    4. Adapter "smartmeter"
      Bandit2001 @Homoran last edited by Bandit2001
      Genau kann ich das leider nicht mehr sagen, ich habe in Admin einfach auf "Alle Adapter aktualisieren" geklickt.
      Gibt es so etwas wie ein Update-Log?
        Homoran Global Moderator Administrators @Bandit2001 last edited by
        @bandit2001 sagte in Adapter "smartmeter":
        aber welche du jetzt hast:
        iobroker update -i
          Ja, das kann ich:
          pi@ioBroker-Pi:~ $ iobroker update -i
          Used repository: stable
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 5.1.25   , installed 5.1.25
          Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
          Adapter    "backitup"      : 2.1.17   , installed 2.1.17
          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          Adapter    "ecovacs-deebot": 1.2.4    , installed 1.2.2 [Updateable]
          Adapter    "email"         : 1.0.10   , installed 1.0.10
          Adapter    "flot"          : 1.10.6   , installed 1.10.6
          Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
          Adapter    "history"       : 1.9.13   , installed 1.9.13
          Adapter    "hm-rega"       : 3.0.31   , installed 3.0.31
          Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
          Adapter    "ical"          : 1.11.4   , installed 1.11.4
          Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
          Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
          Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
          Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
          Adapter    "influxdb"      : 1.9.5    , installed 2.1.1
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "iot"           : 1.8.22   , installed 1.8.22
          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
          Controller "js-controller" : 3.3.18   , installed 3.3.18
          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
          Adapter    "pushover"      : 2.0.5    , installed 2.0.5
          Adapter    "robonect"      : 0.1.3    , installed 0.1.4
          Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "smartmeter"    : 3.2.1    , installed 3.2.1
          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
          Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
          Adapter    "tvspielfilm"   : 1.0.4    , installed 2.0.4
          Adapter    "vis"           : 1.4.4    , installed 1.4.3 [Updateable]
          Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
          Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
          Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
          Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
          Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
          Adapter    "web"           : 3.4.9    , installed 3.4.9
          Das sind alle.
            MartyBr last edited by
            @noox
            Ich habe heute einen Landis Gyr 650 bekommen. Auf der seriellen Schnittstelle sehe ich alle Daten reinkommen. Leider bekommt der Smartmeter-Controller keine Daten.
            Kannst du mir vielleicht deine Einstellungen im Smartmeter-Controller nennen (Baud, Schnittstelleneinrichtung, Protokoll (D0???)
            Ich verzweifle hier
            • N
              noox @MartyBr last edited by
              @martybr
              ich hab halt die Wärmezähler 2WR5
              Die Standard-Werte bekommt man mit '?' - bei meinen kommt man deutlich mehr Werte mit '#'
                MartyBr @noox last edited by
                @noox
                Sehr seltsam, ich habe den Adapter wie bei dir eingestellt und bekomme den Adapter einfach nicht grün.
                Das Terminal liefert aber die Werte:
                Hast du noch eine Idee?
                N Homoran 2 Replies Last reply Reply Quote 0
                • N
                  @martybr
                  Was steht in den Logs?
                  Grad wenn man viel herumprobiert, kann auch sein, dass der USB-Port nicht mehr freigegeben wird.
                  Ich hab dann z.B. sowas bekommen:
                  smartmeter.1 2021-01-19 09:40:30.508 warn (30797) Error on Baudrate changeover: Error: Port is not open
                  Ich hab mir dazu notiert, den Raspberry Pi neu zu starten.
                    Homoran Global Moderator Administrators @MartyBr last edited by
                    @martybr sagte in Adapter "smartmeter":
                    das darf aber nicht parallel zum Adapter laufen
                      MartyBr last edited by MartyBr
                      Ich habe doch nur cat /dev/lesekopf1 auf dem Raspi gestartet. Das sollte doch kein Problem machen, oder doch?
                      Edit:
                      Auch ohne Terminal wird der Adapter nicht grün.
                        was ist denn lesekopf1?
                        der muss doch irgendwomit verbunden sein
                          MartyBr @Homoran last edited by MartyBr
                          Hier mal das Log:
                          smartmeter.0
                          2021-10-25 17:41:06.223	info	Error: Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:05.213	warn	No match for Message "\u0000"
                          smartmeter.0
                          2021-10-25 17:41:05.211	info	Error: No match for Message "\u0000"
                          smartmeter.0
                          2021-10-25 17:41:04.169	warn	Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:04.168	info	Error: Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:03.159	warn	No match for Message "\u0000"
                          smartmeter.0
                          2021-10-25 17:41:03.157	info	Error: No match for Message "\u0000"
                          smartmeter.0
                          smartmeter.0
                          smartmeter.0
                          2021-10-25 17:41:02.115	warn	Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:02.114	info	Error: Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:01.103	warn	No match for Message "\u0000"
                          smartmeter.0
                          2021-10-25 17:41:01.101	info	Error: No match for Message "\u0000"
                          smartmeter.0
                          2021-10-25 17:41:00.059	warn	Error on Baudrate changeover: Error: Port is not open
                          smartmeter.0
                          2021-10-25 17:41:00.057	info	Error: Error on Baudrate changeover: Error: Port is not open
                            passt!
                            entweder falscher Port in der Konfig, oder der Port wird durch ein anderes Programm benutzt
                              Das ist eine Verknüpfung zu den USB Leseköpfen:
                              usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D2C-if00-port0
                              usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D30-if00-port0
                              pi@ioBroker-RasPi:/dev/serial/by-id $
                                Das "lustige" an der Situation ist, dass der Adapter bis heute funktioniert hat. Ich habe heute den neuen Zähler bekommen und den IR Lesekopf umgesteckt.
                                  und warum sind deine Einstellungen so geheim?
                                    Ich hatte die von noox 1 zu 1 übernommen.
                                    Also:
                                      MartyBr @MartyBr last edited by
                                      @Homoran
                                      Ich habe die Einstellung der Schnittstelle:
                                      pi@ioBroker-RasPi:/dev $ sudo stty -F /dev/lesekopf1
                                      speed 300 baud; line = 0;
                                      min = 1; time = 0;
                                      -brkint -icrnl -imaxbel
                                      -opost -onlcr
                                      -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
                                        Ich habe auch den langen Device-Namen eingetragen:
                                        Auch das funktioniert nicht.
                                        Edit:
                                        Kann es sein, das ioBroker nicht (mehr) auf die Schnittstelle zugreifen kann? Die Ausgabe per cat/.... läuft ja.
                                          Homoran Global Moderator Administrators @MartyBr last edited by Homoran
                                          wie ich schrob:
                                          @homoran sagte in Adapter "smartmeter":
                                          passt!
                                          was machst du da???
                                          nix auf der Konsole mit dem Lesekopf machen
                                          und bitte deine Konfig zeigen!
                                          keine Nacherzählung
                                            Ich hatte sie oben gepostet, hier noch mal:
                                            Trotzdem verstehe ich die Meldung nicht
                                            passt!
                                            Es kommen Daten an, sonst könnte ich sie nicht per cat anzeigen. cat blockiert doch keine Ports.
                                            3625
                                            2287173
