    4. Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...
    • AlCalzone
      AlCalzone Developer @Esmax666 last edited by
      @esmax666 Dann installier mal manuell:
        Esmax666 @AlCalzone last edited by Esmax666
        @alcalzone
        Ok gemacht, leider geht es nicht
        Subscribed to logs...
        2021-10-22T11:50:49.553Z SERIAL « 0x01070013050000a54b                                                 (9 bytes)
        2021-10-22T11:50:49.565Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:49.569Z DRIVER « [REQ] [SendData]
                                            callback id:     5
                                            transmit status: OK
        2021-10-22T11:50:49.583Z SERIAL » 0x010800131a01002506dc                                              (10 bytes)
        2021-10-22T11:50:49.584Z DRIVER » [Node 026] [REQ] [SendData]
                                          │ transmit options: 0x25
                                          │ callback id:      6
                                          └─[NoOperationCC]
        2021-10-22T11:50:49.586Z CNTRLR   [Node 022] The node is alive.
        2021-10-22T11:50:49.587Z CNTRLR   [Node 022] The node is ready to be used
        2021-10-22T11:50:49.588Z CNTRLR « [Node 022] ping successful
        2021-10-22T11:50:49.593Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:49.599Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:49.600Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:49.601Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:53.726Z SERIAL « 0x010700130601019e73                                                 (9 bytes)
        2021-10-22T11:50:53.730Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.732Z DRIVER « [REQ] [SendData]
                                            callback id:     6
                                            transmit status: NoAck
        2021-10-22T11:50:53.742Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
        2021-10-22T11:50:53.743Z CNTRLR   [Node 026] The node is dead.
        2021-10-22T11:50:53.748Z SERIAL » 0x010800131d01002507da                                              (10 bytes)
        2021-10-22T11:50:53.749Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      7
                                          └─[NoOperationCC]
        2021-10-22T11:50:53.750Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                          Ack) (ZW0020)
        2021-10-22T11:50:53.751Z CNTRLR » [Node 026] querying node info...
        2021-10-22T11:50:53.751Z CNTRLR » [Node 026] pinging the node...
        2021-10-22T11:50:53.757Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:53.760Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:53.761Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.763Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:53.819Z SERIAL « 0x0107001307000006ea                                                 (9 bytes)
        2021-10-22T11:50:53.821Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.822Z DRIVER « [REQ] [SendData]
                                            callback id:     7
                                            transmit status: OK
        2021-10-22T11:50:53.834Z SERIAL » 0x010800131e01002508d6                                              (10 bytes)
        2021-10-22T11:50:53.834Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      8
                                          └─[NoOperationCC]
        2021-10-22T11:50:53.837Z CNTRLR   [Node 029] The node is alive.
        2021-10-22T11:50:53.838Z CNTRLR   [Node 029] The node is ready to be used
        2021-10-22T11:50:53.839Z CNTRLR « [Node 029] ping successful
        2021-10-22T11:50:53.845Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:53.848Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:53.849Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.850Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:53.909Z SERIAL « 0x0107001308000006e5                                                 (9 bytes)
        2021-10-22T11:50:53.910Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.910Z DRIVER « [REQ] [SendData]
                                            callback id:     8
                                            transmit status: OK
        2021-10-22T11:50:53.925Z SERIAL » 0x010800131f01002509d6                                              (10 bytes)
        2021-10-22T11:50:53.926Z DRIVER » [Node 031] [REQ] [SendData]
                                          │ callback id:      9
                                          └─[NoOperationCC]
        2021-10-22T11:50:53.927Z CNTRLR   [Node 030] The node is alive.
        2021-10-22T11:50:53.928Z CNTRLR   [Node 030] The node is ready to be used
        2021-10-22T11:50:53.929Z CNTRLR « [Node 030] ping successful
        2021-10-22T11:50:53.932Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:53.949Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:53.950Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.954Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:53.961Z SERIAL « 0x0107001309000002e0                                                 (9 bytes)
        2021-10-22T11:50:53.963Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.964Z DRIVER « [REQ] [SendData]
                                            callback id:     9
                                            transmit status: OK
        2021-10-22T11:50:53.972Z SERIAL » 0x01080013200100250aea                                              (10 bytes)
        2021-10-22T11:50:53.972Z DRIVER » [Node 032] [REQ] [SendData]
                                          │ callback id:      10
                                          └─[NoOperationCC]
        2021-10-22T11:50:53.973Z CNTRLR   [Node 031] The node is alive.
        2021-10-22T11:50:53.974Z CNTRLR   [Node 031] The node is ready to be used
        2021-10-22T11:50:53.975Z CNTRLR « [Node 031] ping successful
        2021-10-22T11:50:53.979Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:53.985Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:53.986Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:53.989Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:54.002Z SERIAL « 0x010700130a000002e3                                                 (9 bytes)
        2021-10-22T11:50:54.003Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.005Z DRIVER « [REQ] [SendData]
                                            callback id:     10
                                            transmit status: OK
        2021-10-22T11:50:54.015Z SERIAL » 0x01080013210100250bea                                              (10 bytes)
        2021-10-22T11:50:54.016Z DRIVER » [Node 033] [REQ] [SendData]
                                          │ callback id:      11
                                          └─[NoOperationCC]
        2021-10-22T11:50:54.017Z CNTRLR   [Node 032] The node is alive.
        2021-10-22T11:50:54.018Z CNTRLR   [Node 032] The node is ready to be used
        2021-10-22T11:50:54.019Z CNTRLR « [Node 032] ping successful
        2021-10-22T11:50:54.029Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:54.034Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:54.035Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.037Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:54.046Z SERIAL « 0x010700130b000002e2                                                 (9 bytes)
        2021-10-22T11:50:54.046Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.048Z DRIVER « [REQ] [SendData]
                                            callback id:     11
                                            transmit status: OK
        2021-10-22T11:50:54.059Z SERIAL » 0x01080013220100250cee                                              (10 bytes)
        2021-10-22T11:50:54.060Z DRIVER » [Node 034] [REQ] [SendData]
                                          │ callback id:      12
                                          └─[NoOperationCC]
        2021-10-22T11:50:54.061Z CNTRLR   [Node 033] The node is alive.
        2021-10-22T11:50:54.062Z CNTRLR   [Node 033] The node is ready to be used
        2021-10-22T11:50:54.063Z CNTRLR « [Node 033] ping successful
        2021-10-22T11:50:54.074Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:54.076Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:54.077Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.081Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:54.116Z SERIAL « 0x010700130c000005e2                                                 (9 bytes)
        2021-10-22T11:50:54.117Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.118Z DRIVER « [REQ] [SendData]
                                            callback id:     12
                                            transmit status: OK
        2021-10-22T11:50:54.125Z SERIAL » 0x01080013230100250dee                                              (10 bytes)
        2021-10-22T11:50:54.125Z DRIVER » [Node 035] [REQ] [SendData]
                                          │ callback id:      13
                                          └─[NoOperationCC]
        2021-10-22T11:50:54.127Z CNTRLR   [Node 034] The node is alive.
        2021-10-22T11:50:54.127Z CNTRLR   [Node 034] The node is ready to be used
        2021-10-22T11:50:54.128Z CNTRLR « [Node 034] ping successful
        2021-10-22T11:50:54.140Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:54.143Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:54.144Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.146Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:54.182Z SERIAL « 0x010700130d000004e2                                                 (9 bytes)
        2021-10-22T11:50:54.183Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.187Z DRIVER « [REQ] [SendData]
                                            callback id:     13
                                            transmit status: OK
        2021-10-22T11:50:54.194Z SERIAL » 0x010800131a0100250ed4                                              (10 bytes)
        2021-10-22T11:50:54.194Z DRIVER » [Node 026] [REQ] [SendData]
                                          │ callback id:      14
                                          └─[NoOperationCC]
        2021-10-22T11:50:54.197Z CNTRLR   [Node 035] The node is alive.
        2021-10-22T11:50:54.198Z CNTRLR   [Node 035] The node is ready to be used
        2021-10-22T11:50:54.199Z CNTRLR « [Node 035] ping successful
        2021-10-22T11:50:54.209Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:50:54.215Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:50:54.215Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:54.217Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:50:58.338Z SERIAL « 0x010700130e01019d78                                                 (9 bytes)
        2021-10-22T11:50:58.341Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:50:58.344Z DRIVER « [REQ] [SendData]
                                            callback id:     14
        2021-10-22T11:50:58.362Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
        2021-10-22T11:50:58.365Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                          Ack) (ZW0020)
        2021-10-22T11:50:58.366Z CNTRLR   [Node 026] Interview attempt (1/5) failed, node is dead.
        2021-10-22T11:51:11.340Z SERIAL » 0x010e001322076c018103260132250f17                                  (16 bytes)
        2021-10-22T11:51:11.342Z DRIVER » [Node 034] [REQ] [SendData]
                                          │ callback id:      15
                                          └─[SupervisionCCGet]
                                            │ session id:      1
                                            │ request updates: true
                                            └─[MultilevelSwitchCCSet]
                                                target value: 50
        2021-10-22T11:51:11.345Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:51:11.351Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:51:11.352Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:11.353Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:51:11.398Z SERIAL « 0x010700130f000005e1                                                 (9 bytes)
        2021-10-22T11:51:11.399Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:11.399Z DRIVER « [REQ] [SendData]
                                            callback id:     15
                                            transmit status: OK
        2021-10-22T11:51:11.472Z SERIAL « 0x010b00040022056c02010000b8                                        (13 bytes)
        2021-10-22T11:51:11.478Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:11.483Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                          └─[SupervisionCCReport]
                                              session id:          1
                                              more updates follow: false
                                              status:              NoSupport
                                              duration:            0s
        2021-10-22T11:51:17.565Z SERIAL » 0x010e001322076c01820326013725100e                                  (16 bytes)
        2021-10-22T11:51:17.567Z DRIVER » [Node 034] [REQ] [SendData]
                                          │ callback id:      16
                                            │ session id:      2
                                                target value: 55
        2021-10-22T11:51:17.572Z SERIAL « [ACK]        (0x06)
        2021-10-22T11:51:17.576Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-22T11:51:17.577Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:17.578Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-22T11:51:17.621Z SERIAL « 0x0107001310000004ff                                                 (9 bytes)
        2021-10-22T11:51:17.622Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:17.623Z DRIVER « [REQ] [SendData]
                                            callback id:     16
                                            transmit status: OK
        2021-10-22T11:51:17.692Z SERIAL « 0x010b00040022056c02020000bb                                        (13 bytes)
        2021-10-22T11:51:17.693Z SERIAL » [ACK]        (0x06)
        2021-10-22T11:51:17.695Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                              session id:          2
                                              status:              NoSupport
                                              duration:            0s
        InstallLog
        $ iobroker url iobroker.zwave2@2.2.4 --host ubuntu
        install iobroker.zwave2@2.2.4
        NPM version: 6.14.15
        npm install iobroker.zwave2@2.2.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        ../src/linux/BluetoothSerialPort.cc:18:6: error: variable or field ‘InitAll’ declared void
        18 | void InitAll(Handle<Object> exports) { | ^~~~~~~
        ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope 18 | void InitAll(Handle<Object> exports) { | ^~~~~~../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token 18 | void InitAll(Handle<Object> exports) { | ^
        ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
        In file included from ../src/linux/BluetoothSerialPort.cc:12:
        ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’ 736 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~~~~~
        make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)
        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
        gyp ERR! System Linux 5.11.0-1019-raspigyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.22.7gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
        upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
        upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
        upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
        upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
        upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
        upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
        upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
        upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
        upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
        upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
        upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
        upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
        upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-MTOBDWCR.js.map build/chunk-MTOBDWCR.js.map application/json
        upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-MTOBDWCR.js build/chunk-MTOBDWCR.js application/javascript
        upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-LGH3N725.js.map build/chunk-LGH3N725.js.map application/json
        upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-LGH3N725.js build/chunk-LGH3N725.js application/javascript
        upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-BZNVH3F4.js.map build/chunk-BZNVH3F4.js.map application/json
        upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-BZNVH3F4.js build/chunk-BZNVH3F4.js application/javascript
        upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
        Update "system.adapter.zwave2.0"
        • AlCalzone
          AlCalzone Developer @Esmax666 last edited by AlCalzone
          @esmax666 Bitte mal den Node neu interviewen:
          (ich seh grade, der Text neben dem Button ist falsch - bitte trotzdem draufklicken - halt bei Node 34)
            @alcalzone
            YEs!!!!
            Rollo geht schon wieder 🙂 nice !
            Das kann ich glaich mit alle rollo hier machen oder ?
            Danke 🙂
            • AlCalzone
              @esmax666 Ich würde es gezielt nur bei denen machen, die Probleme haben.
              • Christian Werner
                Christian Werner last edited by
                habe gerade das Update gemacht, danach aber vielleicht zu schnell auf "Interview All" - also noch bevor alle Nodes bei mir aktiv waren. Bin nun erstmal wieder zurück zur 1.10 (per Backup).
                Aber die Frage ist von der Version 1.10.4 kommend.
                1. Adapter Update dann ->
                • Setze ich die S2 Security Keys oder nicht ? (waren bei mir leer und ich hatte auf "Generate" geklickt. Der S0 Key war gesetzt)
                • Soll man dann ein Aktives Interview der Geräte machen oder passiert das von selbst?
                  Ich hatte einen Versuch 8 von 5 im Log vielleicht lief hier auch was doppelt, weil ich mit drauf geklickt hatte?
                    [Node 007] Interview attempt (8/5) failed, node is dead.
                Ich kann hier alles noch mal nachstellen oder testen - falls das was Hilft.
                Grüße und Danke
                  @alcalzone
                  ok mache ich, ich hääte noch ein frage.
                  was heisst das genau ?
                  Gerät ist dead? muss neu kaufen ?
                  3ead093c-13df-4c48-ab35-08feb9d9bffc-grafik.png 32d59793-4c3f-4fb3-8687-2406d0aacd81-grafik.png
                  zwave2.0
                  	24906	2021-10-22 20:38:41.117	error	Node 26 interview failed: The node is dead
                  hat jemand schon sowas bekommen ?
                  2021-10-22T18:39:56.942Z CNTRLR   [Node 026] Beginning interview - last completed stage: None
                  2021-10-22T18:40:01.105Z SERIAL « 0x010700132801019e5d                                                 (9 bytes)
                  2021-10-22T18:40:01.109Z SERIAL » [ACK]        (0x06)
                  2021-10-22T18:40:01.112Z DRIVER « [REQ] [SendData]
                                                      callback id:     40
                  2021-10-22T18:40:01.119Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
                  2021-10-22T18:40:01.121Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                                    Ack) (ZW0020)
                  2021-10-22T18:40:01.121Z CNTRLR » [Node 026] querying node info...
                  2021-10-22T18:40:01.121Z CNTRLR » [Node 026] pinging the node...
                  2021-10-22T18:40:01.127Z SERIAL » 0x010800131a01002529f3                                              (10 bytes)
                  2021-10-22T18:40:01.128Z DRIVER » [Node 026] [REQ] [SendData]
                                                    │ callback id:      41
                                                    └─[NoOperationCC]
                  2021-10-22T18:40:01.131Z SERIAL « [ACK]        (0x06)
                  2021-10-22T18:40:01.139Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                  2021-10-22T18:40:01.139Z SERIAL » [ACK]        (0x06)
                  2021-10-22T18:40:01.140Z DRIVER « [RES] [SendData]
                                                      was sent: true
                  2021-10-22T18:40:05.237Z SERIAL « 0x010700132901019b59                                                 (9 bytes)
                  2021-10-22T18:40:05.241Z SERIAL » [ACK]        (0x06)
                  2021-10-22T18:40:05.243Z DRIVER « [REQ] [SendData]
                                                      callback id:     41
                  2021-10-22T18:40:05.248Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
                  2021-10-22T18:40:05.250Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
                                                    Ack) (ZW0020)
                  2021-10-22T18:40:05.250Z CNTRLR   [Node 026] Interview attempt (1/5) failed, node is dead.
                  • nodoe
                    nodoe last edited by
                    ich habe versucht mein Danalock V3 zu includieren. Nach mehreren Versuchen hat das auch geklappt, allerdings sind die icon für S2 Authenticated und S2 Unauthenticated grau:
                    Unter Door_Lock findet sich kein Eintrag wie targetMode o.ä., so dass ich das Schloss im iobroker nicht öffnen oder schließen kann:
                    Per Smartlock-App funktioniert es. Habt Ihr eine Idee, woran das liegen kann?
                    Vielen Dank und schöne Grüße!
                    • AlCalzone
                      @esmax666 sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
                      Gerät ist dead
                      Das heißt, dass es nicht antwortet. Kann mehrere Gründe haben:
                      1. schlechter Empfang -> Probier mal Netzwerk heilen
                      2. kein Strom -> Verkabelung checken
                      @nodoe
                      Das kann normal sein, z.B. wenn nur S2 Access Control (die höchste Klasse) angefragt wurde.
                      Komisch - currentMode ist da. Lade mal die Ansicht im Admin neu. Wenn das nicht tut, neu interviewen.
                      nodoe 1 Reply Last reply Reply Quote 0
                      • gelberlemmy
                        gelberlemmy @AlCalzone last edited by
                        @alcalzone moin, ich habe die Version 2.3.0 installiert. nach der Installation bekomme ich jetzt eine Fehlermeldung und der Adapter läuft nicht mehr. Bin zurück auf 2.2.4. Auch das gleiche.
                        Geschaut ob der Serial noch im Adapter ist. Über SSH geschaut. USB Stick vorhanden.
                        PI neu gestartet. Keine verbesserung. Ein Issue auf Github erstellen ? Soll ich Dir einmal das LOG zukommen lassen?
                        Anbei die Fehlermeldung:
                        zwave2.0
                        2021-10-25 20:43:36.834	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v14.18.1, js-controller: 3.3.18
                        zwave2.0
                        2021-10-25 20:43:31.294	info	Shutting down driver...
                        zwave2.0
                        2021-10-25 20:43:29.867	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        zwave2.0
                        2021-10-25 20:43:28.866	error	Restarting the adapter in a second...
                        zwave2.0
                        2021-10-25 20:43:28.865	error	Failed to initialize the driver: ZWaveError: The driver is not ready or has been destroyed (ZW0103) at Driver.ensureReady (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:1764:10) at Driver.sendMessage (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:2931:8) at ZWaveController.interview (/opt/iobroker/node_modules/zwave-js/src/lib/controller/Controller.ts:506:22) at Driver.initializeControllerAndNodes (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:932:27) at Immediate.<anonymous> (/opt/iobroker/node_modules/zwave-js/src/lib/driver/Driver.ts:809:16) (ZW0100)
                        gelberlemmy 1 Reply Last reply Reply Quote 0
                        • gelberlemmy
                          gelberlemmy @gelberlemmy last edited by
                          @gelberlemmy sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
                          zwave2.0
                          zwave2.0
                          zwave2.0
                          zwave2.0
                          zwave2.0
                          Habe jetzt einmal die Anleitung aus dem Adapter gelesen und geschaut, ober der Stick eine neue Serielle Adresse bekommen hat. War aber nicht der Fall. Das einzige was geholfen hat, den Haken zu setzen, damit der Controller nicht mit neu gestartet wird. Mit was für Einschränkungen muss ich da rechnen, da dies so in der Beschreibung steht ?
                          • AlCalzone
                            AlCalzone Developer @gelberlemmy last edited by
                            @gelberlemmy
                            Welchen Stick hast du denn?
                            Es kann sein, dass in der Zukunft manche Controller-Funktionen nicht gehen ohne soft reset, z.B. Backup und Restore (kann der Adapter aber noch nicht).
                            • AlCalzone
                              Übrigens, hier gehts weiter: https://forum.iobroker.net/topic/48782/test-adapter-z-wave-2-v2-3-x
                              • gelberlemmy
                                @alcalzone sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
                                @gelberlemmy
                                Moin, ich habe den Z-Wave USB Stick (ZMEEUZB1).
                                Aber ich habe gesehen, dass Du ein Update diesbezüglich heraus gebracht hast. Werde ich gleich einmal testen
                                • nodoe
                                  nodoe @AlCalzone last edited by
                                  @alcalzone
                                  War heute erst wieder am Schloss. Wie immer im Leben: Heilen hilft, auch wenns lange dauert... Danke für den Tipp!!!
                                  31.7k
                                  79.8k
                                  adapter security s2 test z-wave 2
                                  11
                                  49
                                  3167
