:23:29.243	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      	2021-10-24 12:23:28.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        Thomas Braun Most Active @hm_krause last edited by
        @hm_krause
        Dann fällt mir dazu konkret auch nichts mehr ein.
        Versionen von nodeJS und des Adapters? NodeJS senkrecht installiert?
          @thomas-braun said in SONOFF ZigBee 3.0 USB DONGLE PLUS:
          ----keine Ahnung----
          H Thomas Braun 2 Replies Last reply Reply Quote 0
            hm_krause @hm_krause last edited by
            @hm_krause
            zigbee v 1.6.3
              @hm_krause
              which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                pi@iobroker:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                /usr/bin/node
                /usr/bin/npm
                Thomas Braun J 2 Replies Last reply Reply Quote 0
                  @hm_krause
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                    Jan1 @hm_krause last edited by
                    @hm_krause
                    bitte immer alles und in Code Tags angeben, dann sieht das so aus (wenn es richtig ist):
                    jan@Beelink:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.18.1
                    v14.18.1
                    6.14.15
                    [sudo] Passwort für jan:
                    OK:1 http://deb.debian.org/debian bullseye InRelease
                    Holen:2 http://deb.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                    Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                    Holen:4 http://deb.debian.org/debian bullseye-backports InRelease [42,1 kB]
                    OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                    Es wurden 126 kB in 1 s geholt (100 kB/s).
                    Paketlisten werden gelesen… Fertig
                    Abhängigkeitsbaum wird aufgebaut… Fertig
                    Statusinformationen werden eingelesen… Fertig
                    Alle Pakete sind aktuell.
                    nodejs:
                      Installiert:           14.18.1-deb-1nodesource1
                      Installationskandidat: 14.18.1-deb-1nodesource1
                      Versionstabelle:
                     *** 14.18.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                            100 /var/lib/dpkg/status
                         12.22.5~dfsg-2~11u1 500
                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                      @thomas-braun ```
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.18.0
                      v14.18.0
                      6.14.15
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                      Aktualisierung für 19 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      nodejs:
                      Installiert: 14.18.0-deb-1nodesource1
                      Versionstabelle:
                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                      *** 14.18.0-deb-1nodesource1 100
                      10.24.0~dfsg-1~deb10u1 500
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.18.0
                      v14.18.0
                      6.14.15
                      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:2 http://archive.raspberrypi.org/debian buster InRelease
                      nodejs:
                      Versionstabelle:
                        hm_krause @Jan1 last edited by
                        @jan1
                        ...sorry
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.0
                        v14.18.0
                        6.14.15
                        nodejs:
                          Versionstabelle:
                          @hm_krause Okay, passst grundsätzlich. Hau die 19 Updates auf das System.
                            Updates durchgeführt, aber:
                            zigbee.0
                            	2021-10-24 13:06:10.609	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            zigbee.0
                            	2021-10-24 13:06:10.607	info	terminating
                            zigbee.0
                            	2021-10-24 13:06:10.109	info	Zigbee: disabling joining new devices.
                            zigbee.0
                            	2021-10-24 13:06:10.106	info	cleaned everything up...
                            zigbee.0
                            	2021-10-24 13:06:10.097	error	Cannot read property 'getDevice' of undefined
                            zigbee.0
                            	2021-10-24 13:06:10.096	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                            zigbee.0
                            	2021-10-24 13:06:10.094	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                            zigbee.0
                            	2021-10-24 13:06:10.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            zigbee.0
                            	2021-10-24 13:06:09.714	error	Cannot read property 'getDevice' of undefined
                            zigbee.0
                            	2021-10-24 13:06:09.713	error	TypeError: Cannot read property 'getDevice' of undefined at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:103:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:46:26) at Zigbee.emit (events.js:412:35) at Zigbee.emit (domain.js:475:12) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37) at processImmediate (internal/timers.js:464:21)
                            zigbee.0
                            	2021-10-24 13:06:09.698	error	unhandled promise rejection: Cannot read property 'getDevice' of undefined
                            zigbee.0
                            	2021-10-24 13:06:09.697	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            zigbee.0
                            	2021-10-24 13:06:04.251	info	Installed Version: iobroker.zigbee@1.6.3
                            zigbee.0
                            	2021-10-24 13:06:03.782	info	Starting Zigbee npm ...
                              @hm_krause
                              Reboot gemacht?
                                Ja
                                  @hm_krause
                                  Dann bin ich raus. Fällt mir nix zu ein.
                                    Danke und ein schönes Wochenende...
                                      @hm_krause
                                      Da ist auch nix mit Container oder VM im Spiel?
                                        @jan1
                                        nein, nur der iobroker allein auf dem raspi
                                        J Thomas Braun 2 Replies Last reply Reply Quote 0
                                          @hm_krause
                                          Hm, dann weiß ich auch nicht weiter.
                                          Hast nix am Stick gefummelt, nur so wie er ist angesteckt und den Pfad angepasst?
                                            @hm_krause
                                            Warum kann das da nicht gelesen werden frage ich mich.
                                            Mal den Fixer ausgeführt?
                                            iobroker stop
                                            iobroker fix
                                            iobroker start
                                            sonoff zigbee
                                            50
                                            435
                                            126947
