    4. Test Alpha Homekit-Controller 0.0.x
      apollon77 last edited by apollon77
      Update auf GitHub:
      WICHTIG: Channelnamen und damit am Ende fast alle State Namen ändern sich in der Version! Die waren nicht unique genug. Also bitte updaten und ggf channelnamen die danach noch da sind ohne nummer drin löschen. Aber am besten NICHT das Hauptobjekt der geräte löschen - oder nach Update einmal neu starten das er die Pairingdaten speichert, dann sollten die wiederverwendet werden.
      • (Apollon77) Store pairing data additionally in an instance directory and retry them on start if objects where deleted or such
      • (Apollon77) Add info.lastDiscovered state with a timestamp to allow manual cleanup of devices that are paired somewhere else then with the adapter instance (because such objects would currently not be deleted)
      • (Apollon77) Adjust some roles
        pboeck @apollon77 last edited by
        @apollon77 Jetzt kommt wieder diese Meldung:
        2021-10-24 08:10:02.726 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-67:1E:EB:7A:BB:97.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:02.892 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:03.196 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:03.398 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:05.811 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:07.557 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet.lock-physical-controls" has to be type "number" but received type "boolean"
        2021-10-24 08:10:08.329 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.leak-detected" has to be type "number" but received type "boolean"
        2021-10-24 08:10:08.387 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.status-fault" has to be type "number" but received type "boolean"
        2021-10-24 08:10:11.155 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:12.741 - info: homekit-controller.0 (681) IP-9E:DB:2B:41:DE:81 Could not initialize device: connect ECONNREFUSED 192.168.1.31:5010 Error: connect ECONNREFUSED 192.168.1.31:5010
        at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
        2021-10-24 08:10:13.977 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-67:1E:EB:7A:BB:97.info.lastDiscovered" has to be type "boolean" but received type "number"
        2021-10-24 08:10:44.496 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.leak-detected" has to be type "number" but received type "boolean"
        2021-10-24 08:10:44.497 - info: homekit-controller.0 (681) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.sensor-leak.status-fault" has to be type "number" but received type "boolean"
          apollon77 @pboeck last edited by
          @pboeck Ok, da ist was seeehr komisch ... checke heute abend
            Ok, @pboeck komisch ... Bitte update nochmal von GitHub ... Ist dann jetzt die 0.3.0 ... bei mir tut da alles ... Auch sehen in deinem Log die State-IDs noch so aus als ob es nicht eine 0.2.0 war die da lief ...
            P 2 Replies Last reply Reply Quote 0
              @apollon77 Ich habe nochmals die 0.3.0 installiert.
              Der Adapter stellt irgendwann seinen Arbeit ein.
              Log nach dem Start:
              2021-10-25 11:45:40.944 - debug: homekit-controller.0 (4788) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2021-10-25 11:45:41.030 - debug: homekit-controller.0 (4788) Objects client ready ... initialize now
              2021-10-25 11:45:41.070 - debug: homekit-controller.0 (4788) Objects create System PubSub Client
              2021-10-25 11:45:41.091 - debug: homekit-controller.0 (4788) Objects create User PubSub Client
              2021-10-25 11:45:41.093 - debug: homekit-controller.0 (4788) Objects client initialize lua scripts
              2021-10-25 11:45:41.115 - debug: homekit-controller.0 (4788) Objects connected to redis: 127.0.0.1:9001
              2021-10-25 11:45:41.139 - debug: homekit-controller.0 (4788) objectDB connected
              2021-10-25 11:45:41.152 - debug: homekit-controller.0 (4788) Redis States: Use Redis connection: 127.0.0.1:9000
              2021-10-25 11:45:41.173 - debug: homekit-controller.0 (4788) States create System PubSub Client
              2021-10-25 11:45:41.175 - debug: homekit-controller.0 (4788) States create User PubSub Client
              2021-10-25 11:45:41.195 - debug: homekit-controller.0 (4788) States connected to redis: 127.0.0.1:9000
              2021-10-25 11:45:41.197 - debug: homekit-controller.0 (4788) statesDB connected
              2021-10-25 11:45:41.949 - debug: homekit-controller.0 (4788) Plugin sentry Initialize Plugin (enabled=true)
              2021-10-25 11:45:42.288 - info: homekit-controller.0 (4788) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v12.22.7, js-controller: 3.3.18
              2021-10-25 11:45:42.819 - debug: homekit-controller.0 (4788) Discovered IP device up: FA:E2:76:C6:A9:AE/Eve Extend 0630
              2021-10-25 11:45:42.822 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Discovered IP device: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
              2021-10-25 11:45:42.825 - info: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Found stored Pairing data, try it ...
              2021-10-25 11:45:42.828 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Start Homekit Device Client initialization on 192.168.1.65:8080
              2021-10-25 11:45:42.833 - debug: homekit-controller.0 (4788) Service: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
              2021-10-25 11:45:42.845 - debug: homekit-controller.0 (4788) Discovered IP device up: f9:47:a6:e8:4f:f1/hepe 429D
              2021-10-25 11:45:42.846 - debug: homekit-controller.0 (4788) IP-F9:47:A6:E8:4F:F1 Discovered IP device: {"name":"hepe 429D","address":"192.168.1.4","port":42941,"c#":2,"ff":0,"id":"f9:47:a6:e8:4f:f1","md":"iobroker","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
              2021-10-25 11:45:42.847 - info: homekit-controller.0 (4788) IP-F9:47:A6:E8:4F:F1 (hepe 429D) found without known pairing data and already paired: ignoring
              2021-10-25 11:45:42.883 - debug: homekit-controller.0 (4788) Discovered IP device up: 9E:DB:2B:41:DE:81/MSS210-b791
              2021-10-25 11:45:42.884 - debug: homekit-controller.0 (4788) IP-9E:DB:2B:41:DE:81 Discovered IP device: {"name":"MSS210-b791","address":"192.168.1.31","port":5010,"c#":2,"ff":2,"id":"9E:DB:2B:41:DE:81","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.884 - info: homekit-controller.0 (4788) IP-9E:DB:2B:41:DE:81 (MSS210-b791) found without known pairing data and already paired: ignoring
              2021-10-25 11:45:42.892 - debug: homekit-controller.0 (4788) Discovered IP device up: 03:09:A7:12:3E:A6/MSS210-be7e
              2021-10-25 11:45:42.893 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Discovered IP device: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"03:09:A7:12:3E:A6","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.894 - info: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Found stored Pairing data, try it ...
              2021-10-25 11:45:42.895 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Start Homekit Device Client initialization on 192.168.1.44:5010
              2021-10-25 11:45:42.896 - debug: homekit-controller.0 (4788) Service: {"name":"MSS210-be7e","address":"192.168.1.44","port":5010,"c#":2,"ff":2,"id":"03:09:A7:12:3E:A6","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.904 - debug: homekit-controller.0 (4788) Discovered IP device up: 90:09:EC:57:D8:5A/MSS210-bc23
              2021-10-25 11:45:42.905 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Discovered IP device: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.906 - info: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Found stored Pairing data, try it ...
              2021-10-25 11:45:42.907 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Start Homekit Device Client initialization on 192.168.1.40:5010
              2021-10-25 11:45:42.908 - debug: homekit-controller.0 (4788) Service: {"name":"MSS210-bc23","address":"192.168.1.40","port":5010,"c#":2,"ff":2,"id":"90:09:EC:57:D8:5A","md":"MSS210","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.915 - debug: homekit-controller.0 (4788) Discovered IP device up: 48:60:FE:40:13:42/MSS620-6c70
              2021-10-25 11:45:42.915 - debug: homekit-controller.0 (4788) IP-48:60:FE:40:13:42 Discovered IP device: {"name":"MSS620-6c70","address":"192.168.1.54","port":5010,"c#":4,"ff":2,"id":"48:60:FE:40:13:42","md":"MSS620","pv":"1.1","s#":1,"sf":0,"ci":7,"availableToPair":false}
              2021-10-25 11:45:42.916 - info: homekit-controller.0 (4788) IP-48:60:FE:40:13:42 (MSS620-6c70) found without known pairing data and already paired: ignoring
              2021-10-25 11:45:42.931 - debug: homekit-controller.0 (4788) Discovered BLE device up: 38:ab:51:14:7e:a9/Flex Ce
              2021-10-25 11:45:42.931 - debug: homekit-controller.0 (4788) BLE-38:AB:51:14:7E:A9 Discovered BLE device: {"name":"Flex Ce","CoID":76,"TY":6,"AIL":109,"SF":0,"DeviceID":"38:ab:51:14:7e:a9","ACID":5,"GSN":515,"CN":1,"CV":2,"c#":1,"id":"38:ab:51:14:7e:a9","ci":5,"availableToPair":false}
              2021-10-25 11:45:42.932 - info: homekit-controller.0 (4788) BLE-38:AB:51:14:7E:A9 (Flex Ce) found without known pairing data and already paired: ignoring
              2021-10-25 11:45:42.940 - debug: homekit-controller.0 (4788) Init 4 known devices without discovery ...
              2021-10-25 11:45:42.941 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Start Homekit Device Client initialization on 192.168.1.65:8080
              2021-10-25 11:45:42.942 - debug: homekit-controller.0 (4788) Service: {"name":"Eve Extend 0630","address":"192.168.1.65","port":8080,"c#":8,"ff":1,"id":"FA:E2:76:C6:A9:AE","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
              2021-10-25 11:45:42.977 - debug: homekit-controller.0 (4788) state homekit-controller.0.info.connection changed: false (ack = true)
              2021-10-25 11:45:43.694 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Accessory Structure: {"accessories":[{"aid":1,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Extend 0630"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Extend 20EAB9901"},{"format":"string","iid":5,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"DU51I1A00740"},{"format":"string","iid":6,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.1.1"},{"format":"bool","iid":7,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":108,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"tlv8","iid":101,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"format":"tlv8","iid":102,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":103,"perms":["pr"],"type":"E863F150-079E-48FF-8F27-9C2605A29F52","value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEDBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgECBwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZsGAQAHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbAGAQIHAQD/AA=="},{"format":"tlv8","iid":104,"perms":["pw"],"type":"E863F151-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":105,"perms":["pr"],"type":"E863F152-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"data","iid":106,"perms":["pw"],"type":"E863F153-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":107,"perms":["pr","ev"],"type":"E863F154-079E-48FF-8F27-9C2605A29F52","value":"AQ=="}],"hidden":true,"iid":100,"type":"E863F007-079E-48FF-8F27-9C2605A29F52"},{"characteristics":[{"format":"string","iid":201,"perms":["pr"],"type":"00000037-0000-1000-8000-0026BB765291","value":"1.1.0"}],"iid":200,"type":"000000A2-0000-1000-8000-0026BB765291"}]},{"aid":2,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94EC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06310"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"1188AB34-4043-7FAC-6AFD-C3BA3B94F985","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIKAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsELpN4AZ8E9QEAACACLAFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"LpN4AYA3dgFtWCQnBgsCDAINAgcCDgEBAgoBAAwhzwAAMTZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FCXQAAChhXgBLwAAKAkAAAAAJwE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656693245},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAI/VPp/5vo3J"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":234.60000610351562},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":0.9399999976158142},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"28:E9:52:B9:05:48"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":3,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94AC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A05837"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIJAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsEeoJ4AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"e4J4AQAAAAAAAAAABgsCDAINAgcCDgEBAgkBAAwuwwAAsyV2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDLEAAD5dngBLwAANAkAAAAAHQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694369},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAPKB5xEUGLZO"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":236},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.6699999570846558},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"AB:36:FD:90:DB:7C"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":4,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard 5B8A"},{"format":"bool","iid":3,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":4,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":5,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Water Guard 20EBG8701"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"KV45I1A04286"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.2.10"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.0.0"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":18,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard"},{"format":"uint8","iid":19,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000070-0000-1000-8000-0026BB765291","value":0},{"format":"uint8","iid":20,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000077-0000-1000-8000-0026BB765291","value":0}],"iid":17,"type":"00000083-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":23,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"data","iid":24,"perms":["pr","pw"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDkUA1QQKAP0Pevf51bfB"},{"format":"uint32","iid":25,"maxValue":4294967295,"minStep":1,"minValue":0,"perms":["pr","pw"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"data","iid":26,"perms":["pw"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":27,"perms":["pw"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":28,"perms":["pr"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"a1oCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"format":"data","iid":29,"perms":["pr"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"tlv8","iid":30,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBGtaAgDSAA=="},{"format":"tlv8","iid":31,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"}],"iid":22,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"23:7D:8E:0E:0F:08"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":10},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":5,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy C8B1"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06143"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIKAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsEPnF4AZ8E9QEAACACFQFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"PnF4AQAAAAAAAAAABgsCDAINAgcCDgEBAgoBAAw4zQAAYRZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDzOAADdY3gBLzkBHgkdADcBFQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694491},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAE1x8iUbk1uP"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":232.89999389648438},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0.28999999165534973},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":30.600000381469727},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.0499999523162842},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"13:13:B2:5C:17:5E"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]}]}
              2021-10-25 11:45:44.668 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Accessory Structure: {"accessories":[{"aid":1,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Extend 0630"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Extend 20EAB9901"},{"format":"string","iid":5,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"DU51I1A00740"},{"format":"string","iid":6,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.1.1"},{"format":"bool","iid":7,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":108,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"tlv8","iid":101,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"format":"tlv8","iid":102,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":103,"perms":["pr"],"type":"E863F150-079E-48FF-8F27-9C2605A29F52","value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEEBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEDBwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZsGAQEHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbAGAQMHAQD/AA=="},{"format":"tlv8","iid":104,"perms":["pw"],"type":"E863F151-079E-48FF-8F27-9C2605A29F52"},{"format":"tlv8","iid":105,"perms":["pr"],"type":"E863F152-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"data","iid":106,"perms":["pw"],"type":"E863F153-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":107,"perms":["pr","ev"],"type":"E863F154-079E-48FF-8F27-9C2605A29F52","value":"AQ=="}],"hidden":true,"iid":100,"type":"E863F007-079E-48FF-8F27-9C2605A29F52"},{"characteristics":[{"format":"string","iid":201,"perms":["pr"],"type":"00000037-0000-1000-8000-0026BB765291","value":"1.1.0"}],"iid":200,"type":"000000A2-0000-1000-8000-0026BB765291"}]},{"aid":2,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94EC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06310"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"1188AB34-4043-7FAC-6AFD-C3BA3B94F985","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIKAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsELpN4AZ8E9QEAACACLAFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"LpN4AYA3dgFtWCQnBgsCDAINAgcCDgEBAgoBAAwhzwAAMTZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FCXQAAChhXgBLwAAKAkAAAAAJwE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656693245},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAI/VPp/5vo3J"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":234.60000610351562},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":0.9399999976158142},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"28:E9:52:B9:05:48"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":3,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy 94AC"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A05837"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIJAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsEeoJ4AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"e4J4AQAAAAAAAAAABgsCDAINAgcCDgEBAgkBAAwuwwAAsyV2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDLEAAD5dngBLwAANAkAAAAAHQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694369},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAPKB5xEUGLZO"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":236},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.6699999570846558},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"AB:36:FD:90:DB:7C"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":4,"services":[{"characteristics":[{"format":"string","iid":2,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard 5B8A"},{"format":"bool","iid":3,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":4,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":5,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Water Guard 20EBG8701"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"KV45I1A04286"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"1.2.10"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.0.0"}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"string","iid":18,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Water Guard"},{"format":"uint8","iid":19,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000070-0000-1000-8000-0026BB765291","value":0},{"format":"uint8","iid":20,"maxValue":1,"minStep":1,"minValue":0,"perms":["pr","ev"],"type":"00000077-0000-1000-8000-0026BB765291","value":0}],"iid":17,"type":"00000083-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":23,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Logging"},{"format":"data","iid":24,"perms":["pr","pw"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDkUA1QQKAP0Pevf51bfB"},{"format":"uint32","iid":25,"maxValue":4294967295,"minStep":1,"minValue":0,"perms":["pr","pw"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":0},{"format":"data","iid":26,"perms":["pw"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":27,"perms":["pw"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":28,"perms":["pr"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"a1oCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"format":"data","iid":29,"perms":["pr"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":""},{"format":"tlv8","iid":30,"perms":["pr"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBGtaAgDSAA=="},{"format":"tlv8","iid":31,"perms":["pw"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"}],"iid":22,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"23:7D:8E:0E:0F:08"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":10},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]},{"aid":5,"services":[{"characteristics":[{"format":"bool","iid":2,"perms":["pw"],"type":"00000014-0000-1000-8000-0026BB765291"},{"format":"string","iid":3,"perms":["pr"],"type":"00000020-0000-1000-8000-0026BB765291","value":"Eve Systems"},{"format":"string","iid":4,"perms":["pr"],"type":"00000021-0000-1000-8000-0026BB765291","value":"Eve Energy 20EBO8301"},{"format":"string","iid":5,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy C8B1"},{"format":"string","iid":6,"perms":["pr"],"type":"00000030-0000-1000-8000-0026BB765291","value":"RV40J1A06143"},{"format":"string","iid":7,"perms":["pr"],"type":"00000052-0000-1000-8000-0026BB765291","value":"2.1.1"},{"format":"string","iid":8,"perms":["pr"],"type":"00000053-0000-1000-8000-0026BB765291","value":"1.1"},{"format":"string","iid":9,"perms":["pr","hd"],"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","value":"\"5.2\";30b0d575"},{"format":"data","iid":10,"perms":["pr"],"type":"00000220-0000-1000-8000-0026BB765291","value":"IHdXc5VleGE="}],"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"uint16","iid":20,"maxValue":31,"minValue":0,"perms":["pr"],"type":"00000702-0000-1000-8000-0026BB765291","value":8},{"format":"uint16","iid":21,"maxValue":127,"minValue":0,"perms":["pr","ev"],"type":"00000703-0000-1000-8000-0026BB765291","value":1},{"format":"tlv8","iid":22,"perms":["pr","pw"],"type":"00000704-0000-1000-8000-0026BB765291","value":""},{"format":"string","iid":23,"perms":["pr"],"type":"00000706-0000-1000-8000-0026BB765291","value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"format":"bool","iid":25,"perms":["pr"],"type":"0000022B-0000-1000-8000-0026BB765291","value":false}],"iid":19,"type":"00000701-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"tlv8","iid":29,"perms":["pr","hd"],"type":"E863F131-079E-48FF-8F27-9C2605A29F52","value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIKAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsEPnF4AZ8E9QEAACACFQFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"format":"tlv8","iid":30,"perms":["pw","hd"],"type":"E863F11D-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":31,"perms":["pr","pw","hd"],"type":"E863F158-079E-48FF-8F27-9C2605A29F52","value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"format":"data","iid":32,"perms":["pr","hd"],"type":"E863F116-079E-48FF-8F27-9C2605A29F52","value":"PnF4AQAAAAAAAAAABgsCDAINAgcCDgEBAgoBAAw4zQAAYRZ2AQEA"},{"format":"data","iid":33,"perms":["pr","hd"],"type":"E863F117-079E-48FF-8F27-9C2605A29F52","value":"FDzOAADdY3gBLzkBHgkdADcBFQE="},{"format":"data","iid":34,"perms":["pw","hd"],"type":"E863F11C-079E-48FF-8F27-9C2605A29F52"},{"format":"data","iid":35,"perms":["pw","hd"],"type":"E863F121-079E-48FF-8F27-9C2605A29F52"},{"format":"uint32","iid":36,"perms":["pr","pw","hd"],"type":"E863F112-079E-48FF-8F27-9C2605A29F52","value":656694491},{"format":"data","iid":37,"perms":["pr","pw","hd"],"type":"E863F11E-079E-48FF-8F27-9C2605A29F52","value":"HwABDlAAJgsLAE1x8iUbk1uP"}],"iid":26,"type":"E863F007-079E-48FF-8F27-9C2605A29F52","hidden":true},{"characteristics":[{"format":"uint32","iid":40,"maxValue":67108863,"minValue":0,"perms":["pr"],"type":"0000023A-0000-1000-8000-0026BB765291","value":0},{"format":"tlv8","iid":41,"perms":["pr"],"type":"0000023C-0000-1000-8000-0026BB765291","value":""},{"format":"uint32","iid":42,"perms":["pr","ev"],"type":"0000024A-0000-1000-8000-0026BB765291","value":10}],"iid":38,"type":"00000239-0000-1000-8000-0026BB765291"},{"characteristics":[{"format":"bool","iid":44,"perms":["pr","pw","ev"],"type":"00000025-0000-1000-8000-0026BB765291","value":true},{"format":"string","iid":45,"perms":["pr"],"type":"00000023-0000-1000-8000-0026BB765291","value":"Eve Energy"},{"format":"bool","iid":46,"perms":["pr","ev"],"type":"00000026-0000-1000-8000-0026BB765291","value":true},{"format":"float","iid":47,"maxValue":380,"minStep":0.1,"minValue":0,"perms":["pr"],"type":"E863F10A-079E-48FF-8F27-9C2605A29F52","value":232.89999389648438},{"format":"float","iid":48,"maxValue":16,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F126-079E-48FF-8F27-9C2605A29F52","value":0.28999999165534973},{"format":"float","iid":49,"maxValue":5000,"minStep":0.1,"minValue":0,"perms":["pr","ev"],"type":"E863F10D-079E-48FF-8F27-9C2605A29F52","value":30.600000381469727},{"format":"float","iid":50,"minStep":0.01,"minValue":0,"perms":["pr"],"type":"E863F10C-079E-48FF-8F27-9C2605A29F52","value":1.0499999523162842},{"format":"uint8","iid":51,"maxValue":1,"minValue":0,"perms":["pr","pw","ev"],"type":"000000A7-0000-1000-8000-0026BB765291","value":0}],"iid":43,"type":"00000047-0000-1000-8000-0026BB765291","primary":true},{"characteristics":[{"format":"string","iid":100001,"perms":["pr"],"type":"E863F155-079E-48FF-8F27-9C2605A29F52","value":"13:13:B2:5C:17:5E"},{"format":"uint16","iid":100002,"perms":["pr"],"type":"E863F156-079E-48FF-8F27-9C2605A29F52","value":7},{"format":"uint8","iid":100003,"perms":["pr","ev"],"type":"E863F157-079E-48FF-8F27-9C2605A29F52","value":1}],"hidden":true,"iid":100000,"type":"E863F00B-079E-48FF-8F27-9C2605A29F52"}]}]}
              2021-10-25 11:45:44.772 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Accessory Structure: {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"]},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Meross","perms":["pr"],"ev":false},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"MSS210","perms":["pr"],"ev":false},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"MSS210-bc23","perms":["pr"],"ev":false},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"518519200803129","perms":["pr"],"ev":false},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"4.1.9","perms":["pr"],"ev":false},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"4.0.0","perms":["pr"],"ev":false},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"2.0.1;16A75","perms":["pr"],"ev":false}]},{"iid":10,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":11,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false}]},{"iid":12,"type":"00000047-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"linked":[],"characteristics":[{"iid":13,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"outlet","perms":["pr"],"ev":false},{"iid":14,"type":"00000025-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false},{"iid":15,"type":"00000026-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","ev"],"ev":false}]}]}]}
              2021-10-25 11:45:44.795 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connectionType changed: IP (ack = true)
              2021-10-25 11:45:44.849 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Accessory Structure: {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"]},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Meross","perms":["pr"],"ev":false},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"MSS210","perms":["pr"],"ev":false},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"MSS210-be7e","perms":["pr"],"ev":false},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"518519200803732","perms":["pr"],"ev":false},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"4.1.9","perms":["pr"],"ev":false},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"4.0.0","perms":["pr"],"ev":false},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"2.0.1;16A75","perms":["pr"],"ev":false}]},{"iid":10,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"linked":[],"characteristics":[{"iid":11,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false}]},{"iid":12,"type":"00000047-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"linked":[],"characteristics":[{"iid":13,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"outlet","perms":["pr"],"ev":false},{"iid":14,"type":"00000025-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false},{"iid":15,"type":"00000026-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr","ev"],"ev":false}]}]}]}
              2021-10-25 11:45:44.880 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.id changed: FA:E2:76:C6:A9:AE (ack = true)
              2021-10-25 11:45:44.927 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connectionType changed: IP (ack = true)
              2021-10-25 11:45:44.993 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.address changed: 192.168.1.65 (ack = true)
              2021-10-25 11:45:45.011 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connectionType changed: IP (ack = true)
              2021-10-25 11:45:45.035 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.id changed: FA:E2:76:C6:A9:AE (ack = true)
              2021-10-25 11:45:45.084 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connected changed: false (ack = true)
              2021-10-25 11:45:45.088 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.id changed: 90:09:EC:57:D8:5A (ack = true)
              2021-10-25 11:45:45.110 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.connectionType changed: IP (ack = true)
              2021-10-25 11:45:45.200 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.address changed: 192.168.1.65 (ack = true)
              2021-10-25 11:45:45.247 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.address changed: 192.168.1.40 (ack = true)
              2021-10-25 11:45:45.259 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.id changed: 03:09:A7:12:3E:A6 (ack = true)
              2021-10-25 11:45:45.362 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.isPaired changed: true (ack = true)
              2021-10-25 11:45:45.399 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.connected changed: false (ack = true)
              2021-10-25 11:45:45.413 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.connected changed: false (ack = true)
              2021-10-25 11:45:45.494 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number"
              2021-10-25 11:45:45.500 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.address changed: 192.168.1.44 (ack = true)
              2021-10-25 11:45:45.530 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered changed: 1635155142836 (ack = true)
              2021-10-25 11:45:45.604 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.isPaired changed: true (ack = true)
              2021-10-25 11:45:45.615 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.connected changed: false (ack = true)
              2021-10-25 11:45:45.646 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.unpair changed: false (ack = true)
              2021-10-25 11:45:45.650 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.isPaired changed: true (ack = true)
              2021-10-25 11:45:45.677 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered" has to be type "boolean" but received type "number"
              2021-10-25 11:45:45.694 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered changed: 1635155142943 (ack = true)
              2021-10-25 11:45:45.710 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered" has to be type "boolean" but received type "number"
              2021-10-25 11:45:45.735 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.name changed: Eve Extend 0630 (ack = true)
              2021-10-25 11:45:45.742 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.info.lastDiscovered changed: 1635155142909 (ack = true)
              2021-10-25 11:45:45.763 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.admin.isPaired changed: true (ack = true)
              2021-10-25 11:45:45.843 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.admin.unpair changed: false (ack = true)
              2021-10-25 11:45:45.849 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.manufacturer changed: Eve Systems (ack = true)
              2021-10-25 11:45:45.878 - info: homekit-controller.0 (4788) State value to set for "homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered" has to be type "boolean" but received type "number"
              2021-10-25 11:45:45.898 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.admin.unpair changed: false (ack = true)
              2021-10-25 11:45:45.903 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.info.lastDiscovered changed: 1635155142897 (ack = true)
              2021-10-25 11:45:45.930 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.name changed: Eve Extend 0630 (ack = true)
              2021-10-25 11:45:45.932 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.model changed: Eve Extend 20EAB9901 (ack = true)
              2021-10-25 11:45:45.990 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.manufacturer changed: Meross (ack = true)
              2021-10-25 11:45:45.995 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.admin.unpair changed: false (ack = true)
              2021-10-25 11:45:46.016 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.manufacturer changed: Eve Systems (ack = true)
              2021-10-25 11:45:46.021 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.serial-number changed: DU51I1A00740 (ack = true)
              2021-10-25 11:45:46.096 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.model changed: MSS210 (ack = true)
              2021-10-25 11:45:46.102 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.manufacturer changed: Meross (ack = true)
              2021-10-25 11:45:46.135 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.model changed: Eve Extend 20EAB9901 (ack = true)
              2021-10-25 11:45:46.139 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.firmware-revision changed: 1.1.1 (ack = true)
              2021-10-25 11:45:46.198 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.name changed: MSS210-bc23 (ack = true)
              2021-10-25 11:45:46.209 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.model changed: MSS210 (ack = true)
              2021-10-25 11:45:46.289 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.serial-number changed: DU51I1A00740 (ack = true)
              2021-10-25 11:45:46.341 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.serial-number changed: 518519200803129 (ack = true)
              2021-10-25 11:45:46.348 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.name changed: Logging (ack = true)
              2021-10-25 11:45:46.385 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-03:09:A7:12:3E:A6.1.accessory-information-1.name changed: MSS210-be7e (ack = true)
              2021-10-25 11:45:46.388 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.accessory-information-1.firmware-revision changed: 1.1.1 (ack = true)
              2021-10-25 11:45:46.392 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-90:09:EC:57:D8:5A.1.accessory-information-1.firmware-revision changed: 4.1.9 (ack = true)
              Teil 2 folgt
                pboeck @apollon77 last edited by
                @apollon77 Teil 2
                Log vor dem Stop:
                2021-10-25 12:38:37.598 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ...
                2021-10-25 12:38:38.608 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:38:39.455 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ...
                2021-10-25 12:38:40.174 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ...
                2021-10-25 12:38:52.120 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Subscription Event connection disconnected, try to resubscribe
                2021-10-25 12:38:52.125 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Subscription Event connection disconnected, try to resubscribe
                2021-10-25 12:38:52.127 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Subscription Event connection disconnected, try to resubscribe
                2021-10-25 12:38:52.964 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ...
                2021-10-25 12:38:55.248 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Subscription Event connection disconnected, try to resubscribe
                2021-10-25 12:38:56.659 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ...
                2021-10-25 12:38:57.701 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:38:58.614 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:38:59.372 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:04.198 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:05.089 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ...
                2021-10-25 12:39:05.607 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ...
                2021-10-25 12:39:08.609 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ...
                2021-10-25 12:39:09.626 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:16.717 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Set Values to ioBroker: [{"aid":1,"iid":2,"value":"Eve Extend 0630"},{"aid":1,"iid":3,"value":"Eve Systems"},{"aid":1,"iid":4,"value":"Eve Extend 20EAB9901"},{"aid":1,"iid":5,"value":"DU51I1A00740"},{"aid":1,"iid":6,"value":"1.1.1"},{"aid":1,"iid":108,"value":"Logging"},{"aid":1,"iid":101,"value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"aid":1,"iid":103,"value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQMHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbQGAQUHAQD/AA=="},{"aid":1,"iid":105,"value":"AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQIFAbQGAQUIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQMIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA="},{"aid":1,"iid":107,"value":"AQ=="},{"aid":5,"iid":3,"value":"Eve Systems"},{"aid":5,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":5,"iid":5,"value":"Eve Energy C8B1"},{"aid":5,"iid":6,"value":"RV40J1A06143"},{"aid":5,"iid":7,"value":"2.1.1"},{"aid":5,"iid":8,"value":"1.1"},{"aid":5,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":5,"iid":10,"value":"IHdXc5VleGE="},{"aid":5,"iid":20,"value":8},{"aid":5,"iid":21,"value":1},{"aid":5,"iid":22,"value":""},{"aid":5,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":5,"iid":25,"value":false},{"aid":5,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":5,"iid":31,"value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":5,"iid":32,"value":"8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA"},{"aid":5,"iid":33,"value":""},{"aid":5,"iid":36,"value":656694491},{"aid":5,"iid":37,"value":"HwABDlAAJgsLAJUFs8Nb/Yqk"},{"aid":5,"iid":40,"value":0},{"aid":5,"iid":41,"value":""},{"aid":5,"iid":42,"value":10},{"aid":5,"iid":44,"value":true},{"aid":5,"iid":45,"value":"Eve Energy"},{"aid":5,"iid":46,"value":true},{"aid":5,"iid":47,"value":235.8000030517578},{"aid":5,"iid":48,"value":0.2800000011920929},{"aid":5,"iid":49,"value":30.200000762939453},{"aid":5,"iid":50,"value":1.0699999332427979},{"aid":5,"iid":51,"value":0},{"aid":5,"iid":100001,"value":"13:13:B2:5C:17:5E"},{"aid":5,"iid":100002,"value":7},{"aid":5,"iid":100003,"value":1},{"aid":3,"iid":3,"value":"Eve Systems"},{"aid":3,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":3,"iid":5,"value":"Eve Energy 94AC"},{"aid":3,"iid":6,"value":"RV40J1A05837"},{"aid":3,"iid":7,"value":"2.1.1"},{"aid":3,"iid":8,"value":"1.1"},{"aid":3,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":3,"iid":10,"value":"IHdXc5VleGE="},{"aid":3,"iid":20,"value":8},{"aid":3,"iid":21,"value":1},{"aid":3,"iid":22,"value":""},{"aid":3,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":3,"iid":25,"value":false},{"aid":3,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":3,"iid":31,"value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":3,"iid":32,"value":"L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA"},{"aid":3,"iid":33,"value":""},{"aid":3,"iid":36,"value":656694369},{"aid":3,"iid":37,"value":"HwABDlAAJgsLAJZFJW6DVuDk"},{"aid":3,"iid":40,"value":0},{"aid":3,"iid":41,"value":""},{"aid":3,"iid":42,"value":10},{"aid":3,"iid":44,"value":true},{"aid":3,"iid":45,"value":"Eve Energy"},{"aid":3,"iid":46,"value":true},{"aid":3,"iid":47,"value":238.1999969482422},{"aid":3,"iid":48,"value":0},{"aid":3,"iid":49,"value":0},{"aid":3,"iid":50,"value":1.6699999570846558},{"aid":3,"iid":51,"value":0},{"aid":3,"iid":100001,"value":"AB:36:FD:90:DB:7C"},{"aid":3,"iid":100002,"value":7},{"aid":3,"iid":100003,"value":1},{"aid":2,"iid":3,"value":"Eve Systems"},{"aid":2,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":2,"iid":5,"value":"Eve Energy 94EC"},{"aid":2,"iid":6,"value":"RV40J1A06310"},{"aid":2,"iid":7,"value":"2.1.1"},{"aid":2,"iid":8,"value":"1.1"},{"aid":2,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":2,"iid":10,"value":"IHdXc5VleGE="},{"aid":2,"iid":20,"value":8},{"aid":2,"iid":21,"value":1},{"aid":2,"iid":22,"value":""},{"aid":2,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":2,"iid":25,"value":false},{"aid":2,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":2,"iid":31,"value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":2,"iid":32,"value":"4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA"},{"aid":2,"iid":33,"value":""},{"aid":2,"iid":36,"value":656693245},{"aid":2,"iid":37,"value":"HwABDlAAJgsLAFIe8o1p9x0Y"},{"aid":2,"iid":40,"value":0},{"aid":2,"iid":41,"value":""},{"aid":2,"iid":42,"value":10},{"aid":2,"iid":44,"value":true},{"aid":2,"iid":45,"value":"Eve Energy"},{"aid":2,"iid":46,"value":true},{"aid":2,"iid":47,"value":236.5},{"aid":2,"iid":48,"value":0},{"aid":2,"iid":49,"value":0},{"aid":2,"iid":50,"value":0.9399999976158142},{"aid":2,"iid":51,"value":0},{"aid":2,"iid":100001,"value":"28:E9:52:B9:05:48"},{"aid":2,"iid":100002,"value":7},{"aid":2,"iid":100003,"value":1},{"aid":4,"iid":2,"value":"Eve Water Guard 5B8A"},{"aid":4,"iid":4,"value":"Eve Systems"},{"aid":4,"iid":5,"value":"Eve Water Guard 20EBG8701"},{"aid":4,"iid":6,"value":"KV45I1A04286"},{"aid":4,"iid":7,"value":"1.2.10"},{"aid":4,"iid":8,"value":"1.0.0"},{"aid":4,"iid":18,"value":"Eve Water Guard"},{"aid":4,"iid":19,"value":0},{"aid":4,"iid":20,"value":0},{"aid":4,"iid":23,"value":"Logging"},{"aid":4,"iid":24,"value":"HwABDkUA1QQKABvaYBlWSews"},{"aid":4,"iid":25,"value":0},{"aid":4,"iid":28,"value":"I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"aid":4,"iid":29,"value":""},{"aid":4,"iid":30,"value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA=="},{"aid":4,"iid":100001,"value":"23:7D:8E:0E:0F:08"},{"aid":4,"iid":100002,"value":10},{"aid":4,"iid":100003,"value":1}]
                2021-10-25 12:39:16.749 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F131-079E-48FF-8F27-9C2605A29F52 changed: CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdHUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA== (ack = true)
                2021-10-25 12:39:16.788 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F150-079E-48FF-8F27-9C2605A29F52 changed: gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQMHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQEFAbQGAQUHAQD/AA== (ack = true)
                2021-10-25 12:39:16.807 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F152-079E-48FF-8F27-9C2605A29F52 changed: AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQIFAbQGAQUIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQMIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA= (ack = true)
                2021-10-25 12:39:16.810 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true)
                2021-10-25 12:39:16.815 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: 8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA (ack = true)
                2021-10-25 12:39:16.838 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAJUFs8Nb/Yqk (ack = true)
                2021-10-25 12:39:16.839 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 235.8 (ack = true)
                2021-10-25 12:39:16.839 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F126-079E-48FF-8F27-9C2605A29F52 changed: 0.28 (ack = true)
                2021-10-25 12:39:16.840 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.5.outlet-43.E863F10D-079E-48FF-8F27-9C2605A29F52 changed: 30.2 (ack = true)
                2021-10-25 12:39:16.841 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true)
                2021-10-25 12:39:16.846 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA (ack = true)
                2021-10-25 12:39:16.847 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAJZFJW6DVuDk (ack = true)
                2021-10-25 12:39:16.861 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.3.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 238.2 (ack = true)
                2021-10-25 12:39:16.868 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F131-079E-48FF-8F27-9C2605A29F52 changed: 2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA= (ack = true)
                2021-10-25 12:39:16.872 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F116-079E-48FF-8F27-9C2605A29F52 changed: 4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA (ack = true)
                2021-10-25 12:39:16.879 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.E863F007-079E-48FF-8F27-9C2605A29F52-26.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDlAAJgsLAFIe8o1p9x0Y (ack = true)
                2021-10-25 12:39:16.883 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet-43.volt changed: 236.5 (ack = true)
                2021-10-25 12:39:16.890 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F11E-079E-48FF-8F27-9C2605A29F52 changed: HwABDkUA1QQKABvaYBlWSews (ack = true)
                2021-10-25 12:39:16.895 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F116-079E-48FF-8F27-9C2605A29F52 changed: I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA= (ack = true)
                2021-10-25 12:39:16.901 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.4.E863F007-079E-48FF-8F27-9C2605A29F52-22.E863F131-079E-48FF-8F27-9C2605A29F52 changed: AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA== (ack = true)
                2021-10-25 12:39:16.997 - debug: homekit-controller.0 (4788) IP-FA:E2:76:C6:A9:AE Set Values to ioBroker: [{"aid":1,"iid":2,"value":"Eve Extend 0630"},{"aid":1,"iid":3,"value":"Eve Systems"},{"aid":1,"iid":4,"value":"Eve Extend 20EAB9901"},{"aid":1,"iid":5,"value":"DU51I1A00740"},{"aid":1,"iid":6,"value":"1.1.1"},{"aid":1,"iid":108,"value":"Logging"},{"aid":1,"iid":101,"value":"CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA=="},{"aid":1,"iid":103,"value":"gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQQHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQMFAbEGAQAHAQD/AA=="},{"aid":1,"iid":105,"value":"AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQMFAbEGAQAIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQQIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA="},{"aid":1,"iid":107,"value":"AQ=="},{"aid":5,"iid":3,"value":"Eve Systems"},{"aid":5,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":5,"iid":5,"value":"Eve Energy C8B1"},{"aid":5,"iid":6,"value":"RV40J1A06143"},{"aid":5,"iid":7,"value":"2.1.1"},{"aid":5,"iid":8,"value":"1.1"},{"aid":5,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":5,"iid":10,"value":"IHdXc5VleGE="},{"aid":5,"iid":20,"value":8},{"aid":5,"iid":21,"value":1},{"aid":5,"iid":22,"value":""},{"aid":5,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":5,"iid":25,"value":false},{"aid":5,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIF/8AAlAAAwImCwQMUlY0MEoxQTA2MTQzBgIQAQcEOM0AAAUBANgEVFVBWpwBAAsCAABfBAAAAADSAGABZNAE7Rl2AZsE8X14AZ8E9QEAACACGAFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":5,"iid":31,"value":"gAEAAAiWCSHSivQ2JQEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":5,"iid":32,"value":"8n14AQAAAAAAAAAABgsCDAINAgcCDgEBAhABAAw4zQAAYRZ2AQEA"},{"aid":5,"iid":33,"value":""},{"aid":5,"iid":36,"value":656694491},{"aid":5,"iid":37,"value":"HwABDlAAJgsLAJUFs8Nb/Yqk"},{"aid":5,"iid":40,"value":0},{"aid":5,"iid":41,"value":""},{"aid":5,"iid":42,"value":10},{"aid":5,"iid":44,"value":true},{"aid":5,"iid":45,"value":"Eve Energy"},{"aid":5,"iid":46,"value":true},{"aid":5,"iid":47,"value":235.8000030517578},{"aid":5,"iid":48,"value":0.2800000011920929},{"aid":5,"iid":49,"value":30.200000762939453},{"aid":5,"iid":50,"value":1.0699999332427979},{"aid":5,"iid":51,"value":0},{"aid":5,"iid":100001,"value":"13:13:B2:5C:17:5E"},{"aid":5,"iid":100002,"value":7},{"aid":5,"iid":100003,"value":1},{"aid":3,"iid":3,"value":"Eve Systems"},{"aid":3,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":3,"iid":5,"value":"Eve Energy 94AC"},{"aid":3,"iid":6,"value":"RV40J1A05837"},{"aid":3,"iid":7,"value":"2.1.1"},{"aid":3,"iid":8,"value":"1.1"},{"aid":3,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":3,"iid":10,"value":"IHdXc5VleGE="},{"aid":3,"iid":20,"value":8},{"aid":3,"iid":21,"value":1},{"aid":3,"iid":22,"value":""},{"aid":3,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":3,"iid":25,"value":false},{"aid":3,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIFs0AAlAAAwImCwQMUlY0MEoxQTA1ODM3BgIPAQcELsMAAAUBANgET1k2U5wBAAsCAABfBAAAAADSAGABZNAEsSp2AZsELo94AZ8E7AEAACACIgFFBQUAAAAARgkFAAAADgAAQgZEEQUUAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":3,"iid":31,"value":"gAEAAAhKHlGQcAbV9QEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":3,"iid":32,"value":"L494AQAAAAAAAAAABgsCDAINAgcCDgEBAg8BAAwuwwAAsyV2AQEA"},{"aid":3,"iid":33,"value":""},{"aid":3,"iid":36,"value":656694369},{"aid":3,"iid":37,"value":"HwABDlAAJgsLAJZFJW6DVuDk"},{"aid":3,"iid":40,"value":0},{"aid":3,"iid":41,"value":""},{"aid":3,"iid":42,"value":10},{"aid":3,"iid":44,"value":true},{"aid":3,"iid":45,"value":"Eve Energy"},{"aid":3,"iid":46,"value":true},{"aid":3,"iid":47,"value":238.1999969482422},{"aid":3,"iid":48,"value":0},{"aid":3,"iid":49,"value":0},{"aid":3,"iid":50,"value":1.6699999570846558},{"aid":3,"iid":51,"value":0},{"aid":3,"iid":100001,"value":"AB:36:FD:90:DB:7C"},{"aid":3,"iid":100002,"value":7},{"aid":3,"iid":100003,"value":1},{"aid":2,"iid":3,"value":"Eve Systems"},{"aid":2,"iid":4,"value":"Eve Energy 20EBO8301"},{"aid":2,"iid":5,"value":"Eve Energy 94EC"},{"aid":2,"iid":6,"value":"RV40J1A06310"},{"aid":2,"iid":7,"value":"2.1.1"},{"aid":2,"iid":8,"value":"1.1"},{"aid":2,"iid":9,"value":"\"5.2\";30b0d575"},{"aid":2,"iid":10,"value":"IHdXc5VleGE="},{"aid":2,"iid":20,"value":8},{"aid":2,"iid":21,"value":1},{"aid":2,"iid":22,"value":""},{"aid":2,"iid":23,"value":"OPENTHREAD/20170716-02552-geb173c52; NRF52840; Oct 28 2020"},{"aid":2,"iid":25,"value":false},{"aid":2,"iid":29,"value":"2Rhtjj8KmcLTmaM0YZMEgAgEAAxsKhOIGKYAAlAAAwImCwQMUlY0MEoxQTA2MzEwBgIQAQcEIc8AAAUBANgEOVZEM5wBAAsCAABfBAAAAADSAGABZNAEATd2AZsE4594AZ8E9QEAACACLgFFBQUAAAAARgkFAAAADgAAQgZEEQUcAAUDPAAAAEGCPkKFrCNBRxEF3xy4HUseJB+0AAAAPAAAAEgGBQAAAAAASgYFAAAAAAA="},{"aid":2,"iid":31,"value":"gAEAAAj2SVHTicTtfAEC//4CAc8IAIMC//+ECN6tAL7vAMr+hQIAC4YKT3BlblRocmVhZA=="},{"aid":2,"iid":32,"value":"4594AYA3dgFtWCQnBgsCDAINAgcCDgEBAhABAAwhzwAAMTZ2AQEA"},{"aid":2,"iid":33,"value":""},{"aid":2,"iid":36,"value":656693245},{"aid":2,"iid":37,"value":"HwABDlAAJgsLAFIe8o1p9x0Y"},{"aid":2,"iid":40,"value":0},{"aid":2,"iid":41,"value":""},{"aid":2,"iid":42,"value":10},{"aid":2,"iid":44,"value":true},{"aid":2,"iid":45,"value":"Eve Energy"},{"aid":2,"iid":46,"value":true},{"aid":2,"iid":47,"value":236.5},{"aid":2,"iid":48,"value":0},{"aid":2,"iid":49,"value":0},{"aid":2,"iid":50,"value":0.9399999976158142},{"aid":2,"iid":51,"value":0},{"aid":2,"iid":100001,"value":"28:E9:52:B9:05:48"},{"aid":2,"iid":100002,"value":7},{"aid":2,"iid":100003,"value":1},{"aid":4,"iid":2,"value":"Eve Water Guard 5B8A"},{"aid":4,"iid":4,"value":"Eve Systems"},{"aid":4,"iid":5,"value":"Eve Water Guard 20EBG8701"},{"aid":4,"iid":6,"value":"KV45I1A04286"},{"aid":4,"iid":7,"value":"1.2.10"},{"aid":4,"iid":8,"value":"1.0.0"},{"aid":4,"iid":18,"value":"Eve Water Guard"},{"aid":4,"iid":19,"value":0},{"aid":4,"iid":20,"value":0},{"aid":4,"iid":23,"value":"Logging"},{"aid":4,"iid":24,"value":"HwABDkUA1QQKABvaYBlWSews"},{"aid":4,"iid":25,"value":0},{"aid":4,"iid":28,"value":"I2cCAEIBAADxWiQnAS0BCgAAEP0gAAABAAAAAQA="},{"aid":4,"iid":29,"value":""},{"aid":4,"iid":30,"value":"AAJFAAMC1QQEDEtWNDVJMUEwNDI4NgYCCgAHBP0gAAALAgAABQEAAgQIPQAAXwQAAAAAGQKWABQBAw8EAAAAABoEAAAAAE0EAAAAAE4BAIYIWQMAAAAAAACbBCRnAgDSAA=="},{"aid":4,"iid":100001,"value":"23:7D:8E:0E:0F:08"},{"aid":4,"iid":100002,"value":10},{"aid":4,"iid":100003,"value":1}]
                2021-10-25 12:39:17.038 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F131-079E-48FF-8F27-9C2605A29F52 changed: CQbAqAFBkB8MFWV2ZS1leHRlbmQtMDYzMC5sb2NhbAABOwMC+wGcAQAEDERVNTFJMUEwMDc0MAoIAAAAAAAAAAAIAQDTAdLUAgIA1QJ4ANYIBwAAAQMMBQUNAQQOAQQbAQjSAA== (ack = true)
                2021-10-25 12:39:17.040 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F150-079E-48FF-8F27-9C2605A29F52 changed: gAABBijpUrkFSAMPRXZlIEVuZXJneSA5NEVDBAEBBQGsBgEBBwEA/wABBqs2/ZDbfAMPRXZlIEVuZXJneSA5NEFDBAEBBQGsBgEABwEA/wABBiN9jg4PCAMURXZlIFdhdGVyIEd1YXJkIDVCOEEEAQEFAZwGAQQHAQD/AAEGExOyXBdeAw9FdmUgRW5lcmd5IEM4QjEEAQMFAbEGAQAHAQD/AA== (ack = true)
                2021-10-25 12:39:17.041 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.1.E863F007-079E-48FF-8F27-9C2605A29F52-100.E863F152-079E-48FF-8F27-9C2605A29F52 changed: AQarNv2Q23wCAQcDAQAEAQIFAawGAQAIAQAHD0V2ZSBFbmVyZ3kgOTRBQ/8AAQYTE7JcF14CAQcDAQAEAQMFAbEGAQAIAQAHD0V2ZSBFbmVyZ3kgQzhCMf8AAQYjfY4ODwgCAQoDAQAEAQIFAZwGAQQIAQAHFEV2ZSBXYXRlciBHdWFyZCA1QjhB/wABBijpUrkFSAIBBwMBAAQBAgUBrAYBAQgBAAcPRXZlIEVuZXJneSA5NEVD/wA= (ack = true)
                2021-10-25 12:39:17.041 - debug: homekit-controller.0 (4788) state homekit-controller.0.IP-FA:E2:76:C6:A9:AE.2.outlet-43.E863F10A-079E-48FF-8F27-9C2605A29F52 changed: 236.5 (ack = true)
                2021-10-25 12:39:27.702 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ...
                2021-10-25 12:39:28.616 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ...
                2021-10-25 12:39:29.373 - debug: homekit-controller.0 (4788) Device IP-90:09:EC:57:D8:5A Scheduled Characteristic update started ...
                2021-10-25 12:39:29.491 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:30.737 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:31.989 - debug: homekit-controller.0 (4788) IP-90:09:EC:57:D8:5A Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-bc23"},{"aid":1,"iid":6,"value":"518519200803129"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:34.198 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ...
                2021-10-25 12:39:35.988 - debug: homekit-controller.0 (4788) IP-03:09:A7:12:3E:A6 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-be7e"},{"aid":1,"iid":6,"value":"518519200803732"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:39.627 - debug: homekit-controller.0 (4788) Device IP-67:1E:EB:7A:BB:97 Scheduled Characteristic update started ...
                2021-10-25 12:39:40.643 - debug: homekit-controller.0 (4788) IP-67:1E:EB:7A:BB:97 Set Values to ioBroker: [{"aid":1,"iid":3,"value":"Meross"},{"aid":1,"iid":4,"value":"MSS210"},{"aid":1,"iid":5,"value":"MSS210-cd66"},{"aid":1,"iid":6,"value":"518519200807548"},{"aid":1,"iid":7,"value":"4.1.9"},{"aid":1,"iid":8,"value":"4.0.0"},{"aid":1,"iid":9,"value":"2.0.1;16A75"},{"aid":1,"iid":13,"value":"outlet"},{"aid":1,"iid":14,"value":1},{"aid":1,"iid":15,"value":1}]
                2021-10-25 12:39:46.721 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ...
                2021-10-25 12:39:46.999 - debug: homekit-controller.0 (4788) Device IP-FA:E2:76:C6:A9:AE Scheduled Characteristic update started ...
                2021-10-25 12:39:59.493 - debug: homekit-controller.0 (4788) Device IP-03:09:A7:12:3E:A6 Scheduled Characteristic update started ...
                  apollon77 @pboeck last edited by
                  @pboeck Also wenn der Adaoter so dargestellt ist muss e sim Log mehr geben wie einen crash oder sowas ... sehe ich nichts davon in deinem log ... auch das Bild passt nicht ... da steht Loglebel "info" aber du zeigst Debug log ... also ... häää?????
                    @apollon77 Das Bild ist von einem vorherigem Stop.
                    Im Debugmodus habe ich vergessen ein Bild zu machen.
                      @pboeck aber wenn der stoppt muss mehr im Log sein ...
                        @apollon77
                        Ich habe nun den iobrocker neu gestartet, jetzt stopp der Adapter seit ca. 3 Stunden nicht mehr.
                          "type": "state",
                          "common": {
                            "name": "Last Discovered",
                            "type": "boolean",
                            "role": "value.time",
                            "read": true,
                            "write": false
                          "native": {},
                          "from": "system.adapter.homekit-controller.0",
                          "user": "system.user.admin",
                          "ts": 1635176765755,
                          "_id": "homekit-controller.0.IP-FA:E2:76:C6:A9:AE.info.lastDiscovered",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                        Müsste hier, "type": "boolean", nicht ein anderer Typ stehen?
                        2021-10-25 17:51:06.709 - info: homekit-controller.0 (20792) State value to set for "homekit-controller.0.IP-B8:1B:83:7E:C7:6E.info.lastDiscovered" has to be type "boolean" but received type "number"
                          @pboeck Wo Du recht hast haste recht ... Den hab ich übersehen
                          0.3.1 auf GitHub
                            @apollon77 Noch was:
                              @pboeck 0.3.3 auf GitHub sollte das fixen.Danke
                              StrathCole 1 Reply Last reply Reply Quote 0
                              • StrathCole
                                StrathCole @apollon77 last edited by StrathCole
                                @apollon77
                                Ich weiß jetzt gar nicht, ob der Adapter das kann, was ich möchte.
                                Ich würde gern meine Tahoma Box lokal steuern statt über die Cloud. Aaaaaber: Die PIN der Box ist nicht 8-stellig, sondern 12-stellig, also xxxx-xxxx-xxxx. Außerdem zeigt der Adapter komischerweise eine andere MAC an als auf der Box und im QR-Code stehen.
                                Bin ich zu doof? 😆 (nein, eine zweite Box gibts hier nirgends).
                                Danke schon mal
                                  apollon77 @StrathCole last edited by
                                  @strathcole Eine Homekit Pin ist IMMER 8-stellig ... Also musst Du ggf checken wo du die richtige Homekit PIN herbekommst.
                                  Die Homekit ID ist üblicherweise die MAC, bin aber ehrlich das ich zu wenig "vergleichsdaten" habe um das zu 100% zu unterschreiben.
                                  StrathCole 1 Reply Last reply Reply Quote 1
                                  • StrathCole
                                    @apollon77 Okay, danke. Fürchte, dann ist das noch eine der Boxen, die nur nachträglich via Software auf Homekit kompatibel gemacht wurden aber nirgends eine HomeKit-PIN stehen haben 😞 Dann wird das ohne Apple-Gerät wohl nichts.
                                      @strathcole schau doch mal auf der webseite von somfy.
                                      • StrathCole
                                        @apollon77 Leider nein. Alles schon versucht, sogar deren Support angerufen. Die zwingen einen dann dazu, das Koppeln mit Homekit via Tahoma App auf iOS (interne Kommunikation zwischen Tahoma- und Apple-Home-App) zu machen. Anderen Weg gibts angeblich nicht. Aber da kann dein Adapter ja nichts dafür 😉
                                        • I
                                          invidianer @StrathCole last edited by
                                          Servus!
                                          Habe die 0.3.3 installiert, sehe auch was unter „Objekte“, aber unter „Instanzen“ erscheint er nicht.
                                          Muß ich den ioBroker dafür restarten?
                                          Danke und Grüße,
                                          Marcus
                                            Thomas Braun Most Active @invidianer last edited by
                                            @invidianer Über git installiert?
                                            Dann muss die Instanz von Hand angelegt werden.
                                            260
                                            41196
